Other Parts Discussed in Thread: TVP5158
We have a customize board based on DM8148 and we are using RDK-4 on it.
Our application is "8 channel capture + encode + dump". We used default link provided in RDK.
When I run default application for 8 chennel, it only dump 1chennel data.
Please help us on this as soon as possible.
Log is as follow,
root@dm814x:/opt/dvr_rdk/ti814x# ./run.sh
Main Menu
1: 4CH VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
2: 8CH <D1+CIF> VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
3: 16CH RT VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
4: 16CH NRT <D1+CIF> VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
5: VDEC + VDIS - SD/HD Decode ONLY
e: Exit
Enter Choice: 2
--------------- CHANNEL DETAILS-------------
Capture Channels => 8
Enc Channels => Primary 8, Secondary 8
Dec Channels => 8
Disp Channels => 16
0: SYSTEM: System Common Init in progress !!!
2: SYSTEM: IPC init in progress !!!
54: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
54: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
54: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
54: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
58: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
64: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
66: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
67: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
68: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
68: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
71: SYSTEM: Notify register to [DSP] line 0, event 15 ...
73: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
74: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
74: SYSTEM: IPC init DONE !!!
84: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
86: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
87: SYSTEM: ListElem Shared Addr = 0x4068b880
88: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
90: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
91: SYSTEM: ListElem Shared Addr = 0x406c0a80
95: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
97: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
99: SYSTEM: ListElem Shared Addr = 0x406f5c80
100: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
101: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
103: SYSTEM: ListElem Shared Addr = 0x40738f80
104: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
105: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
107: SYSTEM: ListElem Shared Addr = 0x4077c280
127: SYSTEM: System Common Init Done !!!
[host] HDMI Ctrl :Initializing
[host] HDMI Ctrl : ERROR :Could not open HDMI driver
Enable file write (YES - y / NO - n) : y
File write ENABLED !!!
Enter file write path : /media/mmcblk0/storage
Selected file write path [/media/mmcblk0/storage]
[host] Partition Free Size for Path[/media/mmcblk0/storage/VBITS_HDR_0_LAYER_0.bin] = [0x679A1980]
[host] Max File size per channel:0x11445995
AUDIO: Do you enable Audio <Y/N>: n
[FBDEV]
[FBDEV] FB: Starting !!!
[FBDEV] FB: Opened device [/dev/fb0] (fd=405) !!!
[FBDEV]
[FBDEV] Fix Screen Info
[FBDEV] ---------------
[FBDEV] Line Length - 1600
[FBDEV] Physical Address = b6a00000
[FBDEV] Buffer Length = 2097152
[FBDEV]
[FBDEV]
[FBDEV] Var Screen Info
[FBDEV] Xres - 800
[FBDEV] Yres - 600
[FBDEV] Xres Virtual - 800
[FBDEV] Yres Virtual - 600
[FBDEV] Bits Per Pixel - 16
[FBDEV] Pixel Clk - 6734
[FBDEV] Rotation - 0
[FBDEV]
[FBDEV]
[FBDEV] Reg Params Info
[FBDEV] region 0, postion 0 x 0, prioirty 1
[FBDEV] first 1, last 1
[FBDEV] sc en 0, sten en 0
[FBDEV] tran en 0, type 0, key 0
[FBDEV] blend 0, alpha 0
[FBDEV] bb en 0, alpha 0
[FBDEV]
[FBDEV]
[FBDEV] ### BUF SIZE = 960000 Bytes !!!
[FBDEV]
[FBDEV] FB: Opened device [/dev/fb2] (fd2=406) !!!
[FBDEV]
[FBDEV] Line Length - 1440
[FBDEV] Physical Address = b6c00000
[FBDEV] Buffer Length = 1048576
[FBDEV]
[FBDEV]
[FBDEV] Xres - 720
[FBDEV] Yres - 480
[FBDEV] Xres Virtual - 720
[FBDEV] Yres Virtual - 480
[FBDEV] Pixel Clk - 18518
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] ### BUF SIZE = 691200 Bytes !!!
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] Xres - 800
[FBDEV] Yres - 600
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] Xres - 720
[FBDEV] Yres - 480
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] grpx_fb_draw ...
[FBDEV] grpx_fb_draw ... Done !!!
[FBDEV] FB: Start DONE !!!
[FBDEV]
********* Entered usecase 8CH <810x> Enc/Dec OSD Enabled SCD Enabled
18022: MCFW : CPU Revision [ES2.1] !!!
VCAP: DEVICE-0 (0x5c): Chip ID 0x5158, Rev 0x0002, Firmware 0x0000 !!!
VCAP: DEVICE-0 (0x5c): Detected video (720x240@59Hz, 1) !!!
VCAP: DEVICE-1 (0x5d): Chip ID 0x5158, Rev 0x0002, Firmware 0x0000 !!!
VCAP: DEVICE-1 (0x5d): Detected video (720x240@59Hz, 1) !!!
TVP5158: 0x5c: Downloading patch ...
TVP5158: 0x5c: Downloading patch ... DONE !!!
TVP5158: 0x5c: 5158:0002:0302
TVP5158: 0x5d: Downloading patch ...
TVP5158: 0x5d: Downloading patch ... DONE !!!
TVP5158: 0x5d: 5158:0002:0302
DEI EOE pattern is set for ch0!
DEI EOE pattern is set for ch1!
DEI EOE pattern is set for ch2!
DEI EOE pattern is set for ch3!
DEI EOE pattern is set for ch4!
DEI EOE pattern is set for ch5!
DEI EOE pattern is set for ch6!
DEI EOE pattern is set for ch7!
[m3vpss ] 41055: CAPTURE: Create in progress !!!
[m3vpss ] 41088: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
[m3vpss ] 41162: CAPTURE: VIP0 PortB capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
[m3vpss ] CAPTURE::HEAPID:0 USED:520
[m3vpss ] CAPTURE::HEAPID:4 USED:31279104
[m3vpss ] 41237: CAPTURE: Create Done !!!
[m3vpss ] 41238: NSF: Create in progress !!!
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USED:14784
[m3vpss ] NSF::HEAPID:4 USED:12976128
[m3vpss ] 41311: NSF: Create Done !!!
[m3vpss ] 41316: DUP : Create Done !!!
[m3vpss ] 41318: SELECT: OUT QUE0: OUT CH0: IN CH0: 704 x 240, pitch = (704, 704) [INTERLACED ] [NON-TILED ]
[m3vpss ] 41318: SELECT : Create Done !!!
[m3vpss ] 41318: DEI : Create in progress !!!
[m3vpss ] 41336: DEI : Loading Up-scaling Co-effs
[m3vpss ] 41337: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] DEI:HEAPID:0 USED:64
[m3vpss ] DEI:HEAPID:1 USED:5040
[m3vpss ] DEI:HEAPID:4 USED:2872320
[m3vpss ] 41337: DEI : Create Done !!!
[m3vpss ] 41338: DEI : Create in progress !!!
[m3vpss ] 41476: DEI : Loading Up-scaling Co-effs
[m3vpss ] 41476: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] DEI:HEAPID:1 USED:12160
[m3vpss ] DEI:HEAPID:4 USED:22978560
[m3vpss ] 41477: DEI : Create Done !!!
[m3vpss ] 41477: DEI : Create in progress !!!
[m3vpss ] 41487: DEI : Loading Down-scaling Co-effs
[m3vpss ] 41488: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] DEI:HEAPID:1 USED:11584
[m3vpss ] DEI:HEAPID:4 USED:1013760
[m3vpss ] 41488: DEI : Create Done !!!
[m3vpss ] 41489: SCLR: Create in progress !!!
[m3vpss ] 41521: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 41521: SCLR : Co-effs Loading ... DONE !!!
[m3video] 41531: IPC_IN_M3 : Create in progress !!!
[m3video] 41531: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3video] 41532: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] SCLR:HEAPID:1 USED:22976
[m3vpss ] SCLR:HEAPID:4 USED:5406720
[m3vpss ] 41522: SCLR: Create Done !!!
[m3vpss ] 41522: NSF: Create in progress !!!
[m3video] 41534: IPC_IN_M3 : Create Done !!!
[m3video] 41535: ALG : Create in progress !!!
[m3vpss ] NSF::HEAPID:1 USED:11264
[m3vpss ] 41527: NSF: Create Done !!!
[m3vpss ] 41529: MERGE : Create Done !!!
[m3vpss ] 41529: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 41531: IPC_OUT_M3 : Create Done !!!
[m3video] 41548: ALG : Prev Link ID = 10000002 !!!
[m3video] 41549: OSD: Opening algorithm ... !!!
[m3video] 41562: OSD: Opening algorithm ... DONE !!!
[m3video] UTILS: DMA: Allocated CH (TCC) = 51 (51)
[m3video] UTILS: DMA: 0 of 8: Allocated PaRAM = 51 (0x49004660)
[m3video] UTILS: DMA: 1 of 8: Allocated PaRAM = 479 (0x49007BE0)
[m3video] UTILS: DMA: 2 of 8: Allocated PaRAM = 480 (0x49007C00)
[m3video] UTILS: DMA: 3 of 8: Allocated PaRAM = 481 (0x49007C20)
[m3video] UTILS: DMA: 4 of 8: Allocated PaRAM = 482 (0x49007C40)
[m3video] UTILS: DMA: 5 of 8: Allocated PaRAM = 483 (0x49007C60)
[m3video] UTILS: DMA: 6 of 8: Allocated PaRAM = 484 (0x49007C80)
[m3video] UTILS: DMA: 7 of 8: Allocated PaRAM = 485 (0x49007CA0)
[m3video] 41595: SCD: Opening algorithm ... !!!
[m3video] 41596: SCD: Opening algorithm ... DONE !!!
[m3video] UTILS: DMA: Allocated CH (TCC) = 56 (56)
[m3video] UTILS: DMA: 0 of 1: Allocated PaRAM = 56 (0x49004700)
[m3video] ALGLINK:HEAPID:0 USED:30672
[m3video] ALGLINK:HEAPID:3 USED:7836800
[m3video] 41608: ALG : Create Done !!!
[m3video] 41610: ENCODE: Create in progress ... !!!
[m3video] ENCLINK:INFO: !!!Number of output buffers for ch[16] set to [1]
[m3video] 41695: ENCODE: Creating CH0 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3video] ENCLINK_H264:HEAPID:3 USED:45056
[m3video] 41701: ENCODE: Creating CH1 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3video] 41705: ENCODE: Creating CH2 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 21381: IPC_BITS_IN : Create in progress !!!
[host] 21381: IPC_BITS_IN : ListMPOpen start !!!
[host] 21381: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
21383: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
[m3video] 41710: ENCODE: Creating CH3 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[host] 21385: IPC_BITS_IN : ListMPOpen done !!!
[host] 21386: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 21386: IPC_BITS_IN : Create Done !!!
========bitsProducerLinkInfo============
numQ 1, numCh 24
Ch [0] Width 704, Height 480
Ch [1] Width 704, Height 480
Ch [2] Width 704, Height 480
Ch [3] Width 704, Height 480
Ch [4] Width 704, Height 480
Ch [5] Width 704, Height 480
Ch [6] Width 704, Height 480
Ch [7] Width 704, Height 480
Ch [8] Width 176, Height 120
Ch [9] Width 176, Height 120
Ch [10] Width 176, Height 120
Ch [11] Width 176, Height 120
Ch [12] Width 176, Height 120
Ch [13] Width 176, Height 120
Ch [14] Width 176, Height 120
Ch [15] Width 176, Height 120
Ch [16] Width 704, Height 480
Ch [17] Width 704, Height 480
Ch [18] Width 704, Height 480
Ch [19] Width 704, Height 480
Ch [20] Width 704, Height 480
Ch [21] Width 704, Height 480
Ch [22] Width 704, Height 480
Ch [23] Width 704, Height 480
Reducing bitsProducerLinkInfo.numCh to 8
[host] 21390: IPC_BITS_OUT : Create in progress !!!
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:0,Size:0x294000
[host]
******* RingBuf 0 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x41adbe80 To Phy:0x98ea6e80
[host]
###Bit buff of size from the SR # 1 : 2703360 / bufsize 337920, maxQueueDepth 50
[host] ###Bit buff BasePtr: 41ADBE80 / PhyAddr 98EA6E80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:1,Size:0x294000
[host]
******* RingBuf 1 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x41d6fe80 To Phy:0x9913ae80
[host]
[host] ###Bit buff BasePtr: 41D6FE80 / PhyAddr 9913AE80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:2,Size:0x294000
[host]
******* RingBuf 2 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x42003e80 To Phy:0x993cee80
[host]
[host] ###Bit buff BasePtr: 42003E80 / PhyAddr 993CEE80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:3,Size:0x294000
[host]
******* RingBuf 3 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x42297e80 To Phy:0x99662e80
[host]
[host] ###Bit buff BasePtr: 42297E80 / PhyAddr 99662E80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:4,Size:0x294000
[host]
******* RingBuf 4 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x4252be80 To Phy:0x998f6e80
[host]
[host] ###Bit buff BasePtr: 4252BE80 / PhyAddr 998F6E80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:5,Size:0x294000
[host]
******* RingBuf 5 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x427bfe80 To Phy:0x99b8ae80
[host]
[host] ###Bit buff BasePtr: 427BFE80 / PhyAddr 99B8AE80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:6,Size:0x294000
[host]
******* RingBuf 6 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x42a53e80 To Phy:0x99e1ee80
[host]
[host] ###Bit buff BasePtr: 42A53E80 / PhyAddr 99E1EE80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:7,Size:0x294000
[host]
******* RingBuf 7 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x42ce7e80 To Phy:0x9a0b2e80
[host]
[host] ###Bit buff BasePtr: 42CE7E80 / PhyAddr 9A0B2E80
[host] 21729: IPC_BITS_OUT : Create Done !!!
[m3video] 41714: ENCODE: Creating CH4 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] 41719: ENCODE: Creating CH5 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] 41723: ENCODE: Creating CH6 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] 41728: ENCODE: Creating CH7 of 704 x 480, pitch = (16384, 32768) [PROGRESSIVE] [TILED ], bitrate = 2000 Kbps ...
[m3video] 41732: ENCODE: Creating CH8 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:3 USED:184320
[m3video] 41735: ENCODE: Creating CH9 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] 41738: ENCODE: Creating CH10 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3vpss ] 42237: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 42237: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3vpss ] 42237: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3video] 41740: ENCODE: Creating CH11 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3vpss ] 42238: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 42240: IPC_IN_M3 : Create Done !!!
[m3vpss ] 42243: MERGE : Create Done !!!
[m3video] 41743: ENCODE: Creating CH12 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3vpss ] 42248: DUP : Create Done !!!
[m3vpss ] 42249: SWMS: Create in progress !!!
[m3video] 41746: ENCODE: Creating CH13 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] 41748: ENCODE: Creating CH14 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] 41751: ENCODE: Creating CH15 of 176 x 120, pitch = (176, 176) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] 41754: ENCODE: Creating CH16 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3video] ENCLINK_JPEG:HEAPID:0 USED:2064
[m3video] 41755: ENCODE: Creating CH17 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3video] 41755: ENCODE: Creating CH18 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3video] 41756: ENCODE: Creating CH19 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[m3video] 41757: ENCODE: Creating CH20 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
[m3vpss ] 42396: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3video] 41758: ENCODE: Creating CH21 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3vpss ] 42396: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 42396: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[0]
[m3video] 41759: ENCODE: Creating CH22 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3vpss ] 42397: SWMS : ******* Configuring clock 15 secs...
[m3vpss ] 42397: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 42398: SWMS0 : Loading Horizontal Co-effs (10/16)x ...
[m3vpss ] 42398: SWMS : Co-effs Loading ... DONE !!!
[m3video] 41759: ENCODE: Creating CH23 of 704 x 480, pitch = (16384, 32768) [INTERLACED ] [TILED ], bitrate = 100 Kbps ...
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 60
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 1 | 1 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 480, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 2 | 2 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 960, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3video] 41760: ENCODE: All CH Create ... DONE !!!
[m3vpss ] 3 | 3 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 1440, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 4 | 4 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[host] IpcBitsInLink_tskMain:Entered [m3vpss ] 5 | 5 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 480, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3video] ENCLINK:HEAPID:0 USED:209040
[m3vpss ] 6 | 6 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 960, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3video] ENCLINK:HEAPID:2 USED:15363584
[m3vpss ] 7 | 7 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 1440, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3video] ENCLINK:HEAPID:3 USED:1835008
[m3vpss ] 8 | 8 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3video] 41761: ENCODE: Create ... DONE !!!
[m3vpss ] 9 | 9 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 480, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3video] 41761: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] 10 | 10 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 960, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 11 | 11 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 1440, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 12 | 12 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3video] 41764: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 13 | 13 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 480, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3video] 42112: IPC_BITS_IN : Create in progress !!!
[m3vpss ] 14 | 14 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 960, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3video] 42112: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
[m3vpss ] 15 | 15 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 1440, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3video] 42113: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
[m3vpss ]
[m3video] 42114: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[m3video] 42116: IPC_BITS_IN : Create Done !!!
[m3video] 42116: DECODE: Create in progress ... !!!
[m3vpss ] SWMS:HEAPID:0 USED:224
[m3vpss ] SWMS:HEAPID:1 USED:43776
[m3vpss ] SWMS:HEAPID:3 USED:8294400
[m3video] DECLINK_H264:HEAPID:0 USED:2368
[m3vpss ] SWMS:HEAPID:4 USED:16588800
[m3video] DECLINK_H264:HEAPID:3 USED:1249280
[m3vpss ] 42405: SWMS: Create Done !!!
[m3video] 42131: DECODE: Creating CH0 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 42406: SWMS: Create in progress !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 60 (60)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 60 (0x49004780)
[m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 17
[m3vpss ] 42451: SWMS : VipScReq is TRUE!!!
[m3video] 42145: DECODE: Creating CH1 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 42457: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 42457: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 42457: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 42457: SWMS : OutFrames List -> 2 !!!!!!!
[m3video] 42159: DECODE: Creating CH2 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[2]
[m3vpss ] 42458: SWMS : ******* Configuring clock 15 secs...
[m3vpss ] 42458: SWMS1 : Loading Vertical Co-effs (7/16)x ...
[m3vpss ] 42458: SWMS1 : Loading Horizontal Co-effs (3/16)x ...
[m3vpss ] 42459: SWMS : Co-effs Loading ... DONE !!!
[m3video] 42173: DECODE: Creating CH3 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 0 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 1 | 1 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 176, 0 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 2 | 2 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 352, 0 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 3 | 3 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 528, 0 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3video] 42187: DECODE: Creating CH4 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 4 | 4 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 5 | 5 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 176, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 6 | 6 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 352, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3vpss ] 7 | 7 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 528, 120 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
Setting DEI 1, Ch 0, Q 1 with new resolution - 176 X 120!!!!!!
[m3vpss ] 8 | 8 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF |
[m3video] 42201: DECODE: Creating CH5 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 9 | 9 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 176, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 10 | 10 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 352, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 11 | 11 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 528, 240 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 12 | 12 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 13 | 13 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 176, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3video] 42216: DECODE: Creating CH6 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 14 | 14 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 352, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 15 | 15 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 528, 360 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ]
[m3video] 42230: DECODE: Creating CH7 of 704 x 480 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3video] 42232: DECODE: All CH Create ... DONE !!!
[m3vpss ] SWMS:HEAPID:1 USED:20736
[m3vpss ] SWMS:HEAPID:3 USED:6782976
[m3vpss ] 42466: SWMS: Create Done !!!
[m3video] DECLINK:HEAPID:0 USED:18984
[m3vpss ] 42466: DISPLAY: Create in progress !!!
[m3video] DECLINK:HEAPID:3 USED:9994240
[m3vpss ] 42468: DISPLAY: Create Done !!!
[m3video] 42235: DECODE: Create ... DONE !!!
[m3vpss ] 42468: DISPLAY: Create in progress !!!
[m3video] 42235: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 42469: DISPLAY: 44: Field Separate Mode ENABLED for Que 0 !!!
[m3video] 42236: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 42470: DISPLAY: Create Done !!!
[m3vpss ] 42474: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 42474: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 42474: SWMS0 : Loading Horizontal Co-effs (10/16)x ...
[m3vpss ] 42474: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ] Output FPS: 30
[m3vpss ]
[m3vpss ] 0 | 9 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
Setting DEI 1, Ch 1, Q 1 with new resolution - 176 X 120!!!!!!
[m3vpss ] 1 | 10 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 480, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 2 | 11 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 960, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 3 | 12 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 1440, 0 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 4 | 13 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 5 | 14 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 480, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 6 | 15 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 960, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 7 | 16 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 1440, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 8 | 17 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 0, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 9 | 18 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 480, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 10 | 19 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 960, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 11 | 20 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 1440, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 12 | 21 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 0, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 13 | 22 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 480, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 14 | 23 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 960, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 15 | 24 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 1440, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ]
[m3vpss ] 42484: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 42485: SWMS1 : Loading Vertical Co-effs (7/16)x ...
[m3vpss ] 42485: SWMS1 : Loading Horizontal Co-effs (3/16)x ...
[m3vpss ] 42485: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 9 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 0 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 1 | 10 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 176, 0 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 2 | 11 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 352, 0 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 3 | 12 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 528, 0 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 4 | 13 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 5 | 14 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 176, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 6 | 15 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 352, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 7 | 16 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 528, 120 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 8 | 17 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 0, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 9 | 18 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 176, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 10 | 19 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 352, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 11 | 20 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 528, 240 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 12 | 21 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 0, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 13 | 22 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 176, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 14 | 23 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 352, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 15 | 24 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 528, 360 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ]
[m3vpss ] 42532: DISPLAY: Start in progress !!!
[m3vpss ] 42583: DISPLAY: Start Done !!!
[m3vpss ] 42584: DISPLAY: HDDAC(BP0) : 38 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0 ) !!!
Setting DEI 1, Ch 2, Q 1 with new resolution - 176 X 120!!!!!!
Setting DEI 1, Ch 3, Q 1 with new resolution - 176 X 120!!!!!!
Setting DEI 1, Ch 4, Q 1 with new resolution - 176 X 120!!!!!!
Setting DEI 1, Ch 5, Q 1 with new resolution - 176 X 120!!!!!!
Setting DEI 1, Ch 6, Q 1 with new resolution - 176 X 120!!!!!!
[m3vpss ] 42584: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
[m3vpss ] 42584: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 0, DVO2(BP1) 1, SDDAC(SEC1) 1
[m3vpss ] 42584: SYSTEM : FREE SPACE : System Heap = 242592 B, Mbx = 10238 msgs)
Setting DEI 1, Ch 7, Q 1 with new resolution - 176 X 120!!!!!!
Setting DEI 0, Ch 0, Q 1 with new resolution - 704 X 480!!!!!!
Setting DEI 0, Ch 4, Q 1 with new resolution - 704 X 480!!!!!!
Setting DEI 0, Ch 1, Q 1 with new resolution - 352 X 240!!!!!!
Setting DEI 0, Ch 2, Q 1 with new resolution - 352 X 240!!!!!!
[m3vpss ] 42584: SYSTEM : FREE SPACE : SR0 Heap = 1783808 B (1 MB)
Setting DEI 0, Ch 3, Q 1 with new resolution - 352 X 240!!!!!!
Setting DEI 0, Ch 5, Q 1 with new resolution - 352 X 240!!!!!!
Setting DEI 0, Ch 6, Q 1 with new resolution - 352 X 240!!!!!!
Setting DEI 0, Ch 7, Q 1 with new resolution - 352 X 240!!!!!!
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
5: Audio Capture <TVP5158> & Encode <AAC-LC, G711> demo
6: Change Playback Channel <valid only if capture/playback is active>
7: Audio encode demo <File In/Out>
8: Audio decode demo <File In/Out>
c: Change 8CH modes (8CH usecase ONLY!!!!)
d: Change 16CH modes (16CH usecase ONLY!!!!)
i: Print detailed system information
s: Core Status: Active/In-active
e: Stop Demo
Enter Choice: [DECODER ERROR] 23784: DECODE CH <1> ERROR: IH264VDEC_ERR_NOSLICE : 0,
[DECODER ERROR] 24083: DECODE CH <1> ERROR: XDM_PARAMSCHANGE : 8,
[DECODER ERROR] 24083: DECODE CH <1> ERROR: IH264VDEC_ERR_PICSIZECHANGE : 20,
[m3vpss ] 42584: SYSTEM : FREE SPACE : Frame Buffer = 348928 B (0 MB)
[m3video] DEC_LINK: CH1 decoder changing resolution
[m3vpss ] 42585: SYSTEM : FREE SPACE : Bitstream Buffer = 30769536 B (29 MB)
[DECODER ERROR] 24092: DECODE CH <2> ERROR: IH264VDEC_ERR_NOSLICE : 0,
[DECODER ERROR] 24092: DECODE CH <2> ERROR: XDM_PARAMSCHANGE : 8,
[DECODER ERROR] 24092: DECODE CH <2> ERROR: IH264VDEC_ERR_PICSIZECHANGE : 20,
[m3video] 44466: DECODE: CH1: Decoder flush needed (1048833)!!!
[m3vpss ] 42585: DISPLAY: Start in progress !!!
[m3video] 44466: DECODE: CH1: Decoder Flushing !!!
[m3video] DEC_LINK: CH2 decoder changing resolution
[m3video] 44475: DECODE: CH2: Decoder flush needed (1048833)!!!
[m3video] 44476: DECODE: CH2: Decoder Flushing !!!
[m3vpss ] TILER_STATS: CNT :8BIT
[DECODER ERROR] 24103: DECODE CH <3> ERROR: IH264VDEC_ERR_NOSLICE : 0,
[DECODER ERROR] 24103: DECODE CH <3> ERROR: XDM_PARAMSCHANGE : 8,
[DECODER ERROR] 24103: DECODE CH <3> ERROR: IH264VDEC_ERR_PICSIZECHANGE : 20,
[m3video] DEC_LINK: CH3 decoder changing resolution
[m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 5440
[m3video] 44486: DECODE: CH3: Decoder flush needed (1048833)!!!
[m3video] 44486: DECODE: CH3: Decoder Flushing !!!
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 5436
[m3vpss ] TILER_STATS: NUM FREE BUCKETS: 0
[m3vpss ] TILER_STATS: NUM USED BUCKETS: 1
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 48216064 (54 %)
[m3vpss ] TILER_STATS: TOTAL USED AREA: 40847360 (45 %)
[m3vpss ] TILER_STATS: TOTAL WASTE AREA: 264192 (0 %)
[m3vpss ] TILER_STATS: MAX WIDTH RECT: 16384 x 2588
[m3vpss ] TILER_STATS: MAX HEIGHT RECT: 16384 x 2588
[m3vpss ] TILER_STATS: RES ALLOC COUNT [D1] : 88
[m3vpss ] TILER_STATS: CNT :16BIT
[m3vpss ] TILER_STATS: CNT RESOLUTION: 32768 x 1344
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 1344
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 23748608 (53 %)
[m3vpss ] TILER_STATS: TOTAL USED AREA: 20291584 (46 %)
[m3vpss ] TILER_STATS: TOTAL WASTE AREA: 0 (0 %)
[m3vpss ] TILER_STATS: MAX WIDTH RECT: 32768 x 496
[m3vpss ] TILER_STATS: MAX HEIGHT RECT: 32768 x 496
[m3vpss ] 42587: SYSTEM : FREE SPACE : Tiler 8-bit = 48216064 B (45 MB) - TILER ON
[m3vpss ] 42588: SYSTEM : FREE SPACE : Tiler 16-bit = 23748608 B (22 MB) - TILER ON
[m3vpss ] 42635: DISPLAY: Start Done !!!
[m3vpss ] 42635: DISPLAY: SDDAC(SEC1): 20 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0 ) !!!
[m3vpss ] 42635: SWMS: Start in Progress !!!
[m3vpss ] 42636: SWMS: Start Done !!!
[m3vpss ] 42636: DISPLAY DRV: SDDAC(SEC1): Q:[2] Display:[1], Repeat:[0], DQ:[0]
[m3vpss ] 42636: SWMS: Start in Progress !!!
[m3vpss ] 42756: CAPTURE: Start in progress !!!
[m3vpss ] 42855: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 42864: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 42872: CAPTURE: Start Done !!!
[m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS faileddue to invalid cfg
[m3vpss ] Config:DisplayID[0],ChID[17]
[m3vpss ] Config:DisplayID[0],ChID[-1]
[m3vpss ] Config:DisplayID[2],ChID[17]
[m3vpss ] Config:DisplayID[0],ChID[18]
[m3vpss ] Config:DisplayID[2],ChID[18]
[m3vpss ] Config:DisplayID[0],ChID[20]
[m3vpss ] Config:DisplayID[2],ChID[20]
[m3vpss ] Config:DisplayID[0],ChID[19]
[m3vpss ] Config:DisplayID[2],ChID[19]
[m3vpss ] SWMS: *** UPDATING RT Params ***
[m3vpss ] 44497: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 44497: SWMS1 : Loading Vertical Co-effs (7/16)x ...
[m3vpss ] 44497: SWMS1 : Loading Horizontal Co-effs (3/16)x ...
[m3vpss ] 44498: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 4 | 13 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 5 | 14 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 176, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 6 | 15 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 352, 120 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
## AVERAGE: ENCODE [ 49.2] FPS, DECODE [ 24.4] FPS, ENC+DEC [ 73.6] FPS ... in 10.0 secs,
[m3vpss ] 7 | 16 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 528, 120 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 9 | 18 | 0, 0 | 352 x 240 | 16384 / 32768 | TILED | 176, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 10 | 19 | 0, 0 | 352 x 240 | 16384 / 32768 | TILED | 352, 240 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 12 | 21 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 0, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 13 | 22 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 176, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 14 | 23 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 352, 360 | 176 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 15 | 24 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 528, 360 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ]
[m3vpss ] SWMS:Restoring blank frame params for winId:4
[m3vpss ] SWMS:Restoring blank frame params for winId:5
[m3vpss ] SWMS:Restoring blank frame params for winId:6
[m3vpss ] SWMS:Restoring blank frame params for winId:7
[m3vpss ] SWMS:Restoring blank frame params for winId:12
[m3vpss ] SWMS:Restoring blank frame params for winId:13
[m3vpss ] SWMS:Restoring blank frame params for winId:14
[m3vpss ] SWMS:Restoring blank frame params for winId:15
[m3vpss ] 44509: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 44510: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 44510: SWMS0 : Loading Horizontal Co-effs (10/16)x ...
[m3vpss ] 44510: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 4 | 13 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 0, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 5 | 14 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 480, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 6 | 15 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 960, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 7 | 16 | 0, 0 | 704 x 240 | 704 / 704 | NON-TILED | 1440, 270 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 9 | 18 | 0, 0 | 352 x 240 | 16384 / 32768 | TILED | 480, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 10 | 19 | 0, 0 | 352 x 240 | 16384 / 32768 | TILED | 960, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ] 12 | 21 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 0, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 13 | 22 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 480, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 14 | 23 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 960, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ] 15 | 24 | 0, 0 | 704 x 480 | 16384 / 32768 | TILED | 1440, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | ON |
[m3vpss ]
[m3vpss ] 44527: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 44528: SWMS1 : Loading Vertical Co-effs (7/16)x ...
[m3vpss ] 44528: SWMS1 : Loading Horizontal Co-effs (3/16)x ...
[m3vpss ] 44532: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 11 | 20 | 0, 0 | 352 x 240 | 16384 / 32768 | TILED | 528, 240 | 192 x 120 | 1472 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ]
[m3vpss ] 44544: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 44545: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 44545: SWMS0 : Loading Horizontal Co-effs (10/16)x ...
[m3vpss ] 44545: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3video] 45950: SCD: CH8: NO Tamper Detected !!!
[m3video] 45955: SCD: CH11: NO Tamper Detected !!!
[m3vpss ] 11 | 20 | 0, 0 | 352 x 240 | 16384 / 32768 | TILED | 1440, 540 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 420SP | OFF |
[m3vpss ]
[m3video] 46146: SCD: CH9: NO Tamper Detected !!!
## AVERAGE: ENCODE [ 243.1] FPS, DECODE [ 121.4] FPS, ENC+DEC [ 364.5] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.6] FPS, DECODE [ 120.0] FPS, ENC+DEC [ 359.6] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.3] FPS, DECODE [ 119.7] FPS, ENC+DEC [ 359.0] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.7] FPS, DECODE [ 119.8] FPS, ENC+DEC [ 359.5] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.8] FPS, DECODE [ 119.9] FPS, ENC+DEC [ 359.6] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.2] FPS, DECODE [ 119.5] FPS, ENC+DEC [ 358.7] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.6] FPS, DECODE [ 119.8] FPS, ENC+DEC [ 359.4] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.3] FPS, DECODE [ 119.9] FPS, ENC+DEC [ 359.2] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.7] FPS, DECODE [ 119.9] FPS, ENC+DEC [ 359.6] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.5] FPS, DECODE [ 119.8] FPS, ENC+DEC [ 359.3] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.4] FPS, DECODE [ 119.5] FPS, ENC+DEC [ 358.8] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.8] FPS, DECODE [ 120.0] FPS, ENC+DEC [ 359.8] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.6] FPS, DECODE [ 119.7] FPS, ENC+DEC [ 359.2] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.5] FPS, DECODE [ 119.7] FPS, ENC+DEC [ 359.2] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.3] FPS, DECODE [ 119.6] FPS, ENC+DEC [ 358.9] FPS ... in 10.0 secs,
## AVERAGE: ENCODE [ 239.6] FPS, DECODE [ 119.9] FPS, ENC+DEC [ 359.5] FPS ... in 10.0 secs,
e
++++++++ VcapVencVdecVdis_stop()
[m3vpss ] 242313: CAPTURE: Stop in progress !!!
[host] 222021: IPC_BITS_IN : Stop Done !!!
[m3vpss ] 242399: CAPTURE: Stop Done !!!
[m3video] 242404: ENCODE: CH-1:
[m3video] Stop in progress !!!
[m3vpss ] 242400: DEI : Stop in progress, 0 requests pending !!!
[m3vpss ] 242400: DEI : Stop Done !!!
[m3video] Stop done !!!
[m3vpss ] 242401: DEI : Stop in progress, 0 requests pending !!!
[m3video] 242405: DECODE: Stop in progress !!!
[m3vpss ] 242401: DEI : Stop Done !!!
[m3video] 242405: DECODE: Stop Done !!!
[m3vpss ] 242402: DEI : Stop in progress, 0 requests pending !!!
[m3vpss ] 242402: DEI : Stop Done !!!
[m3vpss ] 242403: SCLR : Stop in progress, 0 requests pending !!!
[m3vpss ] 242403: SCLR : Stop Done !!!
[m3vpss ] 242405: SWMS: Stop in Progress !!!
[m3vpss ] 242405: SWMS: Stop Done !!!
[m3vpss ] 242406: SWMS: Stop in Progress !!!
[m3vpss ] 242406: SWMS: Stop Done !!!
[m3vpss ] 242406: DISPLAY: Stop in progress !!!
[m3vpss ] 242450: DISPLAY: Stop Done !!!
[m3vpss ] 242451: DISPLAY: Stop in progress !!!
[FBDEV]
[FBDEV] grpx_fb_exit ...
[FBDEV]
[m3vpss ] 242501: DISPLAY: Stop Done !!!
[FBDEV] grpx_fb_exit ... Done (0) !!!
[FBDEV]
[m3vpss ]
[m3vpss ] *** Capture Driver Advanced Statistics ***
[m3video] 242621: IPC_IN_M3 : Delete in progress !!!
[m3vpss ]
[m3video] 242621: IPC_IN_M3 : Delete Done !!!
[m3video] 242622: ALG : Delete in progress !!!
[m3vpss ] VIP Parser Reset Count : 0
[m3video] UTILS: DMA: Free'ed CH (TCC) = 51 (51)
[m3video] UTILS: DMA: Free'ed CH (TCC) = 56 (56)
[m3vpss ]
[m3video] 242624: ALG : Delete Done !!!
[m3vpss ] | Total Even Odd Total Even Odd Min / Max Min / Max Dropped Fid Repeat Frame Error Y/C
[m3video] 242625: ENCODE: CH-1:
[m3vpss ] CH | Fields Fields Fields FPS FPS FPS Width Height Fields Count (Desc Error Y/C)
[m3video] ENC : Delete in progress !!!
[m3vpss ] 000 | 11956 5979 5977 60 30 30 720 / 720 243 / 244 1 1 0/0 (0/0)
[m3video] 242625:WARN
[m3video] IRES_TILER:Unregistering handle not previously registered,links_m3video/codec_utils/src/iresman_tiledmemory.c:302
[m3video] MemoryLeak:STAGE:0 HEAPNUM:0 ALLOC=13808 FREED=11912
[m3vpss ] 001 | 11956 5979 5977 60 30 30 720 / 720 243 / 244 1 1 0/0 (0/0)
[m3video] 242627:WARN
[m3video] 242629:WARN
[m3vpss ] 002 | 11908 5954 5954 59 29 29 720 / 720 243 / 244 1 0 0/0 (0/0)
[m3video] 242631:WARN
[m3vpss ] 003 | 11956 5978 5978 60 30 30 720 / 720 243 / 244 1 0 0/0 (0/0)
[m3vpss ] 100 | 1 1 0 0 0 0 65535 / 0 65535 / 0 1 0 0/0 (0/0)
[m3video] 242633:WARN
[m3video] 242635:WARN
[m3vpss ] 101 | 1 1 0 0 0 0 65535 / 0 65535 / 0 1 0 0/0 (0/0)
[m3video] 242637:WARN
[m3video] 242639:WARN
[m3vpss ] 102 | 1 1 0 0 0 0 65535 / 0 65535 / 0 1 0 0/0 (0/0)
[host] 222267: IPCBITSIN:Link[3000001a]:
[host] RECV:47772 FREE:47767,DROPPED:0,AVGLATENCY:0,AVG_APP_CB_TIME:1
[host] 222267: IPC_BITS_IN : Delete in progress !!!
[host] 222268: IPC_BITS_IN : Delete Done !!!
[host] 222268: IPC_BITS_OUT : Delete in progress !!!
[host]
222268: IPCBITSOUT:Link[30000018]:
[host] RECV:23880 FREE:23853,DROPPED:0,AVGLATENCY:3072
[host] IPC_BITSOUT:BitBuffer Free.chID:0,Size:0x294000
[host] ******* RingBuf 0 deleted ********
[host] IPC_BITSOUT:BitBuffer Free.chID:1,Size:0x294000
[host] ******* RingBuf 1 deleted ********
[host] IPC_BITSOUT:BitBuffer Free.chID:2,Size:0x294000
[host] ******* RingBuf 2 deleted ********
[host] IPC_BITSOUT:BitBuffer Free.chID:3,Size:0x294000
[host] ******* RingBuf 3 deleted ********
[host] IPC_BITSOUT:BitBuffer Free.chID:4,Size:0x294000
[host] ******* RingBuf 4 deleted ********
[host] IPC_BITSOUT:BitBuffer Free.chID:5,Size:0x294000
[host] ******* RingBuf 5 deleted ********
[host] IPC_BITSOUT:BitBuffer Free.chID:6,Size:0x294000
[host] ******* RingBuf 6 deleted ********
[host] IPC_BITSOUT:BitBuffer Free.chID:7,Size:0x294000
[host] ******* RingBuf 7 deleted ********
[host] 222299: IPC_BITS_OUT : Delete Done !!!
[m3vpss ] 103 | 1 1 0 0 0 0 65535 / 0 65535 / 0 1 0 0/0 (0/0)
[m3video] 242647: ENCODE: CH-1:
[m3video] ENC : Delete done !!!
[m3video] 242647: IPC_BITS_OUT : Delete in progress !!!
[m3vpss ]
[m3video] 242648: IPCBITSOUT:Link[10000018]:
[m3video] RECV:47772 FREE:47767,DROPPED:0,AVGLATENCY:13
[m3video] 242648: PRF : IPC_BITS_OUT0 : t: 1570 ms, c: 24913, f: 47772, fps: 30428, fpc: 1
[m3vpss ] VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
[host] Entered:VcapVencVdecVdis_ipcBitsExit... [c6xdsp ]
[m3vpss ] VIP Capture Port 1 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
[c6xdsp ] 241696: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%
[m3video] 242648: IPC_BITS_OUT : Delete Done !!!
[m3vpss ]
[c6xdsp ]
[m3video] 242682: IPCBITSIN:Link[1000001a]:
[m3video] RECV:23880 FREE:23860,DROPPED:0,AVGLATENCY:201
[m3video] 242682: IPC_BITS_IN : Delete in progress !!!
[m3vpss ] *** Capture List Manager Advanced Statistics ***
[m3video] 242682: IPC_BITS_IN : Delete Done !!!
[m3video] 242682: DECODE: Stop in progress !!!
[m3vpss ]
[m3video] 242683: DECODE: Stop Done !!!
[m3video] 242683: DECODE: Delete in progress !!!
[m3vpss ] List Post Count : 49868
[m3video]
[m3video] 242706:ERR::linkID:10000022::channelID:-1::errorCode:-10::FileName:links_m3video/iva_dec/decLink_common.c::linuNum:158::errorCondition:(Utils_queIsFull(&pObj->dupObj.dupQue) == TRUE)
[m3video] 242706: DECODE: Delete Done !!!
[m3vpss ] List Stall Count : 0
[m3video] 242707: IPC_OUT_M3 : Delete in progress !!!
[m3video] 242707: IPC_OUT_M3 : Delete Done !!!
[m3vpss ] List Post Time (ms) : Max = 0, Min = 0, Avg = 0, Total = 0
[m3video]
[m3video] 242716: LOAD: CPU: 48.7% HWI: 3.7%, SWI:2.6%
[m3vpss ] INTC Timeout Count : (0, 0) (Min timeout value = 956, 976)
[m3video]
[m3vpss ] Descriptor miss found count : 0
[host] Leaving:VcapVencVdecVdis_ipcBitsExit... 222651: SYSTEM: System Common De-Init in progress !!!
[host] OSA_tskDelete:In progress...
[host] OSA_tskDelete:In progress... 222657: SYSTEM: IPC de-init in progress !!!
[m3vpss ]
222666: SYSTEM: IPC de-init DONE !!!
222666: SYSTEM: System Common De-Init Done !!!
Main Menu
e: Exit
Enter Choice: [m3vpss ]
[m3vpss ] VIP and VPDMA registers,
[m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000000
[m3vpss ] VIP1 : FIQ_STATUS : 0x48105a1c = 0x00000000
[m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x00000000
[m3vpss ]
[m3vpss ]
[m3vpss ] 242607: CAPTURE: Fields = 47769 (fps = 239, CPU Load = 0)
[m3vpss ] 242607: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 242607: SYSTEM : FREE SPACE : System Heap = 242624 B, Mbx = 10239 msgs)
[m3vpss ] 242607: SYSTEM : FREE SPACE : SR0 Heap = 2160128 B (2 MB)
[m3vpss ] 242608: SYSTEM : FREE SPACE : Frame Buffer = 348928 B (0 MB)
[m3vpss ] 242608: SYSTEM : FREE SPACE : Bitstream Buffer = 30769536 B (29 MB)
[m3vpss ] 242610: SYSTEM : FREE SPACE : Tiler 8-bit = 48216064 B (45 MB) - TILER ON
[m3vpss ] 242610: SYSTEM : FREE SPACE : Tiler 16-bit = 23748608 B (22 MB) - TILER ON
[m3vpss ] 242610: CAPTURE: Delete in progress !!!
[m3vpss ] UTILS: DMA: Free'ed CH (TCC) = 58 (58)
[m3vpss ] 242611: CAPTURE: Delete Done !!!
[m3vpss ] 242612: NSF : Fields = 47769 (fps = 996) !!!
[m3vpss ] 242612: NSF: Delete in progress !!!
[m3vpss ] 242612: NSF: Delete Done !!!
[m3vpss ] 242613: NSF : Fields = 799 (fps = 475) !!!
[m3vpss ] 242613: NSF: Delete in progress !!!
[m3vpss ] 242614: NSF: Delete Done !!!
[m3vpss ] 242614: DEI : Fields = 23884 (fps = 566), !!!
[m3vpss ] 242614: DEI : Delete in progress !!!
[m3vpss ] 242616: DEI : Delete Done !!!
[m3vpss ] 242616: DEI : Fields = 23884 (fps = 1029), !!!
[m3vpss ] 242616: DEI : Delete in progress !!!
[m3vpss ] 242618: DEI : Delete Done !!!
[m3vpss ] 242618: DEI : Fields = 0 (fps = 0), !!!
[m3vpss ] 242618: DEI : Delete in progress !!!
[m3vpss ] 242619: DEI : Delete Done !!!
[m3vpss ] 242619: SCLR : Stop in progress, 0 requests pending !!!
[m3vpss ] 242619: SCLR : Stop Done !!!
[m3vpss ] 242619: SCLR : Fields = 799 (fps = 422), FRAMES -> Total 200, skipped 5777, fps = 22721743!!!
[m3vpss ] 242619: SCLR: Delete in progress !!!
[m3vpss ] 242620: SCLR: Delete Done !!!
[m3vpss ] 242620: SELECT : Delete Done !!!
[m3vpss ] 242621: IPC_OUT_M3 : Delete in progress !!!
[m3vpss ] 242621: IPC_OUT_M3 : Delete Done !!!
[m3vpss ] 242707: IPC_IN_M3 : Delete in progress !!!
[m3vpss ] 242707: IPC_IN_M3 : Delete Done !!!
[m3vpss ] 242708: SWMS: Frames = 47760 (fps = 1068) !!!
[m3vpss ] 242708: SWMS: Delete in progress !!!
[m3vpss ] UTILS: DMA: Free'ed CH (TCC) = 59 (59)
[m3vpss ] 242709: SWMS: Delete Done !!!
[m3vpss ] 242710: SWMS: Frames = 107694 (fps = 2398) !!!
[m3vpss ] 242710: SWMS: Delete in progress !!!
[m3vpss ] UTILS: DMA: Free'ed CH (TCC) = 60 (60)
[m3vpss ] 242712: SWMS: Delete Done !!!
[m3vpss ] 242713: DISPLAY: Frames = 5990 (fps = 29) !!!
[m3vpss ] 242713: DISPLAY: Delete in progress !!!
[m3vpss ] 242713: DISPLAY: Delete Done !!!
[m3vpss ] 242713: DISPLAY: Frames = 5985 (fps = 29) !!!
[m3vpss ] 242714: DISPLAY: Delete in progress !!!
[m3vpss ] 242714: DISPLAY: Delete Done !!!
[m3vpss ] 242714: DUP : Delete Done !!!
[m3vpss ] 242715: MERGE : Delete Done !!!
[m3vpss ]
[m3vpss ] 242716: LOAD: CPU: 38.5% HWI: 9.0%, SWI:3.0%
[m3vpss ]
[m3vpss ] 242718: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 11991, HDDAC(BP0) 0, DVO2(BP1) 11991, SDDAC(SEC1) 12056
Main Menu
e: Exit
Enter Choice: e
