Need help for MIPI DSI settings (video mode) on OMAP4460
Hi all,
    I'm trying to bring up a 480x800 MIPI DSI interface LCD display (video mode) on our OMAP4460 custom board, but I get a blurry screen on LCD :
Environment :
    1. Custom omap4460 board + linux kernel 3.0.31 + android 4.0.4
    2. System clock : 38.4MHz
LCD spec. :
Maximum 500 Mbps data rate
Pixel clock cycle : 20.3 ~ 32.2 MHz
Vertical Timings for DSI I/F
Item Symbol Condition Min. Typ. Max. Unit
Vertical cycle  VP Resolution=480x800 806 - Line
Vertical low pulse width VS  - 2 255 Line
Vertical front porch  VFP  2 255 Line
Vertical back porch  VBP 2 255 Line
Vertical data start point  VS+VBP  4 510 Line
Vertical blanking period  VBL VS+VBP+VFP 6 765 Line
Vertical active area  - VDISP(480x800)  - 800 - Line
Vertical Refresh rate  VRR - - 60 - Hz
Horizontal Timings for DSI I/F
HS cycle HP Resolution=480x800 504 - 1023 DCK
HS low pulse width HS 21 - 255 DCK
Horizontal back porch HBP 58 - 255 DCK
Horizontal front porch HFP 58 - 255 DCK
Horizontal data start point  HS+HBP 58 - 510 DCK
Horizontal blanking period  HBLK 137 - 765 DCK
Horizontal active area  HDISP Resolution=480x800 - 480 - DCK
My settings for MIPI DSI LCD :
static struct omap_dsi_timings wvga_lcd_dsi_timings = {
.hbp = 99,
.hfp = 70,
.hsa = 0, /* DSI_VM_TIMING1 */
.vbp = 17,
.vfp = 29,
.vsa = 4, /* DSI_VM_TIMING2 */
.vact = 800,
.tl = 894, /* DSI_VM_TIMING3 */
.hsa_hs_int = 0,
.hfp_hs_int = 0,
.hbp_hs_int = 0, /* DSI_VM_TIMING4 */
.hsa_lp_int = 0,
.hfp_lp_int = 0,
.hbp_lp_int = 2, /* DSI_VM_TIMING5 */
.bl_lp_int = 21,
.bl_hs_int = 0, /* DSI_VM_TIMING6 */
.exit_lat = 16,
.enter_lat = 16, /* DSI_VM_TIMING7 */
static struct omap_dss_device lcd_wvga = {
.name = "lcd",
.driver_name = "wvga_lcd",
.type = OMAP_DISPLAY_TYPE_DSI,
.phy.dsi = {
.clk_lane = 1,
.clk_pol = 0,
.data1_lane = 2,
.data1_pol = 0,
.data2_lane = 3,
.data2_pol = 0,
.data3_lane = 0,
.data3_pol = 0,
.data4_lane = 0,
.data4_pol = 0,
.type = OMAP_DSS_DSI_TYPE_VIDEO_MODE,
.line_bufs = 2,
.panel = {
.timings = {
.x_res = 480,
.y_res = 800,
.pixel_clock = 30396,
.hfp = 48,
.hsw = 20,
.hbp = 48,
.vfp = 29,
.vsw = 4,
.vbp = 17,
.acbi = 0,
.acb = 40,
.width_in_um = 75000,
.height_in_um = 130000,
.clocks = {
.dispc = {
.channel = {
.lck_div = 1, /* LCD */
.pck_div = 4, /* PCD */
.lcd_clk_src =
OMAP_DSS_CLK_SRC_DSI_PLL_HSDIV_DISPC,
.dispc_fclk_src = OMAP_DSS_CLK_SRC_FCK,
.dsi = {
.regn = 19, /* DSI_PLL_REGN */
.regm = 178, /* DSI_PLL_REGM */
.regm_dispc = 6, /* PLL_CLK1 (M4) */
.regm_dsi = 5, /* PLL_CLK2 (M5) */
.lp_clk_div = 8, /* LPDIV */
.offset_ddr_clk = 0, /* DDR PRE&DDR POST increase */
.dsi_fclk_src = OMAP_DSS_CLK_SRC_DSI_PLL_HSDIV_DSI,
.tlpx = 0xC,
.tclk = {
.zero = 0x3B,
.prepare = 0xF,
.trail = 0x10,
.ths = {
.zero = 0x18,
.prepare = 0x12,
.exit = 0x21,
.trail = 0x13,
.ctrl = {
.pixel_size = 24,
.reset_gpio = 32,
.channel = OMAP_DSS_CHANNEL_LCD,
.skip_init = false,
.dsi_timings = &wvga_lcd_dsi_timings,
Debug messages :
cat /d/omapdss/clk
- DSS -
dpll4_ck 1536000000
DSS_FCK (DSS_FCLK) = 1536000000 / 9 = 170666666
- DISPC -
dispc fclk source = DSS_FCK (DSS_FCLK)
fck 170666666
- DISPC-CORE-CLK -
lck 170666666 lck div 1
- LCD1 -
lcd1_clk source = DSI_PLL_HSDIV_DISPC (PLL1_CLK1)
lck 119915752 lck div 1
pck 29978938 pck div 4
- LCD2 -
lcd2_clk source = DSS_FCK (DSS_FCLK)
lck 42666666 lck div 4
pck 42666666 pck div 1
- DSI1 PLL -
dsi pll source = dss_sys_clk
Fint 2021052 regn 19
CLKIN4DDR 719494512 regm 178
DSS_FCK (DSS_FCLK) 119915752 regm_dispc 6 (off)
DSI_PLL_HSDIV_DSI (PLL1_CLK2) 143898902 regm_dsi 5 (on)
- DSI1 -
dsi fclk source = DSI_PLL_HSDIV_DSI (PLL1_CLK2)
DSI_FCLK 143898902
DDR_CLK 179873628
TxByteClkHS 44968407
LP_CLK 8993681
cat /d/omapdss/dispc
DISPC_REVISION 00000040
DISPC_SYSCONFIG 00002015
DISPC_SYSSTATUS 00000001
DISPC_IRQSTATUS 000000a2
DISPC_IRQENABLE 0012d640
DISPC_CONTROL 00018309
DISPC_CONFIG 00020004
DISPC_CAPABLE 00000000
DISPC_DEFAULT_COLOR(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DEFAULT_COLOR(OMAP_DSS_CHANNEL_DIGIT) 00000000
DISPC_TRANS_COLOR(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_TRANS_COLOR(OMAP_DSS_CHANNEL_DIGIT) 00000000
DISPC_LINE_STATUS 00000197
DISPC_LINE_NUMBER 00000000
DISPC_TIMING_H(OMAP_DSS_CHANNEL_LCD) 02f02f13
DISPC_TIMING_V(OMAP_DSS_CHANNEL_LCD) 01101d03
DISPC_POL_FREQ(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DIVISORo(OMAP_DSS_CHANNEL_LCD) 00010004
DISPC_GLOBAL_ALPHA ffffffff
DISPC_SIZE_MGR(OMAP_DSS_CHANNEL_DIGIT) 00000000
DISPC_SIZE_MGR(OMAP_DSS_CHANNEL_LCD) 031f01df
DISPC_CONTROL2 00000000
DISPC_CONFIG2 00000000
DISPC_DEFAULT_COLOR(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_TRANS_COLOR(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_TIMING_H(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_TIMING_V(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_POL_FREQ(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_DIVISORo(OMAP_DSS_CHANNEL_LCD2) 00040001
DISPC_SIZE_MGR(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_OVL_BA0(OMAP_DSS_GFX) 10000000
DISPC_OVL_BA1(OMAP_DSS_GFX) 10000000
DISPC_OVL_POSITION(OMAP_DSS_GFX) 00000000
DISPC_OVL_SIZE(OMAP_DSS_GFX) 031f01df
DISPC_OVL_ATTRIBUTES(OMAP_DSS_GFX) 32004099
DISPC_OVL_FIFO_THRESHOLD(OMAP_DSS_GFX) 04ff0358
DISPC_OVL_FIFO_SIZE_STATUS(OMAP_DSS_GFX) 00000500
DISPC_OVL_ROW_INC(OMAP_DSS_GFX) 00007881
DISPC_OVL_PIXEL_INC(OMAP_DSS_GFX) 00000001
DISPC_OVL_WINDOW_SKIP(OMAP_DSS_GFX) 00000000
DISPC_OVL_TABLE_BA(OMAP_DSS_GFX) 00000000
DISPC_DATA_CYCLE1(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DATA_CYCLE2(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DATA_CYCLE3(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_CPR_COEF_R(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_CPR_COEF_G(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_CPR_COEF_B(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DATA_CYCLE1(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_DATA_CYCLE2(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_DATA_CYCLE3(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_CPR_COEF_R(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_CPR_COEF_G(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_CPR_COEF_B(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_OVL_PRELOAD(OMAP_DSS_GFX) 000004ff
DISPC_OVL_BA0(o) 7fa245c0
DISPC_OVL_BA1(o) 7fa245c0
DISPC_OVL_POSITION(o) 00000000
DISPC_OVL_SIZE(o) 031f01df
DISPC_OVL_ATTRIBUTES(o) 02008010
DISPC_OVL_FIFO_THRESHOLD(o) 07ff03d0
DISPC_OVL_FIFO_SIZE_STATUS(o) 00000800
DISPC_OVL_ROW_INC(o) 00000b81
DISPC_OVL_PIXEL_INC(o) 00000001
DISPC_OVL_FIR(o) 04000400
DISPC_OVL_PICTURE_SIZE(o) 031f01df
DISPC_OVL_ACCU0(o) 00000000
DISPC_OVL_ACCU1(o) 00000000
DISPC_OVL_FIR_COEF_H(o, i) 00800000
DISPC_OVL_FIR_COEF_H(o, i) 0d7cf800
DISPC_OVL_FIR_COEF_H(o, i) 1e70f5ff
DISPC_OVL_FIR_COEF_H(o, i) 335ff5fe
DISPC_OVL_FIR_COEF_H(o, i) f74949f7
DISPC_OVL_FIR_COEF_H(o, i) f55f33fb
DISPC_OVL_FIR_COEF_H(o, i) f5701efe
DISPC_OVL_FIR_COEF_H(o, i) f87c0dff
DISPC_OVL_FIR_COEF_HV(o, i) 00800000
DISPC_OVL_FIR_COEF_HV(o, i) 037b02ff
DISPC_OVL_FIR_COEF_HV(o, i) 0c6f05fe
DISPC_OVL_FIR_COEF_HV(o, i) 205907fb
DISPC_OVL_FIR_COEF_HV(o, i) 00404000
DISPC_OVL_FIR_COEF_HV(o, i) 075920fe
DISPC_OVL_FIR_COEF_HV(o, i) 056f0cff
DISPC_OVL_FIR_COEF_HV(o, i) 027b0300
DISPC_OVL_CONV_COEF(o, i) 00000000
DISPC_OVL_FIR_COEF_V(o, i) 00000000
DISPC_OVL_BA0_UV(o) 00000000
DISPC_OVL_BA1_UV(o) 00000000
DISPC_OVL_FIR2(o) 04000400
DISPC_OVL_ACCU2_0(o) 00000000
DISPC_OVL_ACCU2_1(o) 00000000
DISPC_OVL_FIR_COEF_H2(o, i) 00000000
DISPC_OVL_FIR_COEF_HV2(o, i) 00000000
DISPC_OVL_FIR_COEF_V2(o, i) 00000000
DISPC_OVL_ATTRIBUTES2(o) 00000000
DISPC_OVL_PRELOAD(o) 000007ff
DISPC_OVL_BA0(o) 7fdda000
DISPC_OVL_BA1(o) 7fdda000
DISPC_OVL_POSITION(o) 00300000
DISPC_OVL_SIZE(o) 02ef01df
DISPC_OVL_ATTRIBUTES(o) 16008018
DISPC_OVL_ROW_INC(o) 00000001
DISPC_OVL_PICTURE_SIZE(o) 02ef01df
DISPC_OVL_BA0(o) 7ff3b000
DISPC_OVL_BA1(o) 7ff3b000
DISPC_OVL_SIZE(o) 002f01df
DISPC_OVL_ATTRIBUTES(o) 0a008010
DISPC_OVL_PICTURE_SIZE(o) 002f01df
cat /d/omapdss/dsi1_regs
DSI_REVISION 00000030
DSI_SYSCONFIG 00000015
DSI_SYSSTATUS 00000001
DSI_IRQSTATUS 00000080
DSI_IRQENABLE 0015c000
DSI_CTRL 00daea99
DSI_COMPLEXIO_CFG1 6a000321
DSI_COMPLEXIO_IRQ_STATUS 00000000
DSI_COMPLEXIO_IRQ_ENABLE 3ff07fff
DSI_CLK_CTRL a0346008
DSI_TIMING1 7fff7fff
DSI_TIMING2 ffff7fff
DSI_VM_TIMING1 00046063
DSI_VM_TIMING2 04041d11
DSI_VM_TIMING3 037e0320
DSI_CLK_TIMING 00001b10
DSI_TX_FIFO_VC_SIZE 13121110
DSI_RX_FIFO_VC_SIZE 13121110
DSI_COMPLEXIO_CFG2 00030000
DSI_RX_FIFO_VC_FULLNESS 00000000
DSI_VM_TIMING4 00000000
DSI_TX_FIFO_VC_EMPTINESS 1f1f1f1f
DSI_VM_TIMING5 00000002
DSI_VM_TIMING6 00000015
DSI_VM_TIMING7 00100010
DSI_STOPCLK_TIMING 00000080
DSI_VC_CTRL(0) 20808791
DSI_VC_TE(0) 00000000
DSI_VC_LONG_PACKET_HEADER(0) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(0) 00000000
DSI_VC_SHORT_PACKET_HEADER(0) 00000000
DSI_VC_IRQSTATUS(0) 00000004
DSI_VC_IRQENABLE(0) 000000db
DSI_VC_CTRL(1) 20808f81
DSI_VC_TE(1) 00000000
DSI_VC_LONG_PACKET_HEADER(1) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(1) 00000000
DSI_VC_SHORT_PACKET_HEADER(1) 00000000
DSI_VC_IRQSTATUS(1) 00000004
DSI_VC_IRQENABLE(1) 000000db
DSI_VC_CTRL(2) 20808d81
DSI_VC_TE(2) 00000000
DSI_VC_LONG_PACKET_HEADER(2) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(2) 00000000
DSI_VC_SHORT_PACKET_HEADER(2) 00000000
DSI_VC_IRQSTATUS(2) 00000000
DSI_VC_IRQENABLE(2) 000000db
DSI_VC_CTRL(3) 20808d81
DSI_VC_TE(3) 00000000
DSI_VC_LONG_PACKET_HEADER(3) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(3) 00000000
DSI_VC_SHORT_PACKET_HEADER(3) 00000000
DSI_VC_IRQSTATUS(3) 00000000
DSI_VC_IRQENABLE(3) 000000db
DSI_DSIPHY_CFG0 122a1321
DSI_DSIPHY_CFG1 4206103b
DSI_DSIPHY_CFG2 b800000f
DSI_DSIPHY_CFG5 e7000000
DSI_PLL_CONTROL 00000000
DSI_PLL_STATUS 00000383
DSI_PLL_GO 00000000
DSI_PLL_CONFIGURATION1 10a16425
DSI_PLL_CONFIGURATION2 00656008
cat /d/omapdss/dss
DSS_REVISION 00000040
DSS_SYSCONFIG 00000000
DSS_SYSSTATUS 00000001
DSS_CONTROL 00000003
Is there something wrong in my DSI/DISPC settings? How do I fix this issue?
Any assistance you can provide would be greatly appreciated.
  • Hi Tim,
    I am not sure what might be causing the problem, but  is it me or the clock graphics on the screen ( perhaps it  is on different layer) seems quite sharp despite everything else that is blurry?
    Boyko
  • Hi Boyko,
       Thanks for your reply, the clock graphics looks sharper than other items on the screen. Here are more screenshots for your reference (brightness = MAX):
    Original color bar :
    As you can see, LCD has abnormal display on web browsering/color bar/applications.
    Is is possible to solve this issue by adjusting DSI/DISPC settings?
    Tim
  • Tim, if it is software related the problem can always be resolved by re-timing. Are you completely sure there is no noise or  cross-talk source disrupting the DSI?
    BTW Did you try with different pixel clock frequency?
  • Hi Boyko,
        I have tried different pixel clock frequecy but still got similar results. I am also checking our OMAP4460 custom board with hardware engineer and LCD vendor to make sure there are no hardware issues.
    Tim
  • Hi Boyko,
        The problem has been solved by reworking hardware, thanks for your support!
    Tim
