Other Parts Discussed in Thread: TMS320DM6467
Hi all, I'm encountering the problem with running of audio_encode_io1 application to encode raw audio by using of aacheenc codec. root@dm6467t-evm:~# ./audio_encode_io1_dm6467.x470MV -c aacheenc -e encode -i te st.wav -o test.aac -b 128000 -s 44100 Failed to create audio encoder End of application. root@dm6467t-evm:~# My environment is following: Dev board: TMS320DM6467 HD 1080P EVM DVSDK: dvsdk_3_10_00_19 DMAI: dmai_2_10_00_12 Codec Server: cs2dm6467_1_00_00_10 AAC-HE encoder: c64xplus_aacheenc_1_20_005_production I have integrated AAC-HE encoder as described in the article: http://processors.wiki.ti.com/index.php/How_do_I_Integrate_new_codecs_into_DVSDK DMAI was rebuilt with new Codec Server. I tested video codecs (h264enc, h264fhdvenc) on that Codec Server by using video_encode_io1 application and they are working fine. Also I have tried to switch linux kernel mem parameter from 112M to 104M. It doesn't help. Review of debug output (CE_DEBUG=3) shows that something is wrong with audio codec parameters: [DSP] @7,906,613tk: [+7 T:0x8ba0006c S:0x8ba03d1c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch a llocation Anybody has ideas what is wrong in encoder parameters or in my setup? Thanks, Vladimir Davydov P.S. Full debug output is following: root@dm6467t-evm:~# ./audio_encode_io1_dm6467.x470MV -c aacheenc -e encode -i te st.wav -o test.aac -b 128000 -s 44100 @0,115,973us: [+4 T:0x4001f050 S:0xbec079c4] OG - Global_init> This program was built with the following packages: @0,116,637us: [+4 T:0x4001f050 S:0xbec079c4] OG - package gnu.targets.arm.rtsv5T (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/arm/rtsv5T/) [1, 0, 0, 0] @0,116,799us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.aachedec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/) [1, 0, 0] @0,116,910us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.aacheenc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aacheenc/) [1, 0, 0] @0,117,013us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.g711dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/) [1, 0, 0] @0,117,190us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.g711enc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/) [1, 0, 0] @0,117,300us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h264dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1, 0, 0] @0,117,402us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h2641080p60vdec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1, 0, 0] @0,117,504us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h264enc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1, 0, 0] @0,117,606us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h264fhdvenc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1, 0, 0] @0,117,708us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.mpeg2dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0] @0,117,806us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.jpegdec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/) [1, 0, 0] @0,117,907us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.jpegenc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/) [1, 0, 0] @0,118,005us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.mpeg4dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0] @0,118,105us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.mpeg4enc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0] @0,118,205us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.global (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/global/) [1, 0, 0] @0,118,303us: [+4 T:0x4001f050 S:0xbec079c4] OG - package dsplink.gpp (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/gpp/) [5, 0, 0] @0,118,397us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.linuxutils.cmem (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/linuxutils_2_25_04_10/packages/ti/sdo/linuxutils/cmem/) [2, 2, 0] @0,118,496us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.xdais.dm (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/dm/) [1, 0, 5] @0,118,592us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.utils.trace (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/utils/trace/) [1, 0, 0] @0,452,507us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.utils.xdm (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2] @0,452,674us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.xdais (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/) [1, 2.0, 1] @0,452,782us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.node (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/node/) [1, 0, 0] @0,452,883us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.fc.global (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/global/) [1, 0, 0] @0,452,984us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.fc.memutils (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/memutils/) [1, 0, 0] @0,453,084us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.fc.utils (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/utils/) [1, 0, 2] @0,453,184us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.fc.dman3 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dman3/) [1, 0, 4] @0,453,285us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.fc.acpy3 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/acpy3/) [1, 0, 4] @0,453,382us: [+4 T:0x4001f050 S:0xbec079c4] OG - package gnu.targets (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/) [1, 0, 1] @0,453,477us: [+4 T:0x4001f050 S:0xbec079c4] OG - package gnu.targets.arm (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/gnu/targets/arm/) [1, 0, 0, 0] @0,453,575us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.catalog.arm (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/arm/) [1, 0, 1, 0] @0,453,672us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.catalog (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0] @0,453,767us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.catalog.c6000 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0] @0,453,865us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.platforms.evmDM6467 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/platforms/evmDM6467/) [1, 0, 0, 0] @0,453,964us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.osal (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/) [2, 0, 2] @0,454,061us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.ipc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/) [2, 0, 1] @0,454,160us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.osal.linux (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/linux/) [2, 0, 1] @0,454,257us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.ipc.dsplink (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/dsplink/) [2, 0, 1] @0,454,356us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.alg (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/alg/) [1, 0, 1] @0,788,367us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/) [1, 0, 6] @0,788,489us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.speech (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/speech/) [1, 0, 2] @0,788,593us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.speech1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/speech1/) [1, 0, 1] @0,788,695us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.audio (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/audio/) [1, 0, 2] @0,788,794us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.audio1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/audio1/) [1, 0, 1] @0,788,892us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.video (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video/) [1, 0, 3] @0,788,990us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.video1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video1/) [1, 0, 2] @0,789,088us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.video2 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video2/) [1, 0, 2] @0,789,189us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.image (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/image/) [1, 0, 3] @0,789,287us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.ce.image1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/image1/) [1, 0, 1] @0,789,386us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.dmai (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/dmai_2_10_00_12/packages/ti/sdo/dmai/) [1, 0, 0] @0,789,555us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.aachedec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/ce/) [1, 0, 0] @0,789,670us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.aacheenc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aacheenc/ce/) [1, 0, 0] @0,789,776us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.g711dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/ce/) [1, 0, 0] @0,789,877us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.g711enc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/ce/) [1, 0, 0] @0,789,976us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h264dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0] @0,790,076us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h2641080p60vdec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1, 0, 0] @0,790,180us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h264enc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0] @1,124,203us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.h264fhdvenc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1, 0, 0] @1,124,329us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.mpeg2dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0] @1,124,438us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.jpegdec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/ce/) [1, 0, 0] @1,124,541us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.jpegenc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/ce/) [1, 0, 0] @1,124,642us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.mpeg4dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0] @1,124,743us: [+4 T:0x4001f050 S:0xbec079c4] OG - package ti.sdo.codecs.mpeg4enc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0] @1,124,845us: [+4 T:0x4001f050 S:0xbec079c4] OG - package audio_encode_io1_dm6467_config (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/dmai_2_10_00_12/packages/ti/sdo/dmai/apps/audio_encode_io1/linux/audio_encode_io1_dm6467_config/) [] @1,125,000us: [+0 T:0x4001f050 S:0xbec079cc] OG - Global_atexit> enter (fxn=0x259d0) @1,125,115us: [+0 T:0x4001f050 S:0xbec079cc] OG - Global_atexit> enter (fxn=0x24e1c) @1,125,255us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> Enter(0x18) @1,125,361us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> return (0x580f0) @1,125,633us: [+0 T:0x4001f050 S:0xbec079bc] OG - Global_atexit> enter (fxn=0x22ca4) @1,125,799us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> Enter(0x18) @1,125,908us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> return (0x58140) @1,126,006us: [+0 T:0x4001f050 S:0xbec079b4] OG - Global_atexit> enter (fxn=0x21ad0) @1,126,168us: [+0 T:0x4001f050 S:0xbec079bc] OG - Global_atexit> enter (fxn=0x24480) @1,126,343us: [+0 T:0x4001f050 S:0xbec079b4] ti.sdo.ce.osal.Sem - Sem_create> count: 0 @1,126,445us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> Enter(0x14) @1,126,542us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> return (0x581c0) @1,126,655us: [+0 T:0x4001f050 S:0xbec079b4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x581c0] @1,126,754us: [+0 T:0x4001f050 S:0xbec079b4] ti.sdo.ce.osal.Sem - Sem_create> count: 0 @1,126,842us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> Enter(0x14) @1,126,966us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> return (0x581d8) @1,127,057us: [+0 T:0x4001f050 S:0xbec079b4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x581d8] @1,127,147us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> Enter(0x18) @1,127,239us: [+0 T:0x4001f050 S:0xbec0799c] OM - Memory_alloc> return (0x581f0) @1,127,328us: [+0 T:0x4001f050 S:0xbec07994] OT - Thread_create> Enter (fxn=0x202b8, attrs=0x0) @1,127,417us: [+0 T:0x4001f050 S:0xbec0797c] OM - Memory_alloc> Enter(0x64) @1,127,510us: [+0 T:0x4001f050 S:0xbec0797c] OM - Memory_alloc> return (0x58210) @1,128,008us: [+0 T:0x4001f050 S:0xbec07994] OT - Thread_create> Exit (task=0x58210) @1,128,134us: [+0 T:0x4001f050 S:0xbec079cc] OG - Global_atexit> enter (fxn=0x1fcd0) @1,128,250us: [+0 T:0x4001f050 S:0xbec079cc] OG - Global_atexit> enter (fxn=0x2201c) @1,128,428us: [+0 T:0x4001f050 S:0xbec079b4] ti.sdo.ce.alg - ALG_init> Enter @1,462,864us: [+0 T:0x4001f050 S:0xbec079d4] ti.sdo.ce.alg - ALG_init> Exit @1,462,974us: [+0 T:0x4001f050 S:0xbec079cc] OG - Global_atexit> enter (fxn=0x1c690) @1,463,085us: [+0 T:0x4001f050 S:0xbec079a4] OM - Memory_alloc> Enter(0x18) @1,463,192us: [+0 T:0x4001f050 S:0xbec079a4] OM - Memory_alloc> return (0x583e0) @1,463,289us: [+0 T:0x4001f050 S:0xbec079cc] OG - Global_atexit> enter (fxn=0x24970) @1,463,430us: [+6 T:0x4001f050 S:0xbec079c4] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max) @1,463,542us: [+0 T:0x4001f050 S:0xbec079b4] OG - Global_atexit> enter (fxn=0x19850) @1,463,640us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> Enter(0x18) @1,463,737us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> return (0x58420) @1,463,831us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> Enter(0x18) @1,463,925us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> return (0x58440) @1,464,018us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> Enter(0x18) @1,464,113us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_alloc> return (0x58460) @1,464,273us: [+0 T:0x4001f050 S:0xbec079dc] CS - Server_init() @1,464,371us: [+0 T:0x4001f050 S:0xbec079dc] CS - Server_init> Global_useLinkArbiter = 0 @1,464,464us: [+0 T:0x4001f050 S:0xbec079dc] OG - Global_atexit> enter (fxn=0x17a90) @1,464,898us: [+0 T:0x4001f050 S:0xbec0798c] CE - Engine_open> Enter('encode', 0x0, 0xbec079fc) @1,465,025us: [+0 T:0x4001f050 S:0xbec07974] OM - Memory_alloc> Enter(0x2c) @1,465,136us: [+0 T:0x4001f050 S:0xbec07974] OM - Memory_alloc> return (0x58640) @1,465,235us: [+0 T:0x4001f050 S:0xbec0798c] CE - rserverOpen('cs.x64P'), count = 0 @1,465,330us: [+0 T:0x4001f050 S:0xbec07954] OP - Processor_create> Enter(imageName='cs.x64P', linkCfg='(null)', attrs=0xbec079e0) @1,465,598us: [+0 T:0x4001f050 S:0xbec0793c] OM - Memory_alloc> Enter(0x24) @1,465,723us: [+0 T:0x4001f050 S:0xbec0793c] OM - Memory_alloc> return (0x58670) @1,465,819us: [+0 T:0x4001f050 S:0xbec07934] OP - doCmd> Enter (cmdId=1, proc=0x58670) @1,465,915us: [+0 T:0x4001f050 S:0xbec07924] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x581c0] @1,466,066us: [+0 T:0x4001f050 S:0xbec07934] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x581c0] @1,466,178us: [+0 T:0x4001f050 S:0xbec07914] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x581d8] timeout[0xffffffff] @1,466,334us: [+1 T:0x40afe490 S:0x40afdd64] OP - daemon> thread created. @1,466,454us: [+0 T:0x40afe490 S:0x40afdd64] OP - getCmd_d> Enter (proc=0x40afddd8) @1,466,555us: [+0 T:0x40afe490 S:0x40afdd44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x581c0] timeout[0xffffffff] @1,466,656us: [+0 T:0x40afe490 S:0x40afdd44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x581c0] status[0] @1,466,753us: [+0 T:0x40afe490 S:0x40afdd64] OP - getCmd_d> Exit (result=1) @1,466,843us: [+0 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Enter(proc=0x58670) @1,466,936us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Initializing DSP PROC... @1,467,033us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'cs.x64P'] @1,467,138us: [+0 T:0x40afe490 S:0x40afdd4c] OM - Memory_alloc> Enter(0xe0) @1,467,240us: [+0 T:0x40afe490 S:0x40afdd4c] OM - Memory_alloc> return (0x58698) @1,467,340us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x8fb00000, sizeInBytes=0x400000, shared=1, syncd=0 @1,467,459us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8ff00080, sizeInBytes=0xfff80, shared=1, syncd=0 @1,467,576us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000, sizeInBytes=0x80, shared=1, syncd=0 @1,801,478us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x8ba00000, sizeInBytes=0x4100000, shared=0, syncd=0 @1,801,616us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> DODSPCTRL was=1; now=0 @1,801,754us: [+3 T:0x40afe490 S:0x40afdd04] OP - LINKCFG_Object generated for PROC_setup(0x51f50) ... @1,801,864us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->gppObject-> @1,801,955us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "ARM9" @1,802,044us: [+3 T:0x40afe490 S:0x40afdd04] OP - maxMsgqs = 0x82 @1,802,136us: [+3 T:0x40afe490 S:0x40afdd04] OP - maxChnlQueue = 0x10 @1,802,225us: [+3 T:0x40afe490 S:0x40afdd04] OP - poolTableId = 0xffffffff @1,802,315us: [+3 T:0x40afe490 S:0x40afdd04] OP - numPools = 0x0 @1,802,402us: [+3 T:0x40afe490 S:0x40afdd04] OP - @1,802,486us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->dspObject-> @1,802,576us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "DM6467GEM" @1,802,664us: [+3 T:0x40afe490 S:0x40afdd04] OP - dspArch = 0x2 @1,802,753us: [+3 T:0x40afe490 S:0x40afdd04] OP - loaderName = "COFF" @1,802,841us: [+3 T:0x40afe490 S:0x40afdd04] OP - autoStart = FALSE @1,802,929us: [+3 T:0x40afe490 S:0x40afdd04] OP - execName = "DEFAULT.OUT" @1,803,016us: [+3 T:0x40afe490 S:0x40afdd04] OP - doDspCtrl = DSP_BootMode_Boot_NoPwr @1,803,110us: [+3 T:0x40afe490 S:0x40afdd04] OP - resumeAddr = 0x8ff00020 @1,803,202us: [+3 T:0x40afe490 S:0x40afdd04] OP - resetVector = 0x8ff00000 @1,803,294us: [+3 T:0x40afe490 S:0x40afdd04] OP - resetCodeSize = 0x80 @1,803,382us: [+3 T:0x40afe490 S:0x40afdd04] OP - maduSize = 0x1 @1,803,471us: [+3 T:0x40afe490 S:0x40afdd04] OP - cpuFreq = 0x91050 @1,803,559us: [+3 T:0x40afe490 S:0x40afdd04] OP - endian = 0x3 @1,803,648us: [+3 T:0x40afe490 S:0x40afdd04] OP - wordSwap = 0x0 @1,803,735us: [+3 T:0x40afe490 S:0x40afdd04] OP - memTableId = 0x0 @1,803,823us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntries = 0x4 @1,803,910us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkDrvId = 0x0 @1,803,997us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg1 = 0xffffffff @1,804,086us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg2 = 0xffffffff @1,804,202us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg3 = 0x0 @1,804,292us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg4 = 0x0 @1,804,379us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg5 = 0xffffffff @1,804,466us: [+3 T:0x40afe490 S:0x40afdd04] OP - @1,804,551us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->linkDrvObjects-> @1,804,640us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "SHMDRV" @1,804,728us: [+3 T:0x40afe490 S:0x40afdd04] OP - hshkPollCount = 0x5f5e100 @1,804,819us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntry = 0x1 @1,804,907us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsTableId = 0x0 @1,804,996us: [+3 T:0x40afe490 S:0x40afdd04] OP - numIpsEntries = 0x1 @1,805,083us: [+3 T:0x40afe490 S:0x40afdd04] OP - poolTableId = 0x0 @1,805,174us: [+3 T:0x40afe490 S:0x40afdd04] OP - numPools = 0x1 @1,805,261us: [+3 T:0x40afe490 S:0x40afdd04] OP - dataTableId = 0x0 @1,805,348us: [+3 T:0x40afe490 S:0x40afdd04] OP - numDataDrivers = 0x1 @1,805,439us: [+3 T:0x40afe490 S:0x40afdd04] OP - mqtId = 0x0 @1,805,526us: [+3 T:0x40afe490 S:0x40afdd04] OP - ringIoTableId = 0x0 @1,805,616us: [+3 T:0x40afe490 S:0x40afdd04] OP - mplistTableId = 0x0 @1,805,705us: [+3 T:0x40afe490 S:0x40afdd04] OP - mpcsTableId = 0x0 @1,805,791us: [+3 T:0x40afe490 S:0x40afdd04] OP - @1,805,874us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->memTables[0][i]. @1,805,964us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry #0: @1,806,052us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry = 0x0 @2,140,147us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "DDR2" @2,140,257us: [+3 T:0x40afe490 S:0x40afdd04] OP - physAddr = 0x8fb00000 @2,140,353us: [+3 T:0x40afe490 S:0x40afdd04] OP - dspVirtAddr = 0x8fb00000 @2,140,447us: [+3 T:0x40afe490 S:0x40afdd04] OP - gppVirtAddr = 0xffffffff @2,140,542us: [+3 T:0x40afe490 S:0x40afdd04] OP - size = 0x400000 @2,140,631us: [+3 T:0x40afe490 S:0x40afdd04] OP - shared = TRUE @2,140,719us: [+3 T:0x40afe490 S:0x40afdd04] OP - syncd = FALSE @2,140,806us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry #1: @2,140,893us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry = 0x1 @2,140,983us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "DSPLINKMEM" @2,141,072us: [+3 T:0x40afe490 S:0x40afdd04] OP - physAddr = 0x8ff00080 @2,141,165us: [+3 T:0x40afe490 S:0x40afdd04] OP - dspVirtAddr = 0x8ff00080 @2,141,254us: [+3 T:0x40afe490 S:0x40afdd04] OP - gppVirtAddr = 0xffffffff @2,141,343us: [+3 T:0x40afe490 S:0x40afdd04] OP - size = 0xfff80 @2,141,432us: [+3 T:0x40afe490 S:0x40afdd04] OP - shared = TRUE @2,141,518us: [+3 T:0x40afe490 S:0x40afdd04] OP - syncd = FALSE @2,141,605us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry #2: @2,141,693us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry = 0x2 @2,141,782us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "RESET_VECTOR" @2,141,870us: [+3 T:0x40afe490 S:0x40afdd04] OP - physAddr = 0x8ff00000 @2,141,960us: [+3 T:0x40afe490 S:0x40afdd04] OP - dspVirtAddr = 0x8ff00000 @2,142,050us: [+3 T:0x40afe490 S:0x40afdd04] OP - gppVirtAddr = 0xffffffff @2,142,143us: [+3 T:0x40afe490 S:0x40afdd04] OP - size = 0x80 @2,142,231us: [+3 T:0x40afe490 S:0x40afdd04] OP - shared = TRUE @2,142,318us: [+3 T:0x40afe490 S:0x40afdd04] OP - syncd = FALSE @2,142,405us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry #3: @2,142,491us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry = 0x3 @2,142,578us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "DDRALGHEAP" @2,142,667us: [+3 T:0x40afe490 S:0x40afdd04] OP - physAddr = 0x8ba00000 @2,142,757us: [+3 T:0x40afe490 S:0x40afdd04] OP - dspVirtAddr = 0x8ba00000 @2,142,868us: [+3 T:0x40afe490 S:0x40afdd04] OP - gppVirtAddr = 0xffffffff @2,142,967us: [+3 T:0x40afe490 S:0x40afdd04] OP - size = 0x4100000 @2,143,059us: [+3 T:0x40afe490 S:0x40afdd04] OP - shared = FALSE @2,143,151us: [+3 T:0x40afe490 S:0x40afdd04] OP - syncd = FALSE @2,143,242us: [+3 T:0x40afe490 S:0x40afdd04] OP - @2,143,325us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->ipsTables[0][i]. @2,143,417us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry #0: @2,143,501us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "IPS" @2,143,589us: [+3 T:0x40afe490 S:0x40afdd04] OP - numIpsEvents = 0x20 @2,143,678us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntry = 0x1 @2,143,766us: [+3 T:0x40afe490 S:0x40afdd04] OP - gppIntId = 0x2d @2,143,853us: [+3 T:0x40afe490 S:0x40afdd04] OP - dspIntId = 0x10 @2,143,940us: [+3 T:0x40afe490 S:0x40afdd04] OP - dspIntVectorId = 0x4 @2,144,029us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg1 = 0x2faf080 @2,144,118us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg2 = 0x0 @2,144,206us: [+3 T:0x40afe490 S:0x40afdd04] OP - @2,144,289us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->poolTables[0][i]. @2,144,379us: [+3 T:0x40afe490 S:0x40afdd04] OP - @2,144,463us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->dataTables[0][i]. @2,144,555us: [+3 T:0x40afe490 S:0x40afdd04] OP - entry #0: @2,144,642us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "ZCPYDATA" @2,144,729us: [+3 T:0x40afe490 S:0x40afdd04] OP - baseChnlId = 0x0 @2,144,816us: [+3 T:0x40afe490 S:0x40afdd04] OP - numChannels = 0x10 @2,144,903us: [+3 T:0x40afe490 S:0x40afdd04] OP - maxBufSize = 0x4000 @2,144,992us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntry = 0x1 @2,478,868us: [+3 T:0x40afe490 S:0x40afdd04] OP - poolId = 0x0 @2,478,982us: [+3 T:0x40afe490 S:0x40afdd04] OP - queuePerChnl = 0x1 @2,479,077us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsId = 0x0 @2,479,171us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsEventNo = 0x2 @2,479,260us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg1 = 0x0 @2,479,349us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg2 = 0x0 @2,479,437us: [+3 T:0x40afe490 S:0x40afdd04] OP - @2,479,611us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->mqtObjects-> @2,479,710us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "ZCPYMQT" @2,479,802us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntry = 0x1 @2,479,893us: [+3 T:0x40afe490 S:0x40afdd04] OP - maxMsgSize = 0xffffffff @2,479,984us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsId = 0x0 @2,480,073us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsEventNo = 0x1 @2,480,163us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg1 = 0x0 @2,480,251us: [+3 T:0x40afe490 S:0x40afdd04] OP - arg2 = 0x0 @2,480,338us: [+3 T:0x40afe490 S:0x40afdd04] OP - @2,480,421us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->ringIoObjects-> @2,480,511us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "RINGIOTABLE" @2,480,600us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntry = 0x1 @2,480,688us: [+3 T:0x40afe490 S:0x40afdd04] OP - maxEntries = 0x40 @2,480,776us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsId = 0x0 @2,480,865us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsEventNo = 0x0 @2,480,953us: [+3 T:0x40afe490 S:0x40afdd04] OP - @2,481,034us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->mplistObjects-> @2,481,127us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "MPLISTTABLE" @2,481,216us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntry = 0x1 @2,481,305us: [+3 T:0x40afe490 S:0x40afdd04] OP - maxEntries = 0x40 @2,481,395us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsId = 0xffffffff @2,481,485us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsEventNo = 0xffffffff @2,481,600us: [+3 T:0x40afe490 S:0x40afdd04] OP - @2,481,689us: [+3 T:0x40afe490 S:0x40afdd04] OP - linkCfg->dspConfigs[0]->mpcsObjects-> @2,481,783us: [+3 T:0x40afe490 S:0x40afdd04] OP - name = "MPCS" @2,481,871us: [+3 T:0x40afe490 S:0x40afdd04] OP - memEntry = 0x1 @2,481,960us: [+3 T:0x40afe490 S:0x40afdd04] OP - maxEntries = 0x100 @2,482,050us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsId = 0xffffffff @2,482,142us: [+3 T:0x40afe490 S:0x40afdd04] OP - ipsEventNo = 0xffffffff @2,488,742us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Attaching to DSP PROC... @2,506,109us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Opening MSGQ pool... @2,506,995us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Loading cs.x64P on DSP (1 args)... @3,082,799us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Starting DSP PROC... @3,129,753us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> Opening remote transport... @3,131,980us: [+2 T:0x40afe490 S:0x40afdd64] OP - Processor_create_d> return (1) @3,132,108us: [+0 T:0x40afe490 S:0x40afdd54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x581d8] @3,132,259us: [+0 T:0x4001f050 S:0xbec07914] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x581d8] status[0] @3,132,373us: [+0 T:0x4001f050 S:0xbec07934] OP - doCmd> Exit (result=1) @3,132,464us: [+0 T:0x4001f050 S:0xbec07954] OP - Processor_create> return (0x58670) @3,132,555us: [+0 T:0x4001f050 S:0xbec0798c] CE - rserverOpen('cs.x64P'): 0x5769c done. @3,132,649us: [+0 T:0x4001f050 S:0xbec07974] OM - Memory_alloc> Enter(0x24) @3,132,779us: [+0 T:0x4001f050 S:0xbec07974] OM - Memory_alloc> return (0x588d0) @3,132,967us: [+0 T:0x4001f050 S:0xbec07964] OC - Comm_create> Enter(queueName='encode_2325_0', queue=0x58650, attrs=0x0) @3,133,079us: [+0 T:0x4001f050 S:0xbec0794c] OM - Memory_alloc> Enter(0x4) @3,133,183us: [+0 T:0x4001f050 S:0xbec0794c] OM - Memory_alloc> return (0x588f8) @3,135,294us: [+0 T:0x4001f050 S:0xbec07964] OC - Comm_create> return (0x588f8) @3,135,419us: [+0 T:0x4001f050 S:0xbec0796c] OM - Memory_free> Enter(0x588d0, 0x24) @3,135,623us: [+0 T:0x4001f050 S:0xbec0796c] OM - Memory_free> return (0x1) @3,135,736us: [+0 T:0x4001f050 S:0xbec0796c] OC - Comm_alloc> Enter(poolId=0x0, msg=0x5865c, size=576) @3,135,864us: [+0 T:0x4001f050 S:0xbec0796c] OC - Comm_alloc> msg=0x4130b900, returning (0) @3,135,965us: [+0 T:0x4001f050 S:0xbec07954] OC - Comm_locate> Enter(queueName='rmsq', queue=0x5864c) @3,136,669us: [+0 T:0x40afe490 S:0x40afdd64] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x581d8] @3,136,798us: [+0 T:0x40afe490 S:0x40afdd64] OP - getCmd_d> Enter (proc=0x40afddd8) @3,136,899us: [+0 T:0x40afe490 S:0x40afdd44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x581c0] timeout[0xffffffff] @3,137,162us: [+0 T:0x4001f050 S:0xbec07954] OC - Comm_locate> return (0) @3,137,286us: [+0 T:0x4001f050 S:0xbec0798c] CE - checkServer(0x58640) @3,137,426us: [+0 T:0x4001f050 S:0xbec0795c] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @3,137,582us: [+0 T:0x4001f050 S:0xbec0795c] OC - Comm_put> return (0) @3,137,722us: [+0 T:0x4001f050 S:0xbec07954] OC - Comm_get> Enter(queue=0x10000, msg=0xbec079f8, timeout=-1) @3,137,954us: [+0 T:0x4001f050 S:0xbec07954] OC - Comm_get> MSGQ_get() status=0x8000, return (0) @3,138,082us: [+0 T:0x4001f050 S:0xbec0798c] CE - rmsInit> RMS initialized(0x58640); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3 @3,138,198us: [+0 T:0x4001f050 S:0xbec07964] CE - Engine_setTrace> Enter(engine=0x58640, mask='*+01234567,GT_prefix=12345,GT_time=3') @3,138,339us: [+1 T:0x4001f050 S:0xbec07964] CE - Engine_setTrace> Requesting DSP set trace ... @3,138,432us: [+0 T:0x4001f050 S:0xbec07934] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @3,138,568us: [+0 T:0x4001f050 S:0xbec07934] OC - Comm_put> return (0) @3,138,669us: [+0 T:0x4001f050 S:0xbec0792c] OC - Comm_get> Enter(queue=0x10000, msg=0xbec079ac, timeout=-1) @3,140,483us: [+0 T:0x4001f050 S:0xbec0792c] OC - Comm_get> MSGQ_get() status=0x8000, return (0) @3,140,607us: [+0 T:0x4001f050 S:0xbec07964] CE - Engine_setTrace> return(0) @3,140,712us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @3,140,853us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> return (0) @3,140,991us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> Enter(queue=0x10000, msg=0xbec0798c, timeout=-1) @3,141,245us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> MSGQ_get() status=0x8000, return (0) [DSP] @0x000001a2:[T:0x00000000] codec_unitserver - main> Welcome to CS2DM6467 1.00.00.10 DSP server's main(). [DSP] @0,034,292tk: [+0 T:0x8ba0006c S:0x8ba03fe4] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3') [DSP] @0,034,365tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - Global_setSpecialTrace> This program was built with the following packages: [DSP] @0,034,427tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.targets.rts6000 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/targets/rts6000/) [1, 0, 0, 0] [DSP] @0,034,520tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.aachedec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/) [1, 0, 0] [DSP] @0,034,614tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.aacheenc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aacheenc/) [1, 0, 0] [DSP] @0,034,708tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.g711dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/) [1, 0, 0] [DSP] @0,034,802tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.g711enc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/) [1, 0, 0] [DSP] @0,034,896tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h2641080p60vdec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/) [1, 0, 0] [DSP] @0,034,995tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h264dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/) [1, 0, 0] [DSP] @0,035,089tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h264enc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/) [1, 0, 0] [DSP] @0,035,183tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h264fhdvenc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/) [1, 0, 0] [DSP] @0,035,279tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.mpeg2dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0] [DSP] @0,035,374tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.jpegdec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/) [1, 0, 0] [DSP] @0,035,467tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.jpegenc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/) [1, 0, 0] [DSP] @0,035,561tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.mpeg4dec (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/) [1, 0, 0] [DSP] @0,035,655tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.mpeg4enc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0] [DSP] @0,035,750tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.hdvicp (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/hdvicp/) [1, 0, 0] [DSP] @0,035,842tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.xdais (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/) [1, 2.0, 1] [DSP] @0,035,926tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.global (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/global/) [1, 0, 0] [DSP] @0,036,020tk: [+4 T:0x8ba0006c S:0x8b@3,479,925us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @3,480,087us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> return (0) @3,480,336us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> Enter(queue=0x10000, msg=0xbec0798c, timeout=-1) @3,480,468us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> MSGQ_get() status=0x8000, return (0) a03fe4] OG - package ti.rtdx (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/rtdx/) [2, 0, 0, 5] [DSP] @0,036,102tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.psl (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/psl/) [5, 0, 0, 0] [DSP] @0,036,184tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.pmi (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pmi/) [1, 0, 0, 0] [DSP] @0,036,266tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.pscl (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/pscl/) [1, 0, 0, 0] [DSP] @0,036,348tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.bios (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/bios_5_41_00_06/packages/ti/bios/) [5, 2, 5, 19] [DSP] @0,036,431tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.ires (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/) [1, 0, 0] [DSP] @0,036,523tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.ires.hdvicp (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/hdvicp/) [1, 0, 1] [DSP] @0,036,621tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.hdintc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/hdintc/) [1, 0, 4] [DSP] @0,036,715tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.edma3.rm (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/edma3_lld_01_11_00_03/packages/ti/sdo/edma3/rm/) [01, 03, 07] [DSP] @0,036,805tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.ires.nullresource (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/nullresource/) [1, 0, 0] [DSP] @0,036,907tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.utils.trace (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/utils/trace/) [1, 0, 0] [DSP] @0,037,003tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.dskt2 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dskt2/) [1, 0, 4] [DSP] @0,037,096tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.rman (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/rman/) [2, 0, 0] [DSP] @0,037,188tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.edma3 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/edma3/) [3, 0, 0] [DSP] @0,037,281tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.ires.edma3chan (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/ires/edma3chan/) [1, 0, 0] [DSP] @0,037,382tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.global (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/global/) [1, 0, 0] [DSP] @0,037,473tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.xdais.dm (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdais_6_25_02_11/packages/ti/xdais/dm/) [1, 0, 5] [DSP] @0,037,557tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.utils.xdm (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2] [DSP] @0,037,651tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.node (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/node/) [1, 0, 0] [DSP] @0,037,741tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.ipc.dsplink.dsp (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/code@4,154,607us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @4,154,781us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> return (0) @4,155,033us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> Enter(queue=0x10000, msg=0xbec0798c, timeout=-1) @4,155,170us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> MSGQ_get() status=0x8000, return (0) c_engine_2_25_05_16/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2, 0, 1] [DSP] @0,037,839tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.dman3 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/dman3/) [1, 0, 4] [DSP] @0,037,932tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.memutils (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/memutils/) [1, 0, 0] [DSP] @0,038,028tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.fc.acpy3 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/framework_components_2_25_02_06/packages/ti/sdo/fc/acpy3/) [1, 0, 4] [DSP] @0,038,120tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package dsplink.dsp (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/dsplink_linux_1_64/dsplink/dsp/) [1, 4, 0] [DSP] @0,038,203tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.bios.utils (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/biosutils_1_02_02/packages/ti/bios/utils/) [2, 0, 2, 02] [DSP] @0,038,291tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.catalog.c6000 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/c6000/) [1, 0, 0, 0] [DSP] @0,038,381tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.catalog (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/catalog/) [1, 0, 0] [DSP] @0,038,467tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.platforms.evmDM6467 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/xdctools_3_16_01_27/packages/ti/platforms/evmDM6467/) [1, 0, 0, 0] [DSP] @0,038,561tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.osal (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/) [2, 0, 2] [DSP] @0,038,651tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.osal.bios (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/osal/bios/) [2, 0, 1] [DSP] @0,038,744tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.ipc (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/) [2, 0, 1] [DSP] @0,038,833tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.ipc.bios (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/ipc/bios/) [2, 0, 1] [DSP] @0,038,925tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.alg (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/alg/) [1, 0, 1] [DSP] @0,039,014tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/) [1, 0, 6] [DSP] @0,039,099tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.bioslog (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/bioslog/) [1, 0, 1] [DSP] @0,039,191tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.audio1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/audio1/) [1, 0, 1] [DSP] @0,039,282tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.aachedec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aachedec/ce/) [1, 0, 0] [DSP] @0,039,378tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.aacheenc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/aacheenc/ce/) [1, 0, 0] [DSP] @0,039,475tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.speech1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/speech1/) [1, 0, 1] [DSP] @0,039,567tk: [+4 T:0x8ba0006c S@4,493,776us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @4,493,933us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> return (0) @4,494,181us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> Enter(queue=0x10000, msg=0xbec0798c, timeout=-1) @4,494,316us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> MSGQ_get() status=0x8000, return (0) :0x8ba03fe4] OG - package ti.sdo.codecs.g711dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711dec/ce/) [1, 0, 0] [DSP] @0,039,662tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.g711enc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/g711enc/ce/) [1, 0, 0] [DSP] @0,039,758tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.video2 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video2/) [1, 0, 2] [DSP] @0,039,849tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h2641080p60vdec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h2641080p60vdec/ce/) [1, 0, 0] [DSP] @0,039,951tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h264dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264dec/ce/) [1, 0, 0] [DSP] @0,040,047tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.video1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/video1/) [1, 0, 2] [DSP] @0,040,137tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h264enc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0] [DSP] @0,040,233tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.h264fhdvenc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/h264fhdvenc/ce/) [1, 0, 0] [DSP] @0,040,333tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.mpeg2dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0] [DSP] @0,040,429tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.ce.image1 (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/codec_engine_2_25_05_16/packages/ti/sdo/ce/image1/) [1, 0, 1] [DSP] @0,040,520tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.jpegdec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegdec/ce/) [1, 0, 0] [DSP] @0,040,616tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.jpegenc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/jpegenc/ce/) [1, 0, 0] [DSP] @0,040,711tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.mpeg4dec.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4dec/ce/) [1, 0, 0] [DSP] @0,040,808tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.codecs.mpeg4enc.ce (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0] [DSP] @0,040,904tk: [+4 T:0x8ba0006c S:0x8ba03fe4] OG - package ti.sdo.server.cs (/home/roland/work/promwad/telemarker/soft/dvsdk/dvsdk_3_10_00_19/cs2dm6467_1_00_00_10/packages/ti/sdo/server/cs/) [1, 0, 0] [DSP] @0,040,994tk: [+0 T:0x8ba0006c S:0x8ba03fe4] OG - Global_setSpecialTrace> return [DSP] @0,043,109tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @0,043,168tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032 [DSP] @1,354,977tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @1,355,032tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032 [DSP] @3,964,145tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @3,964,202tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032 [DSP] @5,275,712tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @5,275,767tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time @4,833,229us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @4,833,392us: [+0 T:0x4001f050 S:0xbec078f4] OC - Comm_put> return (0) @4,833,646us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> Enter(queue=0x10000, msg=0xbec0798c, timeout=-1) @4,833,779us: [+0 T:0x4001f050 S:0xbec078ec] OC - Comm_get> MSGQ_get() status=0x8000, return (0) = 0x0, trace buffer size = 4032 [DSP] @6,588,464tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @6,588,519tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032 @4,834,127us: [+0 T:0x4001f050 S:0xbec07924] CE - Engine_fwriteTrace> returning count [16855] @4,834,223us: [+0 T:0x4001f050 S:0xbec0798c] CE - Engine_open> return(362048) @4,834,413us: [+0 T:0x4001f050 S:0xbec078e4] ti.sdo.ce.audio1.AUDENC1 - AUDENC1_create> Enter (engine=0x58640, name='aacheenc', params=0xbec07a64) @4,834,547us: [+0 T:0x4001f050 S:0xbec078b4] CV - VISA_create(0x58640, 'aacheenc', 0xbec07a64, 0x480, 'ti.sdo.ce.audio1.IAUDENC1') @4,834,659us: [+0 T:0x4001f050 S:0xbec077ac] CV - VISA_create2(0x58640, 'aacheenc', 0xbec07a64, 0x34, 0x480, 'ti.sdo.ce.audio1.IAUDENC1') @4,834,775us: [+0 T:0x4001f050 S:0xbec07794] OM - Memory_alloc> Enter(0x34) @4,834,878us: [+0 T:0x4001f050 S:0xbec07794] OM - Memory_alloc> return (0x58970) @4,834,973us: [+0 T:0x4001f050 S:0xbec07794] OM - Memory_alloc> Enter(0x4) @4,835,066us: [+0 T:0x4001f050 S:0xbec07794] OM - Memory_alloc> return (0x589a8) @4,835,162us: [+0 T:0x4001f050 S:0xbec0778c] OC - Comm_alloc> Enter(poolId=0x0, msg=0x589a8, size=480) @4,835,286us: [+0 T:0x4001f050 S:0xbec0778c] OC - Comm_alloc> msg=0x4130c900, returning (0) @4,835,385us: [+0 T:0x4001f050 S:0xbec07734] CE - Engine_createNode(0x58640, 'aacheenc', 480, 0xbec07a64, 0x34, 0xbec078a8) @4,835,490us: [+0 T:0x4001f050 S:0xbec07734] CE - Engine> allocNode Enter(engine=0x58640, impId='aacheenc') @4,835,585us: [+0 T:0x4001f050 S:0xbec0771c] OM - Memory_alloc> Enter(0x20) @4,835,677us: [+0 T:0x4001f050 S:0xbec0771c] OM - Memory_alloc> return (0x588d0) @4,835,784us: [+0 T:0x4001f050 S:0xbec07734] CE - Engine> allocNode(). Calling (Comm_create(gppfromnode_2325_1, 0x588d8, NULL) @5,170,333us: [+0 T:0x4001f050 S:0xbec0770c] OC - Comm_create> Enter(queueName='gppfromnode_2325_1', queue=0x588d8, attrs=0x0) @5,170,453us: [+0 T:0x4001f050 S:0xbec076f4] OM - Memory_alloc> Enter(0x4) @5,170,554us: [+0 T:0x4001f050 S:0xbec076f4] OM - Memory_alloc> return (0x589b8) @5,172,715us: [+0 T:0x4001f050 S:0xbec0770c] OC - Comm_create> return (0x589b8) @5,172,844us: [+0 T:0x4001f050 S:0xbec07714] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @5,172,995us: [+0 T:0x4001f050 S:0xbec07714] OC - Comm_put> return (0) @5,173,131us: [+0 T:0x4001f050 S:0xbec0770c] OC - Comm_get> Enter(queue=0x10000, msg=0xbec077bc, timeout=-1) @5,174,645us: [+0 T:0x4001f050 S:0xbec0770c] OC - Comm_get> MSGQ_get() status=0x8000, return (0) @5,174,768us: [+0 T:0x4001f050 S:0xbec0770c] OC - Comm_delete> Enter (comm=0x589b8) @5,175,479us: [+0 T:0x4001f050 S:0xbec076ec] OM - Memory_free> Enter(0x589b8, 0x4) @5,175,611us: [+0 T:0x4001f050 S:0xbec076ec] OM - Memory_free> return (0x1) @5,175,710us: [+0 T:0x4001f050 S:0xbec0772c] OC - Comm_delete> return @5,175,804us: [+0 T:0x4001f050 S:0xbec07714] OM - Memory_free> Enter(0x588d0, 0x20) @5,175,929us: [+0 T:0x4001f050 S:0xbec07714] OM - Memory_free> return (0x1) @5,176,025us: [+6 T:0x4001f050 S:0xbec07734] CE - Engine_createNode> Remote node creation FAILED (0x80008008). @5,176,131us: [+0 T:0x4001f050 S:0xbec0769c] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @5,176,275us: [+0 T:0x4001f050 S:0xbec0769c] OC - Comm_put> return (0) @5,176,513us: [+0 T:0x4001f050 S:0xbec07694] OC - Comm_get> Enter(queue=0x10000, msg=0xbec07734, timeout=-1) @5,176,650us: [+0 T:0x4001f050 S:0xbec07694] OC - Comm_get> MSGQ_get() status=0x8000, return (0) [DSP] @7,901,768tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 0 [DSP] @7,901,832tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> Enter(size=0x18) [DSP] @7,901,883tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> return (0x8fc71ae8) [DSP] @7,901,934tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> Enter(size=0xb) [DSP] @7,901,979tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> return (0x8fc71b00) [DSP] @7,902,034tk: [+0 T:0x8ba0006c S:0x8ba03ed4] OM - Memory_alloc> Enter(size=0x20) [DSP] @7,902,083tk: [+0 T:0x8ba0006c S:0x8ba03ed4] OM - Memory_alloc> return (0x8fc71b10) [DSP] @7,902,134tk: [+0 T:0x8ba0006c S:0x8ba03ea4] OM - Memory_alloc> Enter(size=0x24) [DSP] @7,902,180tk: [+0 T:0x8ba0006c S:0x8ba03ea4] OM - Memory_alloc> return (0x8fc71b30) [DSP] @7,902,252tk: [+0 T:0x8ba0006c S:0x8ba03ebc] ti.sdo.ce.audio1.AUDENC1 - AUDENC1_create> Enter (engine=0x0, name='aacheenc', params=0x8ff03940) [DSP] @7,902,335tk: [+0 T:0x8ba0006c S:0x8ba03e84] CV - VISA_create(0x0, 'aacheenc', 0x8ff03940, 0x480, 'ti.sdo.ce.audio1.IAUDENC1') [DSP] @7,902,406tk: [+0 T:0x8ba0006c S:0x8ba03d64] CV - VISA_create2(0x0, 'aacheenc', 0x8ff03940, 0x34, 0x480, 'ti.sdo.ce.audio1.IAUDENC1') [DSP] @7,902,488tk: [+0 T:0x8ba0006c S:0x8ba03cfc] CE - Engine_open> Enter('local', 0x8ba03d4c, 0x8ff03940) [DSP] @7,902,551tk: [+0 T:0x8ba0006c S:0x8ba03cdc] OM - Memory_alloc> Enter(size=0x2c) [DSP] @7,902,597tk: [+0 T:0x8ba0006c S:0x8ba03cdc] OM - Memory_alloc> return (0x8fc71ba0) [DSP] @7,902,655tk: [+0 T:0x8ba0006c S:0x8ba03cfc] CE - Engine_open> return(-1882776672) [DSP] @7,902,719tk: [+0 T:0x8ba0006c S:0x8ba03d44] OM - Memory_alloc> Enter(size=0x34) [DSP] @7,902,766tk: [+0 T:0x8ba0006c S:0x8ba03d44] OM - Memory_alloc> return (0x8fc71bd0) [DSP] @7,902,820tk: [+0 T:0x8ba0006c S:0x8ba03d1c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8fb879ac, idma3Fxns=0x0, iresFxns=0x0, params=0x8ff03940, attrs=0x8ba03e68) [DSP] @7,902,911tk: [+0 T:0x8ba0006c S:0x8ba03cfc] OM - Memory_alloc> Enter(size=0x10) [DSP] @7,902,957tk: [+0 T:0x8ba0006c S:0x8ba03cfc] OM - Memory_alloc> return (0x8fc71c08) [DSP] @7,906,364tk: [+7 T:0x8ba0006c S:0x8ba03d1c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch allocation [DSP] @7,906,496tk: [+0 T:0x8ba0006c S:0x8ba03cfc] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x8fc71c08) [DSP] @7,906,559tk: [+0 T:0x8ba0006c S:0x8ba03ccc] OM - Memory_free> Enter(addr=0x8fc71c08, size=16) [DSP] @7,906,615tk: [+0 T:0x8ba0006c S:0x8ba03ccc] OM - Memory_free> return (0x1) [DSP] @7,906,658tk: [+0 T:0x8ba0006c S:0x8ba03cfc] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit [DSP] @7,906,709tk: [+0 T:0x8ba0006c S:0x8ba03d1c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0) [DSP] @7,906,764tk: [+6 T:0x8ba0006c S:0x8ba03d64] CV - VISA_create2> FAILED to create local codec. [DSP] @7,906,815tk: [+0 T:0x8ba0006c S:0x8ba03d34] CV - VISA_delete(0x8fc71bd0) [DSP] @7,906,861tk: [+5 T:0x8ba0006c S:0x8ba03d34] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff) [DSP] @7,906,924tk: [+0 T:0x8ba0006c S:0x8ba03d04] OM - Memory_free> Enter(addr=0x8fc71bd0, size=52) [DSP] @7,906,979tk: [+0 T:0x8ba0006c S:0x8ba03d04] OM - Memory_free> return (0x1) [DSP] @7,907,025tk: [+0 T:0x8ba0006c S:0x8ba03ebc] ti.sdo.ce.audio1.AUDENC1 - AUDENC1_create> return (0x0) [DSP] @7,907,087tk: [+0 T:0x8ba0006c S:0x8ba03e94] OM - Memory_free> Enter(addr=0x8fc71b30, size=36) [DSP] @7,907,142tk: [+0 T:0x8ba0006c S:0x8ba03e94] OM - Memory_free> return (0x1) [DSP] @7,907,186tk: [+0 T:0x8ba0006c S:0x8ba03e9c] OM - Memory_free> Enter(addr=0x8fc71b10, size=32) [DSP] @7,907,240tk: [+0 T:0x8ba0006c S:0x8ba03e9c] OM - Memory_free> return (0x1) [DSP] @7,907,286tk: [+0 T:0x8ba0006c S:0x8ba03f24] OM - Memory_free> Enter(addr=0x8fc71b00, size=11) [DSP] @7,907,340tk: [+0 T:0x8ba0006c S:0x8ba03f24] OM - Memory_free> return (0x1) [DSP] @7,907,384tk: [+0 T:0x8ba0006c S:0x8ba03f24] OM - Memory_free> Enter(addr=0x8fc71ae8, size=24) [DSP] @7,907,438tk: [+0 T:0x8ba0006c S:0x8ba03f24] OM - Memory_free> return @5,516,554us: [+0 T:0x4001f050 S:0xbec0769c] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @5,516,718us: [+0 T:0x4001f050 S:0xbec0769c] OC - Comm_put> return (0) @5,516,971us: [+0 T:0x4001f050 S:0xbec07694] OC - Comm_get> Enter(queue=0x10000, msg=0xbec07734, timeout=-1) @5,517,103us: [+0 T:0x4001f050 S:0xbec07694] OC - Comm_get> MSGQ_get() status=0x8000, return (0) (0x1) [DSP] @7,914,471tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @7,914,529tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032 [DSP] @9,231,016tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @9,231,070tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032 @5,517,651us: [+0 T:0x4001f050 S:0xbec076cc] CE - Engine_fwriteTrace> returning count [4678] @5,517,750us: [+2 T:0x4001f050 S:0xbec07734] CE - Engine_createNode> Returning 0x0 @5,517,841us: [+6 T:0x4001f050 S:0xbec077ac] CV - VISA_create2> FAILED to create remote codec (0x8). @5,517,934us: [+0 T:0x4001f050 S:0xbec07784] CV - VISA_delete(0x58970) @5,518,021us: [+5 T:0x4001f050 S:0xbec07784] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff) @5,518,119us: [+0 T:0x4001f050 S:0xbec07774] OC - Comm_free> Enter (msg=0x4130c900) @5,518,233us: [+0 T:0x4001f050 S:0xbec07774] OC - Comm_free> return (0) @5,518,328us: [+0 T:0x4001f050 S:0xbec07764] OM - Memory_free> Enter(0x589a8, 0x4) @5,518,423us: [+0 T:0x4001f050 S:0xbec07764] OM - Memory_free> return (0x1) @5,518,511us: [+0 T:0x4001f050 S:0xbec07764] OM - Memory_free> Enter(0x58970, 0x34) @5,518,604us: [+0 T:0x4001f050 S:0xbec07764] OM - Memory_free> return (0x1) @5,853,241us: [+0 T:0x4001f050 S:0xbec078e4] ti.sdo.ce.audio1.AUDENC1 - AUDENC1_create> return (0x0) @5,853,357us: [+7 T:0x4001f050 S:0xbec0790c] ti.sdo.dmai - [Aenc1] Failed to open audio encode algorithm: aacheenc Failed to create audio encoder @5,853,542us: [+0 T:0x4001f050 S:0xbec079cc] CE - Engine_close(0x58640) @5,853,650us: [+0 T:0x4001f050 S:0xbec07934] OC - Comm_put> Enter(queue=0x0, msg=0x4130b900) @5,853,795us: [+0 T:0x4001f050 S:0xbec07934] OC - Comm_put> return (0) @5,854,047us: [+0 T:0x4001f050 S:0xbec0792c] OC - Comm_get> Enter(queue=0x10000, msg=0xbec079cc, timeout=-1) @5,854,182us: [+0 T:0x4001f050 S:0xbec0792c] OC - Comm_get> MSGQ_get() status=0x8000, return (0) [DSP] @10,534,554tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - processRmsCmd(0x8ff03928, 4056): cmd = 5 [DSP] @10,534,609tk: [+0 T:0x8ba0006c S:0x8ba0402c] CR - remote time = 0x0, trace buffer size = 4032 @5,854,485us: [+0 T:0x4001f050 S:0xbec07964] CE - Engine_fwriteTrace> returning count [199] @5,854,580us: [+0 T:0x4001f050 S:0xbec079ac] CS - Server_disconnectTrace('0x58640', 0x0) @5,854,672us: [+0 T:0x4001f050 S:0xbec079ac] CS - Server_connectTrace> return(0) @5,854,761us: [+0 T:0x4001f050 S:0xbec079bc] OC - Comm_free> Enter (msg=0x4130b900) @5,854,875us: [+0 T:0x4001f050 S:0xbec079bc] OC - Comm_free> return (0) @5,854,970us: [+0 T:0x4001f050 S:0xbec079ac] OC - Comm_delete> Enter (comm=0x588f8) @5,855,670us: [+0 T:0x4001f050 S:0xbec0798c] OM - Memory_free> Enter(0x588f8, 0x4) @5,855,800us: [+0 T:0x4001f050 S:0xbec0798c] OM - Memory_free> return (0x1) @5,855,897us: [+0 T:0x4001f050 S:0xbec079cc] OC - Comm_delete> return @5,856,016us: [+0 T:0x4001f050 S:0xbec079bc] OC - Comm_release> Enter(queue=0x0) @5,856,126us: [+0 T:0x4001f050 S:0xbec079bc] OC - Comm_release> return (0) @5,856,222us: [+0 T:0x4001f050 S:0xbec079cc] CE - rserverClose(0x5769c), count = 1 @5,856,314us: [+0 T:0x4001f050 S:0xbec079b4] OP - Processor_delete> Enter(proc=0x58670) @5,856,406us: [+0 T:0x4001f050 S:0xbec07994] OP - doCmd> Enter (cmdId=2, proc=0x58670) @5,856,496us: [+0 T:0x4001f050 S:0xbec07984] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x581c0] @5,856,631us: [+0 T:0x40afe490 S:0x40afdd44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x581c0] status[0] @5,856,746us: [+0 T:0x40afe490 S:0x40afdd64] OP - getCmd_d> Exit (result=2) @5,856,842us: [+0 T:0x40afe490 S:0x40afdd4c] OP - Processor_delete_d> Enter (proc=0x58670) @5,856,936us: [+2 T:0x40afe490 S:0x40afdd4c] OP - Processor_delete_d> Closing remote transport... @5,857,372us: [+2 T:0x40afe490 S:0x40afdd4c] OP - Processor_delete_d> Stopping DSP... @5,857,555us: [+2 T:0x40afe490 S:0x40afdd4c] OP - Processor_delete_d> Closing pool... @5,857,955us: [+2 T:0x40afe490 S:0x40afdd4c] OP - Processor_delete_d> Detaching from DSP... @5,859,667us: [+0 T:0x4001f050 S:0xbec07994] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x581c0] @5,859,797us: [+0 T:0x4001f050 S:0xbec07974] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x581d8] timeout[0xffffffff] @5,873,441us: [+2 T:0x40afe490 S:0x40afdd4c] OP - Processor_delete_d> Destroying DSP... (object, that is) @5,874,238us: [+0 T:0x40afe490 S:0x40afdd2c] OM - Memory_free> Enter(0x58698, 0x0) @5,874,373us: [+0 T:0x40afe490 S:0x40afdd2c] OM - Memory_free> return (0x1) @5,874,475us: [+0 T:0x40afe490 S:0x40afdd64] OP - Processor_delete_d> return @5,874,567us: [+0 T:0x40afe490 S:0x40afdd54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x581d8] @5,874,706us: [+0 T:0x4001f050 S:0xbec07974] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x581d8] status[0] @5,874,818us: [+0 T:0x4001f050 S:0xbec07994] OP - doCmd> Exit (result=1) @5,874,911us: [+1 T:0x4001f050 S:0xbec079b4] OP - Processor_delete(0x58670) freeing object ... @5,875,004us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_free> Enter(0x58670, 0x24) @5,875,103us: [+0 T:0x4001f050 S:0xbec07994] OM - Memory_free> return (0x1) @5,875,192us: [+0 T:0x4001f050 S:0xbec079cc] OP - Processor_delete> return. @5,875,280us: [+0 T:0x4001f050 S:0xbec079cc] CE - rserverClose(0x5769c) done. @6,208,715us: [+0 T:0x4001f050 S:0xbec079cc] OM - Memory_free> Enter(0x58640, 0x2c) @6,208,835us: [+0 T:0x4001f050 S:0xbec079cc] OM - Memory_free> return (0x1) End of application. @6,209,111us: [+0 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> enter @6,209,215us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x17a90()... @6,209,312us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x19850()... @6,209,429us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> Enter(0x58420, 0x18) @6,209,701us: [+0 T:0x40afe490 S:0x40afdd64] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x581d8] @6,209,819us: [+0 T:0x40afe490 S:0x40afdd64] OP - getCmd_d> Enter (proc=0x40afddd8) @6,209,921us: [+0 T:0x40afe490 S:0x40afdd44] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x581c0] timeout[0xffffffff] @6,210,058us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> return (0x1) @6,210,166us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> Enter(0x58440, 0x18) @6,210,266us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> return (0x1) @6,210,356us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> Enter(0x58460, 0x18) @6,210,447us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> return (0x1) @6,210,539us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x24970()... @6,210,632us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x1c690()... @6,210,726us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x2201c()... @6,210,818us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x1fcd0()... @6,210,908us: [+0 T:0x4001f050 S:0xbec07bac] OP - doCmd> Enter (cmdId=3, proc=0x0) @6,210,998us: [+0 T:0x4001f050 S:0xbec07b9c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x581c0] @6,211,129us: [+0 T:0x40afe490 S:0x40afdd44] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x581c0] status[0] @6,211,245us: [+0 T:0x40afe490 S:0x40afdd64] OP - getCmd_d> Exit (result=3) @6,211,344us: [+0 T:0x40afe490 S:0x40afdd54] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x581d8] @6,211,472us: [+0 T:0x40afe490 S:0x40afdd64] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x581d8] @6,211,764us: [+0 T:0x4001f050 S:0xbec07bac] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x581c0] @6,211,888us: [+0 T:0x4001f050 S:0xbec07b8c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x581d8] timeout[0xffffffff] @6,211,991us: [+0 T:0x4001f050 S:0xbec07b8c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x581d8] status[0] @6,212,085us: [+0 T:0x4001f050 S:0xbec07bac] OP - doCmd> Exit (result=1) @6,212,174us: [+0 T:0x4001f050 S:0xbec07bb4] OT - Thread_delete> Enter (task=0x58210) @6,212,297us: [+4 T:0x4001f050 S:0xbec07bb4] OT - Thread_delete> pthread_cancel (0x3) @6,212,405us: [+4 T:0x4001f050 S:0xbec07bb4] OT - Thread_delete> pthread_join (0x0) @6,212,496us: [+0 T:0x4001f050 S:0xbec07b94] OM - Memory_free> Enter(0x58210, 0x64) @6,212,591us: [+0 T:0x4001f050 S:0xbec07b94] OM - Memory_free> return (0x1) @6,212,681us: [+0 T:0x4001f050 S:0xbec07bcc] OT - Thread_delete> Exit (task=0x58210) @6,212,769us: [+0 T:0x4001f050 S:0xbec07bbc] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x581c0] @6,212,883us: [+0 T:0x4001f050 S:0xbec07b9c] OM - Memory_free> Enter(0x581c0, 0x14) @6,212,988us: [+0 T:0x4001f050 S:0xbec07b9c] OM - Memory_free> return (0x1) @6,213,077us: [+0 T:0x4001f050 S:0xbec07bcc] ti.sdo.ce.osal.Sem - Leaving Sem_delete> @6,213,167us: [+0 T:0x4001f050 S:0xbec07bbc] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x581d8] @6,213,255us: [+0 T:0x4001f050 S:0xbec07b9c] OM - Memory_free> Enter(0x581d8, 0x14) @6,213,346us: [+0 T:0x4001f050 S:0xbec07b9c] OM - Memory_free> return (0x1) @6,213,433us: [+0 T:0x4001f050 S:0xbec07bcc] ti.sdo.ce.osal.Sem - Leaving Sem_delete> @6,213,518us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> Enter(0x581f0, 0x18) @6,547,340us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> return (0x1) @6,547,454us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x24480()... @6,547,581us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x21ad0()... @6,547,685us: [+0 T:0x4001f050 S:0xbec07bbc] OM - Memory_free> Enter(0x58140, 0x18) @6,547,782us: [+0 T:0x4001f050 S:0xbec07bbc] OM - Memory_free> return (0x1) @6,547,872us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x22ca4()... @6,547,997us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> Enter(0x580f0, 0x18) @6,548,097us: [+0 T:0x4001f050 S:0xbec07bac] OM - Memory_free> return (0x1) @6,548,193us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x24e1c()... @6,548,286us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x259d0()... @6,548,378us: [+2 T:0x4001f050 S:0xbec07bdc] OG - Global_exit> calling function *0x24d7c()... root@dm6467t-evm:~#
