Hi,all.
Is 4460 software and pin to pin compatible to 4430? If I want to use 4460 instead of 4430 in previous products, what aspect should I pay attention to?
Regards.
Sean
They are not 100% pin compatible. You need to go through TRM and data manual to understand the differences.
Hi, Mayank,
Is there any document to summarize the differences? It's time-consuming to go through TRM to find out the differences.
Regards.
Sean
Hi Sean,
There is TRM delta document available.
http://www.ti.com/litv/pdf/swpu278d
Thanks and regards,
Koichiro
Hi Sean,
Just an addition small warning as 4460 draw more current on MPU rail than 4430 in its max mode => You need to have a setup with two PMICs. I.e. as described here: http://nishanthmenon.blogspot.dk/2012/02/measuring-boot-voltage-on-pandaboard-es.html. If you today power your 4430 design only by TWL6030 you need to change this as well.
Last but not least some balls have changed default/reset state (high/low). In order for you to find those, I guess you need to compare the Data Manuals (DM), as I'm not sure the above referred delta document mention those?...
Best regards - Good luck with your update
Søren
