Hi all:
I am working on DM8168 with DVRRDK 3.0。
I create 6 decode channels widh decPrm.chCreateParams[0-5].algCreateStatus = DEC_LINK_ALG_CREATE_STATUS_DONOT_CREATE.
There are two cases described as below:
1. If I fisrt create a decode channle using Vdec_CreateChn with channelNum = 0, then create other channels, all things work fine.
2. If I first create a decode channle whose channelNum is not 0, eg. 1, 2 , the decode link is blocked, and no video display.
I wonder whether there are some restrictions on the sequence of the decode channelNum.
Here are the logs from Vsys_printDetailedStatistics().
[m3vpss ]
[m3vpss ] *** [NSF0] NSF Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time : 34 secs
[m3vpss ] Total Fields Processed : 2069
[m3vpss ] Total Fields FPS : 237 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] CH | In Recv In Reject In Process Out User Out Out
[m3vpss ] Num | FPS FPS FPS FPS Skip FPS Skip FPS
[m3vpss ] ------------------------------------------------
[m3vpss ] 0 | 60 0 60 60 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time: 8 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 65 fps (523 frames)
[m3vpss ] Output Actual FPS : 65 fps (522 frames)
[m3vpss ] Output Drop FPS : 0 fps (1 frames)
[m3vpss ] Output Reject FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal : 16 ms
[m3vpss ] Scaling Internal min : 15 ms
[m3vpss ] Scaling Internal max : 19 ms
[m3vpss ]
[m3vpss ] Win | Window Repeat Drop Recv Que FID Invlid Acc Event Invalid Que Reject Reject Latency
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS Count (Max/Min) CH Frames Frames Frames Min / Max
[m3vpss ] ------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 65 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 1 | 0 65 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 2 | 0 65 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 3 | 0 65 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 60
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 16384 / 32768 | TILED | 0, 0 | 640 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 1 | 1 | 0, 0 | 1920 x 1080 | 16384 / 32768 | TILED | 640, 0 | 640 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 2 | 2 | 0, 0 | 1920 x 1080 | 16384 / 32768 | TILED | 0, 360 | 640 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ] 3 | 3 | 0, 0 | 1920 x 1080 | 16384 / 32768 | TILED | 640, 360 | 640 x 360 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | ON |
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time: 36 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 61 fps (2197 frames)
[m3vpss ] Output Actual FPS : 61 fps (2196 frames)
[m3vpss ] Scaling Internal min : 13 ms
[m3vpss ] Scaling Internal max : 22 ms
[m3vpss ]
[m3vpss ] 0 | 0 61 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 1 | 0 61 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 2 | 0 61 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 3 | 0 61 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 3 | 3 | 0, 0 | 1920 x 1080 | 16384 / 32768 | TILED | 640, 360 | 640 x 360 | 3840 / 0 | NON-TILED | OFF | 1 | 420SP | ON |
[m3vpss ]
[m3vpss ]
[m3vpss ] 7801968: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 10 / 39 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
[m3vpss ] 7801969: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 2204, HDDAC(BP0) 2206, DVO2(BP1) 2206, SDDAC(SEC1) 2206
[m3vpss ] 7801969: SYSTEM : FREE SPACE : System Heap = 4664 B, Mbx = 10239 msgs)
[m3vpss ] 7801969: SYSTEM : FREE SPACE : SR0 Heap = 10710912 B (10 MB)
[m3vpss ] 7801970: SYSTEM : FREE SPACE : Frame Buffer = 156773248 B (149 MB)
[m3vpss ] 7801970: SYSTEM : FREE SPACE : Bitstream Buffer = 262227840 B (250 MB)
[m3vpss ] 7801970: SYSTEM : FREE SPACE : Tiler 8-bit = 122137856 B (116 MB) - TILER ON
[m3vpss ] 7801970: SYSTEM : FREE SPACE : Tiler 16-bit = 128177792 B (122 MB) - TILER ON
[m3vpss ] 7801971: DISPLAY: DVO2(BP1) : 59 fps, Latency (Min / Max) = ( 13 / 34 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
[m3video] 7805971: HDVICP-ID:0
[m3video] All percentage figures are based off totalElapsedTime
[m3video] totalAcquire2wait :0 %
[m3video] totalWait2Isr :31 %
[m3video] totalIsr2Done :0 %
[m3video] totalWait2Done :31 %
[m3video] totalDone2Release :0 %
[m3video] totalAcquire2Release :31 %
[m3video] totalAcq2acqDelay :68 %
[m3video] totalElapsedTime in msec : 40598
[m3video] numAccessCnt: 29160
[m3video] IVA-FPS : 729
[m3video] Average time spent per frame in microsec: 431
[m3video] 7805972: HDVICP-ID:1
[m3video] totalWait2Isr :0 %
[m3video] totalWait2Done :0 %
[m3video] totalAcquire2Release :0 %
[m3video] totalAcq2acqDelay :0 %
[m3video] totalElapsedTime in msec : 0
[m3video] numAccessCnt: 0
[m3video] IVA-FPS : 0
[m3video] Average time spent per frame in microsec: 0
[m3video] 7805973: HDVICP-ID:2
[m3video] totalWait2Isr :57 %
[m3video] totalWait2Done :57 %
[m3video] totalAcquire2Release :57 %
[m3video] totalAcq2acqDelay :42 %
[m3video] totalElapsedTime in msec : 1004
[m3video] numAccessCnt: 756
[m3video] IVA-FPS : 756
[m3video] Average time spent per frame in microsec: 756
[m3video]
[m3video] *** ENCODE Statistics ***
[m3video]
[m3video] Elasped Time : 40 secs
[m3video]
[m3video]
[m3video] CH | In Recv In Skip In User Out Latency
[m3video] Num | FPS FPS Skip FPS FPS Min / Max
[m3video] --------------------------------------------
[m3video] 0 | 60 0 0 60 16 / 160
[m3video]
[m3video] Multi Channel Encode Average Submit Batch Size
[m3video] Max Submit Batch Size : 24
[m3video] IVAHD_0 Average Batch Size : 1
[m3video] IVAHD_0 Max achieved Batch Size : 1
[m3video] IVAHD_1 Average Batch Size : 0
[m3video] IVAHD_1 Max achieved Batch Size : 0
[m3video] IVAHD_2 Average Batch Size : 0
[m3video] IVAHD_2 Max achieved Batch Size : 0
[m3video]
[m3video] Multi Channel Encode Batch break Stats
[m3video] Total Number of Batches created: 2426
[m3video] All numbers are based off total number of Batches created
[m3video] Batch breaks due to batch sizeexceeding limit: 0 %
[m3video] Batch breaks due to ReqObj Que being empty: 99 %
[m3video] Batch breaks due to changed resolution class: 0 %
[m3video] Batch breaks due to interlace and progressivecontent mix: 0 %
[m3video] Batch breaks due to channel repeat: 0 %
[m3video] Batch breaks due to different codec: 0 %
[m3video] Total Number of Batches created: 0
[m3video] Batch breaks due to ReqObj Que being empty: 0 %
[m3video]
[m3video] *** DECODE Statistics ***
[m3video]
[m3video] Elasped Time : 12 secs
[m3video]
[m3video]
[m3video] CH | In Recv In User Out
[m3video] Num | FPS Skip FPS FPS
[m3video] 0 | 0 0 0
[m3video] 1 | 0 0 0
[m3video] 2 | 5 0 4
[m3video] 3 | 0 0 0
[m3video] 4 | 0 0 0
[m3video] 5 | 0 0 0
[m3video]
[m3video] Multi Channel Decode Average Submit Batch Size
[m3video] IVAHD_0 Average Batch Size : 0
[m3video] IVAHD_0 Max achieved Batch Size : 0
[m3video] IVAHD_2 Average Batch Size : 1
[m3video] IVAHD_2 Max achieved Batch Size : 1
[m3video]
[m3video] Multi Channel Decode Batch break Stats
[m3video] Total Number of Batches created: 59
[m3video] Batch breaks due to batch sizeexceeding limit: 100 %
[m3video]
[m3vpss ]
[m3vpss ] 7807981: LOAD: CPU: 0.6% HWI: 0.2%, SWI:0.1%
[m3vpss ]
[m3vpss ] 7807981: LOAD: TSK: MISC : 0.3%
[m3vpss ]
[m3video]
[m3video] 7808482: LOAD: CPU: 0.4% HWI: 0.1%, SWI:0.1%
[m3video]
[m3video] 7808482: LOAD: TSK: MISC : 0.2%
[m3video]
[c6xdsp ]
[c6xdsp ] 7934926: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 7934926: LOAD: TSK: MISC : 0.2%
[c6xdsp ]
[m3vpss ]
[m3vpss ]
[m3vpss ] Elasped Time : 86 secs
[m3vpss ] Total Fields Processed : 7231
[m3vpss ] Total Fields FPS : 229 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] Elasped Time: 86 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 60 fps (5161 frames)
[m3vpss ] Output Actual FPS : 60 fps (5161 frames)
[m3vpss ] Output Drop FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal min : 16 ms
[m3vpss ] Scaling Internal max : 17 ms
[m3vpss ]
[m3vpss ] 0 | 0 60 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 1 | 0 60 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 2 | 0 60 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ] 3 | 0 60 0 0 0 0 0 ( 0/255) 0 0 0 255 / 0
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 7887990: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 17 / 21 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
[m3vpss ] 7887990: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 5162, HDDAC(BP0) 5162, DVO2(BP1) 5162, SDDAC(SEC1) 5163
[m3vpss ] 7887990: SYSTEM : FREE SPACE : System Heap = 4664 B, Mbx = 10238 msgs)
[m3vpss ] 7887990: SYSTEM : FREE SPACE : SR0 Heap = 10710912 B (10 MB)
[m3vpss ] 7887991: SYSTEM : FREE SPACE : Frame Buffer = 156773248 B (149 MB)
[m3vpss ] 7887991: SYSTEM : FREE SPACE : Bitstream Buffer = 262227840 B (250 MB)
[m3vpss ] 7887991: SYSTEM : FREE SPACE : Tiler 8-bit = 122137856 B (116 MB) - TILER ON
[m3vpss ] 7887991: SYSTEM : FREE SPACE : Tiler 16-bit = 128177792 B (122 MB) - TILER ON
[m3vpss ] 7887992: DISPLAY: DVO2(BP1) : 59 fps, Latency (Min / Max) = ( 17 / 22 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
[m3video] 7891992: HDVICP-ID:0
[m3video] totalElapsedTime in msec : 126615
[m3video] numAccessCnt: 91092
[m3video] IVA-FPS : 722
[m3video] Average time spent per frame in microsec: 430
[m3video] 7891993: HDVICP-ID:1
[m3video] 7891994: HDVICP-ID:2
[m3video]
[m3video]
[m3video] Elasped Time : 86 secs
[m3video]
[m3video]
[m3video] 0 | 60 0 0 60 16 / 20
[m3video]
[m3video]
[m3video] Total Number of Batches created: 5161
[m3video] Batch breaks due to ReqObj Que being empty: 100 %
[m3video]
[m3video]
[m3video]
[m3video]
[m3video] 0 | 0 0 0
[m3video] 1 | 0 0 0
[m3video] 2 | 0 0 0
[m3video] 3 | 0 0 0
[m3video] 4 | 0 0 0
[m3video] 5 | 0 0 0
[m3video]
[m3video]
[m3video]
[m3vpss ]
[m3vpss ] 7894001: LOAD: CPU: 14.3% HWI: 4.4%, SWI:1.1%
[m3vpss ]
[m3vpss ] 7894002: LOAD: TSK: IPC_OUT_M30 : 0.5%
[m3vpss ] 7894002: LOAD: TSK: IPC_FRAMES_OUT0 : 0.8%
[m3vpss ] 7894002: LOAD: TSK: NSF0 : 0.6%
[m3vpss ] 7894002: LOAD: TSK: DISPLAY0 : 0.5%
[m3vpss ] 7894002: LOAD: TSK: DISPLAY1 : 0.3%
[m3vpss ] 7894002: LOAD: TSK: DUP1 : 0.2%
[m3vpss ] 7894002: LOAD: TSK: SWMS0 : 2.4%
[m3vpss ] 7894002: LOAD: TSK: SWMS1 : 2.7%
[m3vpss ] 7894003: LOAD: TSK: MERGE0 : 0.1%
[m3vpss ] 7894003: LOAD: TSK: MISC : 0.7%
[m3vpss ]
[m3video]
[m3video] 7894504: LOAD: CPU: 5.7% HWI: 0.8%, SWI:0.9%
[m3video]
[m3video] 7894504: LOAD: TSK: IPC_IN_M30 : 0.2%
[m3video] 7894504: LOAD: TSK: IPC_BITS_OUT0 : 0.6%
[m3video] 7894504: LOAD: TSK: ENC0 : 0.9%
[m3video] 7894505: LOAD: TSK: DEC0 : 0.5%
[m3video] 7894505: LOAD: TSK: ENC_PROCESS_TSK_0 : 1.3%
[m3video] 7894505: LOAD: TSK: MISC : 0.5%
[m3video]
[c6xdsp ]
[c6xdsp ] 8022367: LOAD: CPU: 2.3% HWI: 0.1%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 8022367: LOAD: TSK: IPC_FRAMES_IN0 : 0.1%
[c6xdsp ] 8022367: LOAD: TSK: ALG0 : 1.9%
[c6xdsp ] 8022367: LOAD: TSK: MISC : 0.2%
[c6xdsp ]
