Other Parts Discussed in Thread: TVP5158
We have a DM8148 based customize board.We are using RDK4.0.
I am getting following error during load.sh
root@dm814x:/opt/dvr_rdk/ti814x# ./init.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
amixer: Cannot find the given element from control default
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff10820
[m3vpss ] Remote Debug Shared Memory @ 0xbff21040
SysLink version : 2.20.02.20
SysLink module created on Date:Jun 25 2013 Time:10:02:16
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x58, 0x59, 0x5a, 0x5b
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5c): 0x08 = 0x51
I2C (0x5c): 0x09 = 0x58
I2C (0x5d): 0x08 = 0x51
I2C (0x5d): 0x09 = 0x58
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti814x
root@dm814x:/opt/dvr_rdk/ti814x# ./load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_1024M_384M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ISS Freq : 480 MHz
After Ipc_startcallback status [0x00000000]
[m3vpss ] ***** VPSS Firmware build time 17:49:28 Jun 24 2013 EDG gcc 3.0 mode
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 480000 Khz ***
[m3vpss ]
[m3vpss ] 43: SYSTEM : System Common Init in progress !!!
[m3vpss ] 44: SYSTEM: IPC init in progress !!!
[m3vpss ] 44: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 46: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_1024M_384M.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ISS Freq : 480 MHz
[m3video] ***** VIDEO Firmware build time 17:50:19 Jun 24 2013 EDG gcc 3.0 mode
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000
[m3video]
[m3video] *** UTILS: CPU KHz = 480000 Khz ***
[m3video]
[m3video] 721: SYSTEM : System Common Init in progress !!!
[m3video] 722: SYSTEM: IPC init in progress !!!
[m3video] 722: SYSTEM: Attaching to [HOST] ...
[m3video] 725: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_1024M_384M.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] DSP Freq : 750 MHz
[m3video] 1033: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 1035: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[c6xdsp ] ***** VIDEO Firmware build time 17:48:22 Jun 24 2013 EDG gcc 3.0 mode
[m3video] 1037: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 1037: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] ***** SYSTEM : Frequency <ORG> -DMA: Module install successful, device major num = 248
500000000, <NEWDRV: Module install successful
> - 750000000
DRV: Module built on Jun 25 2013 10:07:42
[m3video] 1037: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
[m3vpss ] 1037: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
[c6xdsp ]
[m3video] 1037: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 1037: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[c6xdsp ] *** UTILS: CPU KHz = 750000 Khz ***
[m3video] 1038: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 1038: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ]
[m3video] 1040: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 1040: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[m3video] 1040: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 1040: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[m3video] 1040: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 1040: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
[m3video] 1040: SYSTEM: IPC init DONE !!!
[m3vpss ] 1040: SYSTEM: IPC init DONE !!!
[c6xdsp ] 4: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 6: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] 8: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[c6xdsp ] 8: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
[c6xdsp ] 8: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 8: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 8: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 8: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 8: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[c6xdsp ] 8: SYSTEM: IPC init DONE !!!
[c6xdsp ] 11: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
[m3video] 1048: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
[m3vpss ] 1047: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
[c6xdsp ] 11: MEM: Shared Region 1: Base = 0x98000000, Length = 0x04f00000 (79 MB)
[m3video] 1048: MEM: Shared Region 1: Base = 0x98000000, Length = 0x04f00000 (79 MB)
[m3vpss ] 1048: MEM: Shared Region 1: Base = 0x98000000, Length = 0x04f00000 (79 MB)
[c6xdsp ] 11: SYSTEM : System Common Init Done !!!
[m3video] 1050: SYSTEM : System Common Init Done !!!
[m3vpss ] 1050: SYSTEM : System Common Init Done !!!
[c6xdsp ] 10: SYSTEM : System DSP Init in progress !!!
[m3video] 1050: SYSTEM : System Video Init in progress !!!
[m3vpss ] 1050: SYSTEM : System VPSS Init in progress !!!
[c6xdsp ] 10: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[m3video] 1050: SYSTEM : System Video Init Done !!!
[m3vpss ] !!!!!!!!!!! Initiating pinmux for i2c1: Vps_platformTI814xSetPinMux 870
[c6xdsp ] 15: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
[m3video] 1051: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 15: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
[m3video] 1051: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 15: SYSTEM: ListElem Shared Addr = 0xbf173e00
[m3video] 1052: SYSTEM: ListElem Shared Addr = 0xbf21fc00
[c6xdsp ] 16: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
[m3video] 1054: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[c6xdsp ] 16: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
[m3video] 1055: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[c6xdsp ] 16: SYSTEM: ListElem Shared Addr = 0xbf199600
[m3video] 1055: SYSTEM: ListElem Shared Addr = 0xbf223100
[c6xdsp ] 17: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
[c6xdsp ] 17: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
[c6xdsp ] 17: SYSTEM: ListElem Shared Addr = 0xbf1bee00
[m3video] 1062: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
[m3vpss ] === I2C1/3 Interface Clk is active ===
[c6xdsp ] 18: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[m3video] 1062: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
[m3vpss ] 1073: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 18: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[m3video] 1063: SYSTEM: ListElem Shared Addr = 0xbf226600
[m3vpss ] 1074: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 18: SYSTEM: ListElem Shared Addr = 0xbf1e4600
[m3video] 1066: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
[m3vpss ] 1074: SYSTEM: ListElem Shared Addr = 0xbf296e00
[c6xdsp ] 19: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[m3video] 1066: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
[m3vpss ] 1077: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[c6xdsp ] 19: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[m3video] 1066: SYSTEM: ListElem Shared Addr = 0xbf24be00
[m3vpss ] 1077: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[c6xdsp ] 19: SYSTEM: ListElem Shared Addr = 0xbf202100
[m3video] 1069: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
[m3vpss ] 1077: SYSTEM: ListElem Shared Addr = 0xbf29a300
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 19: SYSTEM : Initializing Links !!!
[m3video] 1069: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
[m3vpss ] 1095: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
[m3video] 1070: SYSTEM: ListElem Shared Addr = 0xbf271600
[m3vpss ] 1095: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
[c6xdsp ] 20: SYSTEM : FREE SPACE : System Heap = 6393472 B, Mbx = 10240 msgs)
[m3video] 1087: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 1096: SYSTEM: ListElem Shared Addr = 0xbf2d8e00
[m3video] 1087: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 1099: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
[c6xdsp ] 33: SYSTEM : Initializing Links ... DONE !!!
[m3video] 1087: SYSTEM: ListElem Shared Addr = 0xbf29d800
[m3vpss ] 1099: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
[m3video] 1090: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 1099: SYSTEM: ListElem Shared Addr = 0xbf2fe600
[c6xdsp ] 33: SYSTEM : System DSP Init Done !!!
[m3video] 1090: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 1102: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
[m3video] 1091: SYSTEM: ListElem Shared Addr = 0xbf2bb300
[m3vpss ] 1102: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
[m3video] 1093: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 1103: SYSTEM: ListElem Shared Addr = 0xbf323e00
[m3video] 1093: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 1105: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3video] 1094: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 1105: SYSTEM : FVID2 Init in progress !!!
[m3video] 1095: SYSTEM : ISS Init in progress !!!
[m3video] 1095: SYSTEM : ISS Power-ON in progress !!!
[m3video] 1105: SYSTEM : ISS Power-ON in progress DONE !!!
[m3video] 1105: SYSTEM : ISS Init in progress DONE !!!
[m3video] 1105: VCOP BOOST BIT is Set
[m3vpss ] TILER_STATS: CNT :8BIT
[m3video] 1105: SYSTEM : VCOP Init in progress !!!
[m3video] 1105: SYSTEM : VCOP needs 172 B of memory !!!
[m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 5440
[m3video] 1107: SYSTEM : VCOP Init in progress DONE !!!
[m3video] 1107: SYSTEM : Initializing Links !!!
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 5436
[m3vpss ] Received character 's'
[m3video] 1107: SYSTEM : FREE SPACE : System Heap = 6263296 B, Mbx = 10240 msgs)
[m3vpss ] TILER_STATS: NUM FREE BUCKETS: 1
[m3video] Received character 's'
[m3vide[module] vpss probe done.
o] 1107: SYSTEM : FREE SPACE : SR0 Heap = 5730304 B (5 MB)
[m3vpss ] TILER_STATS: NUM USED BUCKETS: 0
[c6xdsp ] Received character '[module] ti81xxfb probe done.
s'
/opt/dvr_rdk/ti814x
[m3video] 1107: SYSTEM : FREE SPACE : Frame Buffer = 117440384 B (111 MB)
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 89063424 (99 %)
[m3video] 1108: SYSTEM : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
[m3vpss ] TILER_STATS: TOTAL USED AREA: 0 (0 %)
[m3video] 1108: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 1110: SYSTEM : FREE SPACE : Tiler 8-bit = 89063424 B (84 MB) - TILER ON
[m3video] 1110: SYSTEM : FREE SPACE : Tiler 16-bit = 44040192 B (42 MB) - TILER ON
[m3vpss ] TILER_STATS: CNT :16BIT
[m3video] 1170: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] TILER_STATS: CNT RESOLUTION: 32768 x 1344
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 1344
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 44040192 (100 %)
[m3vpss ] 1187: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 1187: SYSTEM : Device Init in progress !!!
[m3vpss ] 1275: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] HDVPSS Freq : 220 MHz
[m3vpss ] 1322: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 1323: UTILS: DMA: HWI Create for INT63 !!!
[m3vpss ] 1323: SYSTEM : Initializing Links !!!
[m3vpss ] 1323: SYSTEM : FREE SPACE : System Heap = 250280 B, Mbx = 10240 msgs)
[m3vpss ] 1324: SYSTEM : FREE SPACE : SR0 Heap = 5730304 B (5 MB)
[m3vpss ] 1324: SYSTEM : FREE SPACE : Frame Buffer = 113130368 B (107 MB)
[m3vpss ] 1324: SYSTEM : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
[m3vpss ] 1325: SYSTEM : FREE SPACE : Tiler 8-bit = 89063424 B (84 MB) - TILER ON
[m3vpss ] 1325: SYSTEM : FREE SPACE : Tiler 16-bit = 44040192 B (42 MB) - TILER ON
[m3vpss ] 1476: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 1476: SYSTEM : Set Static L3 pressure for HDVPSS as High
Unhandled fault: external abort on non-linefetch (0x1018) at 0x46c00524
./load.sh: line 27: 1126 Bus error ./bin/mem_rdwr.out --wr 0x46c00524 2
please help me on this.
