problem about load
We use RDK4.0, DM8168.  The flash can not be used, so I start with network port.
I update the Uboot and kernel, and it can mount the NFS at beginning, and then I run the login.sh.  The firmware is used as before, it's no problem.
The login.sh is as following:
cd /opt/dvr_rdk/ti816x
./init.sh
./load.sh
cd /opt/dvr_rdk/ti816x/bin
First I run the login.sh twice, and then 8168 is not working all long. If I restart the board, the console prints nothing.  The log is as following:
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dm816x ttyO2
Arago 2012.10 dm816x ttyO2
dm816x login: root
root@dm816x:~# ls
(project)login.sh    login.sh             vtfpga.ko.4.0(geng)
fpgaload             vtfpga.ko.4.0
root@dm816x:~# ./login.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
*** Kernel Base address validated ***
Kernel bootargs validated
amixer: Cannot find the given element from control default
 [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
 [m3video] Remote Debug Shared Memory @ 0xbf010820
 [m3vpss ] Remote Debug Shared Memory @ 0xbf021040
[   54.700000] SysLink version : 2.20.02.20
[   54.700000] SysLink module created on Date:May  3 2013 Time:18:24:47
[   54.710000] Trace enabled
[   54.710000] Trace SetFailureReason enabled
 Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
 Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
 Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
 Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
 *** TVP5158 probe : START ***
 TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
 TI DVR    : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
 Device found     : I2C (0xXX): 0x08 = 0x51
                    I2C (0xXX): 0x09 = 0x58
 Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
 ERROR  (osa_i2c.c|OSA_i2cTestMain|263): OSA_i2cOpen( instId = 2 )
 *** TVP5158 probe : END ***
/opt/dvr_rdk/ti816x
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_1024M_256M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
 [m3vpss ] ***** VPSS Firmware build time 13:48:55 Jul 11 2013  EDG gcc 3.0 mode
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 274909088
 [m3vpss ] notify_attach  rtnVal  0
 [m3vpss ] initProxyServer  rtnVal  0
 [m3vpss ]
 [m3vpss ]  *** UTILS: CPU KHz = 549818 Khz ***
 [m3vpss ]
 [m3vpss ]  35: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  35: SYSTEM: IPC init in progress !!!
 [m3vpss ]  35: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  49: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
Attached to slave procId 1.
 [m3vpss ]  1037: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  2037: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  3037: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_m3video_1024M_256M.xem3 on slave procId 1.
Started slave procId 1.
 [m3video] ***** VIDEO Firmware build time 13:49:54 Jul 11 2013  EDG gcc 3.0 mode
 [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 274909088
 [m3video]
 [m3video]  *** UTILS: CPU KHz = 549818 Khz ***
 [m3video]
 [m3video]  3627: SYSTEM  : System Common Init in progress !!!
 [m3video]  3627: SYSTEM: IPC init in progress !!!
 [m3video]  3627: SYSTEM: Attaching to [HOST] ...
 [m3video]  3630: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  4037: SYSTEM: Attaching to [DSP] ...
 [m3video]  4629: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  5037: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 0.
 [m3video]  5629: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  6037: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_1024M_256M.xe674 on slave procId 0.
Started slave procId 0.
 [c6xdsp ] ***** VIDEO Firmware build time 13:47:05 Jul 11 2013  EDG gcc 3.0 mode
 [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 800000000, <NEW> - 1000000000
 [c6xdsp ]
 [c6xdsp ]  *** UTILS: CPU KHz = 1000000 Khz ***
 [c6xdsp ]
 [c6xdsp ]  5: SYSTEM  : System Common Init in progress !!!
 [c6xdsp ]  5: SYSTEM: IPC init in progress !!!
 [c6xdsp ]  5: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  10: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [c6xdsp ]  12: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  6411: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  6413: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [c6xdsp ]  14: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3video]  6415: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  6415: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [c6xdsp ]  14: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
 [m3video]  6415: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
 [m3vpss ]  6415: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
 [c6xdsp ]  14: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [m3video]  6415: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  6415: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [c6xdsp ]  14: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [m3video]  6415: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  6415: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [c6xdsp ]  15: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3video]  6417: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3vpss ]  6417: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [c6xdsp ]  15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [m3video]  6417: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3vpss ]  6417: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [c6xdsp ]  15: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3video]  6417: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3vpss ]  6417: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [c6xdsp ]  15: SYSTEM: IPC init DONE !!!
 [m3video]  6417: SYSTEM: IPC init DONE !!!
 [m3vpss ]  6417: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  16: MEM: Shared Region 2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
 [c6xdsp ]  17: MEM: ERROR: SharedRegion_setEntry (2, 0x9ffa7b9c) FAILED !!!  (status=-1)
 [m3video]  6423: MEM: Shared Region 2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
 [m3vpss ]  6423: MEM: Shared Region 2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
 [m3video]  6423: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0c900000 (201 MB)
 [m3vpss ]  6423: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0c900000 (201 MB)
 [m3video]  6425: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  6425: SYSTEM  : System Common Init Done !!!
 [m3video]  6425: SYSTEM  : System Video Init in progress !!!
 [m3vpss ]  6425: SYSTEM  : System VPSS Init in progress !!!
 [m3video]  6425: SYSTEM  : System Video Init Done !!!
 [m3video]  6426: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [m3video]  6426: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [m3video]  6426: SYSTEM: ListElem Shared Addr = 0xbf273e00
 [m3video]  6428: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [m3video]  6428: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [m3video]  6428: SYSTEM: ListElem Shared Addr = 0xbf277300
 [m3video]  6434: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
 [m3vpss ] === HDVPSS Clocks are enabled ===
 [m3video]  6435: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
 [m3vpss ] === HDVPSS is fully functional ===
 [m3video]  6435: SYSTEM: ListElem Shared Addr = 0xbf27dd00
 [m3vpss ] === HDVPSS module is not in standby ===
 [m3video]  6437: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
 [m3vpss ] === I2C1 Clk is active ===
 [m3video]  6437: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
 [m3vpss ]  6434: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [m3video]  6438: SYSTEM: ListElem Shared Addr = 0xbf2a6a00
 [m3vpss ]  6434: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [m3video]  6440: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
 [m3vpss ]  6434: SYSTEM: ListElem Shared Addr = 0xbf27ab00
 [m3video]  6440: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
 [m3vpss ]  6437: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [m3video]  6440: SYSTEM: ListElem Shared Addr = 0xbf2cc200
 [m3vpss ]  6437: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [m3video]  6454: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  6437: SYSTEM: ListElem Shared Addr = 0xbf2a3780
 [m3video]  6454: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  6451: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
 [m3video]  6454: SYSTEM: ListElem Shared Addr = 0xbf317500
 [m3vpss ]  6451: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
 [m3video]  6456: SYSTEM: Creating ListMP [V[   64.700000] DMA: Module install successful, device major num = 251
IDEO-M3_IPC_OUT_[   64.710000] DRV: Module install successful
25] in region 0 [   64.710000] DRV: Module built on May  3 2013 18:25:47
 [m3vpss ]  6452: SYSTEM: ListElem Shared Addr = 0xbf2f1a00
 [m3video]  6457: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  6454: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
 [m3video]  6457: SYSTEM: ListElem Shared Addr = 0xbf35a500
 [m3vpss ]  6454: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
 [m3video]  6458: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3vpss ]  6454: SYSTEM: ListElem Shared Addr = 0xbf334d00
 [m3video]  6459: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3vpss ]  6457: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
 [m3video]  6459: HDVICP: Doing PRCM for IVAHD[1] ...
 [m3vpss ]  6457: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
 [m3video]  6459: HDVICP: PRCM for IVAHD[1] ... DONE.
 [m3vpss ]  6457: SYSTEM: ListElem Shared Addr = 0xbf378000
 [m3video]  6459: HDVICP: Doing PRCM for IVAHD[2] ...
 [m3vpss ]  6459: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
 [m3video]  6459: HDVICP: PRCM for IVAHD[2] ... DONE.
 [m3vpss ]  6459: SYSTEM  : FVID2 Init in progress !!!
 [m3video]  6459: SYSTEM  : Initializing Links !!!
 [m3video]  6460: SYSTEM  : FREE SPACE : System Heap      = 6279304 B, Mbx = 10240 msgs)
 [m3video]  6460: SYSTEM  : FREE SPACE : SR0 Heap         = 12987904 B (12 MB)
 [m3vpss ] TILER_STATS: CNT :8BIT
 [m3video]  6460: SYSTEM  : FREE SPACE : Frame Buffer     = 278658944 B (265 MB)
 [m3vpss ] TILER_STATS: CNT RESOLUTION:    16384 x 8192
 [m3video]  6460: SYSTEM  : FREE SPACE : Bitstream Buffer = 210763648 B (200 MB)
 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
 [m3video]  6460: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  1
 [m3video]  6462: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134152192 B (127 MB)  - TILER ON
 [m3vpss ] TILER_STATS: NUM USED BUCKETS:  0
 [m3video]  6462: SYSTEM  : FREE SPACE : Tiler 16-bit     = 100663296 B (96 MB)  - TILER ON
 [m3vpss ] TILER_STATS: TOTAL FREE AREA:   134152192 (99 %)
 [m3video]  6497: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ] TILER_STATS: TOTAL USED AREA:   0 (0 %)
 [m3vpss ] TILER_STATS: CNT :16BIT
 [m3vpss ] TILER_STATS: CNT RESOLUTION:    32768 x 3072
 [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 3072
 [m3vpss ] Received character 's'
 [m3video] Received character 's'
 [m3vpss ] TILER_STATS: TOTAL FREE AREA:   100663296 (100 %)
 [m3vpss ]  6530: SYSTEM  : FVID2 Init in progress DONE !!!
 [m3vpss ]  6530: SYSTEM  : Device Init in progress !!!
 [m3vpss ]  6532: SYSTEM  : Device Init in progress DONE !!!
 [m3vpss ]  6573: SYSTEM  : System VPSS Init Done !!!
 [m3vpss ]  6573: UTILS: DMA: HWI Create for INT63 !!!
 [m3vpss ]  6574: SYSTEM  : Initializing Links !!!
 [m3vpss ]  6574: SYSTEM  : FREE SPACE : System Heap      = 74056 B, Mbx = 10240 msgs)
 [m3vpss ]  6574: SYSTEM  : FREE SPACE : SR0 Heap         = 12987904 B (12 MB)
 [m3vpss ]  6574: SYSTEM  : FREE SPACE : Frame Buffer     = 274348928 B (261 MB)
 [m3vpss ]  6574: SYSTEM  : FREE SPACE : Bitstream Buffer = 210763648 B (200 MB)
 [m3vpss ]  6575: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134152192 B (127 MB)  - TILER ON
 [m3vpss ]  6576: SYSTEM  : FREE SPACE : Tiler 16-bit     = 100663296 B (96 MB)  - TILER ON
 [m3vpss ]  6692: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  6692: SYSTEM  : Set Static L3 pressure for HDVPSS as High
 [c6xdsp ]  1023: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0c900000 (201 MB)
 [c6xdsp ]  1024: SYSTEM  : System Common Init Done !!!
 [c6xdsp ]  1011: SYSTEM  : System DSP Init in progress !!!
 [c6xdsp ]  1011: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
 [c6xdsp ]  1026: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
 [c6xdsp ]  1026: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
 [c6xdsp ]  1026: SYSTEM: ListElem Shared Addr = 0xbf39d800
 [c6xdsp ]  1027: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
 [c6xdsp ]  1027: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
 [c6xdsp ]  1027: SYSTEM: ListElem Shared Addr = 0xbf3c3000
 [c6xdsp ]  1028: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
 [c6xdsp ]  1028: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
 [c6xdsp ]  1028: SYSTEM: ListElem Shared Addr = 0xbf3e8800
 [c6xdsp ]  1028: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [c6xdsp ]  1028: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [c6xdsp ]  1028: SYSTEM: ListElem Shared Addr = 0xbf40e000
 [c6xdsp ]  1029: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [c6xdsp ]  1029: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [c6xdsp ]  1029: SYSTEM: ListElem Shared Addr = 0xbf42bb00
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  1017: SYSTEM  : Initializing Links !!!
 [c6xdsp ]  1029: SYSTEM  : FREE SPACE : System Heap      = 10391168 B, Mbx = 10240 msgs)
 [c6xdsp ] Received character 's'
/opt/dvr_rdk/ti816x
 [c6xdsp ]  1025: SYSTEM  : Initializing Links ... DONE !!!
 [c6xdsp ]  ETH_OFFLOAD: Init !!!
 [c6xdsp ]  1026: SYSTEM  : System DSP Init Done !!!
[   65.470000] [module] vpss probe done.
[   65.500000] FB: no memory to allocate
[   65.500000] ti81xxfb ti81xxfb: failed to allocate framebuffer
[   65.510000] ti81xxfb ti81xxfb: failed to allocate fb memory.
[   65.510000] ti81xxfb: probe of ti81xxfb failed with error -12
[   65.550000] HDMI W1 rev 2.0
[   65.550000] HDMI CEC Spec version 1.2
 ORG 0x46c00524: 0
 NEW 0x46c00524: 2
root@dm816x:~# [  177.790000] PHY: 0:00 - Link is Down
[  178.790000] PHY: 0:00 - Link is Up - 100/Full
[  188.790000] PHY: 0:00 - Link is Down
[  189.790000] PHY: 0:00 - Link is Up - 100/Full
[  191.790000] PHY: 0:00 - Link is Down
[  199.790000] PHY: 0:00 - Link is Up - 100/Full
[  203.790000] PHY: 0:00 - Link is Down
[  206.790000] PHY: 0:00 - Link is Up - 100/Full
root@dm816x:~# . ./login.sh
[  541.270000] Unable to handle kernel paging request at virtual address d337d030
[  541.280000] pgd = cd81c000
[  541.280000] [d337d030] *pgd=8cf3a011, *pte=00000000, *ppte=00000000
[  541.290000] Internal error: Oops: 807 [#1]
[  541.290000] last sysfs file: /sys/bus/platform/drivers/TI81XX_HDMI/uevent
[  541.290000] Modules linked in: ti81xxhdmi ti81xxfb vpss osa_kermod syslink(-)
[  541.290000] CPU: 0    Not tainted  (2.6.37 #3)
[  541.290000] PC is at HeapMemMP_delete+0x16c/0x1bc [syslink]
[  541.290000] LR is at Memory_free+0x78/0x8c [syslink]
[  541.290000] pc : [<bf030e1c>]    lr : [<bf01c5b0>]    psr: 80000013
[  541.290000] sp : cd9dbea0  ip : cd9dbe78  fp : cd9dbec4
[  541.290000] r10: bf07e634  r9 : cd9da000  r8 : 00000000
[  541.290000] r7 : 00000000  r6 : d337a000  r5 : d337d030  r4 : d337d000
[  541.290000] r3 : 00000000  r2 : 00000001  r1 : 00060000  r0 : bf064525
[  541.290000] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  541.290000] Control: 10c5387d  Table: 8d81c019  DAC: 00000015
[  541.290000] Process rmmod (pid: 591, stack limit = 0xcd9da2e8)
[  541.290000] Stack: (0xcd9dbea0 to 0xcd9dc000)
[  541.290000] bea0: 00000003 d337d000 bf07e634 bf07e63c c0049568 00000000 cd9dbee4 cd9dbec8
[  541.290000] bec0: bf031020 bf030cbc bf0ae58c bf0ae808 bedbcb20 00000081 cd9dbefc cd9dbee8
[  541.290000] bee0: bf011ee4 bf030fb8 00000000 bf0ae408 cd9dbf1c cd9dbf00 bf030310 bf011da8
[  541.290000] bf00: c003f298 c0347cdc bf0ae408 00000000 cd9dbf34 cd9dbf20 bf052d84 bf0302d4
[  541.290000] bf20: bf052d70 bf0ae2e0 cd9dbfa4 cd9dbf38 c009a0b0 bf052d7c c00ba8fc 6c737973
[  541.290000] bf40: 006b6e69 00000000 00000000 cd8a4c34 00000000 400ff000 cd8a4c00 c0049568
[  541.290000] bf60: cd9da000 00000000 cd9dbf84 cd9dbf78 c008c2c4 001b9b60 bf0ae2e0 00000880
[  541.290000] bf80: cd9dbf84 00000000 00013008 00011ef0 00000880 bedbcb20 00000000 cd9dbfa8
[  541.290000] bfa0: c00493c0 c0099f08 00011ef0 00000880 bedbcb20 00000880 bedbcb14 00000000
[  541.290000] bfc0: 00011ef0 00000880 bedbcb20 00000081 00000880 00000000 00011f00 bedbcb5c
[  541.290000] bfe0: 00000000 bedbcb20 00008f54 402ad56c 60000010 bedbcb20 00000000 00000000
[  541.290000] Backtrace:
[  541.290000] [<bf030cb0>] (HeapMemMP_delete+0x0/0x1bc [syslink]) from [<bf031020>] (HeapMemMP_destroy+0x74/0x120 [syslink])
[  541.290000] [<bf030fac>] (HeapMemMP_destroy+0x0/0x120 [syslink]) from [<bf011ee4>] (Platform_destroy+0x148/0x2e0 [syslink])
[  541.290000]  r7:00000081 r6:bedbcb20 r5:bf0ae808 r4:bf0ae58c
[  541.290000] [<bf011d9c>] (Platform_destroy+0x0/0x2e0 [syslink]) from [<bf030310>] (Ipc_destroy+0x48/0xc0 [syslink])
[  541.290000]  r4:bf0ae408 r3:00000000
[  541.290000] [<bf0302c8>] (Ipc_destroy+0x0/0xc0 [syslink]) from [<bf052d84>] (KnlUtilsDrv_finalizeModule+0x14/0xb8 [syslink])
[  541.290000]  r5:00000000 r4:bf0ae408
[  541.290000] [<bf052d70>] (KnlUtilsDrv_finalizeModule+0x0/0xb8 [syslink]) from [<c009a0b0>] (sys_delete_module+0x1b4/0x228)
[  541.290000]  r4:bf0ae2e0 r3:bf052d70
[  541.290000] [<c0099efc>] (sys_delete_module+0x0/0x228) from [<c00493c0>] (ret_fast_syscall+0x0/0x30)
[  541.290000]  r6:bedbcb20 r5:00000880 r4:00011ef0
[  541.290000] Code: e1a01006 e3a02018 ebffadc7 e3a03000 (e5853000)
[  541.570000] ---[ end trace bdca7a85c346e393 ]---
./init.sh: line 34:   591 Segmentation fault      rmmod ./kermod/syslink.ko 2> /dev/null
insmod: error inserting './kermod/syslink.ko': -1 File exists
I change to another board, and run the login.sh once, and then 8168 is also not working.  If I restart the board, the console prints nothing.  The log is as following:
NAND read: device 0 offset 0x580000, size 0x440000
 4456448 bytes read: OK
## Booting kernel from Legacy Image at 80009000 ...
   Image Name:   Linux-2.6.37
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2267276 Bytes = 2.2 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Linux version 2.6.37 (root@localhost.localdomain) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #2 Mon Jul 1 11:37:05 CST 2013
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: ti8168evm
[    0.000000] vram size = 20971520 at 0x0
[    0.000000] ti81xx_reserve: ### Reserved DDR region @8ff00000
[    0.000000] reserved size = 20971520 at 0x0
[    0.000000] FB: Reserving 20971520 bytes SDRAM for VRAM
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] OMAP chip is TI8168 2.0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 59648
[    0.000000] Kernel command line: console=ttyO2,115200n8 root=/dev/nfs rw nfsroot=10.1.12.222:/opt/DVRRDK_04.00.00.03/target/rfs_816x ip=dhcp mem=256M vram=20M notifyk.vpssm3_sva=0xBEE00000 ddr_mem=1024M atr
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 234MB 1MB = 235MB total
[    0.000000] Memory: 233464k/233464k available, 28680k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
[    0.000000]     vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0008000 - 0xc003d000   ( 212 kB)
[    0.000000]       .text : 0xc003d000 - 0xc0450000   (4172 kB)
[    0.000000]       .data : 0xc0450000 - 0xc048c7c0   ( 242 kB)
[    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:375
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] GPMC revision 6.0
[    0.000000] Trying to install interrupt handler for IRQ368
[    0.000000] Trying to install interrupt handler for IRQ369
[    0.000000] Trying to install interrupt handler for IRQ370
[    0.000000] Trying to install interrupt handler for IRQ371
[    0.000000] Trying to install interrupt handler for IRQ372
[    0.000000] Trying to install interrupt handler for IRQ373
[    0.000000] Trying to install interrupt handler for IRQ374
[    0.000000] Trying to install type control for IRQ375
[    0.000000] Trying to set irq flags for IRQ375
[    0.000000] OMAP clockevent source: GPTIMER1 at 27000000 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.010000] Calibrating delay loop... 1199.30 BogoMIPS (lpj=5996544)
[    0.240000] pid_max: default: 32768 minimum: 301
[    0.240000] Security Framework initialized
[    0.240000] Mount-cache hash table entries: 512
[    0.240000] CPU: Testing write buffer coherency: ok
[    0.240000] devtmpfs: initialized
[    0.240000] TI81XX: Map 0x8ff00000 to 0xfe500000 for dram barrier
[    0.240000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[    0.240000] omap_voltage_early_init: voltage driver support not added
[    0.240000] regulator: core version 0.5
[    0.240000] regulator: dummy:
[    0.240000] NET: Registered protocol family 16
[    0.240000] omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
[    0.240000] omap_voltage_add_dev: VDD specified does not exist!
[    0.240000] OMAP GPIO hardware version 0.1
[    0.240000] omap_mux_init: Add partition: #1: core, flags: 0
[    0.240000] registered ti816x_gpio_vr device
[    0.240000] registered ti816x_sr device
[    0.240000] Cannot clk_get ck_32
[    0.240000] registered ti81xx_vpss device
[    0.240000] registered ti81xx_vidout device
[    0.240000] registered ti81xx on-chip HDMI device
[    0.240000] registered ti81xx_fb device
[    0.240000] registered ti81xx_vin device
[    0.250000] bio: create slab <bio-0> at 0
[    0.250000] regulator: VFB: 800 <--> 1025 mV at 800 mV
[    0.250000] SCSI subsystem initialized
[    0.250000] Advanced Linux Sound Architecture Driver Version 1.0.23.
[    0.250000] Switching to clocksource gp timer
[    0.250000] NET: Registered protocol family 2
[    0.250000] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.250000] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.250000] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.250000] TCP: Hash tables configured (established 8192 bind 8192)
[    0.250000] TCP reno registered
[    0.250000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.250000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.250000] NET: Registered protocol family 1
[    0.250000] RPC: Registered udp transport module.
[    0.250000] RPC: Registered tcp transport module.
[    0.250000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.250000] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.250000] PMU: registered new PMU device of type 0
[    0.250000] omap-iommu omap-iommu.0: ducati registered
[    0.250000] omap-iommu omap-iommu.1: sys registered
[    0.310000] JFFS2 version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[    0.310000] msgmni has been set to 455
[    0.310000] io scheduler noop registered
[    0.310000] io scheduler deadline registered
[    0.310000] io scheduler cfq registered (default)
[    0.310000] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.310000] omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
[    0.310000] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.310000] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.870000] console [ttyO2] enabled
[    0.880000] brd: module loaded
[    0.890000] loop: module loaded
[    0.890000] ahci probe: devid name is ahci
[    0.890000] ahci CAP register dump =0x6726ff81
[    0.900000] Modified ahci CAP register dump =0x6f26ff81
[    0.900000] ahci ahci.0: forcing PORTS_IMPL to 0x3
[    0.910000] ahci: SSS flag set, parallel bus scan disabled
[    0.910000] ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
[    0.920000] ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc
[    0.930000] scsi0 : ahci_platform
[    0.940000] scsi1 : ahci_platform
[    0.940000] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
[    0.950000] ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
[    0.960000] omap2-nand driver initializing
[    0.960000] ONFI param page 0 valid
[    0.960000] ONFI flash detected
[    0.970000] NAND device: Maf ID: 0x2c, Chip ID: 0xca (Micron, NAND 256MiB 3,3V 16-bit)
[    0.970000]  erasesize: 0x20000, writesize: 2048, oobsize: 64
[    0.980000] omap2-nand: detected x16 NAND flash
[    0.990000] Creating 6 MTD partitions on "omap2-nand.0":
[    0.990000] 0x000000000000-0x000000260000 : "U-Boot"
[    1.000000] 0x000000260000-0x000000280000 : "U-Boot Env"
[    1.010000] 0x000000280000-0x000000580000 : "U-Boot Logo"
[    1.010000] 0x000000580000-0x0000009c0000 : "Kernel"
[    1.020000] 0x0000009c0000-0x00000d1e0000 : "File System"
[    1.110000] 0x00000d1e0000-0x000010000000 : "Reserved"
[    1.180000] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    1.180000] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    1.190000] davinci_mdio.0: probed
[    1.190000] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[    1.200000] mice: PS/2 mouse device common for all mice
[    1.210000] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[    1.210000] i2c /dev entries driver
[    1.220000] Linux video capture interface: v2.00
[    1.220000] OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[    1.240000] notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbee00000
[    1.250000] asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
[    1.250000] ALSA device list:
[    1.250000]   #0: TI81XX SOUND1
[    1.260000] TCP cubic registered
[    1.260000] NET: Registered protocol family 17
[    1.270000] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    1.270000] omap_voltage_late_init: Voltage driver support not added
[    1.280000] Power Management for TI81XX.
[    1.290000] smartreflex smartreflex: Driver initialized
[    1.290000] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[    1.420000] ata1: SATA link down (SStatus 0 SControl 300)
[    1.770000] ata2: SATA link down (SStatus 0 SControl 300)
[    1.810000] davinci_mdio davinci_mdio.0: resetting idled controller
[    1.810000] net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, id=4061e4)
[    2.830000] Sending DHCP requests .
[    3.810000] PHY: 0:00 - Link is Up - 100/Full
[    5.300000] ., OK
[    5.320000] IP-Config: Got DHCP answer from 10.1.3.162, my address is 10.1.12.105
[    5.320000] IP-Config: Complete:
[    5.330000]      device=eth0, addr=10.1.12.105, mask=255.255.255.0, gw=10.1.12.254,
[    5.330000]      host=10.1.12.105, domain=, nis-domain=(none),
[    5.340000]      bootserver=10.1.3.162, rootserver=10.1.12.222, rootpath=
[    6.110000] VFS: Mounted root (nfs filesystem) on device 0:13.
[    6.120000] devtmpfs: mounted
[    6.120000] Freeing init memory: 212K
INIT: version 2.88 booting
 Mounting /dev/shm              :  Mounting /dev/pts          :  Mounting other filesystems : mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
 Mounting /dev/sda1              : mount: mounting /dev/sda1 on /media/sda1 failed: No such file or directory
 Mounting /dev/sda2              : mkdir: can't create directory '/media': File exists
mkdir: can't create directory '/media/sda2': File exists
mount: mounting /dev/sda2 on /media/sda2 failed: No such file or directory
Sync command ...Error opening /dev/fb0: No such file or directory
Starting udev
[   10.230000] udev[69]: starting version 164
udevd-work[101]: error changing net interface name eth0 to eth3: Device or resource busy
Starting Bootlog daemon: bootlogd.
Applying sync command
 _____                    _____           _         _
              |___|                    |___|
dm816x login: root
root@dm816x:~# ls
[ 2205.400000] syslink: disagrees about version of symbol set_user_nice
[ 2205.410000] syslink: Unknown symbol set_user_nice (err -22)
[ 2205.410000] syslink: disagrees about version of symbol clk_set_rate
[ 2205.420000] syslink: Unknown symbol clk_set_rate (err -22)
[ 2205.420000] syslink: disagrees about version of symbol wake_up_process
[ 2205.430000] syslink: Unknown symbol wake_up_process (err -22)
[ 2205.440000] syslink: disagrees about version of symbol cdev_add
[ 2205.440000] syslink: Unknown symbol cdev_add (err -22)
[ 2205.450000] syslink: disagrees about version of symbol clk_get_rate
[ 2205.460000] syslink: Unknown symbol clk_get_rate (err -22)
[ 2205.470000] syslink: disagrees about version of symbol filp_close
[ 2205.470000] syslink: Unknown symbol filp_close (err -22)
[ 2205.480000] syslink: disagrees about version of symbol clk_disable
[ 2205.480000] syslink: Unknown symbol clk_disable (err -22)
[ 2205.490000] syslink: disagrees about version of symbol clk_enable
[ 2205.500000] syslink: Unknown symbol clk_enable (err -22)
[ 2205.500000] syslink: disagrees about version of symbol cdev_init
[ 2205.510000] syslink: Unknown symbol cdev_init (err -22)
[ 2205.510000] syslink: disagrees about version of symbol cdev_del
[ 2205.520000] syslink: Unknown symbol cdev_del (err -22)
insmod: error inserting './kermod/syslink.ko': -1 Invalid parameters
/opt/dvr_rdk/ti816x
Dev_pollOpen: Couldn't open /dev/syslinkipc_Osal: No such file or directory
    Please ensure that SysLink's device driver module (syslink.ko) is installed
OsalDrv driver open: /dev/syslinkipc_Osal: No such file or directory
OsalDrv driver close: /dev/syslinkipc_Osal: Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_MultiProc: No such file or directory
MultiProc driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_SharedRegion: No such file or directory
SharedRegion driver open: : No such file or directory
SharedRegion driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_GateMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_MessageQ: No such file or directory
MessageQ driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_Notify: No such file or directory
Notify driver close: /dev/syslinkipc_Notify: Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_ProcMgr: No such file or directory
ProcMgr driver open: /dev/syslinkipc_ProcMgr: No such file or directory
ProcMgr driver close: /dev/syslinkipc_ProcMgr: Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_HeapBufMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_HeapMemMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_ListMP: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_RingIO: No such file or directory
RingIO driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_RingIOShm: No such file or directory
Dev_pollOpen: Couldn't open /dev/syslinkipc_ClientNotifyMgr: No such file or directory
ClientNotifyMgr driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_FrameQBufMgr: No such file or directory
FrameQBufMgr driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_FrameQ: No such file or directory
FrameQ driver close: : Bad file descriptor
Dev_pollOpen: Couldn't open /dev/syslinkipc_Ipc: No such file or directory
Assertion at Line no: 344 in /datalocal/user/vivek/GA4.0/DVRRDK_04.00.00.03/tmpti81xx/dvr_rdk/../ti_tools/syslink/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/usr/MultiProc.c: (MultiProc_module->refCount > 0) : failed
Invalid <Core name> specified!
Usage : ./fw_load.out <startup|shutdown> <Core name> [File path]
Supported core names:
Note: [File path] argument is only required when first argument is 'startup'
[ 2212.010000] osa_kermod: disagrees about version of symbol cdev_add
[ 2212.010000] osa_kermod: Unknown symbol cdev_add (err -22)
[ 2212.020000] osa_kermod: disagrees about version of symbol cdev_init
[ 2212.020000] osa_kermod: Unknown symbol cdev_init (err -22)
[ 2212.030000] osa_kermod: disagrees about version of symbol cdev_del
[ 2212.040000] osa_kermod: Unknown symbol cdev_del (err -22)
insmod: error inserting '../kermod/osa_kermod.ko': -1 Invalid parameters
BusyBox v1.19.4 (2012-12-16 13:54:20 CST) multi-call binary.
Usage: mknod [-m MODE] NAME TYPE MAJOR MINOR
What's the problem?  We need your help.
Thanks.
  • log1.txt shows you are running login.sh twice which is wrong. Login .sh executes init.sh which does rmmod of syslink. Syslink can be rmmmod only after unload.sh is executed.
    log2.txt shows you have not built syslink using the correct kernel . It looks like you have updated uImage but your filesystem still contains syslink etc built with older kernel and tooolchain.
    But both these crashes will not cause your board to stop working. If you don't get uboot prompt when you power cycle the board probably your nand is corrupted.The crash has nothing to do with your board not working.Try flashing the correct uboot using CCS+JTAG and the nand flash writer utility to recover the board.
  • hello,Michelle.
    I have the same error as you showed in log2.txt . Do you  "flashing the correct uboot using CCS+JTAG and the nand flash writer utility to recover the board" ? Or solved the problem in other ways?
    I have set the env right,and init.sh runs well ,but when it comes to load.sh ,everytime it shows the same error:
    Thanks & Regards
  • You have either not done insmod syslink.ko or your syslink insmod failed due to mismatch between kernel version and syslink module version.Check dmesg trace to see if you get any errors whielk doing insmod of syslink.
    Do make sys_all, flash the uImage and copy all the rebuilt binaries to filesystem
  • hello,Badri.
    In other PC i flash uboot and uImage to nand, the filesystem is in /dvrrdk/DVRRDK_04.01.00.02/target/rfs_816x ,and when executing init.sh and load.sh , there's no Syslink module error. Now in my PC I've installed the same RDK , I have make sys_all , uboot and  uImage has not been updated, that means there's nothing to do with uboot and uImage, but rfs_816x has been updated. So I don't know in which case the  Kernel version will mismatch syslink module version ?  how can I update both kernel and syslink module?
  • You are probably mounting the wrong rootfs .Check the syslink build date and time and your kernel build date and time and confirm they are same as working version.
  •  hello,Badri.Thanks for your help !  maybe I have found the problems.
           The reasons may be presented as follows:
          1 . check the Rules.make<../dvrrdk/DVRRDK_04.01.00.02/dvr_rdk/Rules.make>,
             make sure:    ifeq ($(DVR_RDK_BOARD_TYPE ), )
                                          DVR_RDK_BOARD_TYPE := DM816X_TI_EVM
                                   endif
                                  DM816X_TI_EXM   is  my board_type
             and reset  dvr_rdk_BASE :    ifeq ($(OS),Linux)
        dvr_rdk_BASE     := /home/erik/dvrrdk/DVRRDK_04.01.00.02
        TI_SW_ROOT       := $(dvr_rdk_BASE)/ti_tools
                                                           endif
                               dvr_rdk_BASE  is the  file path
           2.  make and install the  rdk
                                do  as DM81xx_DVR_RDK_Install_Guide.pdf
                                 do not forget any steps
    Hope it helpful for others , and wish your success~
