8148 encoder sei sps pps
As I know, the encoder only output sei sps pps information at the first.
Because I send the data other physical board, it may can't hold the first sei sps pps information.
How can I let encoder to output sei sps pps  every 40ms ?
  • Please go through the Encoder user guide available with the package. That should give you the right answer.
    Just to start with it, If you use rdk software, in encoder Links you can find Flags/Macros defined which does setting SPS/PPS/SEI. You need to customize it little bit to work in the way you want.
