I am having one doubt regarding Programming on TMDSEVM6678.
Would the Boot configuration will effect the hardware initialization especially 80 pin expansion header.
What boot configuration should set at the user switchs(SW3,5,7,9)
I have written a c code using platform library to transfer 3 bytes of data through the master pin of SPI pins(63,65,67,69).
#include <c6x.h>
#include <stdint.h>
#include <evmc66x_spi.h>
#include <stdio.h>
#include <cslr_spi.h>
#include <platform.h>
#include "platform_internal.h"
SPI_STATUS status1, status2;
void main(void) {
int i;
PowerUpDomains();
uint8_t array1[] = {0xAA ,0x55, 0xFF};
uint8_t* ptr1;
// uint16_t array1[] = {0xAA ,0x55, 0xFF};
// uint16_t* ptr1;
ptr1 = &array1[0];
while (1){
status1 =spi_claim(0,10000000);
printf("%d",status1);
if (status1 == SPI_EOK)
break;
for (i=1;i<1000;i++)
status2 = spi_xfer(0x00000003,ptr1,0,0);
printf("%d\n",status2);
printf("data transmitted\n");
// status2 = spi_write_word(ptr1,0x00000003,0x0000,0x00000000);
spi_release();
printf("spi released\n");
* Copyright (c) 2011 Texas Instruments Incorporated - http://www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* File Name: evmc66x_spi.c
* Description: This file implements SPI driver for the NOR flash
* Include Files
#include <stdio.h>
static uint32_t data1_reg_val;
void spi_delay
uint32_t delay
volatile uint32_t i;
for ( i = 0 ; i < delay ; i++ ){ };
* Function: spi_claim
* Description: This function claims the SPI bus in the SPI controller
* Parameters: Uint32 cs - Chip Select number for the slave SPI device
* Uint32 freq - SPI clock frequency
* Return Value: error status
SPI_STATUS
spi_claim
uint32_t cs,
uint32_t freq
uint32_t scalar;
// printf("in spi claim1\n");
PLIBSPILOCK()
/* Enable the SPI hardware */
SPI_SPIGCR0 = CSL_SPI_SPIGCR0_RESET_IN_RESET;
// spi_delay (2000);
SPI_SPIGCR0 = CSL_SPI_SPIGCR0_RESET_OUT_OF_RESET;
/* Set master mode, powered up and not activated */
SPI_SPIGCR1 = (CSL_SPI_SPIGCR1_MASTER_MASTER << CSL_SPI_SPIGCR1_MASTER_SHIFT) |
(CSL_SPI_SPIGCR1_CLKMOD_INTERNAL << CSL_SPI_SPIGCR1_CLKMOD_SHIFT);
/* CS0, CS1, CLK, Slave in and Slave out are functional pins */
if (cs == 0) {
SPI_SPIPC0 = (CSL_SPI_SPIPC0_SCS0FUN0_SPI << CSL_SPI_SPIPC0_SCS0FUN0_SHIFT) |
(CSL_SPI_SPIPC0_CLKFUN_SPI << CSL_SPI_SPIPC0_CLKFUN_SHIFT) |
(CSL_SPI_SPIPC0_SIMOFUN_SPI << CSL_SPI_SPIPC0_SIMOFUN_SHIFT) |
(CSL_SPI_SPIPC0_SOMIFUN_SPI << CSL_SPI_SPIPC0_SOMIFUN_SHIFT);
} else if (cs == 1) {
SPI_SPIPC0 = ((CSL_SPI_SPIPC0_SCS0FUN1_SPI << CSL_SPI_SPIPC0_SCS0FUN1_SHIFT) |
(CSL_SPI_SPIPC0_SOMIFUN_SPI << CSL_SPI_SPIPC0_SOMIFUN_SHIFT)) & 0xFFFF;
/* setup format */
scalar = ((SPI_MODULE_CLK / freq) - 1 ) & 0xFF;
if ( cs == 0) {
SPI_SPIFMT0 = (8 << CSL_SPI_SPIFMT_CHARLEN_SHIFT) |
(scalar << CSL_SPI_SPIFMT_PRESCALE_SHIFT) |
(CSL_SPI_SPIFMT_PHASE_DELAY << CSL_SPI_SPIFMT_PHASE_SHIFT) |
(CSL_SPI_SPIFMT_POLARITY_LOW << CSL_SPI_SPIFMT_POLARITY_SHIFT) |
(CSL_SPI_SPIFMT_SHIFTDIR_MSB << CSL_SPI_SPIFMT_SHIFTDIR_SHIFT);
}else if ( cs == 1) {
SPI_SPIFMT0 = (16 << CSL_SPI_SPIFMT_CHARLEN_SHIFT) |
(CSL_SPI_SPIFMT_PHASE_NO_DELAY << CSL_SPI_SPIFMT_PHASE_SHIFT) |
/* hold cs active at end of transfer until explicitly de-asserted */
data1_reg_val = (CSL_SPI_SPIDAT1_CSHOLD_ENABLE << CSL_SPI_SPIDAT1_CSHOLD_SHIFT) |
(0x02 << CSL_SPI_SPIDAT1_CSNR_SHIFT);
if (cs == 0) {
SPI_SPIDAT1 = (CSL_SPI_SPIDAT1_CSHOLD_ENABLE << CSL_SPI_SPIDAT1_CSHOLD_SHIFT) |
/* including a minor delay. No science here. Should be good even with
* no delay
if (cs == 0) {
SPI_SPIDELAY = (8 << CSL_SPI_SPIDELAY_C2TDELAY_SHIFT) |
(8 << CSL_SPI_SPIDELAY_T2CDELAY_SHIFT);
/* default chip select register */
SPI_SPIDEF = CSL_SPI_SPIDEF_RESETVAL;
SPI_SPIDELAY = (6 << CSL_SPI_SPIDELAY_C2TDELAY_SHIFT) |
(3 << CSL_SPI_SPIDELAY_T2CDELAY_SHIFT);
/* no interrupts */
SPI_SPIINT0 = CSL_SPI_SPIINT0_RESETVAL;
SPI_SPILVL = CSL_SPI_SPILVL_RESETVAL;
/* enable SPI */
SPI_SPIGCR1 |= ( CSL_SPI_SPIGCR1_ENABLE_ENABLE << CSL_SPI_SPIGCR1_ENABLE_SHIFT );
if (cs == 1) {
SPI_SPIDAT0 = 1 << 15;
spi_delay (10000);
/* Read SPIFLG, wait untill the RX full interrupt */
if ( (SPI_SPIFLG & (CSL_SPI_SPIFLG_RXINTFLG_FULL<<CSL_SPI_SPIFLG_RXINTFLG_SHIFT)) ) {
/* Read one byte data */
scalar = SPI_SPIBUF & 0xFF;
/* Clear the Data */
SPI_SPIBUF = 0;
else {
return SPI_EFAIL;
// printf("in spi claim2\n");
return SPI_EOK;
* Function: spi_release
* Description: This function releases the bus in SPI controller
* Parameters: None
* Return Value: None
void
spi_release
void
/* Disable the SPI hardware */
// printf("in spi release1\n");
SPI_SPIGCR1 = CSL_SPI_SPIGCR1_RESETVAL;
PLIBSPIRELEASE()
// printf("in spi release2\n");
* Function: spi_xfer
* Description: This function sends and receives 8-bit data serially
* Parameters: uint32_t nbytes - Number of bytes of the TX data
* uint8_t* data_out - Pointer to the TX data
* uint8_t* data_in - Pointer to the RX data
* Bool terminate - TRUE: terminate the transfer, release the CS
* FALSE: hold the CS
SPI_STATUS
spi_xfer
uint32_t nbytes,
uint8_t* data_out,
uint8_t* data_in,
Bool terminate
uint32_t i, buf_reg;
uint8_t* tx_ptr = data_out;
uint8_t* rx_ptr = data_in;
/* Clear out any pending read data */
SPI_SPIBUF;
// printf("in spi xfer1\n");
for (i = 0; i < nbytes; i++)
/* Wait untill TX buffer is not full */
while( SPI_SPIBUF & CSL_SPI_SPIBUF_TXFULL_MASK );
/* Set the TX data to SPIDAT1 */
data1_reg_val &= ~0xFFFF;
if(tx_ptr)
data1_reg_val |= *tx_ptr & 0xFF;
tx_ptr++;
/* Write to SPIDAT1 */
if((i == (nbytes -1)) && (terminate))
/* Release the CS at the end of the transfer when terminate flag is TRUE */
SPI_SPIDAT1 = data1_reg_val & ~(CSL_SPI_SPIDAT1_CSHOLD_ENABLE << CSL_SPI_SPIDAT1_CSHOLD_SHIFT);
} else
//// value=0x000121DA;
// for (i=0;i<8;i++)
// SPI_SPIDAT1 = (data1_reg_val>>i);
// printf("P2_one\n");
SPI_SPIDAT1= data1_reg_val;
/* Read SPIBUF, wait untill the RX buffer is not empty */
while ( SPI_SPIBUF & ( CSL_SPI_SPIBUF_RXEMPTY_MASK ) );
buf_reg = SPI_SPIBUF;
if(rx_ptr)
*rx_ptr = buf_reg & 0xFF;
rx_ptr++;
// printf("in spi xfer2\n");
return SPI_EOK;
* Function: spi_cmd
* Description: This function sends a single byte command and receives response data
* Parameters: uint8_t cmd - Command sent to the NOR flash
* uint8_t* response - Pointer to the RX response data
* uint32_t len - Lenght of the response in bytes
SPI_STATUS
spi_cmd
uint8_t cmd,
uint8_t* response,
uint32_t len
Bool flags = FALSE;
uint32_t ret;
if (len == 0)
flags = TRUE;
/* Send the command byte */
ret = spi_xfer(1, &cmd, NULL, flags);
if (ret)
IFPRINT (platform_write("SF: Failed to send command %02x: %d\n", cmd, ret));
return ret;
/* Receive the response */
if (len)
ret = spi_xfer(len, NULL, response, TRUE);
if (ret)
IFPRINT (platform_write("SF: Failed to read response (%zu bytes): %d\n", len, ret));
return ret;
* Function: spi_cmd_read
* Description: This function sends a read command and reads data from the flash
* uint32_t cmd_len - Length of the command in bytes
* uint8_t* dat - Pointer to the data read
* uint32_t data_len - Lenght of the data read in bytes
SPI_STATUS
spi_cmd_read
uint8_t* cmd,
uint32_t cmd_len,
uint8_t* data,
uint32_t data_len
Bool flags = FALSE;
uint32_t ret;
if (data_len == 0)
flags = TRUE;
/* Send read command */
ret = spi_xfer(cmd_len, cmd, NULL, flags);
if (ret)
IFPRINT (platform_write("SF: Failed to send read command (%zu bytes): %d\n",
cmd_len, ret));
else if (data_len != 0)
/* Read data */
ret = spi_xfer(data_len, NULL, data, TRUE);
if (ret)
IFPRINT (platform_write("SF: Failed to read %zu bytes of data: %d\n",
data_len, ret));
return ret;
* Function: spi_cmd_write
* Description: This function sends a write command and writes data to the flash
* uint8_t* dat - Pointer to the data to be written
* uint32_t data_len - Lenght of the data in bytes
SPI_STATUS
spi_cmd_write
uint8_t* cmd,
uint32_t cmd_len,
uint8_t* data,
uint32_t data_len
Bool flags = FALSE;
uint32_t ret;
if (data_len == 0)
flags = TRUE;
/* Send write command */
if (ret)
IFPRINT (platform_write("SF: Failed to send write command (%zu bytes): %d\n",
cmd_len, ret));
/* Write data */
ret = spi_xfer(data_len, data, NULL, TRUE);
if (ret)
IFPRINT (platform_write("SF: Failed to write %zu bytes of data: %d\n",
data_len, ret));
return ret;
* Function: spi_read_word
* Description: This function sends a read command and reads data in 16-bit data format
* Parameters: uint16_t* cmd_buf - Pointer to the command sent
* uint32_t cmd_len - Length of the command in words
* uint16_t* data_buf - Pointer to the data read
* uint32_t data_len - Lenght of the data read in words
SPI_STATUS
spi_read_word
uint16_t* cmd_buf,
uint32_t cmd_len,
uint16_t* data_buf,
uint32_t data_len
uint32_t data1_reg;
uint16_t* tx_ptr = cmd_buf;
uint16_t* rx_ptr = data_buf;
/* disable the SPI communication by setting
* the SPIGCR1.ENABLE to 0
* SPIGCR1
* Bit Field Value Description
* 24 ENABLE 0 SPI disable
data1_reg = 0x1 << 24;
data1_reg = ~data1_reg;
SPI_SPIGCR1 &= data1_reg;
* clean TX data into SPIDAT0
* SPIDAT0
* 15-0 TXDATA 0-FFFFh SPI transmit data
SPI_SPIDAT0 = 0;
/* 8.
* Enable the SPI communication by setting
* the SPIGCR1.ENABLE to 1
* SPIGCR1
* 24 ENABLE 1 SPI enable
SPI_SPIGCR1 = (SPI_SPIGCR1 | data1_reg);
SPI_SPIDAT0 = *tx_ptr;
spi_delay(10000);
*rx_ptr = SPI_SPIBUF & 0xFF;
SPI_SPIBUF = 0;
else {
return SPI_EFAIL;
return SPI_EOK;
* Function: spi_write_word
* Description: This function sends a write command and writes data in 16-bit data format
SPI_STATUS
spi_write_word
uint16_t* cmd_buf,
uint32_t cmd_len,
uint16_t* data_buf,
uint32_t data_len
uint32_t data1_reg;
* SPIGCR1
* SPIDAT0
SPI_SPIDAT0 = 0;
/* 8.
* SPIGCR1
spi_delay(10000);
if ( (SPI_SPIFLG & (CSL_SPI_SPIFLG_TXINTFLG_EMPTY<<CSL_SPI_SPIFLG_TXINTFLG_SHIFT)) ) {
/* Clear the SPIBUF */
SPI_SPIBUF = 0;
return SPI_EOK;
else {
return SPI_EFAIL;
Here I am observing the SPI pins in oscilloscope. For my source code I am not observing the 3 bytes of data at master output and no clock at clock pin. Can anybody help me and let me know If I am doing any mistake.
thank you.
regards,
chandu.
