[DM8127 IPNC RDK 3.0]Debug Information
Hi, all
  1. I meet the following error:
TimeOut occure in boot_proc.
Program exit.
Program exit.
It looks like a lot of situation will result in this error. So I want to the Information.
For example, in system_control.c, this following codes
#ifdef SYS_CTRL_DEBUG
#define DBG(fmt, args...)    fprintf(stderr, fmt, ##args)
#else
#endif
#define __E(fmt, args...) fprintf(stderr, "Error: " fmt, ## args)
decides print the debug information or not.
I want to ask that how can just change makefile or rulse.make, so that I can get all debug information, not just some programs.
2.  In our project, we just change power ICs and other little change to hardware. Now I meet the
Program exit.
Program exit.
error. the attachment is the boot log.
I have no idea to solve this problem. pls, give me some suggestions.
U-Boot 2010.06 (Jun 19 2012 - 00:05:44) DM8127_IPNC_3.00.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM:  512 MiB
NAND:  HW ECC BCH8 Selected
256 MiB
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
Hit any key to stop autoboot:  0
NAND read: device 0 offset 0x20000, size 0x40000
 262144 bytes read: OK
## Starting application at 0x81000000 ...
U-Boot 2010.06 (Jul 09 2013 - 01:59:07) DM8127_IPNC_3.00.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C:   ready
DRAM:  512 MiB
256 MiB
MMC:   OMAP SD/MMC: 0, ON-BOARD SDIO: 1
                          .:;rrr;;.
                    ,5#@@@@#####@@@@@@#2,
                 ,A@@@hi;;;r5;;;;r;rrSG@@@A,
               r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
             :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
            B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
           @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
          @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
         @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
        G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
        @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
       X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
       @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
       @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
       @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
       @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
       M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
       :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
        @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
         @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
         ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
          r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
           ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
             B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
              .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
                .A@@#5r;;;r;;;rrr;r:r#AsM@@H.
                   ;&@@@@MhXS5i5SX9B@@@@G;
                       :ihM#@@@@@##hs,
Net:   Detected MACID:84:7e:40:b6:ed:d0
cpsw
Loading from nand0, offset 0x280000
   Image Name:   Linux-2.6.37_DM8127_IPNC_3.00.00
   Created:      2012-06-18  18:42:29 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2338808 Bytes = 2.2 MiB
   Load Address: 80008000
   Entry Point:  80008000
## Booting kernel from Legacy Image at 81000000 ...
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM8127_IPNC_3.00.00 (a0875405@bangvideoapps01) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Tue Jun 19 00:12:25 IST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 19296
Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 rootdelay=10 nfsroot=192.168.1.48:/home/yc/IPNC_RDK/Source/ipnc_rdk/target/filesys,nolock ip=192.168.1.168:192.168.1.43:192.168.1.1:255.255.255.0::eth0:off cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 76MB = 76MB total
Memory: 72024k/72024k available, 9896k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc5800000 - 0xf8000000   ( 808 MB)
    lowmem  : 0xc0000000 - 0xc5000000   (  80 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0038000   ( 192 kB)
      .text : 0xc0038000 - 0xc046d000   (4308 kB)
      .data : 0xc046e000 - 0xc04ab400   ( 245 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 598.01 BogoMIPS (lpj=2990080)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
omap_i2c omap_i2c.1: controller timed out
tps65910 1-002d: read from reg 3f failed
tps65910 1-002d: read from reg 1e failed
set_machine_constraints: failed to enable VRTC
tps65910 1-002d: failed to register tps65910-pmic regulator
tps65910-pmic: probe of tps65910-pmic failed with error -110
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 140
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on Jun 19 2012 at 00:07:25
  Reference Linux version 2.6.37
  File /data/datalocal_videoapps01/user/kudva/DM812x/IPNetCam/ti_tools/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 7 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x00000c000000 : "File System"
0x00000c000000-0x00000cc00000 : "Data"
0x00000cc00000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbfd00000
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
  #0: TI8148 IPNC
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=84:7e:40:b6:ed:d0
tps65911-rtc tps65911-rtc: hctosys: unable to read the hardware clock
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
IP-Config: Complete:
     device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=192.168.1.1,
     host=192.168.1.168, domain=, nis-domain=(none),
     bootserver=192.168.1.43, rootserver=192.168.1.48, rootpath=
Waiting 10sec before mounting root device...
PHY: 0:00 - Link is Up - 1000/Full
PHY: 0:00 - Link is Down
VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: mounted
Freeing init memory: 192K
INIT: version 2.86 booting
Error opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj instead.
udev: starting version 141
udevd-event[79]: error changing netif name eth0 to eth9: Device or resource busy
Root filesystem already rw, not remounting
Caching udev devnodes
Populating dev cachetar: dev/.udev/queue/590: No such file or directory
tar: dev/.udev/queue/589: No such file or directory
tar: error exit delayed from previous errors
NOT configuring network interfaces: / is an NFS mount
rm: cannot remove '/tmp': Device or resource busy
hwclock: RTC_RD_TIME: Connection timed out
Fri Mar 18 06:44:00 GMT-8 2011
hwclock: RTC_SET_TIME: Connection timed out
 inside finish.sh
numid=1,iface=MIXER,name='PCM Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
  : values=127,127
  | dBscale-min=-63.50dB,step=0.50dB,mute=0
 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
 [m3video] Remote Debug Shared Memory @ 0xbff05020
 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.10.06.28
SysLink module created on Date:Aug 28 2013 Time:16:44:09
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
data 2
             BW Phy Addr : 0x48180d00 Data : 0x00030000
             AW Phy Addr : 0x48180d00 Data : 0x00030002
data 3
             BW Phy Addr : 0x48180d10 Data : 0x00000007
             AW Phy Addr : 0x48180d10 Data : 0x00000003
data 2
             BW Phy Addr : 0x48180700 Data : 0x00000001
             AW Phy Addr : 0x48180700 Data : 0x00000002
data 2
             BW Phy Addr : 0x48180720 Data : 0x00070000
             AW Phy Addr : 0x48180720 Data : 0x00070002
data 2
             BW Phy Addr : 0x48180724 Data : 0x00030000
             AW Phy Addr : 0x48180724 Data : 0x00000002
data 60020
             BW Phy Addr : 0x48140924 Data : 0x000e0020
             AW Phy Addr : 0x48140924 Data : 0x000e0020
data 60020
             BW Phy Addr : 0x48140928 Data : 0x000c0040
             AW Phy Addr : 0x48140928 Data : 0x000c0040
data 60001
             BW Phy Addr : 0x48140c18 Data : 0x000e0001
             AW Phy Addr : 0x48140c18 Data : 0x000e0001
data 60001
             BW Phy Addr : 0x48140c1c Data : 0x000e0001
             AW Phy Addr : 0x48140c1c Data : 0x000e0001
data 2
             BW Phy Addr : 0x48181564 Data : 0x00000002
             AW Phy Addr : 0x48181564 Data : 0x00000002
data 2
             BW Phy Addr : 0x48181568 Data : 0x00030000
             AW Phy Addr : 0x48181568 Data : 0x00000002
             Phy Addr : 0x48181560 Data : 0x00000002
data 2
             BW Phy Addr : 0x48181560 Data : 0x00000002
             AW Phy Addr : 0x48181560 Data : 0x00000002
data 60002
             BW Phy Addr : 0x48140aac Data : 0x00040002
             AW Phy Addr : 0x48140aac Data : 0x00040002
data 60002
             BW Phy Addr : 0x48140ab0 Data : 0x00060002
             AW Phy Addr : 0x48140ab0 Data : 0x00060002
data 60002
             BW Phy Addr : 0x48140ab8 Data : 0x00040002
             AW Phy Addr : 0x48140ab8 Data : 0x00040002
data 60020
             BW Phy Addr : 0x48140a58 Data : 0x000c0080
             AW Phy Addr : 0x48140a58 Data : 0x000c0080
data 60080
             BW Phy Addr : 0x48140a60 Data : 0x000c0080
             AW Phy Addr : 0x48140a60 Data : 0x000c0080
data 60020
             BW Phy Addr : 0x48140a64 Data : 0x000c0080
             AW Phy Addr : 0x48140a64 Data : 0x000c0080
data 60020
             BW Phy Addr : 0x48140a68 Data : 0x000c0080
             AW Phy Addr : 0x48140a68 Data : 0x000c0080
data 60002
             BW Phy Addr : 0x48140aa8 Data : 0x00040002
             AW Phy Addr : 0x48140aa8 Data : 0x00040002
data 60002
             BW Phy Addr : 0x48140aa4 Data : 0x00040002
             AW Phy Addr : 0x48140aa4 Data : 0x00040002
data 60002
             BW Phy Addr : 0x48140aa0 Data : 0x00040002
             AW Phy Addr : 0x48140aa0 Data : 0x00040002
data 60002
             BW Phy Addr : 0x48140a9c Data : 0x00060002
             AW Phy Addr : 0x48140a9c Data : 0x00060002
data 60002
             BW Phy Addr : 0x48140a98 Data : 0x00060002
             AW Phy Addr : 0x48140a98 Data : 0x00060002
data 60002
             BW Phy Addr : 0x48140a94 Data : 0x00060002
             AW Phy Addr : 0x48140a94 Data : 0x00060002
data 60002
             BW Phy Addr : 0x48140a90 Data : 0x00060002
             AW Phy Addr : 0x48140a90 Data : 0x00060002
data 60002
             BW Phy Addr : 0x48140a8c Data : 0x00060002
             AW Phy Addr : 0x48140a8c Data : 0x00060002
data 60002
             BW Phy Addr : 0x48140a6c Data : 0x000e0002
             AW Phy Addr : 0x48140a6c Data : 0x000e0002
data 60002
             BW Phy Addr : 0x48140a70 Data : 0x000c0002
             AW Phy Addr : 0x48140a70 Data : 0x000c0002
data 60002
             BW Phy Addr : 0x48140a74 Data : 0x000e0002
             AW Phy Addr : 0x48140a74 Data : 0x000e0002
data 60002
             BW Phy Addr : 0x48140a78 Data : 0x000e0002
             AW Phy Addr : 0x48140a78 Data : 0x000e0002
data 0
             BW Phy Addr : 0x411f4004 Data : 0x0000000e
             AW Phy Addr : 0x411f4004 Data : 0x00000000
data 0
             BW Phy Addr : 0x411f2004 Data : 0x00000001
             AW Phy Addr : 0x411f2004 Data : 0x00000000
data 1
             BW Phy Addr : 0x41140084 Data : 0x00000001
             AW Phy Addr : 0x41140084 Data : 0x00000001
data 1
             BW Phy Addr : 0x411a0084 Data : 0x00000001
             AW Phy Addr : 0x411a0084 Data : 0x00000001
data 1
             BW Phy Addr : 0x41160034 Data : 0x00000001
             AW Phy Addr : 0x41160034 Data : 0x00000001
data 1
             BW Phy Addr : 0x41121ff0 Data : 0x00000001
             AW Phy Addr : 0x41121ff0 Data : 0x00000001
data 1
             BW Phy Addr : 0x41131fe4 Data : 0x00000000
             AW Phy Addr : 0x41131fe4 Data : 0x00000001
data 1
             BW Phy Addr : 0x411e002c Data : 0x00000000
             AW Phy Addr : 0x411e002c Data : 0x00000001
data 1
             BW Phy Addr : 0x481c52ec Data : 0x00000001
             AW Phy Addr : 0x481c52ec Data : 0x00000001
secss put in low power state
data 1
             BW Phy Addr : 0x48180900 Data : 0x00000001
             AW Phy Addr : 0x48180900 Data : 0x00000001
data 0
             BW Phy Addr : 0x48180f00 Data : 0x00030000
             AW Phy Addr : 0x48180f00 Data : 0x00030000
             Phy Addr : 0x48180f10 Data : 0x00000000
data 2
             BW Phy Addr : 0x4818052c Data : 0x00000002
             AW Phy Addr : 0x4818052c Data : 0x00000002
data 2
             BW Phy Addr : 0x48180508 Data : 0x00000302
             AW Phy Addr : 0x48180508 Data : 0x00000302
data 2
             BW Phy Addr : 0x48180520 Data : 0x00000002
             AW Phy Addr : 0x48180520 Data : 0x00000002
data 2
             BW Phy Addr : 0x48180524 Data : 0x00000002
             AW Phy Addr : 0x48180524 Data : 0x00000002
data 2
             BW Phy Addr : 0x48180528 Data : 0x00000002
             AW Phy Addr : 0x48180528 Data : 0x00000002
             Phy Addr : 0x4c0000e4 Data : 0x00170208
data 170208
             BW Phy Addr : 0x4c0000e4 Data : 0x00170208
             AW Phy Addr : 0x4c0000e4 Data : 0x00170208
             Phy Addr : 0x4d0000e4 Data : 0x00170208
data 170208
             BW Phy Addr : 0x4d0000e4 Data : 0x00170208
             AW Phy Addr : 0x4d0000e4 Data : 0x00170208
data 170208
data 170208
DDR IOs RX is shutdown
 [host]  Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
 [host]  Setting DMM priority for [ISS     ] to [0] ( 0x4e000634 = 0x00800000 )
 [host]  Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:32769
 [host] Attached to slave procId 2.
 [host] Attached to slave procId 0.
 [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
 [host] Started slave procId 2.
 [host] Attached to slave procId 1.
 [host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
 [host] Started slave procId 0.
 [host] After Ipc_loadcallback status [0x00000000]
 [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
 [host] Started slave procId 1.
 [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 500000000, <NEW> - 500000000
 [m3video] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 200000000
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 200000000
 [host] After Ipc_startcallback status [0x097d2000]
 [c6xdsp ]
 [m3video]
 [m3vpss ] notify_attach  rtnVal  0
 [c6xdsp ]  *** UTILS: CPU KHz = 500000 Khz ***
 [m3video]  *** UTILS: CPU KHz = 400000 Khz ***
 [m3vpss ] initProxyServer  rtnVal  0
 [c6xdsp ]
 [m3video]
 [m3vpss ]
 [c6xdsp ]  1: SYSTEM  : System Common Init in progress !!!
 [m3video]  355: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  *** UTILS: CPU KHz = 400000 Khz ***
 [c6xdsp ]  1: SYSTEM: IPC init in progress !!!
 [m3video]  355: SYSTEM: IPC init in progress !!!
 [m3vpss ]
 [c6xdsp ]  1: SYSTEM: Attaching to [HOST] ...
 [m3video]  355: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  96: SYSTEM  : System Common Init in progress !!!
 [c6xdsp ]  1001: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  96: SYSTEM: IPC init in progress !!!
 [c6xdsp ]  1004: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  97: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  1004: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3vpss ]  1096: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1120: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  1120: SYSTEM: Attaching to [DSP] ...
 [m3video]  1355: SYSTEM: Attaching to [HOST] ...
 [m3video]  1359: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  1359: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2003: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3vpss ]  2119: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2307: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  2358: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2307: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  2359: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3video]  2359: SYSTEM: Attaching to [VPSS-M3] ...
 [m3vpss ]  3119: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  3306: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  3359: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  4068: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  4119: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  4068: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  4120: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  4120: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  4359: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  5068: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3video]  5121: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  5120: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  5121: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  5121: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  5122: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  5121: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3video]  5122: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  5122: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  5125: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [m3vpss ]  5122: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [m3video]  5125: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [m3vpss ]  5125: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [m3video]  5125: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [m3vpss ]  5125: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [m3video]  5126: SYSTEM: IPC init DONE !!!
 [m3vpss ]  5125: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [m3vpss ]  5125: SYSTEM: IPC init DONE !!!
 [m3vpss ] Received character 's'
 [m3video]  5141: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
 [m3vpss ]  5140: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
 [m3video]  5141: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03800000 (56 MB)
 [m3vpss ]  5141: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03800000 (56 MB)
 [m3video]  5144: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  5143: SYSTEM  : System Common Init Done !!!
 [m3video] Received character 's'
 [c6xdsp ]  6068: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [c6xdsp ]  6068: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [c6xdsp ]  6069: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [c6xdsp ]  6069: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [c6xdsp ]  6069: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [c6xdsp ]  6069: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [c6xdsp ]  6069: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  6073: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
 [c6xdsp ]  6073: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03800000 (56 MB)
 [c6xdsp ]  6074: SYSTEM  : System Common Init Done !!!
 [c6xdsp ] Received character 's'
queue id:65538
CPU is TI812x
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
    IPNC BUILD VERSION: DM8127 IPNC RDK VERSION 03.00.00.05
./bin/ipnc_rdk_mcfw.out   TRISTREAM TRIPLE_H264 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
 [c6xdsp ]  6272: SYSTEM  : System DSP Init in progress !!!
 [c6xdsp ]  6277: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
 [c6xdsp ]  6278: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
 [c6xdsp ]  6278: SYSTEM: ListElem Shared Addr = 0xbe98b280
 [c6xdsp ]  6279: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [c6xdsp ]  6279: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [c6xdsp ]  6279: SYSTEM: ListElem Shared Addr = 0xbe9aa880
 [c6xdsp ]  6280: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [c6xdsp ]  6280: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [c6xdsp ]  6280: SYSTEM: ListElem Shared Addr = 0xbe9c9e80
 [c6xdsp ]  6281: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
 [c6xdsp ]  6281: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
 [c6xdsp ]  6282: SYSTEM: ListElem Shared Addr = 0xbe9e9480
 [c6xdsp ]  6282: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
 [c6xdsp ]  6283: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
 [c6xdsp ]  6283: SYSTEM: ListElem Shared Addr = 0xbea02d00
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  6282: SYSTEM  : Initializing Links !!!
 [c6xdsp ]  6284: SYSTEM  : FREE SPACE : System Heap      = 6282864 B, Mbx = 10240 msgs)
 [m3video]  6343: SYSTEM  : System Video Init in progress !!!
 [m3vpss ]  6343: SYSTEM  : System VPSS Init in progress !!!
 [m3video]  6343: SYSTEM  : System Video Init Done !!!
 [m3video]  6344: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [m3video]  6344: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [m3video]  6345: SYSTEM: ListElem Shared Addr = 0xbea1c580
 [c6xdsp ]  6297: SYSTEM  : Initializing Links ... DONE !!!
 [m3video]  6347: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [m3video]  6348: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [c6xdsp ]  6297: SYSTEM  : System DSP Init Done !!!
 [m3video]  6348: SYSTEM: ListElem Shared Addr = 0xbea1f680
 [m3video]  6360: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
 [m3vpss ] === I2C0/2 Clk is active ===
 [m3video]  6360: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
 [m3vpss ]  6362: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [m3video]  6360: SYSTEM: ListElem Shared Addr = 0xbea22780
 [m3vpss ]  6362: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [m3video]  6363: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
 [m3vpss ]  6363: SYSTEM: ListElem Shared Addr = 0xbea3c000
 [m3video]  6364: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
 [m3vpss ]  6366: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [m3video]  6364: SYSTEM: ListElem Shared Addr = 0xbea3f100
 [m3vpss ]  6366: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [m3video]  6367: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3vpss ]  6366: SYSTEM: ListElem Shared Addr = 0xbea58980
 [m3video]  6367: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3video]  6368: SYSTEM  : Initializing Links !!!
 [m3video]  6368: SYSTEM  : FREE SPACE : System Heap      = 6282384 B, Mbx = 10240 msgs)
 [m3vpss ]  6382: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
 [m3vpss ]  6383: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
 [m3vpss ]  6383: SYSTEM: ListElem Shared Addr = 0xbea5ba80
 [m3vpss ]  6386: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  6387: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  6387: SYSTEM: ListElem Shared Addr = 0xbea7b080
 [m3vpss ]  6390: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
 [m3vpss ]  6390: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  6391: SYSTEM: ListElem Shared Addr = 0xbea9a680
 [m3vpss ]  6398: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
 [m3vpss ]  6399: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
 [m3vpss ]  6399: SYSTEM: ListElem Shared Addr = 0xbeab9c80
 [m3vpss ]  6402: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
 [m3vpss ]  6402: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
 [m3vpss ]  6403: SYSTEM: ListElem Shared Addr = 0xbead3500
 [m3vpss ]  6405: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
 [m3vpss ]  6406: SYSTEM  : FVID2 Init in progress !!!
 [m3video]  6425: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  6467: SYSTEM  : FVID2 Init in progress DONE !!!
 [m3vpss ]  6467: SYSTEM  : Device Init in progress !!!
 [m3vpss ]  Iss_init called !!!!!!
 [m3vpss ]  CPIS_init DONE !!!!!!
 [m3vpss ] initPrms.isI2cInitReq = 1
 [m3vpss ]  Vps_deviceInit Daughter card not detected/connected!
 [m3vpss ]
 [m3vpss ]  6666: SYSTEM  : Device Init in progress DONE !!!
 [m3vpss ]  6693: SYSTEM  : System VPSS Init Done !!!
 [m3vpss ]  6693: UTILS: DMA: HWI Create for INT62 !!!
 [m3vpss ]  6694: SYSTEM  : Initializing Links !!!
 [m3vpss ]  6694: SYSTEM  : FREE SPACE : System Heap      = 1719392 B, Mbx = 10240 msgs)
 [m3vpss ]  6694: SYSTEM  : FREE SPACE : SR0 Heap         = 14759040 B (14 MB)
 [m3vpss ]  6694: SYSTEM  : FREE SPACE : Frame Buffer     = 105790336 B (100 MB)
 [m3vpss ]  6695: SYSTEM  : FREE SPACE : Bitstream Buffer = 58720128 B (55 MB)
 [m3vpss ]  6695: SYSTEM  : FREE SPACE : Tiler Buffer     = 127 B (0 MB)  - TILER OFF
 [m3vpss ]  6817: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ] Received character 't'
 inside autorun
INIT: Entering runlevel: 5
 sbulla: unknown partition table
 [m3video] Received character 't'
 [c6xdsp ] Received character 't'
ApproDrvInit: 7
Creat queue id:131076
queue id:131076
Starting system message bus: DMA: Module install successful, device major num = 250
DRV: Module install successful
DRV: Module built on Aug 28 2013 16:59:11
dbus.
Starting telnet daemon.
HDMI W1 rev 4.0
I2C Bus Low?
mkdosfs 2.11 (12 Mar 2005)
unable to get drive geometry, using default 255/63/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
Root directory contains 512 slots.
Volume ID is 4d828ec9, no volume label.
 [host]
 [host]  ORG 0x46c00524: 0
 [host]  NEW 0x46c00524: 2
 [host]
 [host] Application Start Completed
Starting syslogd/klogd: done
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget-lun0: unable to open backing file: /dev/sbulla
 [host]
VSYS_USECASE_MULTICHN_TRISTREAM_FULLFTR
 [host] Vsys_alDMA: ChannelID allocated:4
locBuf - addr = DMA: ChannelID allocated:9
0x40c58000,size = 65011712
 [host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer  is 40c58000
##########pInfo->totalsize 61865984
 [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
 [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 9
queue id:131076
queue id:65538
 [host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...
 [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
 [host]  0: SYSTEM: System Common Init in progress !!!
 [host]  0: SYSTEM: IPC init in progress !!!
 [host]  8: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [host]  10: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
 [host]  12: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
 [host]  13: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
 [host]  14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 [host]  14: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [host]  15: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [host]  15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [host]  16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [host]  17: SYSTEM: IPC init DONE !!!
 [host]  18: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
 [host]  20: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
 [host]  22: SYSTEM: ListElem Shared Addr = 0x45d9fd80
 [host]  23: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
 [host]  25: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
 [host]  26: SYSTEM: ListElem Shared Addr = 0x45db9600
 [host]  28: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
 [host]  30: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
 [host]  31: SYSTEM: ListElem Shared Addr = 0x45dd2e80
func_
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org DM8127_IPNC ttyO0
Arago 2010.11 DM8127_IPNC ttyO0
DM8127_IPNC login: root (automatic login)
 [m3vpss ]  21373: CAMERA: VIP 0: VID DEC 268436736 (0x36): 8f0f5d80:ffff0000:8f0f8234, AUD_STATUS -1894802272
 [m3vpss ] Stream ID 0: chId = 0 VpsUtils_queCreate.
 [m3vpss ] Stream ID 1: chId = 0 VpsUtils_queCreate.
Simple mixer control 'PGA',0
  Capabilities: cvolume cswitch penum
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 119
  Front Left: Capture 80 [67%] [40.00dB] [on]
  Front Right: Capture 80 [67%] [40.00dB] [on]
 [m3vpss ]  21625: CAMERA: Create Done !!!
root@DM8127_IPNC:~#  [m3vpss ] DCC server task running
 [m3vpss ]  21736: CAMERA: Detect video in progress !!!
 [m3vpss ]  21736: CAMERA: Detect video Done !!!
 [m3vpss ]  21838: DUP   : Create Done !!!
 [m3vpss ]  21839: NSF: Create in progress !!!
 [m3vpss ] NSF::HEAPID:0        USED:128
 [m3vpss ] NSF::HEAPID:1        USED:4928
 [m3vpss ]  21940: NSF: Create Done !!!
 [m3vpss ]  21948: DUP   : Create Done !!!
 [m3vpss ]  21955: DUP   : Create Done !!!
 [m3vpss ]  21956: MERGE   : Create Done !!!
 [m3vpss ] {SWOSD} edma3Handle->tccVal = 34
 [m3vpss ] {SWOSD} edma3Handle->chId   = 34
 [m3vpss ] {SWOSD} edma3Handle->tccVal = 35
 [m3vpss ] {SWOSD} edma3Handle->chId   = 35
 [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
 [m3vpss ] {SWOSD} edma3Handle->chId   = 36
 [m3vpss ]  21921: SWOSD   : Create Done !!!
 [m3vpss ]  22016: SCLR: Create in progress !!!
 [m3vpss ]  22022: SCLR    : Loading Up-scaling Co-effs ...
 [m3vpss ]  22023: SCLR    : Co-effs Loading ... DONE !!!
 [m3video]  22030: IPC_IN_M3   : Create in progress !!!
 [m3video]  22031: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
 [m3vpss ] SCLR:HEAPID:0        USED:64
 [m3video]  22031: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
 [m3vpss ] SCLR:HEAPID:1        USED:5952
 [m3video]  22032: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3vpss ]  22023: SCLR: Create Done !!!
 [m3video]  22035: IPC_IN_M3   : Create Done !!!
 [m3vpss ]  21933: FD   : Alg Create Done !!!
 [m3video]  22035: ENCODE: Create in progress ... !!!
 [m3vpss ]  21933: FD   : Create Done !!!
 [m3vpss ]  22028: IPC_OUT_M3   : Create in progress !!!
 [m3vpss ]  22030: IPC_OUT_M3   : Create Done !!!
 [m3video]  22153: ENCODE: Creating CH0 of 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
 [m3video] ENCLINK_H264:HEAPID:0        USED:13808
 [m3video]  22260: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
 [host] IpcBitsInLink_tskMain:Entered
 [host]  1063: IPC_BITS_IN   : Create in progress !!!
 [host]  1063: IPC_BITS_IN   : ListMPOpen start !!!
 [host]  1063: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
 [host]  1065: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
 [host]  1067: IPC_BITS_IN   : ListMPOpen done !!!
 [host]  1069: IPC_BITS_IN   : System_linkGetInfo done !!!
 [host]  1070: IPC_BITS_IN   : Create Done !!!
 [host] USECASE SETUP DONE
 [m3video] ENCLINK_H264:HEAPID:0        USED:11912
 [m3vpss ]  22383: DISPLAY: Create in progress !!!
 [m3video]  22367: ENCODE: Creating CH2 of 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
 [m3vpss ]  22385: DISPLAY: Create Done !!!
 [m3vpss ]  22385: DISPLAY: Create in progress !!!
 [m3vpss ]  22386: DISPLAY: Create Done !!!
 [m3video] ENCLINK_JPEG:HEAPID:0        USED:2064
 [m3vpss ]  22388: DISPLAY: Start in progress !!!
 [m3video]  22368: ENCODE: All CH Create ... DONE !!!
 [m3video] ENCLINK:HEAPID:0     USED:27944
 [m3video]  22371: ENCODE: Create ... DONE !!!
 [m3video]  22018: VSTAB   : Alg Create Done !!!
 [m3video]  22018: VSTAB   : Create Done !!!
 [m3video]  22373: IPC_BITS_OUT   : Create in progress !!!
 [m3video]  22376: IPC_BITS_OUT   : Create Done !!!
 [m3vpss ]  22424: DISPLAY: Start Done !!!
 [m3vpss ]  22424: DISPLAY: HDDAC(BP0) : 55 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
 [m3vpss ]  22424: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 0, DVO2(BP1) 1, SDDAC(SEC1) 0
 [m3vpss ]  22424: SYSTEM  : FREE SPACE : System Heap      = 1208944 B, Mbx = 10237 msgs)
 [m3vpss ]  22425: SYSTEM  : FREE SPACE : SR0 Heap         = 14164352 B (13 MB)
 [m3vpss ]  22425: SYSTEM  : FREE SPACE : Frame Buffer     = 2441856 B (2 MB)
 [m3vpss ]  22425: SYSTEM  : FREE SPACE : Bitstream Buffer = 39948160 B (38 MB)
 [m3vpss ]  22426: SYSTEM  : FREE SPACE : Tiler Buffer     = 123 B (0 MB)  - TILER OFF
 [m3vpss ]  22426: DISPLAY: Start in progress !!!
 [m3vpss ]  22482: DISPLAY: Start Done !!!
 [m3vpss ]  22483: DISPLAY: SDDAC(SEC1): 17 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
 [m3vpss ]  22390: CAMERA: Start in progress !!!
 [m3vpss ]  22390: CAMERA: Start Done !!!
 [host]
Application Run Completed
queue id:0
 [m3vpss ]  22522: CAMERA: Fields = 2 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
 [m3video]  Channel:1 inputframerate:30 targetfps:60
 [host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn
 [host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video]  Channel:0 inputframerate:60 targetfps:60
 [m3video]  Channel:2 inputframerate:60 targetfps:5
 [host] ITT server task running !!!
 [host]
 ITT ittServer_run
 [host] ITT Server Message initialization successful
 [host]
 ITT capture task created
 [host] DCC server Message ques is open succefully
 [host] Setting cmd <1> in message <45bbe100>
 [host] Posting message <45bbe100> in QId <20002>
 [m3vpss ] Command 1 recived from HOST A8
 [host] Response from M3 is : 1
 [host] Default parameters were sent sucessfully
 [host] Server Socket created with ID <22>
 [m3vpss ] Command 2 recived from HOST A8
 [m3vpss ] New DCC data of size <5402>
 [m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC 0
main 188
ApproDrvInit: 3
queue id:131076
main 192
main 197
queue id:0
main 202
queue id:32769
main 208
main 212
main 216
main 220
main 228
 [m3vpss ]  23692: DISPLAY: Stop in progress !!!
 [host]
 Venc not supported!!
 [m3vpss ]  23752: DISPLAY: Stop Done !!!
 [m3vpss ]  23846: DISPLAY: Start in progress !!!
 [m3vpss ]  23893: DISPLAY: Start Done !!!
 [m3vpss ]  23893: DISPLAY: SDDAC(SEC1): 808 fps, Latency (Min / Max) = ( 16 / 32 ), Callback Interval (Min / Max) = ( 30 / 34 ) !!!
 [host]
 Channel Selected: 0
 [host]
 Channel Selected: 0,rate control = 0
 [host]
 Channel Selected: 0 [m3vpss ] framerateParams->FrameRate = 60
 [host]
 Channel Selected: 0
 [host]
 Channel Selected: 0
 [host]
 Channel Selected: 0,packet size = 100
 [host]
 Channel Selected: 0,encPreset = 0
 [host]
 Channel Selected: 0,enable = 0
 [host]
 Channel Selected: 1
 [host]
 Channel Selected: 1,rate control = 0
 [host]
 Channel Selected: 1 [m3video]  Channel:0 inputframerate:60 targetfps:60
 [m3video]  ENCLINK: new rate control algorithm  to set:0
 [host]
 Channel Selected: 1
 [host]
 Channel Selected: 1
 [host]
 Channel Selected: 1,packet size = 100
 [host]
 Channel Selected: 1,encPreset = 0
 [host]
 Channel Selected: 1,enable = 0Check_device_version : DEVICE VER = 1 !!
 [m3video]  ENCLINK: new intraFrameInterval to set:60
 [m3video]  ENCLINK: new QP I Param to set:10 36 -1
 [m3video]  ENCLINK: new QP P Param to set:10 40 28
 [m3video]  ENCLINK: new PacketSize Param to set:100
  Front Left: Capture 95 [80%] [47.50dB] [on]
  Front Right: Capture 95 [80%] [47.50dB] [on]
 [m3video]  ENCLINK: new Encode Preset Param to set:0
 [m3video]  Channel:1 inputframerate:30 targetfps:30
 [m3video]  ENCLINK: new intraFrameInterval to set:30
Simple mixer control 'PCM',0
  Capabilities: pvolume penum
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 127
  Mono:
  Front Left: Playback 101 [80%] [-13.00dB]
  Front Right: Playback 101 [80%] [-13.00dB]
 [host]
Force IDR on Channel: 0
 [host]
Force IDR on Channel: 1 [m3video]  ENCLINK: new rate control algorithm  to set:0
SystemInit success
Schedule manager init success
Dmva Schedule manager init success
umount: /mnt/mmc: not mounted
killall: dhcpcd: no process killed
queue id:0
Program exit.
Program exit.
 [host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video]  ==================== EncLink_PrintDetails ====================
 [m3video]      46455: HDVICP-ID:0
 [m3video]              totalAcquire2wait in msec:78030998
 [m3video]              totalWait2Isr in msec:   21192
 [m3video]              totalIsr2Done in msec:      47
 [m3video]              totalWait2Done in msec:   21239
 [m3video]              totalDone2Release in msec:       0
 [m3video]              totalAcquire2Release in msec:       0
 [m3video]              totalAcq2acqDelay in msec:       0
 [m3video]              totalElapsedTime in msec:       0
 [m3video]              numAccessCnt:       0
 [m3video]              IVA-FPS :       0
 [m3video]
 [m3video]  *** ENCODE Statistics ***
 [m3video]
 [m3video]  Elasped Time           : 23 secs
 [m3video]
 [m3video]
 [m3video]  CH  | In Recv In Skip In User  Out Latency
 [m3video]  Num | FPS     FPS     Skip FPS FPS Min / Max
 [m3video]  --------------------------------------------
 [m3video]    0 |      59       0        0  60  28 / 101
 [m3video]    1 |      29       0        0  29   9 /  62
 [m3video]    2 |      59       0       54   5  31 / 101
 [m3video]
 [m3video] Multi Channel Encode Average Submit Batch Size
 [m3video] Max Submit Batch Size : 24
 [m3video] IVAHD_0 Average Batch Size : 1
 [m3video] IVAHD_0 Max achieved Batch Size : 1
 [m3video]  =================================================================
regards,
Haitao
  • Haitao,
    Can you please attach your boot log?
    Rajat
  • hi, Rajat
       I have already attached my boot log in the first post.
    I reattached it here.
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    L3 clk: 200MHz
    IVA clk: 450MHz
    ISS clk: 400MHz
    DSP Default OFF
    DSS Default OFF
    DRAM:  512 MiB
    256 MiB
    TI8148-GP rev 2.1
    ARM clk: 600MHz
    DDR clk: 400MHz
    L3 clk: 200MHz
    IVA clk: 450MHz
    ISS clk: 400MHz
    DSP Default OFF
    DSS Default OFF
    I2C:   ready
    DRAM:  512 MiB
    256 MiB
                              .:;rrr;;.
                           :ihM#@@@@@##hs,
    cpsw
    OK
    Starting kernel ...
    Machine: ti8148ipnc
    NR_IRQS:375
    GPMC revision 6.0
    regulator: dummy:
    PWM0 init success.
    PWM1 init success.
    Cppi41 Init Done
    TCP reno registered
    cmemk initialized
    brd: module loaded
    loop: module loaded
    ALSA device list:
      #0: TI8148 IPNC
    PHY 0:01 not found
    devtmpfs: mounted
    Starting udev
     inside finish.sh
      : values=127,127
    Trace enabled
    /dev/mem opened.
    data 2
    data 3
    data 2
    data 2
    data 2
    data 60020
    data 60020
    data 60001
    data 60001
    data 2
    data 2
    data 2
    data 60002
    data 60002
    data 60002
    data 60020
    data 60080
    data 60020
    data 60020
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 60002
    data 0
    data 0
    data 1
    data 1
    data 1
    data 1
    data 1
    data 1
    data 1
    data 1
    data 0
    data 2
    data 2
    data 2
    data 2
    data 2
    data 170208
    data 170208
    data 170208
    data 170208
    Creat queue id:0
    queue id:0
    queue id:32769
    AlramThread created
    queue id:65538
    queue id:98307
    queue id:32769
     [c6xdsp ]
     [m3video]
     [c6xdsp ]
     [m3video]
     [m3vpss ]
     [m3vpss ]
    queue id:65538
    CPU is TI812x
     [m3vpss ]
     inside autorun
    ApproDrvInit: 7
    queue id:131076
    dbus.
    HDMI W1 rev 4.0
    I2C Bus Low?
     [host]
     [host]
     [host]
    queue id:131076
    queue id:65538
    func_
     _____                    _____           _         _
                  |___|                    |___|
     [host]
    queue id:0
     [host]
     ITT ittServer_run
     [host]
    main 188
    ApproDrvInit: 3
    queue id:131076
    main 192
    main 197
    queue id:0
    main 202
    queue id:32769
    main 208
    main 212
    main 216
    main 220
    main 228
     [host]
     [host]
     Channel Selected: 0
     [host]
     [host]
     [host]
     Channel Selected: 0
     [host]
     Channel Selected: 0
     [host]
     [host]
     [host]
     [host]
     Channel Selected: 1
     [host]
     [host]
     [host]
     Channel Selected: 1
     [host]
     Channel Selected: 1
     [host]
     [host]
     [host]
      Mono:
     [host]
     [host]
    SystemInit success
    queue id:0
    Program exit.
    Program exit.
     [m3video]
     [m3video]
     [m3video]
     [m3video]
     [m3video]
    Thank you for your reply!
    Haitao
  • Haitao,
    From the boot log it seems that capture & encode are working fine.
    I see that you are running full feature usecase. Is it possible to check if the low power usecase is also timing out?
    Since you are on older IPNC RDK release (v.3.0) and there have been many changes after that I would suggest you to move to a later version if possible. In the meantime I'll check in the older database on the run-sequence and try provide you more pointers asap.
    Rajat
  • Rajat,
    Thank you for your quick reply.
    I have solve this problem.
    My colleague do not use the gpio which control the static or dhcp. When the program check the gpio status, it time out. So I commented it. It's ok.
    And Polling thread also check the gpio, which also should be commented, or it will time out.
    ps. about the debug information, is there a method that I just modify the makefile to get debug information as mentioned in  the first question.
    Thank you, Rajat.
    Haitao
