Other Parts Discussed in Thread: OMAP-L138
Could I using DDR2 256Mx4 *4(H5PS1G431CFR-E3) that config to 512MB for OMAP-L138 of DDR2/mDDR-memory-controller. thanks!
The L138 device supports up to 512MBbytes of DDR2 memory, however, you need a memory that uses 14 address pins.
Thanks for your reply!
At now, large capacity DDR2-component (>=2Gb) Row-address >= 15-bit(32768) and OMAP-L138 DDR2/mDDR memory controller's DQ width only 16-bit.
I can not find DDR2-component can consist 512MB capacity.
Do you can recommend DDR2-component and part-number?
Thank you!
Unfortunately last time we checked (about a month ago), there wasn't a memory solution available for the L138 that could get you to 512MB at a reasonable cost.
