Other Parts Discussed in Thread: AM3358
I have downloaded AER(aer_16_1_0_3_release_notes) from ti web site and followed the Installation & Verification document to Cross Compile and run the code on SITARA AM335x starter kit. Later running the binary compared the generated output pcm's and ref pcm and found bit exact.
Now the question is, I want to give a manually recorded "single input file" (using gold wave or any other tool) which has an echo and want to run it through the AER code then please let me know the procedure for it.
Note: I have mentioned "single input file" because it is observed that AER test application requires two pcm files viz. near end and far end.
G.Shricharan
