How to set pad conf registers and where to check the result?
Other Parts Discussed in Thread: AM3517
(original question: SPI1 somi data is observed by scope, but no data on register, why?)
I'm using am3517 and adeneo bsp. I used SPI1 channel 1 which is not used by default.
Now my problem is that I can NOT read data from RX register, even when I observed the data on somi pin by a scope.
Which part chould be wrong? I'm wondering the pad conf, but the code should be fine:
#define MCSPI1_PADS \
    PAD_ENTRY(MCSPI1_CS0, INPUT_DISABLED | PULL_RESISTOR_DISABLED | MUXMODE(0)) \
    PAD_ENTRY(MCSPI1_CS1, INPUT_DISABLED | PULL_RESISTOR_DISABLED | MUXMODE(0)) \
    PAD_ENTRY(MCSPI1_SOMI,INPUT_ENABLE | PULL_RESISTOR_DISABLED | MUXMODE(0)) \
    PAD_ENTRY(MCSPI1_SIMO,INPUT_DISABLED | PULL_RESISTOR_DISABLED | MUXMODE(0)) \
    PAD_ENTRY(MCSPI1_CLK, INPUT_ENABLE | PULL_RESISTOR_DISABLED | MUXMODE(0))
Any other place I should check? once the pads is defined, is it possible that padconf is changed by some code else?
