I'm trying to send data out of the McBSP using a DMA on a DM8168 custom board but, for some unknown reason, it's not working
Some info about my setup and the tests I've already done:
- My software is running on the DSP side using SYS/BIOS and a XDS100v2 JTAG emulator
- I tested the McBSP using polling and the data is coming out, so its configuration should be ok.
- When I run my program the DMA end of transfer ISR is called so the DMA has been triggered and has completed its job, but no data comes out of the McBSP DX pin
- I tried changing the DMA destination address to a RAM address or to some other register in order to check if the DMA was working correctly and all seems ok
I'm running out of ideas, do you have any suggestion on what I'm doing wrong or what other test to do?
