Fill blank window in swms with blue Box
Hello everyone
In my usecase, if there is no video input for the window in swms, the window appears as black box;
While the video source pauses or be removed, the corresponding window in swms will appear to show the last frame of the video source;
How can I fill the window with blue box while there is no viedeo source or the video source be removed?
Thanks for your response!
  • How to fill in the dataframe by myself?
    If there is no camera,fill the databuf 0x00 then the windows can be black. But,where is the pointer to the databuf?
  • I am not clear on what you want to do. Pls provide more details.
    Do you want the SwMs blank window to display blue color ?
        - The system blank video frame is common and used in several modules like SwMs and display. If you want to change it to blue color modify
        /dvr_rdk/mcfw/src_bios6/links_m3vpss/swMs/swMsLink_drv.c
        Int32 SwMsLink_fillBlankDataPattern(FVID2_Format * pFormat,  FVID2_Frame * pFrame)
       to set whatever color you want.
    Are you currently seeing the last video and instead you want to show blank video frame ?
        - If you detect video loss you can invoke Vdis_flushSwMs setting holdLastFrame = FALSE which will blank the window.
  • Thanks, I have set color I want.
    Furthur question, how can I detect video loss when one camera be removed
    Thanks for any reply!
  • The external Video decoder you are using to capture video should support a video loss detection feature.
