Syslink module load failed on OMAP-L138
Other Parts Discussed in Thread: OMAP-L138, SYSBIOS, OMAP3530
Hello
I am new in Syslink and embedded Linux.
I am trying to run some Syslink examples on OMAP-L138 (board Hawkboard).
I have built u-boot and Linux kernel successfully.
Linux starts and works fine.
I have run "make syslink" and obtained "syslink.ko".
But command "insmod syslink.ko" failed with error:
syslink: Unknown symbol irq_to_desc
insmod: cannot insert 'syslink.ko': unknown symbol in module, or unknown parameter
"insmod syslink.ko TRACE=1 TRACEFAILURE=1" failed with same error.
What did I wrong?
Versions of pruducts:
Syslink 2.21.01.05
Linux kernel 2.6.33-rc4
DaVinci PSP SDK 03.20.00.11
CodeSourcery Lite arm-2009q1-203-arm-none-linux-gnueabi
IPC 1.25.03.15
SYSBIOS 6.35.03.47
XDCTOOLS 3.24.05.48
My configuration file (products.mak) for Syslink:
# Copyright (c) 2008-2012, Texas Instruments Incorporated
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of Texas Instruments Incorporated nor the names of
# its contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
# THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
# OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
# WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
# OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
# EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
SYSLINK_INSTALL_DIR = $(CURDIR)
# List of supported devices (choose one): OMAP3530, OMAPL1XX, TI816X, TI814X
# TI813X, TI811X
DEVICE = OMAPL1XX
# Master core (GPP) OS type (choose one): Linux, Qnx, Bios
GPPOS = Linux
# SysLink Linux driver DEBUG/TRACE options (choose one): 0 or 1
# Note that these options are only used by the Linux HLOS driver. RTOS
# side libraries, Qnx libraries, and user mode Linux libraries are always
# built in both debug and release profiles, and users can switch between
# them when linking their executable (without rebuilding SysLink).
# Enabling SYSLINK_BUILD_DEBUG enables runtime assertion checking and makes
# some internal 'static' methods and objects global (so you can set
# breakpoints on them and/or inspect them in a debugger).
# Enabling SYSLINK_TRACE_ENABLE enables tracing throughout the SysLink
# code base. This is especially helpful during development, but may not
# be necessary at production.
SYSLINK_BUILD_DEBUG=1
SYSLINK_TRACE_ENABLE=1
# SysLink OPTIMIZE option (choose one): 0 or 1
# Enabling SYSLINK_BUILD_OPTIMIZE removes many runtime API checks. As a
# result, if the user uses SysLink in an unsupported way, rather than getting
# a failing return value, the system may crash or become unstable.
# SYSLINK_BUILD_OPTIMIZED is intended to be used in a closed system where all
# code paths are known, and error conditions are ensured never to occur - so
# it's not for everyone.
# Note that SYSLINK_BUILD_OPTIMIZE removes these checks throughout the
# SysLink stack - that includes RTOS, user, and driver layers if applicable
# to your environment.
SYSLINK_BUILD_OPTIMIZE=0
# SysLink HLOS driver Notify options (choose one): NOTIFYDRIVERSHM,
# NOTIFYDRIVERCIRC
SYSLINK_NOTIFYDRIVER=NOTIFYDRIVERSHM
# SysLink HLOS driver MessageQ Transport options (choose one): TRANSPORTSHM,
# TRANSPORTSHMNOTIFY, TRANSPORTSHMCIRC
SYSLINK_TRANSPORT=TRANSPORTSHM
# Set SDK type when building for a TI SDK kit (choose one): EZSDK or NONE
SDK = EZSDK
# Define root dir to install SysLink driver and samples for target file-system
EXEC_DIR = /home/user/program/syslink_fs
# Define file format for loader and slave executables (choose one): COFF, ELF
LOADER = ELF
# Optional: recommended to install all dependent components in one folder.
DEPOT = /home/user/program
# Define the product variables for the device you will be using.
######## For OMAP3530 device ########
ifeq ("$(DEVICE)","OMAP3530")
LINUXKERNEL = $(DEPOT)/_your_linux_kernel_install_
CGT_ARM_INSTALL_DIR = $(DEPOT)/_your_arm_code_gen_install_
CGT_ARM_PREFIX = $(CGT_ARM_INSTALL_DIR)/bin/arm-none-linux-gnueabi-
IPC_INSTALL_DIR = $(DEPOT)/_your_ipc_install_
BIOS_INSTALL_DIR = $(DEPOT)/_your_bios_install_
XDC_INSTALL_DIR = $(DEPOT)/_your_xdctools_install_
# If LOADER=ELF then below elf tools path is required else set C64P path
ifeq ("$(LOADER)","ELF")
CGT_C64P_ELF_INSTALL_DIR= $(DEPOT)/_your_c64pelf_code_gen_install_
else
CGT_C64P_INSTALL_DIR = $(DEPOT)/_your_c64p_code_gen_install_
endif
######## For TI816X device ########
else ifeq ("$(DEVICE)","TI816X")
CGT_C674_ELF_INSTALL_DIR= $(DEPOT)/_your_c674elf_code_gen_install_
# SYS/BIOS timer frequency (ti.sysbios.timers.dmtimer.Timer.intFreq)
TI81XXDSP_DMTIMER_FREQ = 32768
# If SDK=NONE then below tools path is required
ifeq ("$(SDK)","NONE")
CGT_M3_ELF_INSTALL_DIR = $(DEPOT)/_your_m3elf_code_gen_install_
endif
######## For TI814X device ########
else ifeq ("$(DEVICE)","TI814X")
# Set one of the following OS variables
QNX_INSTALL_DIR = $(DEPOT)/_your_qnx_install_
TI81XXDSP_DMTIMER_FREQ = 20000000
endif
# If GPPOS=Bios then below tools path is required
ifeq ("$(GPPOS)","Bios")
CGT_A8_ELF_INSTALL_DIR = $(DEPOT)/_your_a8elf_code_gen_install_
endif
######## For TI813X device ########
else ifeq ("$(DEVICE)","TI813X")
endif
######## For TI811X device ########
else ifeq ("$(DEVICE)","TI811X")
endif
######## For OMAPL1XX device ########
else ifeq ("$(DEVICE)","OMAPL1XX")
LINUXKERNEL = $(DEPOT)/OMAP-L138_arm_1_00_00_11/DaVinci-PSP-SDK-03.20.00.11/src/kernel/linux-03.20.00.11
CGT_ARM_INSTALL_DIR = $(DEPOT)/CodeSourcery/Sourcery_G++_Lite
IPC_INSTALL_DIR = $(DEPOT)/ipc_1_25_03_15
BIOS_INSTALL_DIR = $(DEPOT)/bios_6_35_03_47
XDC_INSTALL_DIR = $(DEPOT)/xdctools_3_24_05_48
# If LOADER=ELF then below elf tools path is required else set C674 path
CGT_C674_ELF_INSTALL_DIR= $(DEPOT)/TI_CGT_C6000_7.4.5
else
CGT_C674_INSTALL_DIR= $(DEPOT)/_your_c674_code_gen_install_
endif
######## End of device specific variables ########
else ifeq ($(MAKECMDGOALS), clean)
else ifeq ($(MAKECMDGOALS), clobber)
else ifeq ($(MAKECMDGOALS), .show-products)
else ifeq ($(MAKECMDGOALS), help)
else
$(error DEVICE is set to "$(DEVICE)", which is invalid. Set this in <SysLink Install>/products.mak. Refer to the SysLink Install Guide for more information)
endif
# Use this goal to print your product variables.
.show-products:
@echo "DEPOT = $(DEPOT)"
@echo "DEVICE = $(DEVICE)"
@echo "GPPOS = $(GPPOS)"
@echo "SDK = $(SDK)"
@echo "TI81XXDSP_DMTIMER_FREQ = $(TI81XXDSP_DMTIMER_FREQ)"
@echo "SYSLINK_BUILD_DEBUG = $(SYSLINK_BUILD_DEBUG)"
@echo "SYSLINK_BUILD_OPTIMIZE = $(SYSLINK_BUILD_OPTIMIZE)"
@echo "SYSLINK_TRACE_ENABLE = $(SYSLINK_TRACE_ENABLE)"
@echo "LOADER = $(LOADER)"
@echo "SYSLINK_INSTALL_DIR = $(SYSLINK_INSTALL_DIR)"
@echo "IPC_INSTALL_DIR = $(IPC_INSTALL_DIR)"
@echo "BIOS_INSTALL_DIR = $(BIOS_INSTALL_DIR)"
@echo "XDC_INSTALL_DIR = $(XDC_INSTALL_DIR)"
@echo "LINUXKERNEL = $(LINUXKERNEL)"
@echo "QNX_INSTALL_DIR = $(QNX_INSTALL_DIR)"
@echo "CGT_ARM_PREFIX = $(CGT_ARM_PREFIX)"
@echo "CGT_C64P_INSTALL_DIR = $(CGT_C64P_INSTALL_DIR)"
@echo "CGT_C64P_ELF_INSTALL_DIR = $(CGT_C64P_INSTALL_DIR)"
@echo "CGT_C674_INSTALL_DIR = $(CGT_C674_INSTALL_DIR)"
@echo "CGT_C674_ELF_INSTALL_DIR = $(CGT_C674_ELF_INSTALL_DIR)"
@echo "CGT_M3_ELF_INSTALL_DIR = $(CGT_M3_ELF_INSTALL_DIR)"
@echo "CGT_A8_ELF_INSTALL_DIR = $(CGT_A8_ELF_INSTALL_DIR)"
@echo "EXEC_DIR = $(EXEC_DIR)"
