Am working TMS320VC5401 custom kit with XDS100 usb v2 emulator, while loading the out file am getting some error. please solve the problem as soon. my error details are following in this post .
Note:
1. am sure that XDS 100 USB v2 EMULATOR wont have problem. because it detect in device manager as
TI XDS100 CHANNEL A
TI XDS100 CHANNEL B
2. I Checked the voltage and reset it is perfect.
3.i done the debug step by step .....
a) Target --> launch TI Debugger.
after launched i get gel output in console window "C54xx: GEL Output: Gel StartUp Complete."
b) Target --> Connect Target
after connected i get gel output in console window "C54xx: GEL Output: C5401_Init Complete."
c) Target --> Load Program
while loading i get the following error
C54xx: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
C54xx: File Loader: Data verification failed at address 0x0000422B Please verify target memory and memory map.
Error found during data verification.
Ensure the linker command file matches the memory map.
could you please anyone help me in this, for what possible issue errors will occur.... here i attached my gel file and Linker command file for your reference. please kindly reply me soon.... its urgent.......
