EVM is not booting from Original SD Card
Whenever I am booting the EVM via Original SD card , it is showing Auto negotaiation failed on minicom. Please guide me urgently.
Arun Taneja
Booting from SD Card and status on Minicom
U-Boot 2010.06 (Nov 10 2011 - 23:45:47)
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
I2C:   ready
DRAM:  2 GiB
NAND:  HW ECC Hamming Code selected
256 MiB
                          .:;rrr;;.
                    ,5#@@@@#####@@@@@@#2,
                 ,A@@@hi;;;r5;;;;r;rrSG@@@A,
               r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
             :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
            B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
           @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
          @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
         @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
        G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
        @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
       X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
       @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
       @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
       @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
       @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
       M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
       :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
        @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
         @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
         ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
          r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
           ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
             B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
              .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
                .A@@#5r;;;r;;;rrr;r:r#AsM@@H.
                   ;&@@@@MhXS5i5SX9B@@@@G;
                       :ihM#@@@@@##hs,
MMC:   OMAP SD/MMC: 0
Net:   Detected MACID:0:18:32:62:f2:55
cpsw
Hit any key to stop autoboot:  0
Auto negotitation failed
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
Retry count exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
  • Arun,
    What is your SDK? Are you on EZSDK 5.05.02.00?
    You have at least MLO, u-boot.bin and uImage files in the /media/BOOT partition of the SD card, right?
    Make sure you configured the EVM S1 switches for SD boot: 1, 2, 3, 5 = ON; all other switches OFF.
    BR
    Pavel
  • Pavel,
    Mine EZSDK is 5_03_00_09. And I checked the SD Card on host PC ( Ubantu) via card reader and it showed three folder and under BOOT Folder all files are there which you have asked for.
    • START_HERE -
    • ROOTFS
    • Boot
    1. boot.cmd
    2. boot.scr
    3. MLO
    4. README.boot.scr
    5. u-boot.bin
    6. uImage
    7. windows_users.htm ,
    8. Note :  Please Note that EVM was booting from original SD initially and this when EVM was booting from I manually interrupted the autoboot to get the login of the EVM and it hangup. Now after each cycle it only showing the "Auto Negotiation Failed". Please Guide me.
    9. Regards,
    10.  Arun Taneja
  • Please Read Note as
    Note :  Please Note that EVM was booting original SD Earlier;  but this time when EVM was booting from Original SD Card , I manually interrupted the autoboot to get the login of the EVM and it hangup. Now after each cycle it showing the "Auto Negotiation Failed". Please Guide me
    Arun Taneja
  • Arun,
    Can you try the below flow, this with interrupting the countdown and typing the boot commands manually:
    Net:   Detected MACID:90:d7:eb:d5:13:96
    cpsw
    TI8148_EVM#mmc rescan 0
    TI8148_EVM#fatload mmc 0 0x80009000 uImage
    reading uImage
    2722248 bytes read
    TI8148_EVM#setenv bootargs 'console=ttyO0,115200n8 rootwait root=/dev/mmcblk0p2 rw mem=364M@0x80000000 mem=320M@0x9FC00000 vmalloc=500M  notifyk.vpssm3_sva=0xBF900000 ip=off noinitrd'
    TI8148_EVM#print bootargs
    bootargs=console=ttyO0,115200n8 rootwait root=/dev/mmcblk0p2 rw mem=364M@0x80000000 mem=320M@0x9FC00000 vmalloc=500M  notifyk.vpssm3_sva=0xBF900000 ip=off noinitrd
    TI8148_EVM#bootm 0x80009000
    ## Booting kernel from Legacy Image at 80009000 ...
       Image Name:   Linux-2.6.37
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    2722184 Bytes = 2.6 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    BR
    Pavel
  • Pavel,
    I have executed the above instruction the GUI Matrix has come on LCD screen and Kernel has started. And EVM Login has come .
    dm814x-evm login
    Note : When I am booting again the EVM same Error is coming, " Auto negotiation failed" . Do I need to save somewhere ?
    Please Guide me further....
    Thanks & Regards,
    Arun Taneja
  • Arun,
    I will recommend you to download and use the latest EZSDK 5.05.02.00 available at the TI web site. Then we have a special script for creating bootable SD cards. You should run this script over your SD card. Refer to ti-ezsdk_dm814x-evm_5_05_02_00/docs/DM814x_EZ_Software_Developers_Guide.pdf section 6.6 How to create an SD card
    BR
    Pavel
  • Hi Pavel,
    Please guide me what are command I need to run on host PC after downloading the  EZSDK 5.05.02.00 ?. I have tried to make new SD Card from existing EZSDK, its behaving in same way.
    DO I need to run {EZSDK}/setup.sh ? , I feel that this is only require in case of /tftp boot and NFS Boot.
    Waiting for the response.
    Arun Taneja
  • Arun,
    1. Download the EZSDK installer for your platform - in our case, ezsdk_dm814x-evm_5_05_02_00_setuplinux executable file
    2. If necessary make the installer executable manually by executing:
        chmod +x ezsdk_myplatform-evm_5_xx_xx_xx_setuplinux
    3. Execute the installer on the host and follow the instructions:
        ./ezsdk_myplatform-evm_5_xx_xx_xx_setuplinux
    4. Plug an SD card on Linux host machine.
    5. Run dmesg command to check the device node. Triple check this to ensure you do not damage your
    HDD contents!
    On my Linux PC, the SD card is detected on /dev/sdb
    6. Run mksdboot script installed in EZ SDK as show below
    host $ sudo ${EZSDK}/bin/mksdboot.sh --device /dev/sdb --sdk ${EZSDK}
    Wait for script to complete. On successful completion, remove the SD card from the host PC.
    Now the SD card should have two partitions: /media/BOOT and /media/ROOTFS
    For booting from SD card with the mksdboot.sh script, no.
    BR
    Pavel
  • Pavel,
    I have installed the new EZSDK on host PC and prepare the SD Card as command. I did not run the last command written by you, "
    For booting from SD card with the mksdboot.sh script, no.". - what is this. Also I checked that SD CARD is having two partition /media/BOOT and /media/ROOTFS.
    Please is status when I plug the SD card to EVM and boot up the EVM.
    U-Boot 2010.06 (Dec 26 2012 - 18:17:23)
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0
    Using default environment
    The 2nd stage U-Boot will now be auto-loaded
    Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is alr
    eady flashed
    reading u-boot.bin
    184320 bytes read
    ## Starting application at 0x80800000 ...
    U-Boot 2010.06 (Dec 26 2012 - 18:12:01)
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    I2C:   ready
    DRAM:  2 GiB
    NAND:  HW ECC BCH8 Selected
    No NAND device found!!!
    0 MiB
    MMC:   OMAP SD/MMC: 0
    Please Guide me.
    Arun Taneja
    9818957204
  • Arun,
    I mean you do not need to run the {EZSDK}/setup.sh script for your use case (booting from MMC/SD card). Anyway you can run this {EZSDK}/setup.sh script also, it will not damage your bootable SD card. What I mean is that this {EZSDK}/setup.sh is not mandatory when booting from MMC/SD card.
    0 MiB
    The PSP supports both 8 and 16 bit NAND flash. To use 16-bit NAND, set the CS0BW (buswidth) switch on the EVM to ON state. CS0BW switch is the 8th Pin on the EVM Boot Mode Switch.
    Let me know if you have more questions.
    Pavel
  • Which Switch you are talking about ?  Can you send me the Screen shot ?
    Arun Taneja
  • The screen shot:
  • Pavel,
    I have Kept
    1,2,3.5 = ON and rest all are OFF
    And also tried
    1,2,3,5,8 = ON , rest all off -  Status is same , EVM is not loading kernals.
    Guide me Further
    Arun Taneja
  • Arun,
    Arun Taneja said:
    MMC:   OMAP SD/MMC: 0
    Do you mean that your flow stuck at this line?
    This is what I have on my own DM8148 EVM with EZSDK 5.05.02.00 SD card:
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    I2C:   ready
    DRAM:  2 GiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
                              .:;rrr;;.
                           :ihM#@@@@@##hs,
    cpsw
    reading uImage
    2721724 bytes read
       Data Size:    2721660 Bytes = 2.6 MiB
    OK
    Starting kernel ...
    BR
    Pavel
  • Pavel,
    Please find below the command executed when I turned on the 8th pin of Boot switch. Guide me further ........
    Arun Taneja
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0
    eady flashed
    reading u-boot.bin
    184320 bytes read
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    I2C:   ready
    DRAM:  2 GiB
    0 MiB
    MMC:   OMAP SD/MMC: 0
  • Arun,
    Can you try with 1,2,3,5,6,8 = ON, rest all OFF.
    Also SW2 (NAND/SPI boot) 1=ON, 2=OFF.
    BR
    Pavel
  • Pavel,
    Now nothing is happening based on given configuration by you. Blank on minicom.
    Waiting for quick further guidance.
    Arun Taneja
  • Arun,
    Let me clarify something.
    Now you have nothing on the minicom (blank on minicom) or you have some initial messages and the flow stuck at the "MMC:   OMAP SD/MMC: 0" line?
    BR
    Pavel
  • Pavel,
    When I changed the Boot switch setting i.e
    1,2,3,5,6,8 = ON and all offf and SW 2 = 1 ON, 2 = Off,
    Minicom was blank.
    Arun Taneja
  • Arun,
    Arun Taneja said:
    Minicom was blank.
    I suspect this is Minicom issue, as these boot switch settings are working fine for me.
    Is your baud rate set to 115200? Is your port set to /dev/ttyUSB0?
    BR
    Pavel
  • Pavel,
    I restarted the minicom again and command are given below.
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    DRAM:  2 GiB
    MMC:   OMAP SD/MMC: 0
    eady flashed
    reading u-boot.bin
    184320 bytes read
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    I2C:   ready
    DRAM:  2 GiB
    0 MiB
    MMC:   OMAP SD/MMC: 0
    Please guide me further.
    Arun Taneja
  • Arun,
    Now minicom works and the flow stuck at the "MMC: OMAP SD>MMC: 0" line, is that correct?
    If yes, the problem seems to be in the u-boot.bin file. Have you made any modifications in the u-boot source code? Are you using the u-boot.bin that was automatically placed in the /media/BOOT partition of your SD card by the mksdboot.sh script? What is the size of your SD card?
    Pavel
  • Pavel,
    Yes you are right, minicom is working fine and flow stuck at "MMC: OMAP SD>MMC: 0" line.
    I haven't change any thing to u-boot source code and wutomatically created  and size of SD card is 8 GB.
    Arun Taneja
  • Arun,
    This is quite strange. I am booting successfully with the settings already provided.
    Can you try to boot from UART (not SD card). If you boot from UART with success, then most probably the SD card has something wrong.
    For UART boot, you should remove the SD card from the slot, and configure the BOOT MODE SEL switch, pin 1 is ON, 2,3,4,5 are OFF.
    After that you should generate 1st stage bootloader (u-boot.min.uart) and 2nd stage bootloader (u-boot.bin). Refer to the below wiki page to see how:
    http://processors.wiki.ti.com/index.php/TI81XX_PSP_UBOOT_User_Guide#Building_U-Boot
    You can also use mine, I am attaching them: http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/716/6761.u_2D00_boot.min.uart  http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/716/0246.u_2D00_boot.bin
    You can place them in your Desktop folder. Then start the console from Desktop like this:
    pbotev@pbotev:~/Desktop$ sudo picocom -b 115200 /dev/ttyUSB0 --send-cmd "sx -vv"
    Then you should have:
    port is        : /dev/ttyUSB0
    flowcontrol    : none
    baudrate is    : 115200
    parity is      : none
    databits are   : 8
    escape is      : C-a
    noinit is      : no
    noreset is     : no
    nolock is      : no
    send_cmd is    : sx -vv
    receive_cmd is : rz -vv
    Terminal ready
                            ----------------------> press Ctrl+A Ctrl+S
    *** file: u-boot.min.uart   ---> type u-boot.min.uart and press Enter
    sx -vv u-boot.min.uart
    Sending u-boot.min.uart, 397 blocks: Give your local XMODEM receive command now.
    Bytes Sent:  50944   BPS:4847  ---------------> power on the EVM
    Transfer complete
    *** exit status: 0
    U-Boot 2010.06 (Aug 16 2013 - 16:23:00)
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    DRAM:  2 GiB
    Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
    TI-MIN#loady 0x81000000     -----> next step is to define RAM address for the 2nd stage bootloader
    ## Ready for binary (ymodem) download to 0x81000000 at 115200 bps...
    C  ----------------------------------> press Ctrl+A Ctrl+S
    *** file: u-boot.bin   ------> type u-boot.bin and press Enter
    sx -vv u-boot.bin
    Sending u-boot.bin, 1643 blocks: Give your local XMODEM receive command now.
    Xmodem sectors/kbytes sent:   0/ 0kRetry 0: NAK on sector
    Bytes Sent: 210432   BPS:5401
    Transfer complete
    *** exit status: 0
    xyzModem - CRC mode, 1645(SOH)/0(STX)/0(CAN) packets, 3 retries
    ## Total Size      = 0x000335e0 = 210400 Bytes
    TI-MIN#go 0x81000000         ----------------------> go to the 2nd stage bootloader
    ## Starting application at 0x81000000 ...
    U-Boot 2010.06 (Aug 16 2013 - 16:23:56)
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    I2C:   ready
    DRAM:  2 GiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
                              .:;rrr;;.
                           :ihM#@@@@@##hs,
    cpsw
    TI8148_EVM#
    Let me know whether you are able to load the u-boot.bin successfully from the UART.
    BR
    Pavel
  • Pavel,
    I have tried the above commands are working fine and I have used your file and some error has also come mentioned below after completion of the process . I have kept 1= ON, 2,3,4,5,6...12 = off
    Card did not respond to voltage select!
    ** Can't read from device 0 **
    ** Unable to use mmc 0:1 for fatload **
    In case ENV on MMC/SD is required
    Please put a valid script named boot.scr on the card
    Refer to the User Guide on how to generate the image
    TI8148_EVM#
    Arun Taneja
  • Arun,
    I suspect that your SD card is corrupted. Can you try with new SD card, and run the ${EZSDK}/bin/mksdboot.sh scipt over the new SD card.
    You can also try with :
    TI8148_EVM# mmc rescan 0
    TI8148_EVM# fatload mmc 0 0x80009000 uImage
    TI8148_EVM# bootm 0x80009000
    Pavel
