PHY requires RMII hold time
  The PHY we are using on our custom board has an errata which states that the "MIN required RMII hold time is 7ns.  should be 2ns per spec."  What registers control the RMII delay for the data lines?  Is it possible to delay the data lines from the PHY to the 6748 DSP?
Will
  • Will,
    We don't have specific register control to delay the data lines for C6748 .The only way you can do it by adding delay line chip or doing it by PCB trace length to achieve 7ns delay.
    Antony
      Please click the Verify Answer button on this post if it answers your question.
