* @file edma_test.c
* @brief
* This is the Example test code for the EDMA CSL Functional layer.
* \par
* NOTE:
* (C) Copyright 2009 Texas Instruments, Inc.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <ti/csl/csl_edma3.h>
#include <ti/csl/csl_edma3Aux.h>
#include <ti/csl/csl_cacheAux.h>
************************** Global Variables **************************
/* Global Variables which are used to dump the TPCC register overlay in the
* debugger... */
CSL_TpccRegs* gEDMACC0Regs = (CSL_TpccRegs*)CSL_EDMA0CC_REGS; (what is the purpose of using
explian me in detail what these lines do?)
CSL_TpccRegs* gEDMACC1Regs = (CSL_TpccRegs*)CSL_EDMA1CC_REGS;
CSL_TpccRegs* gEDMACC2Regs = (CSL_TpccRegs*)CSL_EDMA2CC_REGS;
/* Global Buffers (Source and Destination) for PING-PONG */
Uint8 srcBuff1[512];
Uint8 srcBuff2[512];
Uint8 dstBuff1[512];
Uint8 dstBuff2[512];
************************ EDMA TEST FUNCTIONS *************************
* @b Description
* @n
* This is utility function used by the EDMA example to verify the
* Data transfer.
* @retval
* Success - TRUE
* @retval
* Error - FALSE
static Bool Verify_Transfer
Uint16 aCnt,
Uint16 bCnt,
Uint16 cCnt,
Uint16 srcBIdx,
Uint16 dstBIdx,
Uint16 srcCIdx,
Uint16 dstCIdx,
Uint8 *srcBuff,
Uint8 *dstBuff,
Bool abSync
Uint32 loopIndex1;
Uint32 loopIndex2;
Uint32 loopIndex3;
Uint8* srcArrayPtr = (Uint8*)srcBuff;
Uint8* dstArrayPtr = (Uint8*)dstBuff;
Uint8* srcFramePtr = (Uint8*)srcBuff;
Uint8* dstFramePtr = (Uint8*)dstBuff;
Uint16 key;
/* Invalidate the cache before verification */
/* Disable Interrupts */
key = _disable_interrupts();
CACHE_invL1d ((void *)srcBuff, 512, CACHE_WAIT);
CACHE_invL2 ((void *)srcBuff, 512, CACHE_WAIT); ( why we are enabling and disabling interruppts?)
CACHE_invL1d ((void *)dstBuff, 512, CACHE_WAIT);
CACHE_invL2 ((void *)dstBuff, 512, CACHE_WAIT);
_mfence();
/* Re-enable Interrupts. */
_restore_interrupts(key);
for (loopIndex1 = 0; loopIndex1 < cCnt; loopIndex1++) {
for (loopIndex2 = 0; loopIndex2 < bCnt; loopIndex2++) { ( y 3 loop iindex required 1 is not enough)
for (loopIndex3 = 0; loopIndex3 < aCnt; loopIndex3++)
if (srcArrayPtr[loopIndex3] != dstArrayPtr[loopIndex3])
return FALSE;
srcArrayPtr = srcArrayPtr + srcBIdx;
dstArrayPtr = dstArrayPtr + dstBIdx;
if (abSync) {
srcFramePtr = srcFramePtr + srcCIdx;
srcArrayPtr = srcFramePtr;
dstFramePtr = dstFramePtr + dstCIdx;
dstArrayPtr = dstFramePtr;
else {
srcFramePtr = srcArrayPtr + srcCIdx - srcBIdx;
dstFramePtr = dstArrayPtr + dstCIdx - dstBIdx;
return TRUE;
* @b Description
* @n
* This is the example routine which perform EDMA ping pong buffer transfer
* using a QDMA Channel.
* It implements following steps:-
* - Initializes and Opens the EDMA module
* - Sets up the Module and gets the module setup values
* - Enables the DMA and QDMA regions
* - Opens the specified QDMA channel 'channelNum'
* - PING uses PARAM Entry 1
* - PONG uses PARAM Entry 2
* - Configures the PARAM Blocks.
* - Enables the channel
* - Initiates the QDMA Transfer by setting the Trigger Word.
* - Poll on the IPR bit
* - Clear the pending bit
* - Compares the transfered data
* - Closes EDMA module
* @param[in] instNum
* EDMA Instance Number on which the test is executed.
* @param[in] channelNum
* EDMA Channel Number on which the test is executed
* @retval
* Success - 0
* @retval
* Failure - <0
static Int32 qdma_link_xfer_region (Int32 instNum, Uint8 channelNum, Int32 regionNum)
CSL_Edma3Handle hModule;
CSL_Edma3Obj edmaObj;
CSL_Edma3ParamHandle hParamPong,hParamPing;
CSL_Edma3ChannelObj chObj;
CSL_Edma3CmdIntr regionIntr;
CSL_Edma3CmdDrae regionAccess;
CSL_Edma3ChannelHandle hChannel;
CSL_Edma3ParamSetup myParamSetup;
CSL_Edma3Context context;
CSL_Edma3ChannelAttr chAttr;
CSL_Edma3CmdQrae qraeSetup;
CSL_Status status;
Uint32 loopIndex;
/* Start the EDMA PING-PONG test over the SHADOW Region. */
printf ("Debug: Testing EDMA(%d) Ping-Pong Test (Shadow) Region %d for QDMA Channel %d...\n",
instNum, regionNum, channelNum);
/* Initialize data */
for (loopIndex = 0; loopIndex < 256; loopIndex++) {
srcBuff1[loopIndex] = loopIndex;
srcBuff2[loopIndex] = loopIndex;
dstBuff1[loopIndex] = 0;
dstBuff2[loopIndex] = 0;
/* Module initialization */
if (CSL_edma3Init(&context) != CSL_SOK)
printf ("Error: EDMA module initialization failed\n");
return -1;
/* Module level open */
hModule = CSL_edma3Open(&edmaObj,instNum,NULL,&status);
if ((hModule == NULL) || (status != CSL_SOK))
printf ("Error: EDMA module open failed\n");
return -1;
/* Is this for GLOBAL or SHADOW Region */
if (regionNum != CSL_EDMA3_REGION_GLOBAL)
/* Shadow Region: Enable DRAE enable(Bits 0-15) it. */
regionAccess.region = regionNum;
regionAccess.drae = 0xFFFF;
regionAccess.draeh = 0x0000;
if (CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_DMAREGION_ENABLE, ®ionAccess) != CSL_SOK)
printf ("Error: EDMA region enable command failed\n");
return -1;
/* Enable access for all QDMA channels in the SHADOW Region. */
qraeSetup.region = regionNum;
qraeSetup.qrae = 0xFF;
if (CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_QDMAREGION_ENABLE, &qraeSetup) != CSL_SOK)
printf ("Error: EDMA QDMA region enable command failed\n");
return -1;
/* QDMA Channel Open */
chAttr.regionNum = regionNum;
chAttr.chaNum = channelNum;
hChannel = CSL_edma3ChannelOpen(&chObj, instNum, &chAttr, &status);
if ((hChannel == NULL) || (status != CSL_SOK))
printf ("Error: EDMA channel open failed\n");
return -1;
/* Map QDMA Channel to the PING Param Block i.e. 1 */
CSL_edma3HwChannelSetupParam (hChannel, 1);
/* Setup the trigger word for the QDMA Channel. */
CSL_edma3HwChannelSetupTriggerWord(hChannel, 7);
/* PING Parameter Entry Handle */
hParamPing = CSL_edma3GetParamHandle(hChannel, 1, &status);
if (hParamPing == NULL)
printf ("Error: EDMA get handle for param entry 1 failed\n");
return -1;
/* PONG Parameter Entry Handle */
hParamPong = CSL_edma3GetParamHandle(hChannel, 2, &status);
if (hParamPong == NULL)
printf ("Error: EDMA get handle for param entry 2 failed\n");
return -1;
/* Setup param entry */
myParamSetup.option = CSL_EDMA3_OPT_MAKE(CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_TCCH_DIS, \
CSL_EDMA3_ITCINT_DIS, \
CSL_EDMA3_TCINT_DIS,\
0,CSL_EDMA3_TCC_NORMAL,\
CSL_EDMA3_FIFOWIDTH_NONE, \
CSL_EDMA3_STATIC_DIS, \
CSL_EDMA3_SYNC_A, \
CSL_EDMA3_ADDRMODE_INCR, \
CSL_EDMA3_ADDRMODE_INCR);
myParamSetup.srcAddr = (Uint32)srcBuff1;
myParamSetup.aCntbCnt = CSL_EDMA3_CNT_MAKE(256,1);
myParamSetup.dstAddr = (Uint32)dstBuff1;
myParamSetup.srcDstBidx = CSL_EDMA3_BIDX_MAKE(1,1);
myParamSetup.linkBcntrld= CSL_EDMA3_LINKBCNTRLD_MAKE(hParamPong,0);
myParamSetup.srcDstCidx = CSL_EDMA3_CIDX_MAKE(0,1);
myParamSetup.cCnt = 1;
/* Setup PING to operate with this PARAM Entry. */
if (CSL_edma3ParamSetup(hParamPing, &myParamSetup) != CSL_SOK)
printf ("Error: EDMA param setup failed\n");
return -1;
/* Setting up the next entry */
CSL_EDMA3_TCINT_EN,\
1,CSL_EDMA3_TCC_NORMAL,\
CSL_EDMA3_STATIC_EN, \
CSL_EDMA3_SYNC_A, \
myParamSetup.srcAddr = (Uint32)srcBuff2;
myParamSetup.dstAddr = (Uint32)dstBuff2;
/* Setup for the Pong buffer */
if (CSL_edma3ParamSetup(hParamPong,&myParamSetup) != CSL_SOK)
return -1;
/* Enable Channel */
if (CSL_edma3HwChannelControl(hChannel,CSL_EDMA3_CMD_CHANNEL_ENABLE, NULL) != CSL_SOK)
printf ("Error: EDMA channel enable command failed\n");
return -1;
/* Trigger the word by writing to the trigger word... */
if (CSL_edma3ParamWriteWord(hParamPing,7,1) != CSL_SOK) {
printf ("Error: EDMA param write word failed\n");
return -1;
/* Poll IPR bit */
regionIntr.region = regionNum;
do {
CSL_edma3GetHwStatus(hModule,CSL_EDMA3_QUERY_INTRPEND,®ionIntr);
} while (!(regionIntr.intr & 0x2));
/* Clear pending interrupt */
if (CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTRPEND_CLEAR, ®ionIntr) != CSL_SOK)
printf ("Error: EDMA clear interrupt pend command failed\n");
return -1;
/* Check transfer by comparing the source and destination buffers */
if(Verify_Transfer( 256, 1, 1, 0, 0, 0, 0, srcBuff1, dstBuff1,TRUE) == FALSE)
printf ("Error: Verification (Source1/Destination1) Failed\n");
return -1;
if(Verify_Transfer( 256, 1, 1, 0, 0, 0, 0, srcBuff2, dstBuff2,TRUE) == FALSE)
printf ("Error: Verification (Source2/Destination2) Failed\n");
return -1;
/* Disable the channel */
CSL_edma3HwChannelControl(hChannel,CSL_EDMA3_CMD_CHANNEL_DISABLE, NULL);
/* Close channel */
if (CSL_edma3ChannelClose(hChannel) != CSL_SOK)
printf("Error: EDMA channel close failed\n");
return -1;
/* Close EDMA module */
if (CSL_edma3Close(hModule) != CSL_SOK)
printf("Error: EDMA module close failed\n");
return -1;
/* Test Passed. */
return 0;
* @b Description
* @n
* where channel is open in the global region.
* - Intializes and Opens the EDMA Module .
* - Sets up the interrupt for the EDMA global region.
* - Sets up the EDMA module using the API csl_edma3Hwsetup ()
* - Enables the EDMA global region
* - Opens the channel 'channelNum' get the param handle for PARAM 1, 2
* - PING is mapped to PARAM Entry 1
* - PONG is mapped to PARAM Entry 2
* - PING is Linked with PONG...
* - Enables the EDMA interrupt using CSL_EDMA3_CMD_INTR_ENABLE.
* - Enables Interrupt (Bit 0-2) for the global region interrupts
* - Manually triggers the DMA channel 'channelNum'(This should be PING)
* - Polls on IPR bit 0 (Since TCC for PING is 0)
* - Manually triggers the channel 'channelNum' (This should be PONG)
* - Polls on IPR bit 1 (Since TCC for PONG is 1)
* - Clears the pending bit
* - Compares the data in the destination buffer is proper or not.
* - Closes the EDMA module and channel.
* @retval
* Success - 0
* @retval
* Failure - <0
static Int32 edma_ping_pong_xfer_gbl_region (Int32 instNum, Uint8 channelNum)
CSL_Edma3ParamHandle hParamPing;
CSL_Edma3ParamHandle hParamPong;
CSL_Status status;
Uint32 loopIndex;
/* Start the EDMA PING-PONG test over the Global Region. */
printf ("Debug: Testing EDMA(%d) Ping-Pong Test (Global) Region for Channel %d...\n", instNum, channelNum);
return -1;
/* Open the EDMA Module using the provided instance number */
hModule = CSL_edma3Open(&edmaObj, instNum, NULL, &status);
if ( (hModule == NULL) || (status != CSL_SOK))
return -1;
/* Channel open */
chAttr.regionNum = CSL_EDMA3_REGION_GLOBAL;
printf ("Error: Unable to open EDMA Channel:%d\n", channelNum);
return -1;
if(!instNum)
/* For first EDMA instance there are only 2 TCs and 2 event queues
* Modify the channel default queue setup from 0 to 1
if (CSL_edma3HwChannelSetupQue(hChannel,CSL_EDMA3_QUE_1) != CSL_SOK)
printf ("Error: EDMA channel setup queue failed\n");
return -1;
else
/* For EDMA instance 1 and 2 maximum of 4 TCs and 4 event queues are supported
* Change Channel Default queue setup from 0 to 3
if (CSL_edma3HwChannelSetupQue(hChannel,CSL_EDMA3_QUE_3) != CSL_SOK)
return -1;
/* Map the DMA Channel to PARAM Block 2. */
CSL_edma3MapDMAChannelToParamBlock (hModule, channelNum, 2);
/* Obtain a handle to parameter set 2 */
hParamPing = CSL_edma3GetParamHandle(hChannel, 2, &status);
printf ("Error: EDMA Get Parameter Entry failed for 2.\n");
return -1;
/* Obtain a handle to parameter set 1 */
hParamPong = CSL_edma3GetParamHandle(hChannel, 1, &status);
printf ("Error: EDMA Get Parameter Entry failed for 1.\n");
return -1;
/* Setup the parameter entry parameters (Ping buffer) */
CSL_EDMA3_TCINT_EN, \
0, CSL_EDMA3_TCC_NORMAL,\
CSL_EDMA3_SYNC_A, \
CSL_EDMA3_ADDRMODE_INCR ); ( can u explain me each line here)
/* Ping setup */
if (CSL_edma3ParamSetup(hParamPing,&myParamSetup) != CSL_SOK)
printf ("Error: EDMA Parameter Entry Setup failed\n");
return -1;
/* Pong setup */
myParamSetup.linkBcntrld = CSL_EDMA3_LINKBCNTRLD_MAKE(hParamPing,0);
1, CSL_EDMA3_TCC_NORMAL,\
CSL_EDMA3_SYNC_A, \
return -1;
/* Interrupt enable (Bits 0-1) for the global region interrupts */
regionIntr.region = CSL_EDMA3_REGION_GLOBAL;
regionIntr.intr = 0x3;
regionIntr.intrh = 0x0000;
CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTR_ENABLE,®ionIntr);
/* Trigger channel */
CSL_edma3HwChannelControl(hChannel,CSL_EDMA3_CMD_CHANNEL_SET,NULL);
regionIntr.intr = 0;
regionIntr.intrh = 0;
/* Poll on IPR bit 0 */
do {
} while (!(regionIntr.intr & 0x1));
/* Clear the pending bit */
CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTRPEND_CLEAR,®ionIntr);
/* Trigger Channel */
/* Poll on IPR bit 2 */
do {
if(Verify_Transfer( 256, 1, 1, 0, 0, 0, 0, srcBuff1, dstBuff1, TRUE) == FALSE)
return -1;
if(Verify_Transfer( 256, 1, 1, 0, 0, 0, 0, srcBuff2, dstBuff2, TRUE) == FALSE)
return -1;
/* Close channel */
printf("Error: EDMA Channel Close failed\n");
return -1;
printf("Error: EDMA Module Close failed\n");
return -1;
/* The test passed. */
return 0;
* @b Description
* @n
* This is the example routine which performs the EDMA ping pong buffer transfer in
* the specified SHADOW Region.
* - Sets up the interrupt for the EDMA SHADOW region.
* - Enables the EDMA interrupts for the specific SHADOW Region.
* @param[in] regionNum
* Shadown Region Number on which the test is executed.
* @retval
* Success - 0
* @retval
* Failure - <0
static Int32 edma_ping_pong_xfer_region (Int32 instNum, Uint8 channelNum, Int32 regionNum)
CSL_Status status;
Uint32 loopIndex;
/* Start the EDMA PING-PONG test over the Shadow Region. */
printf ("Debug: Testing EDMA(%d) Ping-Pong Test Shadow-Region %d for Channel %d...\n", instNum, regionNum, channelNum);
/* Module Initialization */
return -1;
return -1;
/* Determine the number of channels we need to enable. Is this Instance 0? */
if (instNum == 0)
/* YES. DRAE enable(Bits 0-15) for the shadow region; since there are 16 channels. */
regionAccess.draeh = 0x0;
return -1;
else
/* YES. DRAE enable(Bits 0-63) for the shadow region; since there are 64 channels. */
regionAccess.drae = 0xFFFFFFFF;
regionAccess.draeh = 0xFFFFFFFF;
return -1;
/* Interrupt enable (Bits 0-11) for the shadow region 5 */
regionIntr.intr = 0x0FFF;
if (CSL_edma3HwControl(hModule,CSL_EDMA3_CMD_INTR_ENABLE, ®ionIntr) != CSL_SOK)
printf ("Error: EDMA interrupts enable command failed\n");
return -1;
/* Open the channel in context of the specified region number. */
return -1;
/* Map the DMA Channel to the appropriate PARAM Block. We start with PING
* which is located at PARAM Block 2. */
if (CSL_edma3HwChannelSetupParam(hChannel, 2) != CSL_SOK)
printf ("Error: EDMA channel setup param failed\n");
return -1;
if (hParamPing == NULL) {
printf ("Error: EDMA get param handle for param entry 2 failed\n");
return -1;
if (hParamPong == NULL) {
printf ("Error: EDMA get param handle for param entry 1 failed\n");
return -1;
/* Setup the first param set (Ping buffer) */
myParamSetup.option = CSL_EDMA3_OPT_MAKE( CSL_EDMA3_ITCCH_DIS, \
CSL_EDMA3_SYNC_A, \
myParamSetup.aCntbCnt = CSL_EDMA3_CNT_MAKE(512,1);
/* Setup the Ping Entry which loaded after the Pong entry gets exhausted */
printf("Error: EDMA ping parameter entry setup is failed\n");
return -1;
/* Setup the Pong Entry which loaded after the Ping entry gets exhausted */
1,CSL_EDMA3_TCC_NORMAL, \
TRUE,CSL_EDMA3_SYNC_A, \
printf("Error: EDMA pong parameter entry setup is failed\n");
return -1;
/* Enable channel */
printf("Error: EDMA channel enable command is failed\n");
return -1;
for (loopIndex = 0; loopIndex < 512; loopIndex++) {
/* Manually trigger the channel */
if (CSL_edma3HwChannelControl(hChannel,CSL_EDMA3_CMD_CHANNEL_SET,NULL) != CSL_SOK)
printf("Error: EDMA channel set command is failed\n");
return -1;
do {
/* Poll on interrupt bit 0 */
/* Clear interrupt bit 0 */
printf("Error: EDMA clear interrupt bit 0 command is failed\n");
return -1;
/* Mapping channel 0 to event queue 1 */
printf("Error: EDMA channel setup queue is failed\n");
return -1;
return -1;
/* Poll on interrupt pend bit 1 */
do {
/* Clear interrupt bit 1 */
printf("Error: EDMA clear interrupt bit 1 command is failed\n");
return -1;
/* Verify the data has been transferred correctly. */
if(Verify_Transfer(512, 1, 1, 0, 0, 0, 0, srcBuff1, dstBuff1,TRUE) == FALSE)
return -1;
if(Verify_Transfer(512, 1, 1, 0, 0, 0, 0, srcBuff2, dstBuff2,TRUE) == FALSE)
return -1;
/* Close channel */
return -1;
return -1;
/* Test Passed. */
return 0;
* @b Description
* @n
* Entry point for the test code.
* @retval
* Not Applicable.
void main (void)
Uint8 channelNum;
Int32 regionNum;
Uint8 instNum = 0;
printf ("**************************************************\n");
printf ("******************* EDMA Testing *****************\n");
/* EDMA Instance 0: Supports only 16 DMA Channels. */
for (channelNum = 0; channelNum < 16; channelNum++)
if (edma_ping_pong_xfer_gbl_region(instNum, channelNum) < 0)
printf ("Error: Testing EDMA(%d) Ping-Pong Test (Global) Region for Channel %d FAILED\n", instNum, channelNum);
return;
printf ("Debug: Testing EDMA(%d) Ping-Pong Test (Global) Region for Channel %d Passed\n", instNum, channelNum);
/* EDMA Shadow Testing: This is run for all the SHADOW Regions from 0-7
* and on all supported DMA Channels. */
for (regionNum = CSL_EDMA3_REGION_0; regionNum <= CSL_EDMA3_REGION_7; regionNum++)
if (edma_ping_pong_xfer_region(instNum, channelNum, regionNum) < 0)
printf ("Error: Testing EDMA(%d) Ping-Pong Test Shadow-Region %d for Channel %d FAILED\n",
return;
printf ("Debug: Testing EDMA(%d) Ping-Pong Test Shadow-Region %d for Channel %d Passed\n",
/* QDMA Testing: This is run for all SHADOW Regions from 0-7 and on
* all supported QDMA Channels; there are 8 supported. Remember QDMA Channels start after the
* DMA Channels which are 16 for Instance 0. */
for (regionNum = CSL_EDMA3_REGION_GLOBAL; regionNum <= CSL_EDMA3_REGION_7; regionNum++)
for (channelNum = 16; channelNum < 24; channelNum++)
if (qdma_link_xfer_region(instNum, channelNum, regionNum) < 0)
printf ("Error: Testing EDMA(%d) Ping-Pong Test (Shadow) Region %d for QDMA Channel %d FAILED\n",
return;
printf ("Debug: Testing EDMA(%d) Ping-Pong Test (Shadow) Region %d for QDMA Channel %d Passed\n",
/* Run the test for EDMA Instance 1 and 2; both have the same limits. */
for (instNum = 1; instNum < 3; instNum++)
/* EDMA Instance 1 and 2: Supports 64 DMA Channels. */
for (channelNum = 0; channelNum < 64; channelNum++)
return;
return;
* DMA Channels which are 64 for Instance 1 and 2 */
for (channelNum = 64; channelNum < 72; channelNum++)
return;
printf ("************* EDMA Testing Successful ************\n");
return;
iam using c6678 processor and this is the program given by ti in csl and i have in the program in some lines which i have highligted in pink and question posted in some other color beside pls explain me
