Hi, we use RDK4.0, DM8168, ourself board.
There has a warning which constantly printf in console. How to avoid it?
The warning is:
[m3vpss ] MSGQ:Warning!! Forcing waitAck = TRUE as waitAck = FALSE is not supported.Fix send cmd [0x4] to linkId [0x1
root@dm816x:/opt/dvr_rdk/ti816x/bin# ./dvr_rdk_demo_mcfw_api.out
Main Menu
1: VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
2: VCAP + VENC + VDIS - SD Encode ONLY
3: VCAP + VENC + VDEC + VDIS - Progressive HD Encode + Decode
4: VDEC + VDIS - SD/HD Decode ONLY
a: 960H DVR usecase
e: Exit
Enter Choice: 1
--------------- CHANNEL DETAILS-------------
Capture Channels => 2
Enc Channels => Primary 2, Secondary 0
Dec Channels => 2
Disp Channels => 4
0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
13: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
13: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
13: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
13: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
15: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
17: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
18: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
19: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
20: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
20: SYSTEM: Notify register to [DSP] line 0, event 15 ...
21: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
22: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
22: SYSTEM: IPC init DONE !!!
23: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
25: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
27: SYSTEM: ListElem Shared Addr = 0x40717880
28: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
30: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
31: SYSTEM: ListElem Shared Addr = 0x4074ca80
33: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
35: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
36: SYSTEM: ListElem Shared Addr = 0x40781c80
37: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
39: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
41: SYSTEM: ListElem Shared Addr = 0x407c4f80
42: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
44: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
46: SYSTEM: ListElem Shared Addr = 0x40808280
62: SYSTEM: System Common Init Done !!!
[host] HDMI Ctrl :Initializing
[host] HDMI Ctrl :Initialized
[host] HDMI Ctrl :Sink Connected
Enable file write (YES - y / NO - n) : y
File write ENABLED !!!
Enter file write path : /opt
Selected file write path [/opt]
[host] Partition Free Size for Path[/opt/VBITS_HDR_0.bin] = [0xB15C4D00]
[host] Max File size per channel:0x2C571340
********* Entered usecase 16CH Progressive <816x> Cap/Enc/Dec/Dis
4204: MCFW : CPU Revision [ES2.0] !!!
[m3vpss ] 31703: CAPTURE: Create in progress !!!
[m3vpss ] 31733: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!!
[m3vpss ] 32023: CAPTURE: 0: 0xb0ba9480, 1920 x 1080, 003f4800 B --> Extra Frames
[m3vpss ] 32023: CAPTURE: 1: 0xb0f9dc80, 1920 x 1080, 003f4800 B --> Extra Frames
[m3vpss ] 32023: CAPTURE: 2: 0xb1392480, 1920 x 1080, 003f4800 B --> Extra Frames
[m3vpss ] 32023: CAPTURE: 3: 0xb1786c80, 1920 x 1080, 003f4800 B --> Extra Frames
[m3vpss ] 32023: CAPTURE: 4: 0xb1b7b480, 1920 x 1080, 003f4800 B --> Extra Frames
[m3vpss ] 32024: CAPTURE: 5: 0xb1f6fc80, 1920 x 1080, 003f4800 B --> Extra Frames
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
[m3vpss ] CAPTURE::HEAPID:0 USED:328
[m3vpss ] CAPTURE::HEAPID:4 USED:66355200
[m3vpss ] 32025: CAPTURE: Create Done !!!
[m3vpss ] 32025: NSF: Create in progress !!!
[m3video] 32057: IPC_IN_M3 : Create in progress !!!
[m3video] 32057: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3video] 32057: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3vpss ] NSF::HEAPID:4 USED:6266880
[m3vpss ] 32055: NSF: Create Done !!!
[m3vpss ] 32056: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 32056: IPC_OUT_M3 : Create Done !!!
[m3video] 32059: IPC_IN_M3 : Create Done !!!
[m3video] 32059: ENCODE: Create in progress ... !!!
[m3video] 32094: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 4650: IPC_BITS_IN : Create in progress !!!
[host] 4650: IPC_BITS_IN : ListMPOpen start !!!
[host] 4650: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
4652: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
[host] 4653: IPC_BITS_IN : ListMPOpen done !!!
[host] 4654: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 4654: IPC_BITS_IN : Create Done !!!
Reducing bitsProducerLinkInfo.numCh to 1
[host] 4655: IPC_BITS_OUT : Create in progress !!!
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:0,Size:0xBDD800
[host]
******* RingBuf 0 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x48cdfe00 To Phy:0x9067ee00
[host]
###Bit buff of size from the SR # 1 : 12441600 / bufsize 2073600, maxQueueDepth 50
[host] ###Bit buff BasePtr: 48CDFE00 / PhyAddr 9067EE00
[host] 4655: IPC_BITS_OUT : Create Done !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:13888
[m3video] ENCLINK_H264:HEAPID:3 USED:10715136
[m3video] 32144: ENCODE: All CH Create ... DONE !!!
[m3video] ENCLINK:HEAPID:0 USED:14008
[m3video] ENCLINK:HEAPID:2 USED:6811008
[m3video] ENCLINK:HEAPID:3 USED:10715136
[m3video] 32146: ENCODE: Create ... DONE !!!
[m3video] 32146: IPC_BITS_OUT : Create in progress !!!
[m3video] 32148: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 32208: IPC_IN_M3 : Create in progress !!!
[m3video] 32154: IPC_BITS_IN : Create in progress !!!
[m3vpss ] 32208: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3video] 32154: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
[m3vpss ] 32208: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3video] 32154: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
[m3video] 32155: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[m3video] 32156: IPC_BITS_IN : Create Done !!!
[m3video] 32157: DECODE: Create in progress ... !!!
[m3vpss ] 32209: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3video] DECLINK_H264:HEAPID:0 USED:2368
[m3vpss ] 32210: IPC_IN_M3 : Create Done !!!
[m3video] DECLINK_H264:HEAPID:3 USED:8937472
[m3vpss ] 32211: SWMS: Create in progress !!!
[m3video] 32202: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [TILED ],target bitrate = 2000 Kbps ...
[m3video] 32204: DECODE: All CH Create ... DONE !!!
[m3video] DECLINK:HEAPID:0 USED:2488
[m3video] DECLINK:HEAPID:3 USED:8937472
[m3video] 32206: DECODE: Create ... DONE !!!
[m3video] 32207: IPC_OUT_M3 : Create in progress !!!
[m3video] 32207: IPC_OUT_M3 : Create Done !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
[m3vpss ] 32296: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 32296: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 32296: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 32296: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 32297: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 32297: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 32297: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 30
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 16384 / 32768 | TILED | 0, 0 | 1920 x 1080 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ]
Disable Channel: 32
Disable Channel: 33
Disable Channel: 34
Disable Channel: 35
Disable Channel: 36
Disable Channel: 37
Disable Channel: 38
Disable Channel: 39
Disable Channel: 40
Disable Channel: 41
Disable Channel: 42
Disable Channel: 43
Disable Channel: 44
Disable Channel: 45
Disable Channel: 46
[m3vpss ] SWMS:HEAPID:0 USED:224
[m3vpss ] SWMS:HEAPID:1 USED:47296
[m3vpss ] SWMS:HEAPID:4 USED:16588800
[m3vpss ] 32298: SWMS: Create Done !!!
[m3vpss ] 32298: DISPLAY: Create in progress !!!
[m3vpss ] 32299: DISPLAY: Create Done !!!
[m3vpss ] 32300: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 32300: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 32300: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 32300: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
Disable Channel: 47
[host] IpcBitsInLink_tskMain:Entered [m3vpss ]
[m3vpss ] 32304: DISPLAY: Start in progress !!!
[m3vpss ] 32361: DISPLAY: Start Done !!!
[m3vpss ] 32361: DISPLAY: HDDAC(BP0) : 35 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7811 / 0 ) !!!
[m3vpss ] 32362: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
[m3vpss ] 32362: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 1
[m3vpss ] 32362: SYSTEM : FREE SPACE : System Heap = 67392 B, Mbx = 10238 msgs)
[m3vpss ] 32362: SYSTEM : FREE SPACE : SR0 Heap = 8713728 B (8 MB)
[m3vpss ] 32362: SYSTEM : FREE SPACE : Frame Buffer = 165485440 B (157 MB)
[m3vpss ] 32362: SYSTEM : FREE SPACE : Bitstream Buffer = 191511040 B (182 MB)
[m3vpss ] TILER_STATS: CNT :8BIT
[m3vpss ] 32363: SWMS: Start in Progress !!!
[m3vpss ] 32363: SWMS: Start Done !!!
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
5: Audio Capture <TVP5158> & Encode <AAC-LC, G711> demo
6: Change Playback Channel <valid only if capture/playback is active>
7: Audio encode demo <File In/Out>
8: Audio decode demo <File In/Out>
i: Print detailed system information
s: Core Status: Active/In-active
f: Switch IVA Channel Map
e: Stop Demo
Enter Choice: [m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 8192
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
[m3vpss ] TILER_STATS: NUM FREE BUCKETS: 0
[m3vpss ] TILER_STATS: NUM USED BUCKETS: 1
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 122109952 (90 %)
[m3vpss ] TILER_STATS: TOTAL USED AREA: 12042240 (8 %)
[m3vpss ] TILER_STATS: TOTAL WASTE AREA: 0 (0 %)
[m3vpss ] TILER_STATS: MAX WIDTH RECT: 16384 x 7012
[m3vpss ] TILER_STATS: MAX HEIGHT RECT: 16384 x 7012
[m3vpss ] TILER_STATS: RES ALLOC COUNT [1080P] : 5
[m3vpss ] TILER_STATS: CNT :16BIT
[m3vpss ] TILER_STATS: CNT RESOLUTION: 32768 x 3072
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 3072
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 94642176 (94 %)
[m3vpss ] TILER_STATS: TOTAL USED AREA: 6021120 (5 %)
[m3vpss ] TILER_STATS: MAX WIDTH RECT: 32768 x 2484
[m3vpss ] TILER_STATS: MAX HEIGHT RECT: 32768 x 2484
[m3vpss ] 32365: SYSTEM : FREE SPACE : Tiler 8-bit = 122109952 B (116 MB) - TILER ON
[m3vpss ] 32365: SYSTEM : FREE SPACE : Tiler 16-bit = 94642176 B (90 MB) - TILER ON
[m3vpss ] 32657: CAPTURE: Start in progress !!!
[m3vpss ] 32757: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 32765: CAPTURE: Start Done !!!
[m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS faileddue to invalid cfg
[m3vpss ] Config:DisplayID[0],ChID[-1]
[m3vpss ] Config:DisplayID[1],ChID[-1]
[m3vpss ] Config:DisplayID[2],ChID[-1]
[m3vpss ] 32846: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
DEMO: HDMI TV/Monitor connected !!!
DEMO: TV Detected - HDMI interface !!!
DEMO: INFO : Resolution set to 1080P60 !!!
