Other Parts Discussed in Thread: DM3730, SYSCONFIG
We are interfacing a 3M pixel 8bit parallel interface camera to the DM3730 and are unable to get the CAM_XCLK pin from the DM3730 to output a clock
Can you please confirm if we have set the following registers up correctly
PID:00400002 TID:00890006 ************** ISP CTRL **************
PID:00400002 TID:00890006 REVISION 0x000000f0
PID:00400002 TID:00890006 SYSCONFIG 0x00001000
PID:00400002 TID:00890006 SYSSTATUS 0x00000001
PID:00400002 TID:00890006 IRQ0ENABLE 0xf33f7fff
PID:00400002 TID:00890006 IRQ0STATUS 0x00000000
PID:00400002 TID:00890006 IRQ1ENABLE 0x00000000
PID:00400002 TID:00890006 IRQ1STATUS 0x00000000
PID:00400002 TID:00890006 TCTRL GRESET LENGTH 0x00000000
PID:00400002 TID:00890006 TCTRL PSTRB REPLAY 0x00000000
PID:00400002 TID:00890006 CTRL 0x201d8140
PID:00400002 TID:00890006 SECURE 0x00000ÿ000
PID:00400002 TID:00890006 TCTRL_CTRL 0x00000000
PID:00400002 TID:00890006 TCTRL_FRAME 0x000c0000
PID:00400002 TID:00890006 TCTRL_PSTRB_DELAY 0x00000000
PID:00400002 TID:00890006 TCTRL_STRB_DELAY 0x00000000
PID:00400002 TID:00890006 TCTRL_SHUT_DELAY 0x00000000
PID:00400002 TID:00890006 TCTRL_PSTRB_LENGTH 0x00000000
PID:00400002 TID:00890006ÿ TCTRL_STRB_LENGTH 0x00000000
PID:00400002 TID:00890006 TCTRL_SHUT_LENGTH 0x00000000
PID:00400002 TID:00890006 PING_PONG_ADDR 0x00000000
PID:00400002 TID:00890006 PING_PONG_MEM_RANGE 0x00000000
PID:00400002 TID:00890006 PING_PONG_BUF_SIZE 0x00000000
PID:00400002 TID:00890006 ***************** CCDC ****************
PID:00400002 TID:00890006 PID 0x0001fe01
PID:00400002 TID:00890006 PCR 0x00000001
PID:00400002 TID:00890006 SYN MODE 0x00030e80
PID:00400002 TID:00890006 HD VD WID 0x00000000
PID:00400002 TID:00890006 PIX LINES 0x00000000
PID:00400002 TID:00890006 HORZ INFO 0x003c057f
PID:00400002 TID:00890006 VERT START 0x00140014
PID:00400002 TID:00890006 VERT LINES 0x0000011f
PID:00400002 TID:00890006 CULLING 0xffff00ff
PID:00400002 TID:00890006 VERT HSIZE OFF 0x00000580
PID:00400002 TID:00890006 SDOFST 0x00000249
PID:00400002 TID:00890006 SDR ADDR 0x8692b000
PID:00400002 TID:00890006 CLAMP 0x00000010
PID:00400002 TID:00890006 DCSUB 0x0000ÿ0000
PID:00400002 TID:00890006 COLTPIN 0x00000000
PID:00400002 TID:00890006 BLKCMP 0x00000000
PID:00400002 TID:00890006 FPC 0x00000000
PID:00400002 TID:00890006 FPC ADDR 0x00000000
PID:00400002 TID:00890006 VDINT 0x00000000
PID:00400002 TID:00890006 ALAW 0x00000004
PID:00400002 TID:00890006 REC656IF 0x00000001
PID:00400002 TID:00890006 CFG 0x00009040
PID:00400002 TID:00890006 FMTCFG 0x00004000
PID:00400002 TID:00890006 FMT HORZ 0x00000ÿ000
PID:00400002 TID:00890006 FMT VERT 0x00000000
PID:00400002 TID:00890006 FMT ADDR0 0x00000000
PID:00400002 TID:00890006 FMT ADDR1 0x00000000
PID:00400002 TID:00890006 FMT ADDR2 0x00000000
PID:00400002 TID:00890006 FMT ADDR3 0x00000000
PID:00400002 TID:00890006 FMT ADDR4 0x00000000
PID:00400002 TID:00890006 FMT ADDR5 0x00000000
PID:00400002 TID:00890006 FMT ADDR6 0x00000000
PID:00400002 TID:00890006 FMT ADDR7 0x00000000
PID:00400002 TID:00890006 PRGEVEN0 0x00000000
PID:00400002 TID:00890006 PRGEVEN1 0x00000000
PID:00400002 TID:00890006 PRGODD0 0x00000000
PID:00400002 TID:00890006 PRGODD1 0x00000000
PID:00400002 TID:00890006 VP OUT 0x00000000
PID:00400002 TID:00890006 LSC CONFIG 0x00006600
PID:00400002 TID:00890006 LSC INITIAL 0x00000000
PID:00400002 TID:00890006 LSC TABLE_BASE 0x00000000
PID:00400002 TID:00890006 LSC TABLE_OFFSET 0x00000000
PID:00400002 TID:00890006 *** CAMERA GPIO ***
PID:00400002 TID:00890006 0x4800210c = 0x00000108
PID:00400002 TID:00890006 0x4800210e = 0x00000108
PID:00400002 TID:00890006 0x48002110 =ÿ 0x00000000
PID:00400002 TID:00890006 0x48002112 = 0x00000108
PID:00400002 TID:00890006 0x48002114 = 0x0000010c
PID:00400002 TID:00890006 0x48002116 = 0x00000100
PID:00400002 TID:00890006 0x48002118 = 0x00000100
PID:00400002 TID:00890006 0x4800211a = 0x00000100
PID:00400002 TID:00890006 0x4800211c = 0x00000100
PID:00400002 TID:00890006 0x4800211e = 0x00000100
PID:00400002 TID:00890006 0x48002120 = 0x00000100
PID:00400002 TID:00890006 0x48002122 = 0x00000100
PID:00400002 TID:00890006 0x48002124 = 0x00000100
PID:00400002 TID:00890006 0x48002126 = 0x00000100
PID:00400002 TID:00890006 0x48002128 = 0x00000100
PID:00400002 TID:00890006 0x4800212a = 0x00000104
PID:00400002 TID:00890006 0x4800212c = 0x00000104
PID:00400002 TID:00890006 0x4800212e = 0x00000104
PID:00400002 TID:00890006 0x48002130 = 0x00000004
PID:00400002 TID:00890006 0x48002132 = 0x00000000
PID:00400002 TID:00890006 ****** CAMERA CLOCKS ******
PID:00400002 TID:00890006 CM_FCLKEN_CAM = 0x00000003
PID:00400002 TID:00890006 CM_ICLKEN_CAM = 0x00000001
PID:00400002 TID:00890006 CM_IDLEST_CAM = 0x00000000
PID:00400002 TID:00890006 CM_AUTOIDLE_CAM = 0x00000001
PID:00400002 TID:00890006 CM_CLKSEL_CAM = 0x00000004
PID:00400002 TID:00890006 CM_SLEEPDEP_CAM = 0x00000002
PID:00400002 TID:00890006 CM_CLKSTCTRL_CAM = 0x00000003
PID:00400002 TID:00890006 CM_CLKSTST_CAM = 0x00000001
PID:00400002 TID:00890006 CLOCK CONTROL = 0x00770007
