Other Parts Discussed in Thread: TVP5158
we use rdk4.0 to demo 960h in our board and got following message,
root@dm816x:/opt/dvr_rdk/ti816x/bin# ./dvr_rdk_demo_mcfw_api.out
Main Menu
1: VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
2: VCAP + VENC + VDIS - SD Encode ONLY
3: VCAP + VENC + VDEC + VDIS - Progressive HD Encode + Decode
4: VDEC + VDIS - SD/HD Decode ONLY
a: 960H DVR usecase
e: Exit
Enter Choice: a
--------------- CHANNEL DETAILS-------------
Capture Channels => 16
Enc Channels => Primary 16, Secondary 16
Dec Channels => 4
Disp Channels => 20
0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
13: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
13: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
13: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
13: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
15: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
16: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
18: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
18: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
19: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
20: SYSTEM: Notify register to [DSP] line 0, event 15 ...
21: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
21: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
22: SYSTEM: IPC init DONE !!!
23: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
25: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
26: SYSTEM: ListElem Shared Addr = 0x40722880
27: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
29: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
31: SYSTEM: ListElem Shared Addr = 0x40757a80
32: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
34: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
36: SYSTEM: ListElem Shared Addr = 0x4078cc80
36: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
39: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
40: SYSTEM: ListElem Shared Addr = 0x407cff80
41: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
43: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
45: SYSTEM: ListElem Shared Addr = 0x40813280
61: SYSTEM: System Common Init Done !!!
[host] HDMI Ctrl :Initializing
[host] HDMI Ctrl :Initialized
[host] HDMI Ctrl :Sink Connected
Enable file write (YES - y / NO - n) : n
File write DISABLED !!!
[host] MCFW_IPCFRAMES:VcapVenc_ipcFramesSendRecvFxn:Entered... [FBDEV]
[FBDEV] FB: Starting !!!
[FBDEV] FB: Opened device [/dev/fb0] (fd=22) !!!
[FBDEV]
[FBDEV] Fix Screen Info
[FBDEV] ---------------
[FBDEV] Line Length - 2560
[FBDEV] Physical Address = 8ea00000
[FBDEV] Buffer Length = 8294400
[FBDEV]
[FBDEV]
[FBDEV] Var Screen Info
[FBDEV] Xres - 1280
[FBDEV] Yres - 720
[FBDEV] Xres Virtual - 1280
[FBDEV] Yres Virtual - 720
[FBDEV] Bits Per Pixel - 16
[FBDEV] Pixel Clk - 6734
[FBDEV] Rotation - 0
[FBDEV]
[FBDEV]
[FBDEV] Reg Params Info
[FBDEV] region 0, postion 0 x 0, prioirty 1
[FBDEV] first 1, last 1
[FBDEV] sc en 0, sten en 0
[FBDEV] tran en 0, type 0, key 0
[FBDEV] blend 0, alpha 0
[FBDEV] bb en 0, alpha 0
[FBDEV]
[FBDEV]
[FBDEV] ### BUF SIZE = 1843200 Bytes !!!
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] Xres - 1280
[FBDEV] Yres - 720
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] grpx_fb_draw ...
[FBDEV] grpx_fb_draw ... Done !!!
[FBDEV] FB: Start DONE !!!
[FBDEV]
********* Entered usecase HybridDVR <816x> Cap/Enc/Dec/Dis
2372: MCFW : CPU Revision [ES2.0] !!!
omap_i2c omap_i2c.2: controller timed out
ASSERT (multich_hybrid_dvr.c|multich_hybriddvr_get_videodecoder_device_id|513)
