How to config ELF format using C6RUN for OMAPL137?
Hi,Experts,
I'm new to omapL1XX series board and also new to c6run. Now I have problems to set up elf format for omapl137 evm board using c6run and syslink.
Here is my working procedure:
1. Build Linux kernel(Linux version 2.6.33,MontaVista(R) Linux(R) Professional Edition 5.0.0) ,u-boot1.3.3 and flash them to the evm board.
2. Make stand alone c6run env,get components for C6Run_0_98_03_03:
 SYSLINK_VERSION=2_10_08_35
 SYSBIOS_VERSION=6_35_03_47
 IPC_VERSION=1_25_03_15
 XDCTOOLS_VERSION=3_25_02_70
 LINUXUTILS_VERSION=3_23_00_0
3.Write the envionment path for rules.mak,config.mak.
4.Make a new platform named omapl137_syslink in "platforms" folder  copied from omapl138_syslink. Make some tiny modification which I think is right...Also rewrite platform.mak to point to rignt linux kernel and u-boot kernel.
5.In c6run root kernel,type make omapl137_syslink_config in  my host ubuntu-linux,then make everything...
After debug for a week I can build cmemk.ko ,syslink.ko file  insert them to board successfully.Then I make my own executable using c6run lib and app,and run it on target board.Here problems comes:
syslink debug info assert those words below to me:
*** HeapMemMP_sharedMemReq: params->sharedAddr is not in a valid SharedRegion!
Error [0xffffffff] at Line no: 1748 in file /local/home/lc-C6Run_0_98_03_03/syslink_2_10_08_35/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/HeapMemMP.c
Assertion at LinElfLoader_getSymbolAddress: symName [_Ipc_ResetVector]
*** ListMP_getHead: handle passed is NULL!
e no: 220 in /db/atree/library/trees/sl/sl-c35/src/packages/ti/syslink/product/export/syslink_2_10_08_35/packages/ti/syslink/../../ti/syslink/utils/hlos/Memory.c: (size > 0) : failed
Error [0xfffffffe] at Line no: 1181 in file /local/home/lc-/C6Run_0_98_03_03/syslink_2_10_08_35/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/ListMP.c
ProcMgr_translateAddr: srcAddr [0xc3770c00] dstAddr [0xc5be6c00]
I guess my memory mapping is :
0xc000 0000  ~ 0xc200 0000  Linux
0xc200 0000 ~ 0xc300 0000  cmem
0xc300 0000 ~ 0xc3e0 0000  sdram
0xc3e0 0000 ~ 0xc3f0 0000   SR0
0xc3f0 0000 ~ 0xc400 0000  SR1
 What's wrong with my mapping or my config ? It works well when I using dsplink to build coff format,but not for elf format using syslink.
I have also tried to build a c6run helloworld example using omapl137_syslink_config,here's the output of syslink.ko after running:
# ./hello_world_arm
Hello world, from C6RunApp!
# ./hello_world_dsp
MultiProc Module already initialized!
NameServer Module already initialized!
SharedRegion Module already initialized!
GateMP Module already initialized!
Notify Module already initialized!
MessageQ Module already initialized!
HeapBufMP Module already initialized!
HeapMemMP Module already initialized!
ListMP Module already initialized!
ClientNotifyMgr Module already initialized!
FrameQBufMgr Module already initialized!
FrameQ Module already initialized!
    ProcMgr_getProcInfo: bootMode: [0]
MemoryOS_map: entry already exists
    mapInfo->src  [0x1c00000]
    mapInfo->dst  [0xfec00000]
    mapInfo->size [0x400000]
    OMAPL1XXPROC_attach: Mapping memory regions
    OMAPL1XXPROC_attach: Slave is now in reset!
OsalDrv_mmap(): setting cache disabled for physical address 11800000
OsalDrv_mmap(): setting cache disabled for physical address 11f00000
DLOAD: ELF: ELF
DLOAD: ELF file header entry point: c373c400
ElfLoaderTrgWrite_copy: translated 0xc3000000 (sva) --> 0xc3000000 (mpa)
MemoryOS_map: pa=0xc3000000, va=0xc6000000, sz=0x704c20
_ProcMgr_map for SlaveVirt:
    dstAddr       [0xc3000000]
    sgList.paddr  [0xc3000000]
    sgList.offset [0x0]
    sgList.size [0x704c20]
ElfLoaderTrgWrite_copy: translated 0xc3704c20 (sva) --> 0xc3704c20 (mpa)
MemoryOS_map: pa=0xc3704c20, va=0xc5940c20, sz=0x34d4a
    dstAddr       [0xc3704000]
    sgList.paddr  [0xc3704000]
    sgList.offset [0xc20]
    sgList.size [0x3596a]
ElfLoaderTrgWrite_copy: translated 0xc3739970 (sva) --> 0xc3739970 (mpa)
MemoryOS_map: pa=0xc3739970, va=0xc5908970, sz=0x13e4
    dstAddr       [0xc3739000]
    sgList.paddr  [0xc3739000]
    sgList.offset [0x970]
    sgList.size [0x1d54]
ElfLoaderTrgWrite_copy: translated 0xc373ad58 (sva) --> 0xc373ad58 (mpa)
MemoryOS_map: pa=0xc373ad58, va=0xc590cd58, sz=0x1000
    dstAddr       [0xc373a000]
    sgList.paddr  [0xc373a000]
    sgList.offset [0xd58]
    sgList.size [0x1d58]
ElfLoaderTrgWrite_copy: translated 0xc373bd58 (sva) --> 0xc373bd58 (mpa)
MemoryOS_map: pa=0xc373bd58, va=0xc5914d58, sz=0x434
    dstAddr       [0xc373b000]
    sgList.paddr  [0xc373b000]
    sgList.size [0x118c]
ElfLoaderTrgWrite_copy: translated 0xc373c190 (sva) --> 0xc373c190 (mpa)
MemoryOS_map: pa=0xc373c190, va=0xc591c190, sz=0x4c
    dstAddr       [0xc373c000]
    sgList.paddr  [0xc373c000]
    sgList.offset [0x190]
    sgList.size [0x1dc]
ElfLoaderTrgWrite_copy: translated 0xc373c1dc (sva) --> 0xc373c1dc (mpa)
MemoryOS_map: pa=0xc373c1dc, va=0xc59221dc, sz=0x10
    sgList.offset [0x1dc]
    sgList.size [0x1ec]
ElfLoaderTrgWrite_copy: translated 0xc373c400 (sva) --> 0xc373c400 (mpa)
MemoryOS_map: pa=0xc373c400, va=0xc5928400, sz=0x200
    sgList.offset [0x400]
    sgList.size [0x600]
ElfLoaderTrgWrite_copy: translated 0xc373c800 (sva) --> 0xc373c800 (mpa)
MemoryOS_map: pa=0xc373c800, va=0xc592e800, sz=0x8c
    sgList.offset [0x800]
    sgList.size [0x88c]
    ProcMgr_translateAddr: srcAddr [0xc373c800] dstAddr [0xc592e800]
    ProcMgr_translateAddr: srcAddr [0xc373c81c] dstAddr [0xc592e81c]
handle->slaveSRCfg[0].entryBase c3e00000
Platform_loadCallback:
    No SharedRegion.entry[0].cacheEnable configuration value found, using default FALSE
    Mapping SharedRegion 0
    addr[ProcMgr_AddrType_MasterPhys] [0xc3e00000]
    addr[ProcMgr_AddrType_SlaveVirt]  [0xc3e00000]
    size                              [0x100000]
    isCached                          [0]
MemoryOS_map: pa=0xc3e00000, va=0xc5a00000, sz=0x100000
    dstAddr       [0xc3e00000]
    sgList.paddr  [0xc3e00000]
    sgList.offset [0x0]
    sgList.size [0x100000]
handle->slaveSRCfg[1].entryBase c3f00000
    No SharedRegion.entry[1].cacheEnable configuration value found, using default FALSE
    Mapping SharedRegion 1
    addr[ProcMgr_AddrType_MasterPhys] [0xc3f00000]
    addr[ProcMgr_AddrType_SlaveVirt]  [0xc3f00000]
    size                              [0x100000]
    isCached                          [0]
MemoryOS_map: pa=0xc3f00000, va=0xc5c00000, sz=0x100000
    dstAddr       [0xc3f00000]
    sgList.paddr  [0xc3f00000]
    sgList.offset [0x0]
    OMAPL1XXPROC_start: Configuring boot register
        Reset vector [0xc373c400]!
    OMAPL1XXPROC_start: Slave successfully started!
Ipc_attach: Ipc_procSyncStart failed!
ISR already registered!
    NotifyDriverShm_registerEvent
        Added entry in regChart: [0]
   ISR handled
   ISR handled
   ISR handled
OsalDrv_mmap(): setting cache disabled for physical address c3e00000
OsalDrv_mmap(): setting cache disabled for physical address c3f00000
    HeapMemMP_create knl ioctl: Shared addr [0xc5a02d80]
    MessageQ_create: Max number of queues 32
    NameServer_getLocal name [CONTROL_FROM_GPP_MSGQ]
    NameServer_getLocal: Entry not found!
   ISR handled
   ISR handled
   ISR handled
    NameServer_getLocal name [HeapMemMP]
   ISR handled
   ISR handled
   ISR handled
Failed to get value from remote NameServer
    MessageQ_open ioctl queueId [0xffff]
   ISR handled
   ISR handled
   ISR handled
    NameServer_getLocal name [CONTROL_TO_GPP_MSGQ]
   ISR handled
   ISR handled
   ISR handled
    MessageQ_open ioctl queueId [0x0]
    NameServer_getLocal name [CIO_FROM_GPP_MSGQNAME]
   ISR handled
   ISR handled
   ISR handled
    NameServer_getLocal name [CIO_TO_GPP_MSGQNAME]
    MessageQ_open ioctl queueId [0x1]
   ISR handled
   ISR handled
   ISR handled
MessageQ_get
Hello world, fro   ISR handled
m C6RunApp!
   ISR handled
   ISR handled
MessageQ_get
   ISR handled
   ISR handled
   ISR handled
MessageQ_get
   ISR handled
   ISR handled
   ISR handled
MessageQ_get
   ISR handled
   ISR handled
   ISR handled
MessageQ_get
   ISR handled
   ISR handled
   ISR handled
        Error [0xfffffffe] at Line no: 1181 in file /local/home/lc-test/fqian/omapl137/ARM/C6Run_0_98_03_03/syslink_2_10_08_35/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/ListMP.c
Anyone who can please look into it?
