DM 8127 IPNC RDKv3.5.0 nfs boot problem
i have DM8127 IPNC RDKv3.5.0. i compile using
#make -s sysall
but nfs boot is not booting i posed my minicom console and my bootargs
setenv bootargs 'root=/dev/nfs console=ttyO0,115200n8 mem=80M rw vram=4M notifyk.vpssm3_sva=0xBFD00000 nfsroot=192.168.1.109:/home/sesha/Projects/ipnc_3.5.0/Source/ipnc_rdk/target/filesys,nolock,tcp ip=192.168.1.168 eth=00:0C:0C:02:39:1B cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk';saveenv
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
     device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=255.255.255.255,
     host=192.168.1.168, domain=, nis-domain=(none),
     bootserver=255.255.255.255, rootserver=192.168.1.109, rootpath=
PHY: 0:00 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: mounted
Freeing init memory: 192K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
error initializing inotify
Root filesystem already rw, not remounting
Caching udev devnodes
root: mount: mounting /dev/root on / failed: No such file or directory
NOT configuring network interfaces: / is an NFS mount
rm: cannot remove '/tmp': Device or resource busy
hwclock: can't open '/dev/misc/rtc': No such file or directory
 inside finish.sh
libubi: error!: cannot open "/dev/ubi_ctrl"
        error 2 (No such file or directory)
ubiattach: error!: cannot attach mtd5
libubi: error!: cannot get information about "/dev/ubi0"
ubimkvol: error!: error while probing "/dev/ubi0"
mount: mounting ubi0:ubifs_volume on /mnt/nand failed: No such device
ubidetach: error!: cannot remove ubi0
libmtd: error!: cannot get information about "/dev/mtd5"
ubiformat: error!: cannot get information about "/dev/mtd5"
ubiattach: error!: cannot attach mtd7
mount: mounting ubi0:ubifs_volume on /tmp/nand failed: No such device
libmtd: error!: cannot get information about "/dev/mtd7"
ubiformat: error!: cannot get information about "/dev/mtd7"
./init.sh: line 5: -f: not found
amixer: Control default open error: No such file or directory
syslink: disagrees about version of symbol module_layout
Could not open the mem file
/dev/mem opened.
Segmentation fault
Creat queue id:0
queue id:0
FileMngThread created
 [host]  ERROR: /dev/mem open failed !!!
 [host]  Setting DMM priority for [HDVICP0 ] to [1] ( 0x00000000 = 0x00000009 )
 [host]  Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
IPNC_3.00.00 (sesha@sesha-desktop) (gcc version 4.3.3 (Sourcery G++ Lit
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:32769
 [host]  Setting DMM priority for [ISS     ] to [0] ( 0x00000000 = 0x00800000 )
 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
 [m3video] Remote Debug Shared Memory @ 0xbff05020
 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
Segmentation fault
Segmentation fault
Segmentation fault
queue id:65538
CPU is TI812x
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
    IPNC BUILD VERSION: DM8127 IPNC RDK VERSION 03.50.00.08
./bin/ipnc_rdk_mcfw.out   VNF_QUALITY TRISTREAM TRIPLE_H264 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
Dev_pollOpen: Couldn't open /dev/syslinkipc_Osal: No such file or directory
    Please ensure that SysLink's device driver module (syslink.ko) is installed
OsalDrv driver open: /dev/syslinkipc_Osal: No such file or directory
OsalDrv driver close: /dev/syslinkipc_Osal: Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_MultiProc: No such file or directory
MultiProc driver close: : Bad file descriptor
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Dev_pollOpen: Couldn't open /dev/syslinkipc_SharedRegion: No such file or directory
SharedRegion driver open: : No such file or directory
SharedRegion driver close: : Bad file descriptor
SharedRegion driver open: : No such file or directoosa_kermod: disagrees about version of symbol module_layout
ry
Segmentation fault
insmod: error inserting './kermod/osa_kermod.ko': -1 Invalid module format
BusyBox v1.13.2 (2012-11-08 14:57:53 CST) multi-call binary
Usage: mknod [OPTIONS] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
Options:
    vpss: disagrees about version of symbol module_layout
-m    Create the special file using the specified mode (default a=rw)
TYPEs include:
    b:    Make a block device
    c or u:    Make a character device
    p:    Make a named pipe (MAJOR and MINOR are ignored)
Dev_pollOpen: Couldn't open /dev/syslinkipc_GateMP: No sucti81xxhdmi: disagrees about version of symbol module_layout
h file or directory
/dev/syslinkipc_GateMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_GateMP: No such file or directory
insmod: error inserting './kermod/vpss.ko': -1 Invalid module format
 [host] Application Start Completed
Dev_pollOpen: Couldn't open /dev/syslinkipc_MessageQ: No such file or directory
MessageQ driver close: : Bad file descriptor
 [host]  0: SYSTEM: System Common Init in progress !!!
 [host]  0: SYSTEM: IPC init in progress !!!
Dev_pollOpen: Couldn't open /dev/syslinkipc_Notify: No such file or directory
Notify driver close: /dev/syslinkipc_Notify: Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_ProcMgr: No such file or directory
ProcMgr driver open: /dev/syslinkipc_ProcMgr: No such file or directory
ProcMgr driver close: /dev/syslinkipc_ProcMgr: Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_HeapBufMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_HeapMemMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_ListMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_RingIO: No such file or directory
RingIO driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_RingIOShm: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_ClientNotifyMgr: No such file or directory
ClientNotifyMgr driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_FrameQBufMgr: No such file or directory
FrameQBufMgr driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_FrameQ: No such file or directory
FrameQ driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_Ipc: No such file or directory
Assertion at Line no: 344 in /home/sesha/Projects/ipnc_3.5.0/Source/ipnc_rdk/../ti_tools/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/usr/MultiProc.c: (MultiProc_module->refCount > 0) : failed
 [host] Invalid <Core name> specified!
 [host] Usage : ./fw_load.out <startup|shutdown> <Core name> [File path]
Supported core names:
 [host] Note: [File path] argument is only required when first argument is 'startup'
 [host]  1757: SYSTEM: CPU [DSP] is NOT available on this platform !!!
 [host]  1757: SYSTEM: CPU [VIDEO-M3] is NOT available on this platform !!!
 [host]  1757: SYSTEM: CPU [VPSS-M3] is NOT available on this platform !!!
 [host]  1757: SYSTEM: CPU [HOST] is NOT available on this platform !!!
 [host]  1757: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 ASSERT (system_ipc_msgq.c|System_ipcMsgQHeapCreate|38)
 inside autorun
sbull: disagrees about version of symbol module_layout
insmod: error inserting 'sbull.ko': -1 Invalid module format
mkdosfs 3.0.12 (29 Oct 2011)
g_file_storage: disagrees about version of symbol module_layout
insmod: error inserting 'g_file_storage.ko': -1 Invalid module format
amixer: Mixer attach default error: No such file or directory
queue id:0
ApproDrvInit: 7
CMEM Error: init: Failed to open /dev/cmem: 'No such file or directory'
Error: ApproDrvInit fail
SystemInit success
Schedule manager init success
Dmva Schedule manager init success
Error System server receive msg fail
ERROR:: Argument list too long
Recieved Quit event
Kill queue id:65538
Kill queue id:98307
Kill queue id:32769
Error: Maping size is zero!!
ApproDrvExit: 1
Error: DestroySem: Invalid Semaphore handler
Kill queue id:0
ApproDrvInit: 3
Creat queue id:131072
queue id:131
 RAJ M
