I have an "Loop buffer exception" issue. My own program use System Analyzer for collect statistics. When I run it with system analyzer tool it crash after a few seconds with the following error:
[C66xx_0] 3750
A16=0xcd00cd A17=0x19a019a
A18=0xcdcdcdcd A19=0xcd00cd
A20=0x19c019c A21=0xcd00cd
A22=0x1616 A23=0x80f020
A24=0x16161616 A25=0x80f018
A26=0x48 A27=0x1980198
A28=0x40004 A29=0x20002
A30=0x0 A31=0x0
B0=0x0 B1=0x0
B2=0x2020202 B3=0xc150ff8
B4=0xcdcdcdcd B5=0xcd00cd
B6=0x0 B7=0xffffffff
B8=0xcd00cd B9=0xcd00cd
B10=0x848358 B11=0x823740
B12=0x848488 B13=0xc1a85dc
B14=0x876c78 B15=0x848300
B16=0x80dc30 B17=0x19a019a
B18=0x80dc34 B19=0xf
B20=0xcdcdcdcd B21=0x0
B22=0x20002 B23=0x707
B24=0x80dc38 B25=0x7070707
B26=0x80dc30 B27=0x3320332
B28=0xcc00cc B29=0xcc00cc
B30=0xcc00cc B31=0xcc00cc
NTSR=0x1420d
ITSR=0x20d
IRP=0xc15be6c
SSR=0x0
AMR=0x0
RILC=0x8
ILC=0x0
Exception at 0xc189f48
EFR=0x2 NRP=0xc189f48
Internal exception: IERR=0x180
Missed stall exception
ti.sysbios.family.c64p.Exception: line 255: E_exceptionMin: pc = 0x0c189f48, sp = 0x00848300.
To see more exception detail, use ROV or set 'ti.sysbios.family.c64p.Exception.enablePrint = true;'
xdc.runtime.Error.raise: terminating execution
There is my cfg file:
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Error = xdc.useModule('xdc.runtime.Error');
var ti_csl_Settings = xdc.useModule('ti.csl.Settings');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var Exception=xdc.useModule('ti.sysbios.family.c64p.Exception');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var CpIntc = xdc.useModule('ti.sysbios.family.c66.tci66xx.CpIntc');
var H264HPVENC = xdc.useModule('ti.sdo.codecs.h264hpvenc.H264HPVENC');
var ECPY = xdc.useModule('ti.sdo.fc.ecpy.ECPY');
var RMAN = xdc.useModule('ti.sdo.fc.rman.RMAN');
var ti_platform_evmc6678l_Settings = xdc.useModule('ti.platform.evmc6678l.Settings');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var DSKT2 = xdc.useModule('ti.sdo.fc.dskt2.DSKT2');
var Load = xdc.useModule('ti.sysbios.utils.Load');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var NameServer = xdc.useModule('ti.sdo.utils.NameServer');
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var LoggerCircBuf = xdc.useModule('ti.uia.runtime.LoggerCircBuf');
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
var Settings = xdc.useModule('ti.drv.pcie.Settings');
var Idle = xdc.useModule('ti.sysbios.knl.Idle');
Idle.idleFxns[0] = "&idle_check_frame";
var heapMemParams1 = new HeapMem.Params();
var heapMemParams2 = new HeapMem.Params();
Program.global.APPNUM = -1;
Program.global.shmSL2Base = 0x0C000000;
Program.global.shmSL2Size = 0x80000;
MultiProc.setConfig(null,["CORE0","CORE1","CORE2","CORE3","CORE4","CORE5","CORE6","CORE7"]);
Exception.enablePrint=true;
heapMemParams1.size = 0xA000000;
heapMemParams1.sectionName=".extData";
Program.global.ddr3Heap=HeapMem.create(heapMemParams1);
heapMemParams2.size = 0x8000;
heapMemParams2.sectionName=".INTMEM_HEAP";
Program.global.INTMEM_HEAP=HeapMem.create(heapMemParams2);
for(var i=0;i<8;i++){
Ipc.setEntryMeta({remoteProcId:i,
setupMessageQ:false,
SharedRegion.translate=false;
SharedRegion.setEntryMeta(0,{base: Program.global.shmSL2Base,
len: Program.global.shmSL2Size,
ownerProcId:0,
isValid: true,
cacheEnable:true,
cacheLineSize:64,
//var Engine = xdc.useModule('ti.sdo.ce.Engine');
* Program.argSize sets the size of the .args section.
* The examples don't use command line args so argSize is set to 0.
var EDMA3CHAN = xdc.useModule('ti.sdo.fc.ires.edma3chan.EDMA3CHAN');
var META = xdc.useModule('ti.sdo.fc.edma3.Settings');
var EDMA3LLD = xdc.loadPackage('ti.sdo.edma3.rm');
RMAN.useDSKT2 = true;
RMAN.yieldSamePriority = true;
RMAN.tableSize = 10;
//RMAN.maxAlgs = 2;
META.maxPaRams[0] = 42;
META.maxTccs[0] = 8;
META.maxEdmaChannels[0] = 8;
META.maxQdmaChannels[0] = 0;
META.controllerId=1;
DSKT2.ALLOW_EXTERNAL_SCRATCH = false;
DSKT2.DARAM0 = "INTMEM_HEAP";
DSKT2.DARAM1 = "INTMEM_HEAP";
DSKT2.DARAM2 = "INTMEM_HEAP";
DSKT2.SARAM0 = "INTMEM_HEAP";
DSKT2.SARAM1 = "INTMEM_HEAP";
DSKT2.SARAM2 = "INTMEM_HEAP";
DSKT2.ESDATA = "INTMEM_HEAP";
DSKT2.IPROG = "INTMEM_HEAP";
DSKT2.EPROG = "INTMEM_HEAP";
DSKT2.DSKT2_HEAP = "INTMEM_HEAP";
ECPY.persistentAllocFxn = "DSKT2_allocPersistent";
ECPY.persistentFreeFxn = "DSKT2_freePersistent"
BIOS.heapSize = 0xC000;
Program.stack = 0x3000;
Program.argSize = 0x800;
Program.sectMap[".chip_memory"]="MSMCSRAM";
Program.sectMap[".core_memory"]="L2SRAM";
Program.sectMap[".INTMEM_HEAP"]="L2SRAM";
Program.sectMap[".extData"]="DDR3";
Program.sectMap[".extData"].type="NOINT";
Program.sectMap[".extFrameData"]="DDR3";
Program.sectMap[".extFrameData"].type="NOINT";
Program.sectMap[".intFrameData"]="MSMCSRAM";
Program.sectMap[".intFrameData"].type="NOINT";
Program.sectMap[".intData"]="L2SRAM";
Program.sectMap[".intData"].type="NOINT";
Program.sectMap[".cabactables"]="MSMCSRAM";
Program.sectMap[".constTables"]="MSMCSRAM";
Program.sectMap[".qpTable_shared_dtcm2"]="MSMCSRAM";
Program.sectMap[".text"] = "MSMCSRAM";
Program.sectMap[".text:cabac"] = "MSMCSRAM";
Program.sectMap[".stack"] = "L2SRAM";
Program.sectMap[".cinit"] = "MSMCSRAM";
Program.sectMap[".cio"] = "L2SRAM";
Program.sectMap[".const"] = "MSMCSRAM";
Program.sectMap[".qpTable_shared_dtcm2"] = "MSMCSRAM";
Program.sectMap[".switch"] = "L2SRAM";
Program.sectMap[".args"] = "MSMCSRAM";
Program.sectMap[".bss"] = "L2SRAM";
Program.sectMap[".bios"] = "L2SRAM";
Program.sectMap[".fardata"] = "L2SRAM";
Program.sectMap[".neardata"] = "L2SRAM";
Program.sectMap[".rodata"] = "L2SRAM";
Program.sectMap[".tables"] = "DDR3";
Program.sectMap[".cabactables"] = "MSMCSRAM";
Program.sectMap[".sysmem"] = "L2SRAM";
Program.sectMap[".far"] = "L2SRAM";
SysMin.bufSize = 0x400;
System.SupportProxy = SysMin;
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var loggerCircBuf3Params = new LoggerCircBuf.Params();
loggerCircBuf3Params.instance.name = "loggerCircBuf3";
Program.global.loggerCircBuf3 = LoggerCircBuf.create(loggerCircBuf3Params);
LoggingSetup.mainLogger = Program.global.loggerCircBuf3;
LoggingSetup.sysbiosLogger = Program.global.loggerCircBuf3;
BIOS.cpuFreq.lo = 1250000000;
Could you explain what can lead to this?
With best Regards, Ilya.
