openssl - invalid engine "cryptodev"
Hi
I am trying to use cryptodev engine using openssl in OMAP4460. When I run the application I get the following error :
/ # openssl speed -evp aes-128-cbc -engine cryptodev
3069236400:error:25066067:DSO support routines:DLFCN_LOAD:could not load the shared library:dso_dlfcn.c:187:filename(libcryptodev.so): /lib/engines/libcryptodev.so: cannot open shared object file: No such file or directory
I have used the latest openssl from github to run this experiment. There is no libcryptodev.so after compiling the package.
Does anyone know why this is happening?
  • Hello Anees,
    There is a requirement that OpenSSL loads the "crypto-engines" after entered in the chroot environment.
    I would suggest to follow the steps described in this link - http://processors.wiki.ti.com/index.php/OMAP_WLAN_build_instructions_on_any_SDK
    After build of OpenSSL, you must update the paths to new OpenSSL files.
    What OS do you run on your OMAP4460 board?
    Yanko
