DM8148 Graphics overlay
I'm looking for a solution to overlay OSD graphics on video that uses hardware acceleration on DM8148 - currently I have a working solution based on the EZSDK software OSD examples that can run on DSP or M3 core (using EDMA copy) but this uses a big chunk of cpu time.
Is it possible to use the video compositor and GRPX graphics module to overlay a graphics buffer on a single video stream?
there is no local display on my setup - I need to convert the output of video_mixer to H264 and stream over ethernet using RTSP.
I have been investigating omx_videomixer with little progress..
are there any examples of this approach?
William.
    Here are two examples if I understanding you right.
    gst-launch omx_videomixer port-index=0 framerate=25 name=mix sink_00::outX=0 sink_00::outY=0 sink_00::outWidth=1920 sink_00::outHeight=1080  sink_01::outX=360 sink_01::outY=150 sink_01::outWidth=848 sink_01::outHeight=360 ! omx_ctrl display-mode=OMX_DC_MODE_1080P_60 ! omx_videosink sync=false filesrc location=/usr/share/ti/data/videos/dm816x_1080p_demo.264 ! 'video/x-h264' ! h264parse access-unit=true ! omx_h264dec ! mix. filesrc location=/usr/share/ti/data/videos/dm816x_1080p_demo.264 ! 'video/x-h264' ! h264parse access-unit=true ! omx_h264dec ! clockoverlay halign=center valign=bottom text="UTC time:" shaded-background=true ! mix.
    gst-launch omx_videomixer port-index=0 framerate=25 name=mix sink_00::outX=0 sink_00::outY=0 sink_00::outWidth=1280 sink_00::outHeight=720  sink_01::outX=1080 sink_01::outY=720 sink_01::outWidth=848 sink_01::outHeight=360 ! omx_ctrl display-mode=OMX_DC_MODE_1080P_60 ! omx_videosink sync=false filesrc location=/usr/share/ti/data/videos/dm816x_1080p_demo.264 ! 'video/x-h264,framerate=(fraction)30000/1252' ! h264parse access-unit=true ! omx_h264dec ! clockoverlay halign=center valign=bottom text="UTC time:" shaded-background=true ! mix. filesrc location=/usr/share/ti/data/videos/dm816x_1080p_demo.264 ! 'video/x-h264,framerate=(fraction)30000/1252' ! h264parse access-unit=true ! omx_h264dec ! mix.
    Let me know is this what you are looking for?
    What is the EZSDK version that you are using also?
    Margarita
  • Hi Margarita - thanks for the reply.
    does the clockoverlay component use any hardware acceleration?
    I am using EZSDK 5.05.
    William.
    clockoverlay is part of GStreamer  Base Plugin, so I do not think so.
    EZSDK 5.05.01 or 5.05.02?
    Margarita
    I had a look at the textoverlay/clockoverlay components previously but they were not suitable for what we wanted - ideally we want to apply OSD graphics using hardware so that the cores are freed up for other tasks.
    the graphics include masking/blanking regions of video which can take up significant cpu time to perform on every video frame buffer.
    I thought there could be a way to do this using the GRPX module to overlay the contents of a graphics buffer on top of a single video stream - is this possible?
    EZSDK version is 5.05.01.04.
    William.
