Hi all,
I have two TMDSEVM6670LE board and i want to transfer data between them using Ethernet cable ,
So i want any guide for this purpose .
Thanks in advanced ,
Muhammad.
Hi all,
Muhammad.
Can you use the C:\ti\pdk_C6670_1_1_2_6\packages\ti\drv\exampleProjects\PA_simpleExample_exampleProject or PA_emacExample_exampleProject as the starting point? Those two projects tried to send out some packets and loop them back and verify. You can change the code as no loopback and test between 2 6670 EVMs.
Regards, Eric
Hi lding ,
Thanks for your response , i will try to do what you say .
Muhammad.
Hi lding ,
Can you told me what are configurations must be changed to make Board_1 to send and Board_2 to receive? , i know that i must change the IP of the EMAC on the two boards to match each other and stop the receiving in Board_1 and Transmission in Board_2
Any other configurations must be changed ?
Thanks in Advanced,
Muhammad .
Can you check: http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/p/273000/961813.aspx#961813
- Eric
