UART0 on AM335X IDK board
I am porting rtos SMX on the UART0 on AM335X IDK board. But I cannot make UART0 work. I did port SMX on the UART0 on AM335X SK board before. And the UART0 worked on AM335X SK boad good. How can I make UART0 works on AM335X IDK board?I attached the UART code.
* Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    Redistributions in binary form must reproduce the above copyright
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
//MDI:WXS: This file is come from TI sample with a lot of changes.
#include "smxbase.h"
#include "uart.h"
#include "am335x.h"
void UART0ModuleClkConfig(void)
    /* Configuring L3 Interface Clocks. */
    /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
    CM_PER_L3_CLKCTRL |= 0x2;
    /* Waiting for MODULEMODE field to reflect the written value. */
    while(0x2 != ((CM_PER_L3_CLKCTRL) & 0x3));
    /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
    (CM_PER_L3_INSTR_CLKCTRL) |= 0x2;
    while(0x2 != ((CM_PER_L3_INSTR_CLKCTRL) & 0x3));
    /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
    (CM_PER_L3_CLKSTCTRL) |= 0x2;
    /* Waiting for CLKTRCTRL field to reflect the written value. */
    while(0x2 != ((CM_PER_L3_CLKSTCTRL) & 0x3));
    /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
    (CM_PER_OCPWP_L3_CLKSTCTRL) |= 0x2;
    /*Waiting for CLKTRCTRL field to reflect the written value. */
    while(0x2 != ((CM_PER_OCPWP_L3_CLKSTCTRL) & 0x3));
    /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
    (CM_PER_L3S_CLKSTCTRL) |= 0x2;
    while(0x2 != ((CM_PER_L3S_CLKSTCTRL) & 0x3));
    /* Checking fields for necessary values.  */
    /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
    while((0x0)!= ((CM_PER_L3_CLKCTRL) & 0x00030000));
    ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
    ** desired value.
    while((0x0)!=((CM_PER_L3_INSTR_CLKCTRL) & 0x00030000));
    ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
    ** attain the desired value.
    while(0x10 != ((CM_PER_L3_CLKSTCTRL) & 0x10));
    ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
    ** register to attain the desired value.
    while(0x10 != ((CM_PER_OCPWP_L3_CLKSTCTRL) & 0x10));
    ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
    ** to attain the desired value.
    while(0x8 != ((CM_PER_L3S_CLKSTCTRL) & 0x8));
    /* Configuring registers related to Wake-Up region. */
    /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
    (CM_WKUP_CONTROL_CLKCTRL) |= 0x2;
    while(0x2 != ((CM_WKUP_CONTROL_CLKCTRL) & 0x3));
    (CM_WKUP_CLKSTCTRL) |= 0x2;
    while(0x2 != ((CM_WKUP_CLKSTCTRL) & 0x3));
    /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
    (CM_L3_AON_CLKSTCTRL) |= 0x2;
    while(0x2 != ((CM_L3_AON_CLKSTCTRL) & 0x3));
    /* Writing to MODULEMODE field of CM_WKUP_UART0_CLKCTRL register. */
    (CM_WKUP_UART0_CLKCTRL) |= 0x2;
    while(0x2 != ((CM_WKUP_UART0_CLKCTRL) & 0x3));
    /* Verifying if the other bits are set to required settings. */
    ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
    ** desired value.
    while((0x0) != ((CM_WKUP_CONTROL_CLKCTRL) & 0x00030000));
    ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
    ** register to attain desired value.
    while(0x8 != ((CM_L3_AON_CLKSTCTRL) & 0x8));
    ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
    ** desired value.
    while((0x0) != ((CM_WKUP_L4WKUP_CLKCTRL) & 0x00030000));
    ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
    ** to attain desired value.
    while(0x4 != ((CM_WKUP_CLKSTCTRL) & 0x4));
    ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in CM_L4_WKUP_AON_CLKSTCTRL
    while(0x4 != ((CM_L4_WKUP_AON_CLKSTCTRL) & 0x4));
    ** Waiting for CLKACTIVITY_UART0_GFCLK field in CM_WKUP_CLKSTCTRL
    while(0x00001000u != ((CM_WKUP_CLKSTCTRL) & 0x00001000));
    ** Waiting for IDLEST field in CM_WKUP_UART0_CLKCTRL register to attain
    ** desired value.
    while((0x0) != ((CM_WKUP_UART0_CLKCTRL) & 0x00030000));
void Uart0Init(u32 baud)
   u32 divisor;
   /* Configuring the system clocks for UART0 instance. */
   UART0ModuleClkConfig();
   /* Set pins multiplexing for UART0 */
   /* RX pin: receiver enabled and pullup selected */
   CONF_UART0_RXD = 0x28;
   /* TX pin: pullup selected */
   CONF_UART0_TXD = 0x8;
   /* Set software reset for UART0 */
   UART0_SYSC |= 0x2;
   /* Wait until the software reset is done. */
   while(!(UART0_SYSS & 0x1)) {}
   /* Switch to configuration mode B */
   UART0_LCR = 0xBF;
   /* Enables writing to enhanced function bits in IER, FCR, and MCR */
   UART0_EFR |= 0x10;
   /* Switch to configuration mode A */
   UART0_LCR = 0x80;
   /* Enable access to TCR and TLR */
   UART0_MCR |= 0x40;
   /* Set baud rate...assumes default 16x oversampling */
   divisor = UART_CLOCK / (baud * 16);
   UART0_DLH = (divisor & 0x0000FF00) >> 8;
   UART0_DLL = divisor & 0x000000FF;
   /* Enable xmtr/rcvr fifos */
   UART0_FCR = 0x0;
   UART0_FCR = 0xF;
   /* Switch to operational mode */
   UART0_LCR = 0x0;
   /* disable interrupts, flow control, and loop back */
   UART0_IER = 0x0;
   UART0_MCR = 0x0;
   UART0_TLR = 0x0;
   /* Config LCR for no parity, one stop bit, 8 data bits, no flow control */
   UART0_LCR = 0x3;
   /* Change mode from disabled to uart 16x */
   UART0_MDR1 = 0x0;
void Uart0PutChar(unsigned char chr)
   /* Waiting untill the FIFO is not full */
   while (UART0_SSR & 0x1) {}
   /* Send the character */
   UART0_THR = chr;
unsigned char Uart0GetChar(void)
   unsigned char chr = 0;
   /* Waiting untill char available */
   //while (!(UART0_LSR & 0x1)) {}
   /* receive character */
   chr = UART0_RHR;
   return chr;
