Question about customed usecase crash down
Hi all,
My environment is rdk 03.50.00.05.
Here is my usecase's data flow:
the program crashed when creating the usecase, here is the full crash log:
0042.app_crash_log.TXT
and the CCS_CRASH_DUMP_VIDEO-M3.txt:
6840.CCS_CRASH_DUMP_VIDEO-M3.txt
my usecase src file:
#define MULTI_DEI_TEST
#ifdef MULTI_DEI_TEST
#include "mcfw/src_linux/mcfw_api/usecases/multich_common.h"
#include "mcfw/src_linux/mcfw_api/usecases/multich_ipcbits.h"
#define ENABLE_FRAMES_EXPORT
// Keeping TILER disabled for 4D1 usecase
#define TILER_ENABLE    TRUE;//FALSE
#define DEI_OUT_MAIN_STRAMER	(DEI_LINK_OUT_QUE_DEI_SC)
#define DEI_OUT_SUB_STRAMER		(DEI_LINK_OUT_QUE_VIP_SC)
#if(defined(TI_814X_BUILD) || defined(DDR_MEM_256M))
#define     NUM_CAPTURE_BUFFERS          8
#define     NUM_NSF_BUFFERS              4
#define     NUM_ENCODE_D1_BUFFERS       4
#define     NUM_ENCODE_CIF_BUFFERS       4
#define     NUM_DECODE_BUFFERS           4
#define     NUM_IPC_OUT_BUFFERS          4
#define     NUM_SWMS_MAX_BUFFERS         8
#else
#define     NUM_NSF_BUFFERS              6
#define     NUM_ENCODE_D1_BUFFERS       6
#define     NUM_ENCODE_CIF_BUFFERS       6
#define     NUM_DECODE_BUFFERS           6
#define     NUM_IPC_OUT_BUFFERS          6
#endif
#define DEI_INFRAME_RATE		(30)	//(30)
#define DEI_OUTFRAME_RATE	(30)	//(30)
#define DEI_OUTFRAME_RATE_SUB	(30)	//(30)
#define MAX_DEI_NSF_LINK_CHAIN	(3)
 static SystemVideo_Ivahd2ChMap_Tbl system_IvaChMapTbl_HDEX1002F =
	.isPopulated = 1,
	.ivaMap[0] =
		.EncNumCh  = 1,
		.EncChList = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0, 0},
		.DecNumCh  = 0,
		.DecChList = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0, 0},
	.ivaMap[1] =
		.EncNumCh  = 2,
		.EncChList = {2, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0, 0},
		.DecNumCh  = 0,
	.ivaMap[2] =
		.EncNumCh  = 3,
		.EncChList = {1, 3, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 , 0, 0},
		.DecNumCh  = 0,
Void MultiCh_createVcapVenc(Adv7441InputPrm *pAdv7441Inputprm)
    int i_index;
    int j_index;
	for (i_index = 0;i_index < 3;i_index++)
		TRACE_LOG("index %d chid %d inputtype %d\n", i_index, pAdv7441Inputprm[i_index].chId, pAdv7441Inputprm[i_index].inputType);
    if(gVcapModuleContext.vcapConfig.numChn > MAX_DEI_NSF_LINK_CHAIN)
    	TRACE_ERROR("Current usecase only support %d <= %d\n ",
    		gVcapModuleContext.vcapConfig.numChn, MAX_DEI_NSF_LINK_CHAIN);
    int i_dei_nsf_link_num = gVcapModuleContext.vcapConfig.numChn;
    CaptureLink_VipInstParams         *pCaptureInstPrm;
    CaptureLink_OutParams             *pCaptureOutPrm
    CaptureLink_CreateParams	capturePrm;
    DeiLink_CreateParams	deiPrm[MAX_DEI_LINK];
    NsfLink_CreateParams	nsfPrm[MAX_NSF_LINK];
    MergeLink_CreateParams	mergePrm[MAX_MERGE_LINK];
    IpcLink_CreateParams	ipcOutVpssPrm;
    IpcLink_CreateParams        ipcInVideoPrm;
    EncLink_CreateParams        encPrm;
    IpcBitsOutLinkRTOS_CreateParams   ipcBitsOutVideoPrm;
    IpcBitsInLinkHLOS_CreateParams    ipcBitsInHostPrm[2];
    System_LinkInfo                   bitsProducerLinkInfo;
#ifdef ENABLE_FRAMES_EXPORT
    IpcFramesOutLinkRTOS_CreateParams  ipcFramesOutVpssToHostPrm;
    IpcFramesInLinkHLOS_CreateParams   ipcFramesInHostPrm;
    IpcFramesOutLinkHLOS_CreateParams  ipcFramesOutHostPrm;
    IpcFramesInLinkRTOS_CreateParams   ipcFramesInVpssFromHostPrm;
	System_LinkInfo framesProducerLinkInfo;
#endif
    UInt32 vipInstId;
    UInt32 i;
    VCAP_ADV7441_OUT_PARAMS_S adv7441_outparams[MAX_DEI_NSF_LINK_CHAIN];
    //UInt32 j;
    MULTICH_INIT_STRUCT(CaptureLink_CreateParams, capturePrm);
    for(i_index=0; i_index<i_dei_nsf_link_num; i_index++)
    	MULTICH_INIT_STRUCT(DeiLink_CreateParams, deiPrm[i_index]);
    	MULTICH_INIT_STRUCT(NsfLink_CreateParams, nsfPrm[i_index]);
    MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcOutVpssPrm);
    MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcInVideoPrm);
    MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);
    MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams,ipcBitsOutVideoPrm);
    MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams,ipcBitsInHostPrm[0]);
    MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams ,ipcFramesOutVpssToHostPrm);
    MULTICH_INIT_STRUCT(IpcFramesInLinkHLOS_CreateParams  ,ipcFramesInHostPrm);
    MULTICH_INIT_STRUCT(IpcFramesOutLinkHLOS_CreateParams ,ipcFramesOutHostPrm);
    MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams  ,ipcFramesInVpssFromHostPrm);
#endif
    MultiCh_detectBoard();
    TRACE_LOG("\n");
    System_linkControl(
    	SYSTEM_LINK_ID_M3VPSS,
    	SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,
    	NULL,
    	0,
    	TRUE
    TRACE_LOG("\n");
    if(VSYS_USECASE_MULTICHN_VCAP_VENC_3HD_EX1002F == gVsysModuleContext.vsysConfig.systemUseCase)
    	System_linkControl(
    		SYSTEM_LINK_ID_M3VIDEO,
    		SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
    		 &system_IvaChMapTbl_HDEX1002F,
    		sizeof(SystemVideo_Ivahd2ChMap_Tbl),
    		TRUE
    else
    	System_linkControl(
    		TRUE
    TRACE_LOG("\n");
    gVcapModuleContext.captureId    = SYSTEM_LINK_ID_CAPTURE;
    gVcapModuleContext.deiId[0]     = SYSTEM_LINK_ID_DEI_HQ_0;//---SYSTEM_LINK_ID_DEI_0;
    gVcapModuleContext.deiId[1]     = SYSTEM_LINK_ID_DEI_0;//---SYSTEM_LINK_ID_DEI_0;
    gVcapModuleContext.deiId[2]     = SYSTEM_LINK_ID_DEI_1;//---SYSTEM_LINK_ID_DEI_0;
    gVcapModuleContext.nsfId[0]     = SYSTEM_LINK_ID_NSF_0;//---SYSTEM_LINK_ID_DEI_0;
    gVcapModuleContext.nsfId[1]     = SYSTEM_LINK_ID_NSF_1;//---SYSTEM_LINK_ID_DEI_0;
    gVcapModuleContext.nsfId[2]     = SYSTEM_LINK_ID_NSF_2;//---SYSTEM_LINK_ID_DEI_0;
    gVcapModuleContext.mergeId[0]	= SYSTEM_VPSS_LINK_ID_MERGE_0;//SYSTEM_VPSS_LINK_ID_MERGE_1;
    gVcapModuleContext.ipcOutVpssId = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0;
    gVencModuleContext.ipcM3InId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;
    gVencModuleContext.encId        = SYSTEM_LINK_ID_VENC_0;
    gVencModuleContext.ipcBitsOutRTOSId  = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0;
    gVencModuleContext.ipcBitsInHLOSId   = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;
    gVcapModuleContext.ipcFramesOutVpssToHostId  = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_OUT_1;
    gVcapModuleContext.ipcFramesInHostId         = SYSTEM_HOST_LINK_ID_IPC_FRAMES_IN_0;
    gVdisModuleContext.ipcFramesOutHostId        = SYSTEM_HOST_LINK_ID_IPC_FRAMES_OUT_0;
    gVdisModuleContext.ipcFramesInVpssFromHostId = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_IN_0;
#endif
    TRACE_LOG("Capture link Params\n");
    	capturePrm.outQueParams[i_index].nextLink   = gVcapModuleContext.deiId[i_index];
    capturePrm.numVipInst    = i_dei_nsf_link_num;
    capturePrm.tilerEnable                = TRUE;//FALSE;
    capturePrm.numBufsPerCh               = NUM_CAPTURE_BUFFERS;
    capturePrm.maxBlindAreasPerCh         = 4;
    int standard;
    for(vipInstId=0; vipInstId < capturePrm.numVipInst; vipInstId++)
        pCaptureInstPrm = &capturePrm.vipInst[vipInstId];
        pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_TVP7002_DRV;
        pCaptureInstPrm->inDataFormat   = SYSTEM_DF_YUV422P;
        adv7441_outparams[vipInstId].instChId = vipInstId;
    #ifdef LPW_DEBUG
        standard = Vcap_GetAdv7441Resolution2(&adv7441_outparams[vipInstId], pAdv7441Inputprm[vipInstId]);/**/
    #else
        standard = Vcap_GetAdv7441Resolution(&adv7441_outparams[vipInstId]);
    #endif
    	TRACE_LOG("VCap Ch cfg to standard %d \n", standard);
    	if(standard != SYSTEM_STD_INVALID)
    		pCaptureInstPrm->standard = standard;/*SYSTEM_Standard*/
    	else
    		pCaptureInstPrm->standard = SYSTEM_STD_XGA_60;
    	pCaptureInstPrm->numOutput      = 1;
    	pCaptureOutPrm = &pCaptureInstPrm->outParams[0];
    	if (vipInstId == 0)
    		pCaptureInstPrm->vipInstId 	= (SYSTEM_CAPTURE_INST_VIP0_PORTA+
    		                              vipInstId)%SYSTEM_CAPTURE_INST_MAX;
    	else
    		pCaptureInstPrm->vipInstId 	= (SYSTEM_CAPTURE_INST_VIP0_PORTB+
    	pCaptureOutPrm->outQueId = vipInstId;
    	pCaptureOutPrm->dataFormat      = SYSTEM_DF_YUV422I_YUYV;
    	pCaptureOutPrm->scEnable        = FALSE;
    	pCaptureOutPrm->scOutWidth      = 0;
    	pCaptureOutPrm->scOutHeight     = 0;
    TRACE_LOG("\n");
    int i_dei_cfg_out_index = 0;
    	deiPrm[i_index].inQueParams.prevLinkId = gVcapModuleContext.captureId;
    	deiPrm[i_index].inQueParams.prevLinkQueId  = i_index ;
    	deiPrm[i_index].enableLineSkipSc = FALSE;
    	if (adv7441_outparams[i_index].bInterlaced)
    		deiPrm[i_index].enableDeiForceBypass = FALSE;
    	else
    		deiPrm[i_index].enableDeiForceBypass = TRUE;
    	if(0 == i_index)
    		deiPrm[i_index].inputDeiFrameRate = 60;
    		deiPrm[i_index].outputDeiFrameRate = 60;
    	else
    	deiPrm[i_index].outQueParams[DEI_OUT_MAIN_STRAMER].nextLink = gVcapModuleContext.nsfId[i_index];
    	deiPrm[i_index].outQueParams[DEI_OUT_SUB_STRAMER].nextLink     = gVcapModuleContext.mergeId[0];
    	deiPrm[i_index].enableOut[DEI_OUT_MAIN_STRAMER] = TRUE;
    	deiPrm[i_index].enableOut[DEI_OUT_SUB_STRAMER] = TRUE;
    	deiPrm[i_index].tilerEnable[DEI_OUT_MAIN_STRAMER]          = TILER_ENABLE;
    	deiPrm[i_index].comprEnable = FALSE;
    	deiPrm[i_index].setVipScYuv422Format = FALSE;
    	deiPrm[i_index].inputFrameRate[DEI_OUT_MAIN_STRAMER] = DEI_INFRAME_RATE;
    	deiPrm[i_index].outputFrameRate[DEI_OUT_MAIN_STRAMER] = DEI_OUTFRAME_RATE;
    	deiPrm[i_index].inputFrameRate[DEI_OUT_SUB_STRAMER] = DEI_INFRAME_RATE;
    	deiPrm[i_index].outputFrameRate[DEI_OUT_SUB_STRAMER] = DEI_OUTFRAME_RATE_SUB;
    	TRACE_LOG("VCap ch %d DEI %d ������֡��: %d %d ������֡��: %d %d\n",
    		i_index, i_index, 	DEI_INFRAME_RATE, DEI_OUTFRAME_RATE,
    							DEI_INFRAME_RATE, DEI_OUTFRAME_RATE_SUB);
    	TRACE_LOG("��Ƶͨ�� %d �������ֱ���Auto\n", i_index);
    	deiPrm[i_index].outScaleFactor[DEI_OUT_MAIN_STRAMER][i_dei_cfg_out_index].scaleMode = DEI_SCALE_MODE_RATIO;
    	deiPrm[i_index].outScaleFactor[DEI_OUT_MAIN_STRAMER][i_dei_cfg_out_index].ratio.heightRatio.numerator = 1;
    	deiPrm[i_index].outScaleFactor[DEI_OUT_MAIN_STRAMER][i_dei_cfg_out_index].ratio.heightRatio.denominator = 1;
    	deiPrm[i_index].outScaleFactor[DEI_OUT_MAIN_STRAMER][i_dei_cfg_out_index].ratio.widthRatio.numerator = 1;
    	deiPrm[i_index].outScaleFactor[DEI_OUT_MAIN_STRAMER][i_dei_cfg_out_index].ratio.widthRatio.denominator = 1;
    	TRACE_LOG("��Ƶͨ�� %d ������ %d %d %d\n", i_index,
    					gVcapModuleContext.vcapConfig.channelParams[i_index].strmResolution[1].scaleMode,
    					gVcapModuleContext.vcapConfig.channelParams[i_index].strmResolution[1].param_x,
    					gVcapModuleContext.vcapConfig.channelParams[i_index].strmResolution[1].param_y);
    	if(1 == gVcapModuleContext.vcapConfig.channelParams[i_index].strmResolution[1].scaleMode)
    		TRACE_LOG("��Ƶͨ�� %d ������ �ֱ���ָ��%d %d\n", i_index,
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].scaleMode = DEI_SCALE_MODE_ABSOLUTE;
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].absoluteResolution.outWidth = gVcapModuleContext.vcapConfig.channelParams[i_index].strmResolution[1].param_x;
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].absoluteResolution.outHeight = gVcapModuleContext.vcapConfig.channelParams[i_index].strmResolution[1].param_y;
    	else
    		TRACE_LOG("��Ƶͨ�� %d ������ �ֱ���AUTO\n", i_index);
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].scaleMode = DEI_SCALE_MODE_RATIO;
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].ratio.heightRatio.numerator = 1;
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].ratio.heightRatio.denominator = 1;
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].ratio.widthRatio.numerator = 1;
    		deiPrm[i_index].outScaleFactor[DEI_OUT_SUB_STRAMER][i_dei_cfg_out_index].ratio.widthRatio.denominator = 1;
    	nsfPrm[i_index].inQueParams.prevLinkId	= gVcapModuleContext.deiId[i_index];
    	nsfPrm[i_index].inQueParams.prevLinkQueId	= DEI_OUT_MAIN_STRAMER;
    	nsfPrm[i_index].numOutQue	= 1;
    	nsfPrm[i_index].outQueParams[0].nextLink 		= gVcapModuleContext.mergeId[0];
    	nsfPrm[i_index].bypassNsf	= TRUE;
    	nsfPrm[i_index].tilerEnable	= TILER_ENABLE;
    	nsfPrm[i_index].numBufsPerCh	=  NUM_NSF_BUFFERS;
    	nsfPrm[i_index].inputFrameRate = 30;
    	nsfPrm[i_index].outputFrameRate = 30;
    mergePrm[0].numInQue = 2 * i_dei_nsf_link_num;
    	mergePrm[0].inQueParams[i_index*2].prevLinkId       = gVcapModuleContext.nsfId[i_index];
    	mergePrm[0].inQueParams[i_index*2].prevLinkQueId    = 0;
    	mergePrm[0].inQueParams[i_index*2 + 1].prevLinkId       = gVcapModuleContext.deiId[i_index];
    	mergePrm[0].inQueParams[i_index*2 + 1].prevLinkQueId    = DEI_OUT_SUB_STRAMER;
	mergePrm[0].outQueParams.nextLink  = gVcapModuleContext.ipcFramesOutVpssToHostId;
	#else
    mergePrm[0].outQueParams.nextLink  = gVcapModuleContext.ipcOutVpssId;
	#endif
    mergePrm[0].notifyNextLink                  = TRUE;
    ipcOutVpssPrm.inQueParams.prevLinkQueId    = 0;
        /* Set ipcFramesOutVpss link info */
        ipcFramesOutVpssToHostPrm.baseCreateParams.noNotifyMode = TRUE;
        ipcFramesOutVpssToHostPrm.baseCreateParams.notifyNextLink = TRUE;//FALSE;
        ipcFramesOutVpssToHostPrm.baseCreateParams.notifyPrevLink = TRUE;
        ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.mergeId[0];
        ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
        ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.ipcFramesInHostId;
        ipcFramesInHostPrm.baseCreateParams.noNotifyMode = TRUE;
        ipcFramesInHostPrm.baseCreateParams.notifyNextLink = TRUE;//FALSE;
        ipcFramesInHostPrm.baseCreateParams.notifyPrevLink = FALSE;
        ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkId = gVcapModuleContext.ipcFramesOutVpssToHostId;
        ipcFramesInHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
        ipcFramesInHostPrm.baseCreateParams.outQueParams[0].nextLink = SYSTEM_LINK_ID_INVALID;
        ipcFramesInHostPrm.exportOnlyPhyAddr = TRUE;
        ipcFramesInHostPrm.cbCtx = &gVcapModuleContext;
        ipcFramesInHostPrm.cbFxn = Vcap_ipcFramesInCbFxn;
        ipcFramesOutHostPrm.baseCreateParams.noNotifyMode = TRUE;
        ipcFramesOutHostPrm.baseCreateParams.notifyNextLink = TRUE;//FALSE;
        ipcFramesOutHostPrm.baseCreateParams.notifyPrevLink = FALSE;
        ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkId = SYSTEM_LINK_ID_INVALID;
        ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
        ipcFramesOutHostPrm.baseCreateParams.outQueParams[0].nextLink = gVdisModuleContext.ipcFramesInVpssFromHostId;
		#if 1
        ipcFramesInVpssFromHostPrm.baseCreateParams.noNotifyMode = TRUE;
        ipcFramesInVpssFromHostPrm.baseCreateParams.notifyNextLink = TRUE;
        ipcFramesInVpssFromHostPrm.baseCreateParams.notifyPrevLink = FALSE;
        ipcFramesInVpssFromHostPrm.baseCreateParams.inQueParams.prevLinkId = gVdisModuleContext.ipcFramesOutHostId;
        ipcFramesInVpssFromHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
        ipcFramesInVpssFromHostPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.ipcOutVpssId;//gVdisModuleContext.swMsId[0];
		#endif
        ipcOutVpssPrm.inQueParams.prevLinkId    = gVdisModuleContext.ipcFramesInVpssFromHostId;
    #else
        ipcOutVpssPrm.inQueParams.prevLinkId = gVcapModuleContext.mergeId[0];
	#endif
	#if 1
    ipcOutVpssPrm.outQueParams[0].nextLink     = gVencModuleContext.ipcM3InId;
    ipcOutVpssPrm.numOutQue = 1;
    ipcOutVpssPrm.notifyNextLink               = TRUE;
    ipcOutVpssPrm.notifyPrevLink               = TRUE;
    ipcOutVpssPrm.noNotifyMode                 = FALSE;
    ipcOutVpssPrm.notifyProcessLink			   = FALSE;
	#endif
    ipcInVideoPrm.inQueParams.prevLinkId       = gVcapModuleContext.ipcOutVpssId;
    ipcInVideoPrm.inQueParams.prevLinkQueId    = 0;
    ipcInVideoPrm.numOutQue                    = 1;
    ipcInVideoPrm.outQueParams[0].nextLink     = gVencModuleContext.encId;
    ipcInVideoPrm.notifyNextLink               = TRUE;
    ipcInVideoPrm.notifyPrevLink               = TRUE;
    ipcInVideoPrm.noNotifyMode                 = FALSE;
    TRACE_LOG("\n");
    	EncLink_ChCreateParams *pLinkChPrm;
    	EncLink_ChDynamicParams *pLinkDynPrm;
    	VENC_CHN_PARAMS_S *pChPrm;
    	VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;
    	TRACE_LOG("������ͨ����: %d ������ͨ����: %d MJPEGͨ����: %d\n",
    		gVencModuleContext.vencConfig.numPrimaryChn,
    		gVencModuleContext.vencConfig.numSecondaryChn,
    		gVencModuleContext.vencConfig.numTertiaryChn);
    	encPrm.inQueParams.prevLinkId    = gVencModuleContext.ipcM3InId;
    	encPrm.inQueParams.prevLinkQueId = 0;
    	encPrm.outQueParams.nextLink     = gVencModuleContext.ipcBitsOutRTOSId;
    	encPrm.numBufPerCh[0] = NUM_ENCODE_D1_BUFFERS;
    	encPrm.numBufPerCh[1] = NUM_ENCODE_CIF_BUFFERS;
    	/* Primary Stream Params - D1 */
    	for (i=0; i<(gVencModuleContext.vencConfig.numPrimaryChn + gVencModuleContext.vencConfig.numSecondaryChn); i++)
    		pLinkChPrm  = &encPrm.chCreateParams[i];
    		pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
    		pChPrm      = &gVencModuleContext.vencConfig.encChannelParams[i];
    		pDynPrm     = &pChPrm->dynamicParam;
    		pLinkChPrm->format                  = IVIDEO_H264HP;
    		pLinkChPrm->profile                 = gVencModuleContext.vencConfig.h264Profile[i];
    		pLinkChPrm->dataLayout              = IVIDEO_FIELD_SEPARATED;
    		pLinkChPrm->fieldMergeEncodeEnable  = FALSE;
    		pLinkChPrm->enableAnalyticinfo      = pChPrm->enableAnalyticinfo;
    		pLinkChPrm->enableWaterMarking      = pChPrm->enableWaterMarking;/*ͼ���Ƿ���ʾˮӡ*/
    		pLinkChPrm->maxBitRate              = pChPrm->maxBitRate;
    		pLinkChPrm->encodingPreset          = pChPrm->encodingPreset;
    		pLinkChPrm->rateControlPreset       = pChPrm->rcType;
    		pLinkChPrm->enableSVCExtensionFlag  = pChPrm->enableSVCExtensionFlag;
    		pLinkChPrm->numTemporalLayer        = pChPrm->numTemporalLayer;
    		pLinkChPrm->sliceCodingPreset = pChPrm->sliceCodingPreset;
    		pLinkChPrm->sliceMode = pChPrm->sliceMode;
    		pLinkChPrm->sliceUnitSize = pChPrm->sliceUnitSize;
    		TRACE_LOG("Pri ch %d slice params %d %d %d\n",
    			i, pLinkChPrm->sliceCodingPreset, pLinkChPrm->sliceMode, pLinkChPrm->sliceUnitSize);
    		pLinkDynPrm->intraFrameInterval     = pDynPrm->intraFrameInterval;
    		pLinkDynPrm->targetBitRate          = pDynPrm->targetBitRate;
    		pLinkDynPrm->interFrameInterval     = 1;
    		pLinkDynPrm->mvAccuracy             = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
    		pLinkDynPrm->inputFrameRate         = pDynPrm->inputFrameRate;
    		pLinkDynPrm->rcAlg                  = pDynPrm->rcAlg;
    		pLinkDynPrm->qpMin                  = pDynPrm->qpMin;
    		pLinkDynPrm->qpMax                  = pDynPrm->qpMax;
    		pLinkDynPrm->qpInit                 = pDynPrm->qpInit;
    		pLinkDynPrm->vbrDuration            = pDynPrm->vbrDuration;
    		pLinkDynPrm->vbrSensitivity         = pDynPrm->vbrSensitivity;
    	#if 0
    	/* Secondary Out <CIF> Params */
    	for (i=gVencModuleContext.vencConfig.numPrimaryChn, j=VENC_PRIMARY_CHANNELS;
    		i++, j++)
    		pChPrm      = &gVencModuleContext.vencConfig.encChannelParams[j];
    	#endif
    ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId;
    ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
    ipcBitsOutVideoPrm.baseCreateParams.numOutQue                 = 1;
    ipcBitsOutVideoPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId;
    TRACE_LOG("\n");
    MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutVideoPrm,
                                               TRUE);
    TRACE_LOG("\n");
    ipcBitsInHostPrm[0].baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId;
    ipcBitsInHostPrm[0].baseCreateParams.inQueParams.prevLinkQueId = 0;
    MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm[0]);
    TRACE_LOG("\n");
    System_linkCreate (gVcapModuleContext.captureId, &capturePrm, sizeof(capturePrm));
    TRACE_LOG("\n");
    	System_linkCreate(gVcapModuleContext.deiId[i_index], &(deiPrm[i_index]), sizeof(DeiLink_CreateParams));
    	TRACE_LOG("\n");
    	System_linkCreate(gVcapModuleContext.nsfId[i_index], &(nsfPrm[i_index]), sizeof(NsfLink_CreateParams));
    	TRACE_LOG("\n");
    System_linkCreate(gVcapModuleContext.mergeId[0], &mergePrm[0], sizeof(mergePrm[0]));
    TRACE_LOG("\n");
    System_linkCreate(gVcapModuleContext.ipcOutVpssId, &ipcOutVpssPrm , sizeof(ipcOutVpssPrm) );
	System_linkCreate(gVcapModuleContext.ipcFramesOutVpssToHostId	  , &ipcFramesOutVpssToHostPrm	  , sizeof(ipcFramesOutVpssToHostPrm));
	System_linkCreate(gVcapModuleContext.ipcFramesInHostId	   , &ipcFramesInHostPrm	, sizeof(ipcFramesInHostPrm));
	System_linkGetInfo(gVcapModuleContext.ipcFramesInHostId,&framesProducerLinkInfo);
	OSA_assert(framesProducerLinkInfo.numQue == 1);
	ipcFramesOutHostPrm.inQueInfo = framesProducerLinkInfo.queInfo[0];
	System_linkCreate(gVdisModuleContext.ipcFramesOutHostId 	, &ipcFramesOutHostPrm	  , sizeof(ipcFramesOutHostPrm));
	System_linkCreate(gVdisModuleContext.ipcFramesInVpssFromHostId	   , &ipcFramesInVpssFromHostPrm	, sizeof(ipcFramesInVpssFromHostPrm));
#endif
    TRACE_LOG("\n");
    System_linkCreate(gVencModuleContext.ipcM3InId , &ipcInVideoPrm , sizeof(ipcInVideoPrm) );
    TRACE_LOG("\n");
    System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));
    TRACE_LOG("\n");
    System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoPrm, sizeof(ipcBitsOutVideoPrm));
    TRACE_LOG("\n");
    System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm[0], sizeof(ipcBitsInHostPrm[0]));
    TRACE_LOG("\n");
    System_linkGetInfo(gVencModuleContext.ipcBitsInHLOSId,&bitsProducerLinkInfo);
    OSA_assert(bitsProducerLinkInfo.numQue == 1);
    printf ("\n\n========bitsProducerLinkInfo============\n");
    System_LinkQueInfo  *p_queInfo = NULL;
    for(i_index=0; i_index<bitsProducerLinkInfo.numQue; i_index++)
    	p_queInfo = &(bitsProducerLinkInfo.queInfo[i_index]);
    	for(j_index=0; j_index<p_queInfo->numCh; j_index++)
    		printf ("Que [%d] Ch [%d]/[%d] Width %d, Height %d\n",
    			i_index, j_index, p_queInfo->numCh,
    			p_queInfo->chInfo[j_index].width,
    			p_queInfo->chInfo[j_index].height);
    	/*if(p_queInfo->numCh > gVencModuleContext.vencConfig.numPrimaryChn)
    	p_queInfo->numCh = gVencModuleContext.vencConfig.numPrimaryChn;
    	printf ("Reducing bitsProducerLinkInfo.numCh to %d\n", p_queInfo->numCh);
    printf ("\n=================================================\n\n");
    TRACE_LOG("Create finish\n");
Void MultiCh_deleteVcapVenc()
	int i_index;
	System_linkDelete(gVcapModuleContext.captureId);
	TRACE_LOG("Delete %d NumCh\n", gVcapModuleContext.vcapConfig.numChn);
	for(i_index=0; i_index<gVcapModuleContext.vcapConfig.numChn; i_index++)
		System_linkDelete(gVcapModuleContext.deiId[i_index]);
		System_linkDelete(gVcapModuleContext.nsfId[i_index]);
	System_linkDelete(gVcapModuleContext.mergeId[0]);
#ifdef SUPPORT_OSD
	System_linkDelete(gVcapModuleContext.ipcFramesOutVpssId[0]);
	System_linkDelete(gVcapModuleContext.ipcFramesInDspId[0]);
	System_linkDelete(gVcapModuleContext.dspAlgId[0]);
#endif
	System_linkDelete(gVcapModuleContext.ipcOutVpssId);
	System_linkDelete(gVencModuleContext.ipcM3InId);
	System_linkDelete(gVencModuleContext.encId);
	System_linkDelete(gVencModuleContext.ipcBitsOutRTOSId);
	System_linkDelete(gVencModuleContext.ipcBitsInHLOSId);
	System_linkDelete(gVcapModuleContext.ipcFramesOutVpssToHostId);
	System_linkDelete(gVcapModuleContext.ipcFramesInHostId);
	System_linkDelete(gVdisModuleContext.ipcFramesOutHostId);
	System_linkDelete(gVdisModuleContext.ipcFramesInVpssFromHostId);
#endif
	/* Print the HWI, SWI and all tasks load */
	/* Reset the accumulated timer ticks */
	MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE);
#endif
If I disable ENABLE_FRAMES_EXPORT in the source file, the program work fine
the links added for ENABLE_FRAMES_EXPORT are "ipc frames out1", "ipc frames out1", "ipc frames out", "ipc frames in1"
the intent is to save YUV frames data at A8 side.
my question is :
1) why the program crash down?
2)  Is there any problem with my usecase?, because when the program work fine, the image of  encoded bits have the "offset " problem:
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/275328.aspx
Thanks!
  • The following issues with your usecase:
    1. You are not populating ipcFramesOutHost channelInfo so encLink will not know how many channels and the resolution info.
    2. The order of creating links is wrong. You are creating ipcOutVpss before creating ipcFramesOutVpss and ipcFramesInVpss.
    3. The notify configuration for ipcFrames link is wrong. If you enable noNotify for ipcFramesOut notifyNextLink should be FALSE not TRUE.
    Such a complicated data flow is not required. Use the below data flow to export frames to A8.
    Capure -> DEI -> Merge -> ipcFramesOutVpss ---(processLink) --> ipcFramesInHost
        ---(nextLink) --> ipcOutVpss --> ipcInVideo --> encLink.
  • Thanks for your reply!
    I made some modify to my usecase, the crash gone,but the program does not work fine,the log:
    3823.0704log.TXT
    It seems the encode link does not get any data. why? Is any problem with the program.
    the modified usecase:
    #define TILER_ENABLE    FALSE
    #else
    #endif
    	.isPopulated = 1,
    	.ivaMap[0] =
    		.EncNumCh  = 1,
    		.DecNumCh  = 0,
    	.ivaMap[1] =
    		.EncNumCh  = 2,
    		.DecNumCh  = 0,
    	.ivaMap[2] =
    		.EncNumCh  = 3,
    		.DecNumCh  = 0,
        int i_index;
        int j_index;
        //IpcFramesOutLinkHLOS_CreateParams  ipcFramesOutHostPrm;
        //IpcFramesInLinkRTOS_CreateParams   ipcFramesInVpssFromHostPrm;
    #endif
        UInt32 vipInstId;
        UInt32 i;
        //UInt32 j;
        //MULTICH_INIT_STRUCT(IpcFramesOutLinkHLOS_CreateParams ,ipcFramesOutHostPrm);
        //MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams  ,ipcFramesInVpssFromHostPrm);
    #endif
        TRACE_LOG("\n");
        System_linkControl(
        	NULL,
        	0,
        	TRUE
        TRACE_LOG("\n");
        	System_linkControl(
        		TRUE
        else
        	System_linkControl(
        		TRUE
        TRACE_LOG("\n");
        //gVdisModuleContext.ipcFramesOutHostId        = SYSTEM_HOST_LINK_ID_IPC_FRAMES_OUT_0;
        //gVdisModuleContext.ipcFramesInVpssFromHostId = SYSTEM_VPSS_LINK_ID_IPC_FRAMES_IN_0;
    #endif
        capturePrm.tilerEnable                = FALSE;
        int standard;
        #ifdef LPW_DEBUG
        #else
        #endif
        	else
        	if (vipInstId == 0)
        	else
        TRACE_LOG("\n");
        	else
        	if(0 == i_index)
        	else
        	else
    	#else
    	#endif
            ipcFramesOutVpssToHostPrm.baseCreateParams.noNotifyMode = FALSE;//TRUE;
    		ipcFramesOutVpssToHostPrm.baseCreateParams.numOutQue = 1;
    		ipcFramesOutVpssToHostPrm.baseCreateParams.numChPerOutQue[0] = 6;
    		ipcFramesOutVpssToHostPrm.baseCreateParams.inputFrameRate = 30;
    		ipcFramesOutVpssToHostPrm.baseCreateParams.outputFrameRate = 30;
            ipcFramesInHostPrm.baseCreateParams.noNotifyMode = FALSE;//TRUE;
            ipcFramesInHostPrm.baseCreateParams.notifyPrevLink = TRUE;//FALSE;
            ipcFramesInHostPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.ipcOutVpssId;//SYSTEM_LINK_ID_INVALID;
            ipcFramesInHostPrm.exportOnlyPhyAddr = FALSE;//TRUE;
    		ipcFramesInHostPrm.baseCreateParams.inputFrameRate = 30;
    		ipcFramesInHostPrm.baseCreateParams.outputFrameRate = 30;
    		#if 0
            ipcFramesOutHostPrm.baseCreateParams.notifyNextLink = FALSE;
    		#endif
            ipcOutVpssPrm.inQueParams.prevLinkId  = gVcapModuleContext.ipcFramesInHostId;//gVdisModuleContext.ipcFramesInVpssFromHostId;
        #else
    	#endif
    	#if 1
    	#endif
        TRACE_LOG("\n");
        	#if 0
        		i++, j++)
        	#endif
        TRACE_LOG("\n");
                                                   TRUE);
        TRACE_LOG("\n");
        TRACE_LOG("\n");
        TRACE_LOG("\n");
        	TRACE_LOG("\n");
        	TRACE_LOG("\n");
        TRACE_LOG("\n");
    	//ipcFramesOutHostPrm.inQueInfo = framesProducerLinkInfo.queInfo[0];
    	//System_linkCreate(gVdisModuleContext.ipcFramesOutHostId 	, &ipcFramesOutHostPrm	  , sizeof(ipcFramesOutHostPrm));
    	//System_linkCreate(gVdisModuleContext.ipcFramesInVpssFromHostId	   , &ipcFramesInVpssFromHostPrm	, sizeof(ipcFramesInVpssFromHostPrm));
    #endif
        TRACE_LOG("\n");
        TRACE_LOG("\n");
        TRACE_LOG("\n");
        TRACE_LOG("\n");
        TRACE_LOG("\n");
    	int i_index;
    #ifdef SUPPORT_OSD
    #endif
    	//System_linkDelete(gVdisModuleContext.ipcFramesOutHostId);
    	//System_linkDelete(gVdisModuleContext.ipcFramesInVpssFromHostId);
    #endif
    #endif
    Thanks!
  • As I mentioned you should use processLink. Pls go thru the linkAPI training part of RDK release to understand about ipcLinks.
    Your code is wrong.Code should be as below
            ipcFramesOutVpssToHostPrm.baseCreateParams.notifyProcessLink = TRUE;
            ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.ipcOutVpssId;
      ipcFramesOutVpssToHostPrm.baseCreateParams.outQueParams[0].processLink = gVcapModuleContext.ipcFramesInHostId;
            ipcFramesInHostPrm.baseCreateParams.notifyNextLink = FALSE;
            ipcOutVpssPrm.inQueParams.prevLinkId  = gVcapModuleContext.ipcFramesOutVpssToHostId;
        #else
     #endif
  • It works now!
