faxlib, duration of v21 preamble
hi,
i'm using fiu and fm, but i wonder how the duration of v21 preamble pcm is determined ? i found the amount of V21 preamble IFP send to fiu doesn't correspond to preamble pcm duration generated by fm.
send following IFP to fiu
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 02 06 c0 01 80 00 00 ff 00 00
00 03 06 c0 01 80 00 00 c8 00 00
00 04 06 c0 01 80 00 00 c1 00 00
00 05 06 c0 01 80 00 00 00 00 00
00 06 06 c0 01 80 00 00 46 00 00
00 07 06 c0 01 80 00 00 15 00 00
00 08 06 c0 01 80 00 00 00 00 00
00 09 03 c0 01 20 00 00
00 0a 03 c0 01 10 00 00
has the same output pcm by fm with following IFPs
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
00 01 01 06 00 00
it seems that the amount of v21 preamble IFP("00 01 01 06 00 00") doesn't decide the duration of  v21 preamble pcm generated by fm.
  • V.21 preamble IFP are repeat packets, that are repeated every 70 ms. The Fax Modem (FM) will start playing the preamble on the PCM side after receiving the first V.21 preamble indication packet and will keep playing until it receives the V.21 data packet.
     As per the T.30 standard the preamble should be minimum 850 ms. So if the FIU receives the V.21 data T.38 packet before 850ms of receiving the first V.21 preamble indication packet, the Fax Modem(FM) will ensure that the preamble is played out for minimum 850 ms before starting V.21 data. In that case the duration for the time V.21 preamble indication is received will not be same as  the time you generate the V.21 preamble on the PCM side.
    Yogesh
  • hi,Yogesh
    i send 13 V.21 preamble IFP, that is 13x70=910ms, but the pcm generate by FM, it seems that the preamble is more than 5seconds long, why ? is there any setting ?
    thanks!
    following are IFP send and recieve, attachment is the pcm, 16bit little endian6825.s.zip
    first column is time in ms
    R:recieve
    S:send
    [ 0] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 70] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 80] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 140] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 150] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 210] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 220] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 280] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 290] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 350] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 360] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 420] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 430] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 490] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 500] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 560] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 570] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 630] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 640] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 700] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 710] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 770] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 780] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 840] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 850] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 910] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 920] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 980] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 990] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1050] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1060] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1120] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1130] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1190] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1200] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1260] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1270] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1330] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1340] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1400] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1410] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1470] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1480] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1540] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1550] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1610] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1620] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1680] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1690] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1750] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1760] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1820] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1830] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1890] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1900] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 1960] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 1970] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2030] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2040] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2100] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2110] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2170] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2180] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2240] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2250] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2310] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2320] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2380] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2390] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2450] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2460] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2520] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2530] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2590] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2600] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2660] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2670] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2730] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2740] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2800] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2810] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2870] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2880] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 2940] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 2950] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3010] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3020] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3080] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3090] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3150] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3160] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3220] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3230] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3290] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3300] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3360] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3370] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3430] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3440] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3500] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3510] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3570] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3580] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3640] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3650] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3710] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3720] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3780] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3790] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3850] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3860] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3920] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 3930] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 3990] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4000] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4060] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4070] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4130] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4140] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4200] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4210] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4270] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4280] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4340] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4350] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4410] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4420] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4480] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4490] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4550] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4560] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4620] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4630] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4690] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4700] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4760] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4770] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4830] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4840] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4900] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4910] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 4970] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 4980] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5040] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5050] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5110] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5120] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5180] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5190] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5250] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5260] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5320] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5330] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5390] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5400] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5460] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5470] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5530] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5540] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5600] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5610] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5670] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5680] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5740] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5750] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5810] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5820] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5880] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5890] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 5950] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 5960] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6020] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6030] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6090] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6100] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6160] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6170] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6230] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6240] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6300] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6310] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6370] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6380] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6440] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6450] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6510] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6520] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6580] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6590] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6650] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6660] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6720] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6730] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6790] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6800] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6860] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6870] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 6930] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 6940] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7000] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7010] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7070] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7080] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7140] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7150] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7210] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7220] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7280] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7290] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7350] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7360] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7420] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7430] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7490] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7500] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7560] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7570] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7630] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7640] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7700] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7710] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7770] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7780] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7840] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7850] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7910] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7920] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 7980] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 7990] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8050] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8060] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8120] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8130] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8190] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8200] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8260] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8270] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8330] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8340] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8400] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8410] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8470] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8480] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8540] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8550] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8610] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8620] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8680] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8690] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8750] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8760] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8820] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8830] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8890] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8900] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 8960] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 8970] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9030] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9040] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9100] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9110] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9170] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9180] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9240] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9250] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9310] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9320] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9380] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9390] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9450] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9460] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9520] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9530] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9590] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9600] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9660] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9670] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9730] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9740] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9800] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9810] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9870] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9880] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 9940] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 9950] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10010] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10020] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10080] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10090] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10150] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10160] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10220] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10230] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10290] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10300] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10360] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10370] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10430] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10440] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10500] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10510] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10570] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10580] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10640] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10650] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10710] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10720] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10780] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10790] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10850] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10860] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10920] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 10930] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 10990] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11000] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11060] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11070] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11130] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11140] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11200] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11210] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11270] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11280] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11340] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11350] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11410] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11420] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11480] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11490] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11550] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11560] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11620] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11630] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11690] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11700] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11760] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11770] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11830] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11840] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11900] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11910] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 11970] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 11980] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12040] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12050] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12110] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12120] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12180] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12190] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12250] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12260] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12320] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12330] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12390] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12400] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12460] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12470] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12530] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12540] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12600] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12610] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12670] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12680] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12740] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12750] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12810] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12820] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12880] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12890] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 12950] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 12960] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13020] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13030] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13090] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13100] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13160] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13170] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13230] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13240] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13300] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13310] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13370] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13380] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13440] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13450] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13510] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13520] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13580] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13590] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13650] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13660] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13720] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13730] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13790] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13800] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13860] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13870] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 13930] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 13940] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14000] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14010] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14070] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14080] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14140] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14150] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14210] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14220] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14280] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14290] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14350] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14360] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14420] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14430] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14490] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14500] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14560] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14570] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14630] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14640] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14700] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14710] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14770] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14780] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14840] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14850] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14910] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14920] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 14980] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 14990] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 15050] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 15060] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 15120] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 15130] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 15190] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 15200] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 15260] R IFP [ 0: 6] 00 00 01 00 00 00
    [ 15270] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 15280] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15350] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15420] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15490] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15560] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15630] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15700] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15770] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15840] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15910] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 15980] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 16050] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 16120] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 16190] R IFP [ 0: 6] 00 01 01 06 00 00
    [ 16210] R IFP [ 0:11] 00 02 06 c0 01 80 00 00 ff 00 00
    [ 16240] R IFP [ 0:11] 00 03 06 c0 01 80 00 00 c0 00 00
    [ 16260] R IFP [ 0:11] 00 04 06 c0 01 80 00 00 04 00 00
    [ 16290] R IFP [ 0:11] 00 05 06 c0 01 80 00 00 b5 00 00
    [ 16320] R IFP [ 0:11] 00 06 06 c0 01 80 00 00 00 00 00
    [ 16340] R IFP [ 0:11] 00 07 06 c0 01 80 00 00 8a 00 00
    [ 16370] R IFP [ 0:11] 00 08 06 c0 01 80 00 00 5a 00 00
    [ 16400] R IFP [ 0:11] 00 09 06 c0 01 80 00 00 00 00 00
    [ 16420] R IFP [ 0:11] 00 0a 06 c0 01 80 00 00 00 00 00
    [ 16450] R IFP [ 0:11] 00 0b 06 c0 01 80 00 00 00 00 00
    [ 16480] R IFP [ 0:11] 00 0c 06 c0 01 80 00 00 00 00 00
    [ 16500] R IFP [ 0:11] 00 0d 06 c0 01 80 00 00 00 00 00
    [ 16530] R IFP [ 0:11] 00 0e 06 c0 01 80 00 00 00 00 00
    [ 16560] R IFP [ 0:11] 00 0f 06 c0 01 80 00 00 00 00 00
    [ 16580] R IFP [ 0:11] 00 10 06 c0 01 80 00 00 00 00 00
    [ 16610] R IFP [ 0:11] 00 11 06 c0 01 80 00 00 00 00 00
    [ 16640] R IFP [ 0:11] 00 12 06 c0 01 80 00 00 00 00 00
    [ 16660] R IFP [ 0: 8] 00 13 03 c0 01 20 00 00
    [ 16730] R IFP [ 0: 8] 00 13 03 c0 01 20 00 00
    [ 16770] R IFP [ 0:11] 00 14 06 c0 01 80 00 00 ff 00 00
    [ 16800] R IFP [ 0:11] 00 15 06 c0 01 80 00 00 c8 00 00
    [ 16820] R IFP [ 0:11] 00 16 06 c0 01 80 00 00 01 00 00
    [ 16850] R IFP [ 0:11] 00 17 06 c0 01 80 00 00 00 00 00
    [ 16880] R IFP [ 0:11] 00 18 06 c0 01 80 00 00 76 00 00
    [ 16900] R IFP [ 0:11] 00 19 06 c0 01 80 00 00 15 00 00
    [ 16930] R IFP [ 0:11] 00 1a 06 c0 01 80 00 00 01 00 00
    [ 16960] R IFP [ 0:11] 00 1b 06 c0 01 80 00 00 01 00 00
    [ 16980] R IFP [ 0:11] 00 1c 06 c0 01 80 00 00 88 00 00
    [ 17010] R IFP [ 0: 8] 00 1d 03 c0 01 20 00 00
    [ 17060] R IFP [ 0: 8] 00 1e 03 c0 01 10 00 00
    [ 17060] RCV CMD 17 ff:c0:04:b5:00:8a:5a:00:00:00:00:00:00:00:00:00:00:
    [ 17060] RCV CMD 9 ff:c8:01:00:76:15:01:01:88:
    [ 17070] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17080] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 17140] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17150] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 17210] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17220] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 17280] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17290] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 17350] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17360] S IFP [ 0: 6] 00 00 01 00 00 00
    [ 17380] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17420] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17450] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17490] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17520] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17560] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17590] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17630] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17660] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17700] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17730] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17770] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17800] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17840] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17870] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17910] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 17940] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 17980] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18010] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 18050] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18080] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 18120] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18150] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 18190] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18220] S IFP [ 0: 6] 00 01 01 06 00 00
    [ 18230] S IFP [ 0:11] 00 02 06 c0 01 80 00 00 ff 00 00
    [ 18250] S IFP [ 0:11] 00 03 06 c0 01 80 00 00 c8 00 00
    [ 18270] S IFP [ 0:11] 00 04 06 c0 01 80 00 00 c1 00 00
    [ 18290] S IFP [ 0:11] 00 05 06 c0 01 80 00 00 00 00 00
    [ 18310] S IFP [ 0:11] 00 06 06 c0 01 80 00 00 46 00 00
    [ 18330] S IFP [ 0:11] 00 07 06 c0 01 80 00 00 15 00 00
    [ 18350] S IFP [ 0:11] 00 08 06 c0 01 80 00 00 00 00 00
    [ 18380] S IFP [ 0: 8] 00 09 03 c0 01 20 00 00
    [ 18420] S IFP [ 0: 8] 00 0a 03 c0 01 10 00 00
    [ 18430] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18470] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18500] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18540] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18570] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18610] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18640] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18680] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18710] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18750] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18780] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18820] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18850] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18890] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18920] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 18960] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 18990] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19030] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19060] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19100] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19130] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19170] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19200] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19240] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19270] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19310] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19340] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19380] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19410] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19450] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19480] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19520] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19550] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19590] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19620] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19660] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19690] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19730] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19760] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19800] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19830] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19870] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19900] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 19940] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 19970] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20010] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20040] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20080] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20110] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20150] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20180] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20220] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20250] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20290] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20320] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20360] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20390] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20430] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20460] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20500] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20530] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20570] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20600] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20640] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20670] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20710] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20740] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20780] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20810] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20850] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20880] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20920] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 20950] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 20990] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21020] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21060] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21090] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21130] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21160] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21200] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21230] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21270] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21300] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21340] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21370] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21410] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21440] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21480] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21510] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21550] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21580] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21620] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21650] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21690] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21720] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21760] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21790] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21830] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21860] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21900] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 21930] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 21970] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22000] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22040] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22070] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22110] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22140] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22180] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22210] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22250] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22280] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22320] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22350] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22390] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22420] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22460] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22490] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22530] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22560] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22600] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22630] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22670] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22700] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22740] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22770] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22810] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22840] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22880] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22910] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 22950] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 22980] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23020] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23050] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23090] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23120] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23160] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23190] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23230] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23260] S IFP [ 0: 6] 00 0b 01 00 00 00
    Tone detect control is called 0
    [ 23300] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23330] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23370] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23400] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23440] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23470] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23510] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23540] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23580] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23610] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23650] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23680] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23720] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23750] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23790] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23820] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23860] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23890] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 23930] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 23960] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24000] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24030] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24070] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24100] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24140] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24170] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24210] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24240] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24280] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24310] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24350] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24380] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24420] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24450] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24490] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24520] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24560] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24590] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24630] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24660] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24700] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24730] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24770] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24800] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24840] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24870] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24910] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 24940] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 24980] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25010] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25050] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25080] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25120] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25150] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25190] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25220] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25260] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25290] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25330] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25360] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25400] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25430] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25470] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25500] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25540] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25570] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25610] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25640] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25680] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25710] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25750] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25780] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25820] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25850] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25890] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25920] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 25960] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 25990] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26030] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26060] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26100] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26130] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26170] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26200] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26240] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26270] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26310] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26340] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26380] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26410] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26450] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26480] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26520] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26550] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26590] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26620] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26660] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26690] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26730] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26760] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26800] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26830] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26870] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26900] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 26940] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 26970] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27010] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27040] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27080] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27110] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27150] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27180] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27220] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27250] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27290] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27320] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27360] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27390] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27430] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27460] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27500] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27530] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27570] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27600] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27640] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27670] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27710] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27740] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27780] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27810] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27850] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27880] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27920] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 27950] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 27990] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28020] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28060] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28090] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28130] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28160] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28200] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28230] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28270] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28300] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28340] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28370] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28410] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28440] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28480] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28510] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28550] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28580] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28620] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28650] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28690] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28720] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28760] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28790] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28830] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28860] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28900] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 28930] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 28970] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29000] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29040] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29070] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29110] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29140] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29180] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29210] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29250] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29280] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29320] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29350] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29390] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29420] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29460] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29490] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29530] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29560] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29600] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29630] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29670] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29700] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29740] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29770] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29810] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29840] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29880] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29910] S IFP [ 0: 6] 00 0b 01 00 00 00
    [ 29950] R IFP [ 0: 6] 00 1f 01 00 00 00
    [ 29980] S IFP [ 0: 6] 00 0b 01 00 00 00
  • Yes, I see the issue. Is it possible for you to capture the fax debug 2 log for this call?
    Yogesh
  • hi,Yogesh
    this is the log, thanks!
    [ 0] FIU : FRP successful startup
    [ 0] FIU : T.38 version 0
    [ 0] FIU : FND successful startup: T.38 UDPTL network protocol
    [ 0] FIU : FIU is opened: frame size = 10 ms
    [ 0] FIU : FRP has been activated in state: startup
    [ 0] FM : State transition: low speed rx
    [ 0] FM : New modulation: V.21 300bps
    [ 0] FIU : Sent T.38 packet to network: no signal ind
    [ 90] FIU : Received T.38 packet with new payload type from network: no signal ind
    [ 11250] FIU : Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT
    [ 15030] FIU : Received ignored modem event in current FRP state: FM_FP_SIGNAL_LOSS
    [ 15200] FIU : Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT
    [ 15270] FM : Carrier detected in state: low speed rx
    [ 15270] FM : Preamble detected in state: low speed rx
    [ 15270] FIU : Received ignored modem event in current FRP state: FM_FP_CARRIER_DETECT
    [ 15270] FIU : FRP state change: local low-speed receive
    [ 15280] FIU : Sent T.38 packet to network: V.21 preamble ind
    [ 16200] FIU : Received first byte of a low-speed data frame: 0xFF
    [ 16250] FIU : FCF of current frame: NSF (0x4)
    [ 16660] FIU : Sent T.38 packet to network: V.21 data
    [ 16760] FIU : Received first byte of a low-speed data frame: 0xFF
    [ 16790] FIU : Received the final frame of a low-speed transmission
    [ 16810] FIU : FCF of current frame: DIS (0x1)
    [ 17010] FIU : Sent T.38 packet to network: V.21 data
    [ 17050] FM : Carrier loss detected in state: low speed rx
    [ 17050] FIU : FRP state change: idle
    [ 17060] FM : State transition: low speed rx
    [ 17060] FM : New modulation: V.21 300bps
    [ 17060] SND CMD 7 ff:c8:c1:00:46:15:00:
    [ 17060] FIU : Sent T.38 packet to network: V.21 data
    [ 17070] FIU : Sent T.38 packet to network: no signal ind
    [ 17390] FIU : Received T.38 packet with new payload type from network: preamble ind
    [ 17390] FIU : FND T.38 decoder state change: transparent
    [ 17390] FIU : FRP state change: remote low-speed receive
    [ 17400] FM : State transition: low speed tx flag
    [ 17400] FM : New modulation: V.21 300bps
    [ 17430] FM : Beginning of the delay message processing: msgData = 352
    [ 18240] FIU : Received T.38 packet with new payload type from network: V.21 data
    [ 18240] FIU : FND T.38 decoder state change: low-speed data
    [ 18240] FIU : Received first byte of a low-speed data frame: 0xFF
    [ 18320] FIU : Received the final frame of a low-speed transmission
    [ 18430] FIU : FND T.38 decoder state change: transparent
    [ 18440] FIU : Received T.38 packet with new payload type from network: no signal ind
    [ 18450] FIU : FCF of current frame: DCS (0x41)
    [ 19150] FIU : SLP page mode: transparent
    [ 19150] FIU : FRP state change: idle
    [ 23130] FM : Beginning of data RX or TX during transmission
    [ 23130] FM : State transition: low speed tx data
    [ 23350] FM : TX or RX of a good HDLC frame: number of bytes in the frame = 0
    [ 23350] FM : State transition: low speed tx flag
    [ 23510] FM : State transition: offline
    time out
    [ 30010] FIU : FIU is closed
  • Hi Huang,
    I went through the trace. There seems to be delay in processing messages from FIU to FM. I need more information to investigate this further
    1) Did you make any changes to FIU and FM open configuration provided with Example. If yes,  could you provide your updated configuration.
    2) Are the timer function in FIU & FM context in sync with system time?
    Yogesh
  • hi,Yogesh
    i change the timer function in FM&FIU, the preamble seems to be correct, i will check it further, thanks!
  • If this issue is closed, could you mark this thread as answered
  • Hi Huang,
    I'm also facing a similar issue. Can you be bit more elaborating on what changes you made to the timer functions in FM and FIU..? Did you make any other changes apart from this to make it work..?
    Ashok
