OMAP-L138 - Naming convention for EMAC signals
Other Parts Discussed in Thread: OMAP-L138, OMAPL138
OMAP-L138 datasheet appears to be rather inconsistent in terms of EMAC signals.
Example:
MDIO_CLK  vs MDCLK
MDIO_D      vs MDIO
May I ask you to take approriate measures towards fixing the problem?
Many thanks,
Milan Zelenka
  • Milan Zelenka,
    Thanks for your notification about the MDIO pins(signal name) in the OMAL138 datasheet.
    I also verified both the OMAPL138 datasheet and TRM.
    Yes,It will confuse the MDIO naming used bit different at some point.
    I would like to inform about MDIO pin signal naming.
    Management data clock (MDIO_CLK) is equivalent to MDCLK
    Management data input output (MDIO_D) is equivalent to MDIO
    I will inform to EMAC team about the MDIO signal naming correction.
  • Thanks Pubesh.
    Let's consider this SR closed.
