After a seemingly good initialization where the musb+am35x glue driver running in host mode with DMA, the host driver detected both the root and a built-in hub w/ 2 USB ports. The module seemed to load properly as seen in the attach log file, but once I plugged in a USB device the system just lock up (question #1). Also, another issue that I observed was that when I tried unloading the module (am35x.ko), it got stuck in a tight loop printing "Popping value 0 from queue @ d09b6440" over and over again, effectively hanging the system (question #2). The other question I have is whether the IRQ number should still be 71 even if the host controller is running in DMA mode (question #3).
As a background info, I am running kernel version 3.6.11 with the USB host controller (musb) driver fixes pulled from the TI Arago repo. The USB controller runs fine under this kernel in PIO mode without the fixes or any other modification. Also, we have a 2-port USB hub connected directly to the OTG port (port 0) on the AM3505; the other 3 USB ports on the SoC are not used.
Thank you in advance!
Texas Instruments X-Loader 1.45 (Jul 29 2013 - 15:39:06) X-Load Enphase Part Number: <....> [u-boot0] = valid [u-boot1] = valid Using U-Boot image [0], based on time Starting OS Bootloader... U-Boot Enphase Part Number: <........> Last Reset: POWER U-Boot 2009.11-00025-g360a7d7-dirty (Jul 29 2013 - 15:39:12) OMAP34xx/35xx-GP ES1.0, CPU-OPP2 L3-165MHz EnvoyR Board + LPDDR/NAND I2C: ready DRAM: 256 MB NAND: (4-bit BCH ECC): 1024 MiB In: serial Out: serial Err: serial Die ID #3bbe000100000000015da3960b00b025 Envoy Compat 0 nand ecc [1] corrected, err_loc=2972 [linux0] = valid [linux1] = valid Using Linux image [0], based on time Reinit NAND: (4-bit BCH ECC): 1024 MiB Net: davinci_emac_initialize Ethernet PHY: GENERIC @ 0x1f DaVinci EMAC Hit any key to stop autoboot: 1 0 Booting from nand ... NAND read: device 0 offset 0x0, size 0x420000 4325376 bytes read: OK ## Booting kernel from Legacy Image at 87000000 ... Image Name: Linux-3.6.11-ee6e568a Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3203224 Bytes = 3.1 MB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Switching to clocksource gp_timer NET: Registered protocol family 2 TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 6, 294912 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP: reno registered UDP hash table entries: 256 (order: 2, 20480 bytes) UDP-Lite hash table entries: 256 (order: 2, 20480 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) NFS: Registering the id_resolver key type Key type id_resolver registered Key type id_legacy registered msgmni has been set to 482 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) omap_uart.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0 console [ttyS0] enabled omap_uart.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2 brd: module loaded loop: module loaded omap-dma-engine omap-dma-engine: allocating channel for 36 omap-dma-engine omap-dma-engine: allocating channel for 35 m25p80 spi1.0: found s25fl064k, expected m25p80 m25p80 spi1.0: s25fl064k (8192 Kbytes) Creating 9 MTD partitions on "spi1.0": <<<locations redacted>>>> omap-dma-engine omap-dma-engine: allocating channel for 44 omap-dma-engine omap-dma-engine: allocating channel for 43 tun: Universal TUN/TAP device driver, 1.6 tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> davinci_mdio davinci_mdio.0: davinci mdio revision 1.5 davinci_mdio davinci_mdio.0: detected phy mask 7fffffff libphy: davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[31]: device davinci_mdio-0:1f, driver SMSC LAN8700 usbcore: registered new interface driver asix usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 usbcore: registered new interface driver cdc_wdm usbcore: registered new interface driver usbtest musb-hdrc: version 6.0, ?dma?, otg (peripheral+host) mousedev: PS/2 mouse device common for all mice pcf2123 spi driver pcf2123 chip found pcf2123 spiclk 3000 KHz. pcf2123 spi2.0: rtc core: registered pcf2123 as rtc0 i2c /dev entries driver omap_wdt: OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP: cubic registered Initializing XFRM netlink socket NET: Registered protocol family 17 NET: Registered protocol family 15 lib80211: common routines for IEEE802.11 drivers Key type dns_resolver registered VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1 voltdm_scale: No voltage scale API registered for vdd_mpu_iva voltdm_scale: No voltage scale API registered for vdd_core PM: no software I/O chain control; some wakeups may be lost clock: disabling unused clocks to save power omap-dma-engine omap-dma-engine: allocating channel for 4 enabling NAND BCH ecc with 4-bit correction NAND device: Manufacturer ID: 0x2c, Chip ID: 0x38 (Micron NAND 1GiB 3,3V 8-bit), page size: 4096, OOB size: 128 Scanning device for bad blocks Bad eraseblock 190 at 0x000005f00000 Bad eraseblock 1270 at 0x000027b00000 Bad eraseblock 1502 at 0x00002ef00000 Bad eraseblock 1865 at 0x00003a480000 Bad eraseblock 1936 at 0x00003c800000 nand_read_bbt: bad blocks: 5, reserved blocks: 0 Creating 4 MTD partitions on "omap2-am35-nand.0": <<<locations redacted>>>> pcf2123 spi2.0: setting system clock to 2013-09-12 15:01:15 UTC (1378998075) Freeing init memory: 1508K Mounting Flash Device yaffs: dev is 32505868 name is "mtdblock12" rw yaffs: passed flags "" Creating intermediate base dev files... Configure links for partition: part/769 Starting Envoy System INIT: version 2.86 booting Starting the hotplug events dispatcher: udevdudevd (1259): /proc/1259/oom_adj is deprecated, please use /proc/1259/oom_score_adj instead. . Synthesizing the initial hotplug events...done. Waiting for /dev to be fully populated...done. nand ecc[1] corrected bitflip 1684 Activating swap...failed. kernel.panic = 2 vm.panic_on_oom = 1 Mounting local filesystems...mount: none already mounted or /dev/pts busy mount: sysfs already mounted or /sys busy failed. Activating swapfile swap...done. INIT: Entering runlevel: 3 Starting system log daemon: syslogd. Setting hostname.... Bringing up interface eth0.. davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=davinci_mdio-0:1f, id=7c0c4) Determining IP information for eth0....udhcpc (v1.15.2) started deleting routers for eth0 Sending discover... libphy: davinci_mdio-0:1f - Link is Up - 100/Full Sending discover... Sending discover... No lease, forking to background done.... Bringing up interface eth1.. Bringing up interface lo.. Starting Network Interface Plugging Daemon: eth0. Starting NTP server: ntpdStarting OpenBSD Secure Shell server: sshd. Starting system message bus: dbus. Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon. Starting periodic command scheduler: cron. Loading emuk2u...done Starting pmi...done Loading cp210x...usbcore: registered new interface driver usbserial usbserial: USB Serial Driver core usbcore: registered new interface driver cp210x USB Serial support registered for cp210x done Starting ZigBee arbiter...done EMU database exists: -rw-r--r-- 1 root root 757760 Sep 12 08:01 [0;0m/var/opt/emu/emu.db[0m Loading emuk2u...done Starting emu...done Starting scgi server...done Starting EMU Web UI/API...done Starting CBUS Util...done Starting environ scanner...done Starting comm check...done Starting Bin roller rest server...done Starting PFA Monitor...done Technologic Systems TS-LINUX/arm 7.0 envoy-00069 login: Password: Last login: Thu Sep 12 00:47:34 PDT 2013 on ttyS0 [08:02:58][envoy-00069:~$] [08:02:58][envoy-00069:~$] [08:02:58][envoy-00069:~$] lsmod cp210x 11288 0 - Live 0xbf012000 usbserial 29137 1 cp210x, Live 0xbf004000 emuk2u 2401 1 - Live 0xbf000000 [08:03:05][envoy-00069:~$] [08:03:13][envoy-00069:~$] [08:03:13][envoy-00069:~$] <<<<<inserting/loading module 'am35x'>>>>>>>> [08:03:13][envoy-00069:~$] [08:03:13][envoy-00069:~$] modprobe am35x am35x_probe: pdev->id -1[<c0019364>] (unwind_backtrace+0x0/0xec) from [<bf0197c8>] (am35x_probe+0x54/0x2ac [am35x]) [<bf0197c8>] (am35x_probe+0x54/0x2ac [am35x]) from [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) from [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) from [<c01ec3ec>] (__driver_attach+0x68/0x8c) [<c01ec3ec>] (__driver_attach+0x68/0x8c) from [<c01ea928>] (bus_for_each_dev+0x4c/0x8c) [<c01ea928>] (bus_for_each_dev+0x4c/0x8c) from [<c01eb128>] (bus_add_driver+0xb0/0x234) [<c01eb128>] (bus_add_driver+0xb0/0x234) from [<c01eca34>] (driver_register+0xa4/0x144) [<c01eca34>] (driver_register+0xa4/0x144) from [<c0008650>] (do_one_initcall+0x94/0x160) [<c0008650>] (do_one_initcall+0x94/0x160) from [<c0075fd4>] (sys_init_module+0x74/0x19c) [<c0075fd4>] (sys_init_module+0x74/0x19c) from [<c00138c0>] (ret_fast_syscall+0x0/0x3c) musb_probe: pdev->id -1, iomem 0xced9c2dc, irq 71 [<c0019364>] (unwind_backtrace+0x0/0xec) from [<c024fd34>] (musb_probe+0xac/0xf8c) [<c024fd34>] (musb_probe+0xac/0xf8c) from [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) from [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) from [<c01ea89c>] (bus_for_each_drv+0x4c/0x8c) [<c01ea89c>] (bus_for_each_drv+0x4c/0x8c) from [<c01ec4f4>] (device_attach+0x68/0x98) [<c01ec4f4>] (device_attach+0x68/0x98) from [<c01eb410>] (bus_probe_device+0x28/0x9c) [<c01eb410>] (bus_probe_device+0x28/0x9c) from [<c01ea138>] (device_add+0x478/0x614) [<c01ea138>] (device_add+0x478/0x614) from [<c01edb98>] (platform_device_add+0x12c/0x190) [<c01edb98>] (platform_device_add+0x12c/0x190) from [<bf019914>] (am35x_probe+0x1a0/0x2ac [am35x]) [<bf019914>] (am35x_probe+0x1a0/0x2ac [am35x]) from [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) from [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) from [<c01ec3ec>] (__driver_attach+0x68/0x8c) [<c01ec3ec>] (__driver_attach+0x68/0x8c) from [<c01ea928>] (bus_for_each_dev+0x4c/0x8c) [<c01ea928>] (bus_for_each_dev+0x4c/0x8c) from [<c01eb128>] (bus_add_driver+0xb0/0x234) [<c01eb128>] (bus_add_driver+0xb0/0x234) from [<c01eca34>] (driver_register+0xa4/0x144) [<c01eca34>] (driver_register+0xa4/0x144) from [<c0008650>] (do_one_initcall+0x94/0x160) [<c0008650>] (do_one_initcall+0x94/0x160) from [<c0075fd4>] (sys_init_module+0x74/0x19c) [<c0075fd4>] (sys_init_module+0x74/0x19c) from [<c00138c0>] (ret_fast_syscall+0x0/0x3c) musb_probe: pdev->id -1,nIrq 71, base(ctrl) 0xd09b0000, iomem->start(ctrl phys addr) 0x5c040000 allocate_instance: mbase addr 0xd09b0000 allocate_instance: musb->ctrl_base addr 0xd09b0000 musb-hdrc musb-hdrc: dma type: dma-cppi41 musb_init_controller: pdev->id/musb id/mregs(b4 adj)/ctrl_base addr -1/-1/0xd09b0000/0xd09b0000[<c0019364>] (unwind_backtrace+0x0/0xec) from [<bf019be8>] (am35x_musb_init+0x2c/0x134 [am35x]) [<bf019be8>] (am35x_musb_init+0x2c/0x134 [am35x]) from [<c0250048>] (musb_probe+0x3c0/0xf8c) [<c0250048>] (musb_probe+0x3c0/0xf8c) from [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) from [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) from [<c01ea89c>] (bus_for_each_drv+0x4c/0x8c) [<c01ea89c>] (bus_for_each_drv+0x4c/0x8c) from [<c01ec4f4>] (device_attach+0x68/0x98) [<c01ec4f4>] (device_attach+0x68/0x98) from [<c01eb410>] (bus_probe_device+0x28/0x9c) [<c01eb410>] (bus_probe_device+0x28/0x9c) from [<c01ea138>] (device_add+0x478/0x614) [<c01ea138>] (device_add+0x478/0x614) from [<c01edb98>] (platform_device_add+0x12c/0x190) [<c01edb98>] (platform_device_add+0x12c/0x190) from [<bf019914>] (am35x_probe+0x1a0/0x2ac [am35x]) [<bf019914>] (am35x_probe+0x1a0/0x2ac [am35x]) from [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) [<c01ed5f8>] (platform_drv_probe+0x1c/0x24) from [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) [<c01ec1bc>] (driver_probe_device+0x10c/0x2d4) from [<c01ec3ec>] (__driver_attach+0x68/0x8c) [<c01ec3ec>] (__driver_attach+0x68/0x8c) from [<c01ea928>] (bus_for_each_dev+0x4c/0x8c) [<c01ea928>] (bus_for_each_dev+0x4c/0x8c) from [<c01eb128>] (bus_add_driver+0xb0/0x234) [<c01eb128>] (bus_add_driver+0xb0/0x234) from [<c01eca34>] (driver_register+0xa4/0x144) [<c01eca34>] (driver_register+0xa4/0x144) from [<c0008650>] (do_one_initcall+0x94/0x160) [<c0008650>] (do_one_initcall+0x94/0x160) from [<c0075fd4>] (sys_init_module+0x74/0x19c) [<c0075fd4>] (sys_init_module+0x74/0x19c) from [<c00138c0>] (ret_fast_syscall+0x0/0x3c) am35x_musb_init: musb mregs/ctrl_base addr 0xd09b0400/0xd09b0000 6Waiting for PHY clock good... cppi41_queue_mgr_init: top of func, cppi41_queue_mgr(0xc0b791a8) cppi41_queue_mgr_init: after dmaAllocCoh(), cppi41_queue_mgr(0xc0b791a8), ptr(0xd09b9000)linking_ram[0].phys_addr(0x8b090000), q_mgr_regs(0xd09b4000), qmgrLRamRgn0BaseReg(0x80)Linking RAM region 0 base @ d09b4080, value: 8b090000 cppi41_queue_mgr_init: after __raw_wr()#1Linking RAM region 0 size @ d09b4084, value: 3fff cppi41_queue_mgr_init: after __raw_wr()#2 cppi41_queue_mgr_init: after kzalloc(), ptr(0xcb042ac0) cppi41_queue_mgr_init: allocated_queues[0]=0xcb042ac0 cppi41_dma_block_init: top of func, _tbl(0xbf01a228)Teardown descriptor queue 67 in queue manager 0 allocated Teardown free descriptor control @ d09b1004, value: 43 cppi41_mem_rgn_alloc called with rgn_addr = 8fb01000, size_order = 5, num_order = 5 Descriptor region base @ d09b5000, value: 8fb01000 Descriptor region control @ d09b5004, value: 200000 Pushing value 8fb01002 to queue @ d09b6430 Pushing value 8fb01022 to queue @ d09b6430 Pushing value 8fb01042 to queue @ d09b6430 Pushing value 8fb01062 to queue @ d09b6430 Pushing value 8fb01082 to queue @ d09b6430 Pushing value 8fb010a2 to queue @ d09b6430 Pushing value 8fb010c2 to queue @ d09b6430 Pushing value 8fb010e2 to queue @ d09b6430 Pushing value 8fb01102 to queue @ d09b6430 Pushing value 8fb01122 to queue @ d09b6430 Pushing value 8fb01142 to queue @ d09b6430 Pushing value 8fb01162 to queue @ d09b6430 Pushing value 8fb01182 to queue @ d09b6430 Pushing value 8fb011a2 to queue @ d09b6430 Pushing value 8fb011c2 to queue @ d09b6430 Pushing value 8fb011e2 to queue @ d09b6430 Pushing value 8fb01202 to queue @ d09b6430 Pushing value 8fb01222 to queue @ d09b6430 Pushing value 8fb01242 to queue @ d09b6430 Pushing value 8fb01262 to queue @ d09b6430 Pushing value 8fb01282 to queue @ d09b6430 Pushing value 8fb012a2 to queue @ d09b6430 Pushing value 8fb012c2 to queue @ d09b6430 Pushing value 8fb012e2 to queue @ d09b6430 Pushing value 8fb01302 to queue @ d09b6430 Pushing value 8fb01322 to queue @ d09b6430 Pushing value 8fb01342 to queue @ d09b6430 Pushing value 8fb01362 to queue @ d09b6430 Pushing value 8fb01382 to queue @ d09b6430 Pushing value 8fb013a2 to queue @ d09b6430 Pushing value 8fb013c2 to queue @ d09b6430 Pushing value 8fb013e2 to queue @ d09b6430 cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b2800, value written: 81018000 cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b2804, value written: 83038202 cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b2808, value written: 85058404 cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b280c, value written: 87078606 cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b2810, value written: 89098808 cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b2814, value written: 8b0b8a0a cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b2818, value written: 8d0d8c0c cppi41_dma_block_init: b4 accessing sched_tbl(0xbf01a228) DMA scheduler table @ d09b281c, value written: 8e0e DMA scheduler control @ d09b2000, value: 8000001d controller: musb mregs(after adj)/ctrl_base addr 0xd09b0400/0xd09b0000cppi41_mem_rgn_alloc called with rgn_addr = 8b0a0000, size_order = 6, num_order = 11 Descriptor region base @ d09b5010, value: 8b0a0000 Descriptor region control @ d09b5014, value: 400106 musb-hdrc: ConfigData=0x1e (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn) musb-hdrc: MHDRC RTL version 1.900 musb-hdrc: setup fifo_mode 4 musb-hdrc: 28/31 max ep, 16384/16384 memory musb-hdrc musb-hdrc: MUSB HDRC host driver musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 3.6.11-ee6e568a musb-hcd usb usb1: SerialNumber: musb-hdrc hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc: USB Host mode controller at d09b0000 using DMA, IRQ 71 am35x_probe: b4 ret 0 [08:03:18][envoy-00069:~$] usb 1-1: new high-speed USB device number 2 using musb-hdrc usb 1-1: New USB device found, idVendor=0424, idProduct=2512 usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 hub 1-1:1.0: USB hub found hub 1-1:1.0: 2 ports detected Rx channel global configuration @ d09b1928, value written: 1004041, value read: 0 Rx channel host packet configuration A @ d09b192c, value written: 0 Rx channel host packet configuration B @ d09b1930, value written: 0 Enable channel @ d09b1928, value written: 81004041, value read: 80000000 Pushing value 8b0bffca to queue @ d09b6000 [08:03:26][envoy-00069:~$] [08:03:27][envoy-00069:~$] [08:03:27][envoy-00069:~$] <<<<<removing/unloading module 'am35x'>>>>>>>> [08:03:27][envoy-00069:~$] rmmod am35x [08:04:14][envoy-00069:~$] [08:04:17][envoy-00069:~$] rmmod am35x Popping value 8fb01003 from queue @ d09b6430 Popping value 8fb01023 from queue @ d09b6430 Popping value 8fb01043 from queue @ d09b6430 Popping value 8fb01063 from queue @ d09b6430 Popping value 8fb01083 from queue @ d09b6430 Popping value 8fb010a3 from queue @ d09b6430 Popping value 8fb010c3 from queue @ d09b6430 Popping value 8fb010e3 from queue @ d09b6430 Popping value 8fb01103 from queue @ d09b6430 Popping value 8fb01123 from queue @ d09b6430 Popping value 8fb01143 from queue @ d09b6430 Popping value 8fb01163 from queue @ d09b6430 Popping value 8fb01183 from queue @ d09b6430 Popping value 8fb011a3 from queue @ d09b6430 Popping value 8fb011c3 from queue @ d09b6430 Popping value 8fb011e3 from queue @ d09b6430 Popping value 8fb01203 from queue @ d09b6430 Popping value 8fb01223 from queue @ d09b6430 Popping value 8fb01243 from queue @ d09b6430 Popping value 8fb01263 from queue @ d09b6430 Popping value 8fb01283 from queue @ d09b6430 Popping value 8fb012a3 from queue @ d09b6430 Popping value 8fb012c3 from queue @ d09b6430 Popping value 8fb012e3 from queue @ d09b6430 Popping value 8fb01303 from queue @ d09b6430 Popping value 8fb01323 from queue @ d09b6430 Popping value 8fb01343 from queue @ d09b6430 Popping value 8fb01363 from queue @ d09b6430 Popping value 8fb01383 from queue @ d09b6430 Popping value 8fb013a3 from queue @ d09b6430 Popping value 8fb013c3 from queue @ d09b6430 Popping value 8fb013e3 from queue @ d09b6430 cppi41_mem_rgn_free called. DMA scheduler table @ d09b2800, value written: 0 DMA scheduler table @ d09b2804, value written: 0 DMA scheduler table @ d09b2808, value written: 0 DMA scheduler table @ d09b280c, value written: 0 DMA scheduler table @ d09b2810, value written: 0 DMA scheduler table @ d09b2814, value written: 0 DMA scheduler table @ d09b2818, value written: 0 DMA scheduler table @ d09b281c, value written: 0 (NULL device *): gadget not registered. musb-hdrc musb-hdrc: remove, state 1 usb usb1: USB disconnect, device number 1 usb 1-1: USB disconnect, device number 2 cppi41_channel_abort: DMA busy, status = 2 Before teardown: 00 d09e9f80 d09e9f40 d09e9f00 d09e9ec0 d09e9e80 d09e9e40 d09e9e00 d09e9dc0 08 d09e9d80 d09e9d40 d09e9d00 d09e9cc0 d09e9c80 d09e9c40 d09e9c00 d09e9bc0 10 d09e9b80 d09e9b40 d09e9b00 d09e9ac0 d09e9a80 d09e9a40 d09e9a00 d09e99c0 18 d09e9980 d09e9940 d09e9900 d09e98c0 d09e9880 d09e9840 d09e9800 d09e97c0 20 d09e9780 d09e9740 d09e9700 d09e96c0 d09e9680 d09e9640 d09e9600 d09e95c0 28 d09e9580 d09e9540 d09e9500 d09e94c0 d09e9480 d09e9440 d09e9400 d09e93c0 30 d09e9380 d09e9340 d09e9300 d09e92c0 d09e9280 d09e9240 d09e9200 d09e91c0 38 d09e9180 d09e9140 d09e9100 d09e90c0 d09e9080 d09e9040 d09e9000 d09e8fc0 40 d09e8f80 d09e8f40 d09e8f00 d09e8ec0 d09e8e80 d09e8e40 d09e8e00 d09e8dc0 48 d09e8d80 d09e8d40 d09e8d00 d09e8cc0 d09e8c80 d09e8c40 d09e8c00 d09e8bc0 50 d09e8b80 d09e8b40 d09e8b00 d09e8ac0 d09e8a80 d09e8a40 d09e8a00 d09e89c0 58 d09e8980 d09e8940 d09e8900 d09e88c0 d09e8880 d09e8840 d09e8800 d09e87c0 60 d09e8780 d09e8740 d09e8700 d09e86c0 d09e8680 d09e8640 d09e8600 d09e85c0 68 d09e8580 d09e8540 d09e8500 d09e84c0 d09e8480 d09e8440 d09e8400 d09e83c0 70 d09e8380 d09e8340 d09e8300 d09e82c0 d09e8280 d09e8240 d09e8200 d09e81c0 78 d09e8180 d09e8140 d09e8100 d09e80c0 d09e8080 d09e8040 d09e8000 d09e7fc0 80 d09e7f80 d09e7f40 d09e7f00 d09e7ec0 d09e7e80 d09e7e40 d09e7e00 d09e7dc0 88 d09e7d80 d09e7d40 d09e7d00 d09e7cc0 d09e7c80 d09e7c40 d09e7c00 d09e7bc0 90 d09e7b80 d09e7b40 d09e7b00 d09e7ac0 d09e7a80 d09e7a40 d09e7a00 d09e79c0 98 d09e7980 d09e7940 d09e7900 d09e78c0 d09e7880 d09e7840 d09e7800 d09e77c0 a0 d09e7780 d09e7740 d09e7700 d09e76c0 d09e7680 d09e7640 d09e7600 d09e75c0 a8 d09e7580 d09e7540 d09e7500 d09e74c0 d09e7480 d09e7440 d09e7400 d09e73c0 b0 d09e7380 d09e7340 d09e7300 d09e72c0 d09e7280 d09e7240 d09e7200 d09e71c0 b8 d09e7180 d09e7140 d09e7100 d09e70c0 d09e7080 d09e7040 d09e7000 d09e6fc0 c0 d09e6f80 d09e6f40 d09e6f00 d09e6ec0 d09e6e80 d09e6e40 d09e6e00 d09e6dc0 c8 d09e6d80 d09e6d40 d09e6d00 d09e6cc0 d09e6c80 d09e6c40 d09e6c00 d09e6bc0 d0 d09e6b80 d09e6b40 d09e6b00 d09e6ac0 d09e6a80 d09e6a40 d09e6a00 d09e69c0 d8 d09e6980 d09e6940 d09e6900 d09e68c0 d09e6880 d09e6840 d09e6800 d09e67c0 e0 d09e6780 d09e6740 d09e6700 d09e66c0 d09e6680 d09e6640 d09e6600 d09e65c0 e8 d09e6580 d09e6540 d09e6500 d09e64c0 d09e6480 d09e6440 d09e6400 d09e63c0 f0 d09e6380 d09e6340 d09e6300 d09e62c0 d09e6280 d09e6240 d09e6200 d09e61c0 f8 d09e6180 d09e6140 d09e6100 d09e60c0 d09e6080 d09e6040 d09e6000 d09e5fc0 100 d09e5f80 d09e5f40 d09e5f00 d09e5ec0 d09e5e80 d09e5e40 d09e5e00 d09e5dc0 108 d09e5d80 d09e5d40 d09e5d00 d09e5cc0 d09e5c80 d09e5c40 d09e5c00 d09e5bc0 110 d09e5b80 d09e5b40 d09e5b00 d09e5ac0 d09e5a80 d09e5a40 d09e5a00 d09e59c0 118 d09e5980 d09e5940 d09e5900 d09e58c0 d09e5880 d09e5840 d09e5800 d09e57c0 120 d09e5780 d09e5740 d09e5700 d09e56c0 d09e5680 d09e5640 d09e5600 d09e55c0 128 d09e5580 d09e5540 d09e5500 d09e54c0 d09e5480 d09e5440 d09e5400 d09e53c0 130 d09e5380 d09e5340 d09e5300 d09e52c0 d09e5280 d09e5240 d09e5200 d09e51c0 138 d09e5180 d09e5140 d09e5100 d09e50c0 d09e5080 d09e5040 d09e5000 d09e4fc0 140 d09e4f80 d09e4f40 d09e4f00 d09e4ec0 d09e4e80 d09e4e40 d09e4e00 d09e4dc0 148 d09e4d80 d09e4d40 d09e4d00 d09e4cc0 d09e4c80 d09e4c40 d09e4c00 d09e4bc0 150 d09e4b80 d09e4b40 d09e4b00 d09e4ac0 d09e4a80 d09e4a40 d09e4a00 d09e49c0 158 d09e4980 d09e4940 d09e4900 d09e48c0 d09e4880 d09e4840 d09e4800 d09e47c0 160 d09e4780 d09e4740 d09e4700 d09e46c0 d09e4680 d09e4640 d09e4600 d09e45c0 168 d09e4580 d09e4540 d09e4500 d09e44c0 d09e4480 d09e4440 d09e4400 d09e43c0 170 d09e4380 d09e4340 d09e4300 d09e42c0 d09e4280 d09e4240 d09e4200 d09e41c0 178 d09e4180 d09e4140 d09e4100 d09e40c0 d09e4080 d09e4040 d09e4000 d09e3fc0 180 d09e3f80 d09e3f40 d09e3f00 d09e3ec0 d09e3e80 d09e3e40 d09e3e00 d09e3dc0 188 d09e3d80 d09e3d40 d09e3d00 d09e3cc0 d09e3c80 d09e3c40 d09e3c00 d09e3bc0 190 d09e3b80 d09e3b40 d09e3b00 d09e3ac0 d09e3a80 d09e3a40 d09e3a00 d09e39c0 198 d09e3980 d09e3940 d09e3900 d09e38c0 d09e3880 d09e3840 d09e3800 d09e37c0 1a0 d09e3780 d09e3740 d09e3700 d09e36c0 d09e3680 d09e3640 d09e3600 d09e35c0 1a8 d09e3580 d09e3540 d09e3500 d09e34c0 d09e3480 d09e3440 d09e3400 d09e33c0 1b0 d09e3380 d09e3340 d09e3300 d09e32c0 d09e3280 d09e3240 d09e3200 d09e31c0 1b8 d09e3180 d09e3140 d09e3100 d09e30c0 d09e3080 d09e3040 d09e3000 d09e2fc0 1c0 d09e2f80 d09e2f40 d09e2f00 d09e2ec0 d09e2e80 d09e2e40 d09e2e00 d09e2dc0 1c8 d09e2d80 d09e2d40 d09e2d00 d09e2cc0 d09e2c80 d09e2c40 d09e2c00 d09e2bc0 1d0 d09e2b80 d09e2b40 d09e2b00 d09e2ac0 d09e2a80 d09e2a40 d09e2a00 d09e29c0 1d8 d09e2980 d09e2940 d09e2900 d09e28c0 d09e2880 d09e2840 d09e2800 d09e27c0 1e0 d09e2780 d09e2740 d09e2700 d09e26c0 d09e2680 d09e2640 d09e2600 d09e25c0 1e8 d09e2580 d09e2540 d09e2500 d09e24c0 d09e2480 d09e2440 d09e2400 d09e23c0 1f0 d09e2380 d09e2340 d09e2300 d09e22c0 d09e2280 d09e2240 d09e2200 d09e21c0 1f8 d09e2180 d09e2140 d09e2100 d09e20c0 d09e2080 d09e2040 d09e2000 d09e1fc0 200 d09e1f80 d09e1f40 d09e1f00 d09e1ec0 d09e1e80 d09e1e40 d09e1e00 d09e1dc0 208 d09e1d80 d09e1d40 d09e1d00 d09e1cc0 d09e1c80 d09e1c40 d09e1c00 d09e1bc0 210 d09e1b80 d09e1b40 d09e1b00 d09e1ac0 d09e1a80 d09e1a40 d09e1a00 d09e19c0 218 d09e1980 d09e1940 d09e1900 d09e18c0 d09e1880 d09e1840 d09e1800 d09e17c0 220 d09e1780 d09e1740 d09e1700 d09e16c0 d09e1680 d09e1640 d09e1600 d09e15c0 228 d09e1580 d09e1540 d09e1500 d09e14c0 d09e1480 d09e1440 d09e1400 d09e13c0 230 d09e1380 d09e1340 d09e1300 d09e12c0 d09e1280 d09e1240 d09e1200 d09e11c0 238 d09e1180 d09e1140 d09e1100 d09e10c0 d09e1080 d09e1040 d09e1000 d09e0fc0 240 d09e0f80 d09e0f40 d09e0f00 d09e0ec0 d09e0e80 d09e0e40 d09e0e00 d09e0dc0 248 d09e0d80 d09e0d40 d09e0d00 d09e0cc0 d09e0c80 d09e0c40 d09e0c00 d09e0bc0 250 d09e0b80 d09e0b40 d09e0b00 d09e0ac0 d09e0a80 d09e0a40 d09e0a00 d09e09c0 258 d09e0980 d09e0940 d09e0900 d09e08c0 d09e0880 d09e0840 d09e0800 d09e07c0 260 d09e0780 d09e0740 d09e0700 d09e06c0 d09e0680 d09e0640 d09e0600 d09e05c0 268 d09e0580 d09e0540 d09e0500 d09e04c0 d09e0480 d09e0440 d09e0400 d09e03c0 270 d09e0380 d09e0340 d09e0300 d09e02c0 d09e0280 d09e0240 d09e0200 d09e01c0 278 d09e0180 d09e0140 d09e0100 d09e00c0 d09e0080 d09e0040 d09e0000 d09dffc0 280 d09dff80 d09dff40 d09dff00 d09dfec0 d09dfe80 d09dfe40 d09dfe00 d09dfdc0 288 d09dfd80 d09dfd40 d09dfd00 d09dfcc0 d09dfc80 d09dfc40 d09dfc00 d09dfbc0 290 d09dfb80 d09dfb40 d09dfb00 d09dfac0 d09dfa80 d09dfa40 d09dfa00 d09df9c0 298 d09df980 d09df940 d09df900 d09df8c0 d09df880 d09df840 d09df800 d09df7c0 2a0 d09df780 d09df740 d09df700 d09df6c0 d09df680 d09df640 d09df600 d09df5c0 2a8 d09df580 d09df540 d09df500 d09df4c0 d09df480 d09df440 d09df400 d09df3c0 2b0 d09df380 d09df340 d09df300 d09df2c0 d09df280 d09df240 d09df200 d09df1c0 2b8 d09df180 d09df140 d09df100 d09df0c0 d09df080 d09df040 d09df000 d09defc0 2c0 d09def80 d09def40 d09def00 d09deec0 d09dee80 d09dee40 d09dee00 d09dedc0 2c8 d09ded80 d09ded40 d09ded00 d09decc0 d09dec80 d09dec40 d09dec00 d09debc0 2d0 d09deb80 d09deb40 d09deb00 d09deac0 d09dea80 d09dea40 d09dea00 d09de9c0 2d8 d09de980 d09de940 d09de900 d09de8c0 d09de880 d09de840 d09de800 d09de7c0 2e0 d09de780 d09de740 d09de700 d09de6c0 d09de680 d09de640 d09de600 d09de5c0 2e8 d09de580 d09de540 d09de500 d09de4c0 d09de480 d09de440 d09de400 d09de3c0 2f0 d09de380 d09de340 d09de300 d09de2c0 d09de280 d09de240 d09de200 d09de1c0 2f8 d09de180 d09de140 d09de100 d09de0c0 d09de080 d09de040 d09de000 d09ddfc0 300 d09ddf80 d09ddf40 d09ddf00 d09ddec0 d09dde80 d09dde40 d09dde00 d09dddc0 308 d09ddd80 d09ddd40 d09ddd00 d09ddcc0 d09ddc80 d09ddc40 d09ddc00 d09ddbc0 310 d09ddb80 d09ddb40 d09ddb00 d09ddac0 d09dda80 d09dda40 d09dda00 d09dd9c0 318 d09dd980 d09dd940 d09dd900 d09dd8c0 d09dd880 d09dd840 d09dd800 d09dd7c0 320 d09dd780 d09dd740 d09dd700 d09dd6c0 d09dd680 d09dd640 d09dd600 d09dd5c0 328 d09dd580 d09dd540 d09dd500 d09dd4c0 d09dd480 d09dd440 d09dd400 d09dd3c0 330 d09dd380 d09dd340 d09dd300 d09dd2c0 d09dd280 d09dd240 d09dd200 d09dd1c0 338 d09dd180 d09dd140 d09dd100 d09dd0c0 d09dd080 d09dd040 d09dd000 d09dcfc0 340 d09dcf80 d09dcf40 d09dcf00 d09dcec0 d09dce80 d09dce40 d09dce00 d09dcdc0 348 d09dcd80 d09dcd40 d09dcd00 d09dccc0 d09dcc80 d09dcc40 d09dcc00 d09dcbc0 350 d09dcb80 d09dcb40 d09dcb00 d09dcac0 d09dca80 d09dca40 d09dca00 d09dc9c0 358 d09dc980 d09dc940 d09dc900 d09dc8c0 d09dc880 d09dc840 d09dc800 d09dc7c0 360 d09dc780 d09dc740 d09dc700 d09dc6c0 d09dc680 d09dc640 d09dc600 d09dc5c0 368 d09dc580 d09dc540 d09dc500 d09dc4c0 d09dc480 d09dc440 d09dc400 d09dc3c0 370 d09dc380 d09dc340 d09dc300 d09dc2c0 d09dc280 d09dc240 d09dc200 d09dc1c0 378 d09dc180 d09dc140 d09dc100 d09dc0c0 d09dc080 d09dc040 d09dc000 d09dbfc0 380 d09dbf80 d09dbf40 d09dbf00 d09dbec0 d09dbe80 d09dbe40 d09dbe00 d09dbdc0 388 d09dbd80 d09dbd40 d09dbd00 d09dbcc0 d09dbc80 d09dbc40 d09dbc00 d09dbbc0 390 d09dbb80 d09dbb40 d09dbb00 d09dbac0 d09dba80 d09dba40 d09dba00 d09db9c0 398 d09db980 d09db940 d09db900 d09db8c0 d09db880 d09db840 d09db800 d09db7c0 3a0 d09db780 d09db740 d09db700 d09db6c0 d09db680 d09db640 d09db600 d09db5c0 3a8 d09db580 d09db540 d09db500 d09db4c0 d09db480 d09db440 d09db400 d09db3c0 3b0 d09db380 d09db340 d09db300 d09db2c0 d09db280 d09db240 d09db200 d09db1c0 3b8 d09db180 d09db140 d09db100 d09db0c0 d09db080 d09db040 d09db000 d09dafc0 3c0 d09daf80 d09daf40 d09daf00 d09daec0 d09dae80 d09dae40 d09dae00 d09dadc0 3c8 d09dad80 d09dad40 d09dad00 d09dacc0 d09dac80 d09dac40 d09dac00 d09dabc0 3d0 d09dab80 d09dab40 d09dab00 d09daac0 d09daa80 d09daa40 d09daa00 d09da9c0 3d8 d09da980 d09da940 d09da900 d09da8c0 d09da880 d09da840 d09da800 d09da7c0 3e0 d09da780 d09da740 d09da700 d09da6c0 d09da680 d09da640 d09da600 d09da5c0 3e8 d09da580 d09da540 d09da500 d09da4c0 d09da480 d09da440 d09da400 d09da3c0 3f0 d09da380 d09da340 d09da300 d09da2c0 d09da280 d09da240 d09da200 d09da1c0 3f8 d09da180 d09da140 d09da100 d09da0c0 d09da080 d09da040 d09da000 d09d9fc0 400 d09d9f80 d09d9f40 d09d9f00 d09d9ec0 d09d9e80 d09d9e40 d09d9e00 d09d9dc0 408 d09d9d80 d09d9d40 d09d9d00 d09d9cc0 d09d9c80 d09d9c40 d09d9c00 d09d9bc0 410 d09d9b80 d09d9b40 d09d9b00 d09d9ac0 d09d9a80 d09d9a40 d09d9a00 d09d99c0 418 d09d9980 d09d9940 d09d9900 d09d98c0 d09d9880 d09d9840 d09d9800 d09d97c0 420 d09d9780 d09d9740 d09d9700 d09d96c0 d09d9680 d09d9640 d09d9600 d09d95c0 428 d09d9580 d09d9540 d09d9500 d09d94c0 d09d9480 d09d9440 d09d9400 d09d93c0 430 d09d9380 d09d9340 d09d9300 d09d92c0 d09d9280 d09d9240 d09d9200 d09d91c0 438 d09d9180 d09d9140 d09d9100 d09d90c0 d09d9080 d09d9040 d09d9000 d09d8fc0 440 d09d8f80 d09d8f40 d09d8f00 d09d8ec0 d09d8e80 d09d8e40 d09d8e00 d09d8dc0 448 d09d8d80 d09d8d40 d09d8d00 d09d8cc0 d09d8c80 d09d8c40 d09d8c00 d09d8bc0 450 d09d8b80 d09d8b40 d09d8b00 d09d8ac0 d09d8a80 d09d8a40 d09d8a00 d09d89c0 458 d09d8980 d09d8940 d09d8900 d09d88c0 d09d8880 d09d8840 d09d8800 d09d87c0 460 d09d8780 d09d8740 d09d8700 d09d86c0 d09d8680 d09d8640 d09d8600 d09d85c0 468 d09d8580 d09d8540 d09d8500 d09d84c0 d09d8480 d09d8440 d09d8400 d09d83c0 470 d09d8380 d09d8340 d09d8300 d09d82c0 d09d8280 d09d8240 d09d8200 d09d81c0 478 d09d8180 d09d8140 d09d8100 d09d80c0 d09d8080 d09d8040 d09d8000 d09d7fc0 480 d09d7f80 d09d7f40 d09d7f00 d09d7ec0 d09d7e80 d09d7e40 d09d7e00 d09d7dc0 488 d09d7d80 d09d7d40 d09d7d00 d09d7cc0 d09d7c80 d09d7c40 d09d7c00 d09d7bc0 490 d09d7b80 d09d7b40 d09d7b00 d09d7ac0 d09d7a80 d09d7a40 d09d7a00 d09d79c0 498 d09d7980 d09d7940 d09d7900 d09d78c0 d09d7880 d09d7840 d09d7800 d09d77c0 4a0 d09d7780 d09d7740 d09d7700 d09d76c0 d09d7680 d09d7640 d09d7600 d09d75c0 4a8 d09d7580 d09d7540 d09d7500 d09d74c0 d09d7480 d09d7440 d09d7400 d09d73c0 4b0 d09d7380 d09d7340 d09d7300 d09d72c0 d09d7280 d09d7240 d09d7200 d09d71c0 4b8 d09d7180 d09d7140 d09d7100 d09d70c0 d09d7080 d09d7040 d09d7000 d09d6fc0 4c0 d09d6f80 d09d6f40 d09d6f00 d09d6ec0 d09d6e80 d09d6e40 d09d6e00 d09d6dc0 4c8 d09d6d80 d09d6d40 d09d6d00 d09d6cc0 d09d6c80 d09d6c40 d09d6c00 d09d6bc0 4d0 d09d6b80 d09d6b40 d09d6b00 d09d6ac0 d09d6a80 d09d6a40 d09d6a00 d09d69c0 4d8 d09d6980 d09d6940 d09d6900 d09d68c0 d09d6880 d09d6840 d09d6800 d09d67c0 4e0 d09d6780 d09d6740 d09d6700 d09d66c0 d09d6680 d09d6640 d09d6600 d09d65c0 4e8 d09d6580 d09d6540 d09d6500 d09d64c0 d09d6480 d09d6440 d09d6400 d09d63c0 4f0 d09d6380 d09d6340 d09d6300 d09d62c0 d09d6280 d09d6240 d09d6200 d09d61c0 4f8 d09d6180 d09d6140 d09d6100 d09d60c0 d09d6080 d09d6040 d09d6000 d09d5fc0 500 d09d5f80 d09d5f40 d09d5f00 d09d5ec0 d09d5e80 d09d5e40 d09d5e00 d09d5dc0 508 d09d5d80 d09d5d40 d09d5d00 d09d5cc0 d09d5c80 d09d5c40 d09d5c00 d09d5bc0 510 d09d5b80 d09d5b40 d09d5b00 d09d5ac0 d09d5a80 d09d5a40 d09d5a00 d09d59c0 518 d09d5980 d09d5940 d09d5900 d09d58c0 d09d5880 d09d5840 d09d5800 d09d57c0 520 d09d5780 d09d5740 d09d5700 d09d56c0 d09d5680 d09d5640 d09d5600 d09d55c0 528 d09d5580 d09d5540 d09d5500 d09d54c0 d09d5480 d09d5440 d09d5400 d09d53c0 530 d09d5380 d09d5340 d09d5300 d09d52c0 d09d5280 d09d5240 d09d5200 d09d51c0 538 d09d5180 d09d5140 d09d5100 d09d50c0 d09d5080 d09d5040 d09d5000 d09d4fc0 540 d09d4f80 d09d4f40 d09d4f00 d09d4ec0 d09d4e80 d09d4e40 d09d4e00 d09d4dc0 548 d09d4d80 d09d4d40 d09d4d00 d09d4cc0 d09d4c80 d09d4c40 d09d4c00 d09d4bc0 550 d09d4b80 d09d4b40 d09d4b00 d09d4ac0 d09d4a80 d09d4a40 d09d4a00 d09d49c0 558 d09d4980 d09d4940 d09d4900 d09d48c0 d09d4880 d09d4840 d09d4800 d09d47c0 560 d09d4780 d09d4740 d09d4700 d09d46c0 d09d4680 d09d4640 d09d4600 d09d45c0 568 d09d4580 d09d4540 d09d4500 d09d44c0 d09d4480 d09d4440 d09d4400 d09d43c0 570 d09d4380 d09d4340 d09d4300 d09d42c0 d09d4280 d09d4240 d09d4200 d09d41c0 578 d09d4180 d09d4140 d09d4100 d09d40c0 d09d4080 d09d4040 d09d4000 d09d3fc0 580 d09d3f80 d09d3f40 d09d3f00 d09d3ec0 d09d3e80 d09d3e40 d09d3e00 d09d3dc0 588 d09d3d80 d09d3d40 d09d3d00 d09d3cc0 d09d3c80 d09d3c40 d09d3c00 d09d3bc0 590 d09d3b80 d09d3b40 d09d3b00 d09d3ac0 d09d3a80 d09d3a40 d09d3a00 d09d39c0 598 d09d3980 d09d3940 d09d3900 d09d38c0 d09d3880 d09d3840 d09d3800 d09d37c0 5a0 d09d3780 d09d3740 d09d3700 d09d36c0 d09d3680 d09d3640 d09d3600 d09d35c0 5a8 d09d3580 d09d3540 d09d3500 d09d34c0 d09d3480 d09d3440 d09d3400 d09d33c0 5b0 d09d3380 d09d3340 d09d3300 d09d32c0 d09d3280 d09d3240 d09d3200 d09d31c0 5b8 d09d3180 d09d3140 d09d3100 d09d30c0 d09d3080 d09d3040 d09d3000 d09d2fc0 5c0 d09d2f80 d09d2f40 d09d2f00 d09d2ec0 d09d2e80 d09d2e40 d09d2e00 d09d2dc0 5c8 d09d2d80 d09d2d40 d09d2d00 d09d2cc0 d09d2c80 d09d2c40 d09d2c00 d09d2bc0 5d0 d09d2b80 d09d2b40 d09d2b00 d09d2ac0 d09d2a80 d09d2a40 d09d2a00 d09d29c0 5d8 d09d2980 d09d2940 d09d2900 d09d28c0 d09d2880 d09d2840 d09d2800 d09d27c0 5e0 d09d2780 d09d2740 d09d2700 d09d26c0 d09d2680 d09d2640 d09d2600 d09d25c0 5e8 d09d2580 d09d2540 d09d2500 d09d24c0 d09d2480 d09d2440 d09d2400 d09d23c0 5f0 d09d2380 d09d2340 d09d2300 d09d22c0 d09d2280 d09d2240 d09d2200 d09d21c0 5f8 d09d2180 d09d2140 d09d2100 d09d20c0 d09d2080 d09d2040 d09d2000 d09d1fc0 600 d09d1f80 d09d1f40 d09d1f00 d09d1ec0 d09d1e80 d09d1e40 d09d1e00 d09d1dc0 608 d09d1d80 d09d1d40 d09d1d00 d09d1cc0 d09d1c80 d09d1c40 d09d1c00 d09d1bc0 610 d09d1b80 d09d1b40 d09d1b00 d09d1ac0 d09d1a80 d09d1a40 d09d1a00 d09d19c0 618 d09d1980 d09d1940 d09d1900 d09d18c0 d09d1880 d09d1840 d09d1800 d09d17c0 620 d09d1780 d09d1740 d09d1700 d09d16c0 d09d1680 d09d1640 d09d1600 d09d15c0 628 d09d1580 d09d1540 d09d1500 d09d14c0 d09d1480 d09d1440 d09d1400 d09d13c0 630 d09d1380 d09d1340 d09d1300 d09d12c0 d09d1280 d09d1240 d09d1200 d09d11c0 638 d09d1180 d09d1140 d09d1100 d09d10c0 d09d1080 d09d1040 d09d1000 d09d0fc0 640 d09d0f80 d09d0f40 d09d0f00 d09d0ec0 d09d0e80 d09d0e40 d09d0e00 d09d0dc0 648 d09d0d80 d09d0d40 d09d0d00 d09d0cc0 d09d0c80 d09d0c40 d09d0c00 d09d0bc0 650 d09d0b80 d09d0b40 d09d0b00 d09d0ac0 d09d0a80 d09d0a40 d09d0a00 d09d09c0 658 d09d0980 d09d0940 d09d0900 d09d08c0 d09d0880 d09d0840 d09d0800 d09d07c0 660 d09d0780 d09d0740 d09d0700 d09d06c0 d09d0680 d09d0640 d09d0600 d09d05c0 668 d09d0580 d09d0540 d09d0500 d09d04c0 d09d0480 d09d0440 d09d0400 d09d03c0 670 d09d0380 d09d0340 d09d0300 d09d02c0 d09d0280 d09d0240 d09d0200 d09d01c0 678 d09d0180 d09d0140 d09d0100 d09d00c0 d09d0080 d09d0040 d09d0000 d09cffc0 680 d09cff80 d09cff40 d09cff00 d09cfec0 d09cfe80 d09cfe40 d09cfe00 d09cfdc0 688 d09cfd80 d09cfd40 d09cfd00 d09cfcc0 d09cfc80 d09cfc40 d09cfc00 d09cfbc0 690 d09cfb80 d09cfb40 d09cfb00 d09cfac0 d09cfa80 d09cfa40 d09cfa00 d09cf9c0 698 d09cf980 d09cf940 d09cf900 d09cf8c0 d09cf880 d09cf840 d09cf800 d09cf7c0 6a0 d09cf780 d09cf740 d09cf700 d09cf6c0 d09cf680 d09cf640 d09cf600 d09cf5c0 6a8 d09cf580 d09cf540 d09cf500 d09cf4c0 d09cf480 d09cf440 d09cf400 d09cf3c0 6b0 d09cf380 d09cf340 d09cf300 d09cf2c0 d09cf280 d09cf240 d09cf200 d09cf1c0 6b8 d09cf180 d09cf140 d09cf100 d09cf0c0 d09cf080 d09cf040 d09cf000 d09cefc0 6c0 d09cef80 d09cef40 d09cef00 d09ceec0 d09cee80 d09cee40 d09cee00 d09cedc0 6c8 d09ced80 d09ced40 d09ced00 d09cecc0 d09cec80 d09cec40 d09cec00 d09cebc0 6d0 d09ceb80 d09ceb40 d09ceb00 d09ceac0 d09cea80 d09cea40 d09cea00 d09ce9c0 6d8 d09ce980 d09ce940 d09ce900 d09ce8c0 d09ce880 d09ce840 d09ce800 d09ce7c0 6e0 d09ce780 d09ce740 d09ce700 d09ce6c0 d09ce680 d09ce640 d09ce600 d09ce5c0 6e8 d09ce580 d09ce540 d09ce500 d09ce4c0 d09ce480 d09ce440 d09ce400 d09ce3c0 6f0 d09ce380 d09ce340 d09ce300 d09ce2c0 d09ce280 d09ce240 d09ce200 d09ce1c0 6f8 d09ce180 d09ce140 d09ce100 d09ce0c0 d09ce080 d09ce040 d09ce000 d09cdfc0 700 d09cdf80 d09cdf40 d09cdf00 d09cdec0 d09cde80 d09cde40 d09cde00 d09cddc0 708 d09cdd80 d09cdd40 d09cdd00 d09cdcc0 d09cdc80 d09cdc40 d09cdc00 d09cdbc0 710 d09cdb80 d09cdb40 d09cdb00 d09cdac0 d09cda80 d09cda40 d09cda00 d09cd9c0 718 d09cd980 d09cd940 d09cd900 d09cd8c0 d09cd880 d09cd840 d09cd800 d09cd7c0 720 d09cd780 d09cd740 d09cd700 d09cd6c0 d09cd680 d09cd640 d09cd600 d09cd5c0 728 d09cd580 d09cd540 d09cd500 d09cd4c0 d09cd480 d09cd440 d09cd400 d09cd3c0 730 d09cd380 d09cd340 d09cd300 d09cd2c0 d09cd280 d09cd240 d09cd200 d09cd1c0 738 d09cd180 d09cd140 d09cd100 d09cd0c0 d09cd080 d09cd040 d09cd000 d09ccfc0 740 d09ccf80 d09ccf40 d09ccf00 d09ccec0 d09cce80 d09cce40 d09cce00 d09ccdc0 748 d09ccd80 d09ccd40 d09ccd00 d09cccc0 d09ccc80 d09ccc40 d09ccc00 d09ccbc0 750 d09ccb80 d09ccb40 d09ccb00 d09ccac0 d09cca80 d09cca40 d09cca00 d09cc9c0 758 d09cc980 d09cc940 d09cc900 d09cc8c0 d09cc880 d09cc840 d09cc800 d09cc7c0 760 d09cc780 d09cc740 d09cc700 d09cc6c0 d09cc680 d09cc640 d09cc600 d09cc5c0 768 d09cc580 d09cc540 d09cc500 d09cc4c0 d09cc480 d09cc440 d09cc400 d09cc3c0 770 d09cc380 d09cc340 d09cc300 d09cc2c0 d09cc280 d09cc240 d09cc200 d09cc1c0 778 d09cc180 d09cc140 d09cc100 d09cc0c0 d09cc080 d09cc040 d09cc000 d09cbfc0 780 d09cbf80 d09cbf40 d09cbf00 d09cbec0 d09cbe80 d09cbe40 d09cbe00 d09cbdc0 788 d09cbd80 d09cbd40 d09cbd00 d09cbcc0 d09cbc80 d09cbc40 d09cbc00 d09cbbc0 790 d09cbb80 d09cbb40 d09cbb00 d09cbac0 d09cba80 d09cba40 d09cba00 d09cb9c0 798 d09cb980 d09cb940 d09cb900 d09cb8c0 d09cb880 d09cb840 d09cb800 d09cb7c0 7a0 d09cb780 d09cb740 d09cb700 d09cb6c0 d09cb680 d09cb640 d09cb600 d09cb5c0 7a8 d09cb580 d09cb540 d09cb500 d09cb4c0 d09cb480 d09cb440 d09cb400 d09cb3c0 7b0 d09cb380 d09cb340 d09cb300 d09cb2c0 d09cb280 d09cb240 d09cb200 d09cb1c0 7b8 d09cb180 d09cb140 d09cb100 d09cb0c0 d09cb080 d09cb040 d09cb000 d09cafc0 7c0 d09caf80 d09caf40 d09caf00 d09caec0 d09cae80 d09cae40 d09cae00 d09cadc0 7c8 d09cad80 d09cad40 d09cad00 d09cacc0 d09cac80 d09cac40 d09cac00 d09cabc0 7d0 d09cab80 d09cab40 d09cab00 d09caac0 d09caa80 d09caa40 d09caa00 d09ca9c0 7d8 d09ca980 d09ca940 d09ca900 d09ca8c0 d09ca880 d09ca840 d09ca800 d09ca7c0 7e0 d09ca780 d09ca740 d09ca700 d09ca6c0 d09ca680 d09ca640 d09ca600 d09ca5c0 7e8 d09ca580 d09ca540 d09ca500 d09ca4c0 d09ca480 d09ca440 d09ca400 d09ca3c0 7f0 d09ca380 d09ca340 d09ca300 d09ca2c0 d09ca280 d09ca240 d09ca200 d09ca1c0 7f8 d09ca180 d09ca140 d09ca100 d09ca0c0 d09ca080 d09ca040 d09ca000 Rx channel teardown, cppi_ch = cb0106e0 Channel global configuration @ d09b1928, value written: 81004044, value read: 80000000 Tear down channel @ d09b1928, value written: c1004044, value read: c0000000 Popping value 1 from queue @ d09b6440 Popping value 0 from queue @ d09b6440 Popping value 0 from queue @ d09b6440 Popping value 0 from queue @ d09b6440 <<<<<<<<stuck in this loop where this message repeats forever>>>>>>
