Is there any way to change the default boot sequence of the TWL6030?
I would like to control the SYSEN pin. Is this user-controlled at all or will it always be pulled high at boot, according to the default boot sequence.
Hello Ryan,
What is your application with TWL6030?
If you use TWL6030 to supply OMAP44xx platform, you can refer to OMAP4460 Errata document version I at TI website.
For more information about SYSEN pin usage, see Errata ID i746 - "SYSEN Usage for an OMAP44xx Platform based on TWL6030/TWL6032 and TPS62361B". The link to this document is - http://www.ti.com/lit/er/swpz017i/swpz017i.pdf There is an example, how is right to use this pin.
Refer to application notes for TWL6030 - TWL6030 Gas Gauging Basics and TWL6030 Battery Charging in TI website.
If you need additional information, contact with your TI sales representative.
Yanko
