DM8168 DVRRDK standalone decoder using LinkAPI
I am writing a decoder app that will take input from .h264 file , decode and write the output to another file. I am using TI DM8168 platform.
After reading other forum articles, my present form of code is below.
Being inside the directory "dvr_rdk/demos/link_api_demos/vpss_chains", I compiled the below program by linking with ./dec_single_syslink.c ../common/chains_ipcBits.c dvr_rdk_mcfw_api.a dvr_rdk_link_api.a dvr_rdk_mcfw_api.a dvr_rdk_osa.a syslink.a -lpthread -lm
I ran the resultant output executable, on the target-board after performing /opt/dvr_rdk/ti816x/init.sh and load.sh.
I am able to run the program, and it shows the links as successfully created as follows:
[host] 3676: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_19] ...
3678: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_19] ...
[host] 3680: IPC_FRAMES_IN : Create Done !!!
SYSTEM INFO >>> FILE - DEC - FILE Links Created
Enter Choice: [m3video] 23665: IPC_FRAMES_OUT : Create in progress !!!
[m3video] 23667: IPC_FRAMES_OUT : Create Done !!!
But the statistics show that the frames are never processed through the links and there is no output frame.
I wrote my own "input_from_file" thread and didnt use chains_ipcBitsinit.
I am also not sure whether i am using the getBitstream buffer APIs correctly,
I dont know what i am missing here and will appreciate the help.
Code:
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <stdio.h>
#include <demos/link_api_demos/common/chains.h>
Void Chains_FileDecFileWr(Chains_Ctrl *chainsCfg);
#define TRUE 1
#define FALSE 0
#define SRC_NUM_CH 1
#define NUM_BUF_PER_CH 1
pthread_mutex_t g_mutex;
pthread_cond_t g_condition;
int conditionMet=0;
FILE (H264)
IPC_BITS_OUT_A8 (BitStream)
IPC_BITS_IN_M3 (BitStream)
DEC
IPC_FRAMES_OUT_M3 (Frames)
IPC_FRAMES_IN_A8 (Frames)
FILE (YUV)
static SystemVideo_Ivahd2ChMap_Tbl systemVid_encDecIvaChMapTbl =
.isPopulated = 1,
.ivaMap[0] =
.EncNumCh = 0,
.EncChList = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
.DecNumCh = 1,
.DecChList = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 , 14, 15},
.ivaMap[1] =
.EncNumCh = 0,
.DecNumCh = 0,
.DecChList = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0, 0},
.ivaMap[2] =
.EncNumCh = 0,
.DecNumCh = 0,
.DecChList = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
Int32 Chains_memPrintHeapStatus()
printf("Stub: chains_memPrintHeap");
return 0;
char gChains_runTimeMenu[] = {
"\r\n ===================="
"\r\n Chains Run-time Menu"
"\r\n"
"\r\n 0: Stop Chain"
"\r\n"
"\r\n i: Print IVA-HD Statistics "
"\r\n "
"\r\n Enter Choice: "
/* Heap Id registered with MessageQ for allocating message buffers.
The heap associated with PE_MESSAGEQ_SHARED_REGION_ID is registered
as PE_MESSAGEQ_HEAP_ID. */
const unsigned short Rpe_messageqHeapId = 0;
char Chains_menuRunTime()
char ch[128];
printf(gChains_runTimeMenu);
fgets(ch, 128, stdin);
if(ch[1] != '\n' || ch[0] == '\n')
ch[0] = '\n';
return ch[0];
Void Chains_run(Chains_RunFunc chainsRunFunc)
Chains_Ctrl chainsCtrl;
//Chains_detectBoard();
System_linkControl(
SYSTEM_LINK_ID_M3VPSS,
SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,
NULL,
0,
TRUE
#if 0
UInt32 displayResDefault[SYSTEM_DC_MAX_VENC] =
{VSYS_STD_1080P_60, //SYSTEM_DC_VENC_HDMI,
VSYS_STD_1080P_60, //SYSTEM_DC_VENC_HDCOMP,
VSYS_STD_1080P_60, //SYSTEM_DC_VENC_DVO2
VSYS_STD_NTSC //SYSTEM_DC_VENC_SD,
chainsCtrl.enableNsfLink = FALSE;
chainsCtrl.enableOsdAlgLink = FALSE;
chainsCtrl.enableVidFrameExport = FALSE;
chainsCtrl.bypassNsf = FALSE;
// memcpy(gChains_ctrl.displayRes,displayResDefault,sizeof(gChains_ctrl.displayRes));
// memcpy(&chainsCtrl, &gChains_ctrl, sizeof(gChains_ctrl));
// Chains_memPrintHeapStatus();
#endif
UTILS_assert( chainsRunFunc!=NULL);
chainsRunFunc(&chainsCtrl);
char gChains_menuMain0[] = {
"\r\n ============"
"\r\n Chain Select"
"\r\n ============"
"\r\n"
char gChains_menuMainVs[] = {
"\r\n"
"\r\n 1: <H264 FILERD-> DEC->FILEWR>"
"\r\n "
"\r\n s: System Settings "
"\r\n "
"\r\n x: Exit "
"\r\n "
Void Chains_menuMainShow()
printf(gChains_menuMain0);
//Chains_menuCurrentSettingsShow();
printf(gChains_menuMainVs);
Void Chains_menuMainRunVs(char ch)
switch(ch)
case '1':
Chains_run(Chains_FileDecFileWr);
break;
case '2':
printf("invalid option 2");
// Chains_run(Chains_multiChEncDecLoopBack);
break;
case '3':
printf("invalid option 3");
break;
case '4':
printf("invalid option 4");
break;
default:
break;
Void Chains_main()
char ch[128];
Bool done;
done = FALSE;
// Chains_setDefaultCfg();
while(!done)
Chains_menuMainShow();
continue;
printf(" \r\n");
Chains_menuMainRunVs(ch[0]);
switch(ch[0])
case 's':
// Chains_menuSettings();
break;
case 'x':
done = TRUE;
break;
case 'd':
break;
#define INI_FILE "/opt/sample.h264"
#define INI_FRAME_WIDTH 2048
#define INI_FRAME_HEIGHT 1536
#define INI_ENABLE 1
#define INI_CODEC h264
#define INI_NUMBUF 0
#define INI_DISP_DELAY 0
IpcBitsOutLinkHLOS_CreateParams ipcBitsOutHostPrm;
IpcBitsInLinkRTOS_CreateParams ipcBitsInVideoPrm;
DecLink_CreateParams decPrm;
IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVideoPrm;
IpcFramesInLinkHLOS_CreateParams ipcFramesInHostPrm;
Int i;
Bool isProgressive;
System_LinkInfo bitsProducerLinkInfo;
UInt32 decId;
UInt32 ipcFramesOutVideoId, ipcFramesInHostId;
UInt32 ipcBitsInVideoId, ipcBitsOutHostId;
char ch;
int rc;
//Chains_ipcBitsInit();
CHAINS_INIT_STRUCT(IpcBitsOutLinkHLOS_CreateParams,ipcBitsOutHostPrm);
CHAINS_INIT_STRUCT(IpcBitsInLinkRTOS_CreateParams,ipcBitsInVideoPrm);
CHAINS_INIT_STRUCT(DecLink_CreateParams, decPrm);
CHAINS_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams,ipcFramesOutVideoPrm);
CHAINS_INIT_STRUCT(IpcFramesInLinkHLOS_CreateParams,ipcFramesInHostPrm);
ipcBitsOutHostId = SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0;
ipcBitsInVideoId = SYSTEM_VIDEO_LINK_ID_IPC_BITS_IN_0;
decId = SYSTEM_LINK_ID_VDEC_0;
ipcFramesOutVideoId = SYSTEM_VIDEO_LINK_ID_IPC_FRAMES_OUT_0;
ipcFramesInHostId = SYSTEM_HOST_LINK_ID_IPC_FRAMES_IN_0;
//decPrm.tilerEnable = FALSE;
isProgressive = TRUE;
System_linkControl(
SYSTEM_LINK_ID_M3VIDEO,
SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
&systemVid_encDecIvaChMapTbl,
sizeof(SystemVideo_Ivahd2ChMap_Tbl),
TRUE
ipcBitsOutHostPrm.baseCreateParams.outQueParams[0].nextLink = ipcBitsInVideoId;
ipcBitsOutHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcBitsOutHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcBitsOutHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcBitsOutHostPrm.baseCreateParams.numOutQue = 1;
ipcBitsOutHostPrm.inQueInfo.numCh = SRC_NUM_CH;
ipcBitsOutHostPrm.bufPoolPerCh = TRUE;
for (i=0; i<SRC_NUM_CH; i++)
ipcBitsOutHostPrm.inQueInfo.chInfo[i].width = INI_FRAME_WIDTH;
ipcBitsOutHostPrm.inQueInfo.chInfo[i].height = INI_FRAME_HEIGHT;
ipcBitsOutHostPrm.inQueInfo.chInfo[i].scanFormat = SYSTEM_SF_PROGRESSIVE;
ipcBitsOutHostPrm.inQueInfo.chInfo[i].bufType = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].codingformat = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].dataFormat = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].memType = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].startX = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].startY = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].pitch[0] = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].pitch[1] = 0; // NOT USED
ipcBitsOutHostPrm.inQueInfo.chInfo[i].pitch[2] = 0; // NOT USED
ipcBitsOutHostPrm.numBufPerCh[i] = NUM_BUF_PER_CH;
/* IPC Host to IPC Video*/
ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkId = ipcBitsOutHostId;
ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcBitsInVideoPrm.baseCreateParams.outQueParams[0].nextLink = decId;
ipcBitsInVideoPrm.baseCreateParams.noNotifyMode = TRUE;
ipcBitsInVideoPrm.baseCreateParams.notifyNextLink = TRUE;
ipcBitsInVideoPrm.baseCreateParams.notifyPrevLink = TRUE;
ipcBitsInVideoPrm.baseCreateParams.numOutQue = 1;
/* IPC Video to DEC*/
for (i=0; i<SRC_NUM_CH; i++) {
decPrm.chCreateParams[i].format = IVIDEO_H264HP;
decPrm.chCreateParams[i].profile = IH264VDEC_PROFILE_ANY;
decPrm.chCreateParams[i].targetMaxWidth = INI_FRAME_WIDTH;
decPrm.chCreateParams[i].targetMaxHeight = INI_FRAME_HEIGHT;
#if 0
if (isProgressive)
decPrm.chCreateParams[i].fieldMergeDecodeEnable = FALSE;
else
decPrm.chCreateParams[i].fieldMergeDecodeEnable = TRUE;
#endif
decPrm.chCreateParams[i].numBufPerCh = NUM_BUF_PER_CH;
decPrm.chCreateParams[i].defaultDynamicParams.targetFrameRate = 25;
decPrm.chCreateParams[i].defaultDynamicParams.targetBitRate = (2 * 1000 * 1000);
decPrm.inQueParams.prevLinkId = ipcBitsInVideoId;
decPrm.inQueParams.prevLinkQueId = 0;
decPrm.outQueParams.nextLink = ipcFramesOutVideoId;
/*DEC to IPC Video Frame out*/
ipcFramesOutVideoPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesOutVideoPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesOutVideoPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesOutVideoPrm.baseCreateParams.inQueParams.prevLinkId = decId;
ipcFramesOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesOutVideoPrm.baseCreateParams.numOutQue = 1;
ipcFramesOutVideoPrm.baseCreateParams.outQueParams[0].nextLink = ipcFramesInHostId;
/*IPC Frame video out to Host IN*/
ipcFramesInHostPrm.baseCreateParams.noNotifyMode = TRUE;
ipcFramesInHostPrm.baseCreateParams.notifyNextLink = FALSE;
ipcFramesInHostPrm.baseCreateParams.notifyPrevLink = FALSE;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkId = ipcFramesOutVideoId;
ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
ipcFramesInHostPrm.baseCreateParams.outQueParams[0].nextLink = SYSTEM_LINK_ID_INVALID;
System_linkCreate(ipcBitsOutHostId,&ipcBitsOutHostPrm,sizeof(ipcBitsOutHostPrm));
System_linkCreate(ipcBitsInVideoId,&ipcBitsInVideoPrm,sizeof(ipcBitsInVideoPrm));
System_linkCreate(decId, &decPrm, sizeof(decPrm));
sleep(2);
System_linkCreate(ipcFramesOutVideoId, &ipcFramesOutVideoPrm, sizeof(ipcFramesOutVideoPrm));
System_linkCreate(ipcFramesInHostId, &ipcFramesInHostPrm, sizeof(ipcFramesInHostPrm));
printf("SYSTEM INFO >>> FILE - DEC - FILE Links Created\n");
System_linkStart(ipcFramesInHostId);
System_linkStart(ipcFramesOutVideoId);
System_linkStart(decId);
System_linkStart(ipcBitsInVideoId);
System_linkStart(ipcBitsOutHostId);
rc = pthread_mutex_lock(&g_mutex);
conditionMet =1;
rc = pthread_cond_broadcast(&g_condition);
rc = pthread_mutex_unlock(&g_mutex);
/* Start taking CPU load just before starting of links */
while(1)
ch = Chains_menuRunTime();
if(ch=='0')
break;
if(ch=='i')
System_linkControl(decId, DEC_LINK_CMD_PRINT_IVAHD_STATISTICS, NULL, 0, TRUE);
if(ch=='d')
System_linkControl(decId, DEC_LINK_CMD_PRINT_STATISTICS, NULL, 0, TRUE);
if(ch=='D')
System_linkControl(decId, DEC_LINK_CMD_PRINT_BUFFER_STATISTICS, NULL, 0, TRUE);
if(ch=='b')
System_linkControl(ipcBitsOutHostId, IPCBITSOUT_LINK_CMD_PRINT_BUFFER_STATISTICS, NULL, 0, TRUE);
//Chains_ipcBitsStop();
System_linkStop(ipcBitsOutHostId);
System_linkStop(ipcBitsInVideoId);
System_linkStop(decId);
System_linkDelete(ipcBitsOutHostId);
System_linkDelete(ipcBitsInVideoId);
System_linkDelete(decId);
System_linkDelete(ipcFramesOutVideoId);
System_linkDelete(ipcFramesInHostId);
//Chains_ipcBitsExit();
#if 0
static Void VdecVdis_setFrameTimeStamp(VCODEC_BITSBUF_S *pEmptyBuf)
UInt64 curTimeStamp =
gVdecVdis_config.frameCnt[pEmptyBuf->chnId] * VDEC_VDIS_FRAME_DURATION_MS;
pEmptyBuf->lowerTimeStamp = (UInt32)(curTimeStamp & 0xFFFFFFFF);
pEmptyBuf->upperTimeStamp = (UInt32)((curTimeStamp >> 32)& 0xFFFFFFFF);
if (0 == gVdecVdis_config.frameCnt[pEmptyBuf->chnId])
UInt32 displayChId;
Vdec_mapDec2DisplayChId(VDIS_DEV_HDMI,pEmptyBuf->chnId,&displayChId);
Vdis_setFirstVidPTS(VDIS_DEV_HDMI,displayChId,curTimeStamp);
Vdec_mapDec2DisplayChId(VDIS_DEV_HDCOMP,pEmptyBuf->chnId,&displayChId);
Vdis_setFirstVidPTS(VDIS_DEV_HDCOMP,displayChId,curTimeStamp);
Vdec_mapDec2DisplayChId(VDIS_DEV_SD,pEmptyBuf->chnId,&displayChId);
Vdis_setFirstVidPTS(VDIS_DEV_SD,displayChId,curTimeStamp);
gVdecVdis_config.frameCnt[pEmptyBuf->chnId] += 1;
#endif
static Void Vdec_copyBitBufInfoLink2McFw(VCODEC_BITSBUF_S *dstBuf,
Bitstream_Buf *srcBuf)
dstBuf->reserved = (UInt32)srcBuf;
dstBuf->bufVirtAddr = srcBuf->addr;
dstBuf->bufSize = srcBuf->bufSize;
dstBuf->chnId = srcBuf->channelNum;
dstBuf->codecType = srcBuf->codingType;
dstBuf->filledBufSize = srcBuf->fillLength;
dstBuf->timestamp = srcBuf->timeStamp;
dstBuf->upperTimeStamp = srcBuf->upperTimeStamp;
dstBuf->lowerTimeStamp = srcBuf->lowerTimeStamp;
dstBuf->bottomFieldBitBufSize = srcBuf->bottomFieldBitBufSize;
dstBuf->inputFileChanged = srcBuf->inputFileChanged;
if (srcBuf->isKeyFrame)
dstBuf->frameType = VCODEC_FRAME_TYPE_I_FRAME;
else
dstBuf->frameType = VCODEC_FRAME_TYPE_P_FRAME;
dstBuf->bufPhysAddr = (Void *)srcBuf->phyAddr;
dstBuf->frameWidth = srcBuf->frameWidth;
dstBuf->frameHeight = srcBuf->frameHeight;
dstBuf->doNotDisplay = FALSE;
/*TODO the following members need to be added to bitstream buf */
dstBuf->fieldId = 0;
dstBuf->strmId = 0;
dstBuf->seqId = srcBuf->seqId;
print_diag(dstBuf);
void print_diag(VCODEC_BITSBUF_S *dstBuf)
printf("dstBuf->reserved = %u\n",dstBuf->reserved);
printf("dstBuf->bufVirtAddr = %u\n", dstBuf->bufVirtAddr);
printf("dstBuf->bufSize = %u\n", dstBuf->bufSize);
printf("dstBuf->chnId = %u\n", dstBuf->chnId);
printf("dstBuf->codecType = %u\n", dstBuf->codecType);
printf("dstBuf->filledBufSize = %u\n", dstBuf->filledBufSize);
printf("dstBuf->timestamp = %u\n", dstBuf->timestamp);
printf("dstBuf->upperTimeStamp = %u\n", dstBuf->upperTimeStamp);
printf("dstBuf->lowerTimeStamp = %u\n", dstBuf->lowerTimeStamp);
printf("dstBuf->bottomFieldBitBufSize = %u\n", dstBuf->bottomFieldBitBufSize);
printf("dstBuf->inputFileChanged = %u\n", dstBuf->inputFileChanged);
printf("dstBuf->frameType = %u\n", dstBuf->frameType);
printf("dstBuf->bufPhysAddr = %u\n", dstBuf->bufPhysAddr);
printf("dstBuf->frameWidth = %u\n", dstBuf->frameWidth);
printf("dstBuf->frameHeight = %u\n", dstBuf->frameHeight);
printf("dstBuf->doNotDisplay = %u\n", dstBuf->doNotDisplay);
printf("dstBuf->seqId = %u\n", dstBuf->seqId);
fflush(stdout);
void input_from_file(void *parm)
int rc;
IpcBitsOutLinkHLOS_BitstreamBufReqInfo reqInfo;
Bitstream_BufList emptyBufList;
Bitstream_BufList bufList;
int iRet;
int i;
int read_size;
int status;
FILE *fphdr;
int fd;
VCODEC_BITSBUF_S *pEmptyBuf;
VCODEC_BITSBUF_S *pOutBuf, *pInBuf;
VCODEC_BITSBUF_LIST_S BitsBufList;
VCODEC_BITSBUF_LIST_S *pBitsBufList;
int ret_status;
int input_frame_count = 0;
/* wait for links to be created*/
int pthread_cond_wait(pthread_cond_t *restrict cond,
pthread_mutex_t *restrict mutex);
while (!conditionMet) {
printf("input Thread blocked\n");
rc = pthread_cond_wait(&g_condition, &g_mutex);
fd = open("/opt/sample.h264", O_RDONLY);
if(fd <= 0)
printf("file open error");
exit(-1);
fphdr = fopen("/opt/sample.h264.hdr", "r");
if(fphdr == NULL)
exit(-1);
while(1)
reqInfo.numBufs = 1;
reqInfo.reqType = IPC_BITSOUTHLOS_BITBUFREQTYPE_CHID;
for (i = 0; i< 1; i++)
reqInfo.u[i].chNum = i;
ret_status = IpcBitsOutLink_getEmptyVideoBitStreamBufs(SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0, &emptyBufList, &reqInfo);
OSA_assert(0 == ret_status);
pBitsBufList = &BitsBufList;
pBitsBufList->numBufs = emptyBufList.numBufs;
for (i = 0; i < emptyBufList.numBufs; i++)
pOutBuf = &pBitsBufList->bitsBuf[i];
pInBuf = emptyBufList.bufs[i];
Vdec_copyBitBufInfoLink2McFw(pOutBuf, pInBuf);
pEmptyBuf= &BitsBufList.bitsBuf[0];
/*iChains_ipcBitsReadBitsFromFile(&emptyBufList, maxDataSize);*/
int statHdr, statData;
int curCh;
statHdr = fscanf(fphdr,"%d",&(pEmptyBuf->filledBufSize));
OSA_assert(pEmptyBuf->filledBufSize <= pEmptyBuf->bufSize);
statData = read(fd, pEmptyBuf->bufVirtAddr, pEmptyBuf->filledBufSize);
print_diag(pEmptyBuf);
if( feof(fphdr) || statData != pEmptyBuf->filledBufSize)
printf(" CH Reached the end of file, inputframecount = %d !!!",input_frame_count);
#if 0
/*rewind*/
clearerr(fphdr);
rewind(fphdr);
lseek(fp, 0, SEEK_SET);
statData = read(fp, pEmptyBuf->bufVirtAddr, pEmptyBuf->filledBufSize);
#endif
break;
ret_status = IpcBitsOutLink_putFullVideoBitStreamBufs(SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0, &BitsBufList);
input_frame_count++;
//sleep(1);
close(fd);
fclose(fphdr);
static Void Chains_ipcFramesPrintFrameInfo(VIDFrame_Buf *buf)
OSA_printf("CHAINS_IPCFRAMES:VIDFRAME_INFO:"
"chNum:%d\t"
"fid:%d\t"
"frameWidth:%d\t"
"frameHeight:%d\t"
"timeStamp:%d\t"
"virtAddr[0][0]:%p\t"
"phyAddr[0][0]:%p",
buf->channelNum,
buf->fid,
buf->frameWidth,
buf->frameHeight,
buf->timeStamp,
buf->addr[0][0],
buf->phyAddr[0][0]);
void receive_output_and_filw(void *parm)
int fd;
VIDFrame_BufList bufList;
int status;
int i;
int rc;
OSA_printf("CHAINS_IPCFRAMES:%s:Entered...",__func__);
// OSA_semWait(&thrObj->framesInNotifySem,OSA_TIMEOUT_FOREVER);
OSA_printf("CHAINS_IPCFRAMES:Received first frame notify...");
#if 0
fd = open("/opt/out.yuv", O_WRONLY);
if(fd <= 0)
exit(-1);
#endif
printf("Output Thread blocked\n");
sleep(1);
while(1)
status = IpcFramesInLink_getFullVideoFrames(SYSTEM_HOST_LINK_ID_IPC_FRAMES_IN_0,
&bufList);
OSA_assert(0 == status);
if (bufList.numFrames > 0)
printf("FULLF:");
for(i = 0; i < bufList.numFrames;i++)
/*writetofile(bufList.frames[i])*/
Chains_ipcFramesPrintFrameInfo(&bufList.frames[i]);
// pEmptyBuf= &BitsBufList.bitsBuf[0];
// statData = write(fd, pEmptyBuf->bufVirtAddr, pEmptyBuf->filledBufSize);
status = IpcFramesInLink_putEmptyVideoFrames(SYSTEM_HOST_LINK_ID_IPC_FRAMES_IN_0, &bufList);
#if 0
status = IpcFramesOutLink_getEmptyVideoFrames(SYSTEM_HOST_LINK_ID_IPC_FRAMES_OUT_0,
&bufList);
if (bufList.numFrames)
printf("emptyF:");
&bufList);
#endif
close(fd);
int main()
pthread_t thrd,thrd2;
char *message1 = "Thread 1";
char *message2 = "Thread 2";
pthread_mutexattr_t mutexattr; // Mutex Attribute
pthread_condattr_t attr;
int rc;
int iret1;
System_init();
rc = pthread_condattr_init(&attr);
pthread_mutexattr_init(&mutexattr);
pthread_mutex_init(&(g_mutex), &mutexattr);
pthread_cond_init(&(g_condition), &attr);
conditionMet = 0;
iret1 = pthread_create( &thrd, NULL, input_from_file, (void*) message1);
iret1 = pthread_create( &thrd2, NULL, receive_output_and_filw, (void*) message2);
Chains_main();
System_deInit();
pthread_cond_destroy(&g_condition);
return 0;
  • The statistic infor for IOCTL  "IPCBITSOUT_LINK_CMD_PRINT_BUFFER_STATISTICS" is:
    [m3video] *** Decode Statistics ***
    [m3video] 213312: DEC: Rcvd from prev = 0, Returned to prev = 0
    [m3video] DEC Out BufExt Q Status
    [m3video] Empty Q 0 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Full Q -> count 0, wrPtr 0, rdPtr 0
    Does it mean that  i am not sending the input buffers correctly?.
    thanks,
  • There are a couple of issues with your usecase file:.Below code is wrong:
    It should be
    ipcFramesInHostPrm.baseCreateParams.notifyPrevLink = TRUE;
    ipcBitsInVideoPrm.baseCreateParams.notifyPrevLink = FALSE;
  • Thanks Badri  for replying. But still i am not able to get the output frame.
    I have attached the C file that i used. The statistics that i collected after the links are started is below.
    I suspect that i am not giving the input buffers at all.
    Is it possible that "IpcBitsOutLink_getEmptyVideoBitStreamBufs" to block, because i am not getting the subsequent printfs.
    stats:
    [m3video] *** DECODE Statistics ***
    [m3video]
    [m3video] Elasped Time : 38 secs
    [m3video]
    [m3video]
    [m3video] CH | In Recv In User Out
    [m3video] Num | FPS Skip FPS FPS
    [m3video] -----------------------------------
    [m3video] 0 | 0 0 0
    [m3video] 1 | 0 0 0
    [m3video] 2 | 0 0 0
    [m3video] 3 | 0 0 0
    [m3video] 4 | 0 0 0
    [m3video] 5 | 0 0 0
    [m3video] 6 | 0 0 0
    [m3video] 7 | 0 0 0
    [m3video] 8 | 0 0 0
    [m3video] 9 | 0 0 0
    [m3video] 10 | 0 0 0
    [m3video] 11 | 0 0 0
    [m3video] 12 | 0 0 0
    [m3video] 13 | 0 0 0
    [m3video] 14 | 0 0 0
    [m3video] 15 | 0 0 0
    [m3video]
    [m3video] Multi Channel Decode Average Submit Batch Size
    [m3video] Max Submit Batch Size : 24
    [m3video] IVAHD_0 Average Batch Size : 0
    [m3video] IVAHD_0 Max achieved Batch Size : 0
    [m3video] IVAHD_1 Average Batch Size : 0
    [m3video] IVAHD_1 Max achieved Batch Size : 0
    [m3video] IVAHD_2 Average Batch Size : 0
    [m3video] IVAHD_2 Max achieved Batch Size : 0
    [m3video]
    [m3video] Multi Channel Decode Batch break Stats
    [m3video] Total Number of Batches created: 0
    [m3video] All numbers are based off total number of Batches created
    [m3video] Batch breaks due to batch sizeexceeding limit: 0 %
    [m3video] Batch breaks due to ReqObj Que being empty: 0 %
    [m3video] Batch breaks due to changed resolution class: 0 %
    [m3video] Batch breaks due to interlace and progressivecontent mix: 0 %
    [m3video] Batch breaks due to channel repeat: 0 %
    [m3video] Batch breaks due to different codec: 0 %
    [m3video]
    IPCBITSOUTLINK:Buffer Statistics
    Num Alloc Pools:16
    PoolId | TotalBufCnt | FreeBufCnt | BufSize | AppAllocCount
    0| 1| 1| 230400| 0
    1| 1| 1| 230400| 0
    2| 1| 1| 230400| 0
    3| 1| 1| 230400| 0
    4| 1| 1| 230400| 0
    5| 1| 1| 230400| 0
    6| 1| 1| 230400| 0
    7| 1| 1| 230400| 0
    8| 1| 1| 230400| 0
    9| 1| 1| 230400| 0
    10| 1| 1| 230400| 0
    11| 1| 1| 230400| 0
    12| 1| 1| 230400| 0
    13| 1| 1| 230400| 0
    14| 1| 1| 230400| 0
    15| 1| 1| 230400| 0
    #include <fcntl.h>
    #include <stdio.h>
    #define TRUE              1
    #define FALSE 0
    #define SRC_NUM_CH 16
    int conditionMet=0;
                           FILE (H264)
                             DEC
                            FILE (YUV)
    #if 0
        .isPopulated = 1,
        .ivaMap[0] =
            .EncNumCh  = 0,
            .DecNumCh  = 16,
        .ivaMap[1] =
            .EncNumCh  = 0,
            .DecNumCh  = 0,
        .ivaMap[2] =
            .EncNumCh  = 0,
            .DecNumCh  = 0,
    #endif
        .isPopulated = 1,
        .ivaMap[0] =
            .EncNumCh  = 0,
            .DecNumCh  = SRC_NUM_CH,
        return 0;
        "\r\n"
        "\r\n"
        "\r\n "
    	char ch[128];
    	ch[0] = '\n';
    	return ch[0];
    	System_linkControl(
    		NULL,
    		0,
    		TRUE
    #if 0
    #endif
        "\r\n ============"
        "\r\n Chain Select"
        "\r\n ============"
        "\r\n"
        "\r\n"
        "\r\n "
        "\r\n "
        "\r\n x: Exit "
        "\r\n "
    	switch(ch)
    	case '1':
    		break;
    	case '2':
    		break;
    	case '3':
    		break;
    	case '4':
    		break;
    	default:
    		break;
    Void Chains_main()
    	char ch[128];
    	Bool done;
    	done = FALSE;
    	while(!done)
    			continue;
    		printf(" \r\n");
    		switch(ch[0])
    			case 's':
    			break;
    			case 'x':
    			done = TRUE;
    			break;
    			case 'd':
    			break;
    #define INI_FRAME_WIDTH 640
    #define INI_FRAME_HEIGHT 360
    	Int i;
    	Bool isProgressive;
    	UInt32 decId;
    	char ch;
    	int rc;
    	System_linkControl(
    	TRUE
    	/* badri's changes*/
    	#if 0
    		if (isProgressive)
    		else
    	#endif
    	sleep(2);
    	conditionMet =1;
    	while(1)
    		if(ch=='0')
    		break;
    		if(ch=='i')
    		if(ch=='d')
    		if(ch=='D')
    		if(ch=='b')
    #if 0
            UInt32 displayChId;
    #endif
        else
        dstBuf->strmId         = 0;
       print_diag(dstBuf);
        fflush(stdout);
    	int rc;
    	int iRet;
    	int i;
    	int read_size;
    	int status;
    	FILE *fphdr;
    	int fd;
    	int ret_status;
    	fd = open("/opt/sample_tmr.h264", O_RDONLY);
    	if(fd <= 0)
    		exit(-1);
    	fphdr = fopen("/opt/sample_tmr.h264.hdr", "r");
    	if(fphdr == NULL)
    		exit(-1);
    	while(1)
    		reqInfo.numBufs = NUM_BUF_PER_CH;
    		for (i = 0; i< NUM_BUF_PER_CH; i++)
    		int curCh;
    			#if 0
    			/*rewind*/
    			clearerr(fphdr);
    			rewind(fphdr);
    			#endif
    			break;
    		//sleep(1);
    	close(fd);
    	fclose(fphdr);
                   "chNum:%d\t"
                   "fid:%d\t"
                   "frameWidth:%d\t"
                   "frameHeight:%d\t"
                   "timeStamp:%d\t"
                   "phyAddr[0][0]:%p",
                    buf->channelNum,
                    buf->fid,
                    buf->frameWidth,
                    buf->frameHeight,
                    buf->timeStamp,
                    buf->addr[0][0],
    	int fd;
    	int status;
    	int i;
    	int rc;
    #if 0
    	if(fd <= 0)
    		exit(-1);
    #endif
    	sleep(1);
    	while(1)
                                                        &bufList);
    			printf("FULLF:");
    #if 0
                                                           &bufList);
    			printf("emptyF:");
                                                             &bufList);
    #endif
    	close(fd);
    int main()
    	int rc;
    	int iret1;
    	System_init();
    	conditionMet = 0;
    	Chains_main();
    	System_deInit();
    	return 0;
    [m3video] 362474: DEC: Rcvd from prev = 0, Returned to prev = 0
    [m3video] Empty Q 1 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 2 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 3 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 4 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 5 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 6 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 7 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 8 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 9 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 10 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 11 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 12 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 13 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 14 -> count 1, wrPtr 1, rdPtr 0
    [m3video] Empty Q 15 -> count 1, wrPtr 1, rdPtr 0
    The C test file:
    #include <fcntl.h>
    #include <stdio.h>
    #define TRUE 1
    #define FALSE 0
    int conditionMet=0;
    FILE (H264)
    DEC
    FILE (YUV)
    #if 0
    .isPopulated = 1,
    .ivaMap[0] =
    .EncNumCh = 0,
    .DecNumCh = 16,
    .ivaMap[1] =
    .EncNumCh = 0,
    .DecNumCh = 0,
    .ivaMap[2] =
    .EncNumCh = 0,
    .DecNumCh = 0,
    #endif
    .isPopulated = 1,
    .ivaMap[0] =
    .EncNumCh = 0,
    return 0;
    "\r\n"
    "\r\n"
    "\r\n "
    char ch[128];
    ch[0] = '\n';
    return ch[0];
    System_linkControl(
    NULL,
    0,
    TRUE
    #if 0
    #endif
    "\r\n ============"
    "\r\n Chain Select"
    "\r\n ============"
    "\r\n"
    "\r\n"
    "\r\n "
    "\r\n "
    "\r\n x: Exit "
    "\r\n "
    switch(ch)
    case '1':
    break;
    case '2':
    break;
    case '3':
    break;
    case '4':
    break;
    default:
    break;
    Void Chains_main()
    char ch[128];
    Bool done;
    done = FALSE;
    while(!done)
    continue;
    printf(" \r\n");
    switch(ch[0])
    case 's':
    break;
    case 'x':
    done = TRUE;
    break;
    case 'd':
    break;
    Int i;
    Bool isProgressive;
    UInt32 decId;
    char ch;
    int rc;
    System_linkControl(
    TRUE
    #if 0
    if (isProgressive)
    else
    #endif
    sleep(2);
    conditionMet =1;
    while(1)
    if(ch=='0')
    break;
    if(ch=='i')
    if(ch=='d')
    if(ch=='D')
    if(ch=='b')
    #if 0
    UInt32 displayChId;
    #endif
    else
    dstBuf->strmId = 0;
    print_diag(dstBuf);
    fflush(stdout);
    int rc;
    int iRet;
    int i;
    int read_size;
    int status;
    FILE *fphdr;
    int fd;
    int ret_status;
    if(fd <= 0)
    exit(-1);
    if(fphdr == NULL)
    exit(-1);
    while(1)
    int curCh;
    #if 0
    /*rewind*/
    clearerr(fphdr);
    rewind(fphdr);
    #endif
    break;
    //sleep(1);
    close(fd);
    fclose(fphdr);
    "chNum:%d\t"
    "fid:%d\t"
    "frameWidth:%d\t"
    "frameHeight:%d\t"
    "timeStamp:%d\t"
    "phyAddr[0][0]:%p",
    buf->channelNum,
    buf->fid,
    buf->frameWidth,
    buf->frameHeight,
    buf->timeStamp,
    buf->addr[0][0],
    int fd;
    int status;
    int i;
    int rc;
    #if 0
    if(fd <= 0)
    exit(-1);
    #endif
    sleep(1);
    while(1)
    &bufList);
    printf("FULLF:");
    #if 0
    &bufList);
    printf("emptyF:");
    &bufList);
    #endif
    close(fd);
    int main()
    int rc;
    int iret1;
    System_init();
    conditionMet = 0;
    Chains_main();
    System_deInit();
    return 0;
  • In my input_from_file thread , I am calling IpcBitsOutLink_getEmptyVideoBitStreamBufs to get bufs
    while(1){
    the emptyBufList.numBufs is 1, only for the first call and subsequent call is zero, so i am not passing the input buffers correctly.
    What is the right way to use IpcBitsOutLink_getEmptyVideoBitStreamBufs?
  • You are getting only one buffer because you have set NUM_BUF_PER_CH  to 1.
    Your code is wrong. Pls look at the prorotype of IpcBitsOutLink_getEmptyVideoBitStreamBufs & IpcBitsOutLink_putFullVideoBitStreamBufs.It expects Bitstream_BufList *. You are passing something else. You should have got compiler warnings. Delete all code related to VCODEC_BITSBUF_LIST_S and VCODEC_BITSBUF_S.When using links they should not be used.
    I incorporated BitsBufList based changes. But i was not able to make it work.
    when i run i get the info that the links are created:
    [host] 1739: IPC_BITS_OUT : Create in progress !!!
    ###Bit buff of size from the SR # 1 : 230400
    [host] IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x38400
    [host] IPCBITSOUTLINK:Translated Addr Virt:0x412d3080 To Phy:0x90000080
    [host] 1740: IPC_BITS_OUT : Create Done !!!
    [m3video] 20620: IPC_BITS_IN : Create in progress !!!
    [m3video] 20620: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
    [m3video] 20621: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
    [m3video] 20622: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
    [m3video] 20623: IPC_BITS_IN : Create Done !!!
    [m3video] 20623: DECODE: Create in progress ... !!!
    [m3video] DECLINK_H264:HEAPID:0 USED:4264
    [m3video] DECLINK_H264:HEAPID:3 USED:3678208
    [m3video] 20647: DECODE: Creating CH0 of 640 x 360 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
    [m3video] 20648: DECODE: All CH Create ... DONE !!!
    [m3video] DECLINK:HEAPID:0 USED:4384
    [m3video] DECLINK:HEAPID:3 USED:4581376
    [m3video] 20651: DECODE: Create ... DONE !!!
    [host] IpcFramesInLink_tskMain:Entered
    [host] 3773: IPC_FRAMES_IN : Create in progress !!!
    [host] 3773: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_19] ...
    3775: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_19] ...
    [m3video] 22652: IPC_FRAMES_OUT : Create in progress !!!
    [host] 3778: IPC_FRAMES_IN : Create Done !!!
    [m3video] 22653: IPC_FRAMES_OUT : Create Done !!!
    Then i pass the input buffer from another "input_from_file" pthread. For testing, I just give only 8 frame-input.
    1. I first get the empty buffer
    calling "IpcBitsOutLink_getEmptyVideoBitStreamBufs"
    2. then fill it with data from input .h264 file with fillsize obtained from .h264hdr file and
    3. then directly give it to "IpcBitsOutLink_putFullVideoBitStreamBufs". I am not changing the timestamp or sequenceId
    info of the buffers. is that a problem?
    I am printing the buffer statistics before i pass it to "IpcBitsOutLink_putFullVideoBitStreamBufs" and the for the 8 buffers that i get
    the statistics is as follows:
    dstBuf->reserved = 1080806656
    dstBuf->addr = 1093480576
    dstBuf->bufSize = 230400
    dstBuf->fillLength = 0
    dstBuf->startOffset = 0
    dstBuf->mvDataOffset = 4294967295
    dstBuf->mvDataFilledSize = 0
    dstBuf->channelNum = 0
    dstBuf->codingType = 4294967295
    dstBuf->appData = 4294967295
    dstBuf->timeStamp = 4294967295
    dstBuf->temporalId = 0
    dstBuf->numTemporalLayerSetInCodec = 0
    dstBuf->upperTimeStamp = 4294967295
    dstBuf->lowerTimeStamp = 4294967295
    dstBuf->encodeTimeStamp = 4294967295
    dstBuf->bottomFieldBitBufSize = 0
    dstBuf->frameWidth = 4294967295
    dstBuf->frameHeight = 4294967295
    dstBuf->isKeyFrame = 4294967295
    dstBuf->allocPoolID = 0
    dstBuf->inputFileChanged = 0
    dstBuf->phyAddr = 2415919232
    dstBuf->doNotDisplay = 0
    dstBuf->seqId = 0
    dstBuf->seqId = 0
    .. ..(the above dstBuf info is repeated for 8 times)
    I am still getting the statistics showing no decoding as happening.
    and
    DEC_LINK_CMD_PRINT_BUFFER_STATISTICS :
    [m3video] 143569: DEC: Rcvd from prev = 0, Returned to prev = 0
    Num Alloc Pools:1
    0| 1| 1| 230400| 0
    and the IVAHD buffer statistics is all 0's
    I suspect the problem is in my input feeding part. I would greatly appreciate your help.
    My present file is :
    #include <fcntl.h>
    #include <stdio.h>
    #define TRUE              1
    #define FALSE 0
    int conditionMet=0;
    pthread_mutex_t g_mutex2;
    pthread_cond_t g_condition2;
    int conditionMet2=0;
                           FILE (H264)
                             DEC
                            FILE (YUV)
        .isPopulated = 1,
        .ivaMap[0] =
            .EncNumCh  = 0,
        "\r\n"
        "\r\n"
        "\r\n i: Print  DEC_LINK_CMD_PRINT_IVAHD_STATISTICS "
        "\r\n "
        "\r\n d: Print DEC_LINK_CMD_PRINT_STATISTICS "
        "\r\n "
        "\r\n D: Print DEC_LINK_CMD_PRINT_BUFFER_STATISTICS "
        "\r\n "
        "\r\n b: Print IPCBITSOUT_LINK_CMD_PRINT_BUFFER_STATISTICS "
        "\r\n "
        "\r\n ============"
        "\r\n Chain Select"
        "\r\n ============"
        "\r\n"
        "\r\n"
        "\r\n "
        "\r\n x: Exit "
        "\r\n "
    	char ch[128];
    	ch[0] = '\n';
    	return ch[0];
    	System_linkControl(
    		NULL,
    		0,
    		TRUE
    	switch(ch)
    	case '1':
    		break;
    	case '2':
    		break;
    	case '3':
    		break;
    	case '4':
    		break;
    	default:
    		printf("invalid option ");
    		break;
    Void Chains_main()
    	char ch[128];
    	Bool done;
    	done = FALSE;
    	while(!done)
    			continue;
    		printf(" \r\n");
    		switch(ch[0])
    			case 's':
    			break;
    			case 'x':
    			done = TRUE;
    			break;
    			case 'd':
    			break;
    	Int i;
    	Bool isProgressive;
    	UInt32 decId;
    	char ch;
    	int rc;
    	System_linkControl(
    	TRUE
    	#if 0
    		if (isProgressive)
    		else
    	#endif
    	sleep(2);
    	conditionMet =1;
    	rc = pthread_mutex_lock(&g_mutex2);
    	conditionMet2 =1;
    	rc = pthread_cond_broadcast(&g_condition2);
    	rc = pthread_mutex_unlock(&g_mutex2);
    	while(1)
    		if(ch=='0')
    		break;
    		if(ch=='i')
    		if(ch=='d')
    		if(ch=='D')
    		if(ch=='b')
    void print_diagnostics(	Bitstream_Buf  *dstBuf)
        printf("dstBuf->addr = %u\n", dstBuf->addr);
        printf("dstBuf->fillLength = %u\n", dstBuf->fillLength);
        printf("dstBuf->startOffset = %u\n", dstBuf->startOffset);
        printf("dstBuf->mvDataOffset = %u\n", dstBuf->mvDataOffset);
        printf("dstBuf->mvDataFilledSize = %u\n", dstBuf->mvDataFilledSize);
        printf("dstBuf->channelNum = %u\n", dstBuf->channelNum);
        printf("dstBuf->codingType = %u\n", dstBuf->codingType);
        printf("dstBuf->appData = %u\n", dstBuf->appData);
        printf("dstBuf->timeStamp = %u\n", dstBuf->timeStamp);
        printf("dstBuf->temporalId = %u\n", dstBuf->temporalId);
        printf("dstBuf->numTemporalLayerSetInCodec = %u\n", dstBuf->numTemporalLayerSetInCodec);
        printf("dstBuf->encodeTimeStamp = %u\n", dstBuf->encodeTimeStamp);
        printf("dstBuf->isKeyFrame = %u\n", dstBuf->isKeyFrame);
        printf("dstBuf->allocPoolID = %u\n", dstBuf->allocPoolID);
        printf("dstBuf->phyAddr = %u\n", dstBuf->phyAddr);
        printf("=====\n");
        fflush(stdout);
                   "chNum:%d\t"
                   "fid:%d\t"
                   "frameWidth:%d\t"
                   "frameHeight:%d\t"
                   "timeStamp:%d\t"
                   "phyAddr[0][0]:%p",
                    buf->channelNum,
                    buf->fid,
                    buf->frameWidth,
                    buf->frameHeight,
                    buf->timeStamp,
                    buf->addr[0][0],
    	int rc;
    	int iRet;
    	int i;
    	int read_size;
    	int status;
    	FILE *fphdr;
    	int fd;
    	Bitstream_Buf  *thisbuf_struct;
    	int ret_status;
    	int curCh;
    	unsigned long filledBufSize;
    	if(fd <= 0)
    		exit(-1);
    	if(fphdr == NULL)
    		exit(-1);
    	int framei;
    //	while(1)
    	for (framei = 0; framei < 8; framei++)
    		    	// reqInfo.u[i].minBufSize =  ((INI_FRAME_WIDTH) * (INI_FRAME_HEIGHT)/2);
    		emptyBufList.numBufs = 0;
    		if(emptyBufList.numBufs == 0)
    			printf("no empty buf received\n");
    			continue;
    		//for (bufi = 0; bufi< emptyBufList.numBufs; bufi++)
    		int bufi;
    		bufi = 0;
    			thisbuf_struct = emptyBufList.bufs[bufi];
    			statHdr  = fscanf(fphdr,"%d",&(filledBufSize));
    			OSA_assert(filledBufSize <= thisbuf_struct->bufSize);
    			statData = read(fd, thisbuf_struct->addr, filledBufSize);
    			if( feof(fphdr) || statData != filledBufSize)
    				break;
    		print_diagnostics(thisbuf_struct);
    		ret_status = IpcBitsOutLink_putFullVideoBitStreamBufs(SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0, &emptyBufList);
    		sleep(1);
    	close(fd);
    	fclose(fphdr);
    	int fd;
    	int status;
    	int i;
    	int rc;
    #if 0
    	if(fd <= 0)
    		exit(-1);
    #endif
    	while (!conditionMet2) {
    	rc = pthread_cond_wait(&g_condition2, &g_mutex2);
    	sleep(2);
    	while(1)
                                                        &bufList);
    			printf("FULLF:");
    #if 0
                                                           &bufList);
    			printf("emptyF:");
                                                             &bufList);
    #endif
    	close(fd);
    int main()
    	int rc;
    	int iret1;
    	System_init();
    	pthread_mutex_init(&(g_mutex2), &mutexattr);
    	pthread_cond_init(&(g_condition2), &attr);
    	conditionMet = 0;
    	conditionMet2 = 0;
    	Chains_main();
    	System_deInit();
    	pthread_cond_destroy(&g_condition2);
    	return 0;
    thanks.
  • The problem with your implementation are:
    NUM_BUF_PER_CH 1 will not work.It should be 6 atleast.
    You are only copying the bitstream but are not populating any info in the bitstream buffer.
    You should atleast populate the filledBufSize for decoding to happen.
  • I also have got the same problem but my application is : Receiving encoded stream from network via RTSPClient and decode those stream. I just know copy the encoded stream from the network into Bitstream_Buf->addr and I don't know how to initialize (fill up) all fields of Bitstream_Buf before put them to the decoder by calling the function IpcBitsOutLink_putFullVideoBitStreamBufs.
    Could you help of give me information abow how to resolve this problem. Thank you very much!
  • I am working on DM8148 RDK 3.5. I use ENC_A8_DEC usecase(multich_encode_decode.c) for my application
  • You have to set filledBufSize and channelNum atleast
