Hi
I am trying to upgrade from DVRRDK_2.0 to DVRRDK_4.0 on our customized DM8168 platform.(env_1024_256)
run: init.sh
all is ok.
but when i run :load.sh Hold on!
the log is like:
==========================BEGIN=============================
root@dm816x:/opt/dvr_rdk/ti816x# ./load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_1024M_256M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** VPSS Firmware build time 22:08:00 Sep 26 2013 EDG gcc 3.0 mode
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 279999968
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
After Ipc_startcallback status [0x00000000]
[m3vpss ] *** UTILS: CPU KHz = 559999 Khz ***
[m3vpss ]
[m3vpss ] 35: SYSTEM: IPC init in progress !!!
[m3vpss ] 35: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 38: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 1.
[m3vpss ] 1037: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 2037: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3037: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_m3video_1024M_256M.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** VIDEO Firmware build time 22:09:20 Sep 26 2013 EDG gcc 3.0 mode
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 50000000
[m3video]
[m3video] *** UTILS: CPU KHz = 100000 Khz ***
[m3video]
[m3video] 21166: SYSTEM: IPC init in progress !!!
[m3video] 21166: SYSTEM: Attaching to [HOST] ...
[m3video] 21180: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 0.
[m3video] 22180: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 4037: SYSTEM: Attaching to [DSP] ...
[m3video] 23180: SYSTEM: Attaching to [DSP] ...
[m3video] 24180: SYSTEM: Attaching to [DSP] ...
[m3video] 25180: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 5037: SYSTEM: Attaching to [DSP] ...
[m3video] 26180: SYSTEM: Attaching to [DSP] ...
[m3video] 27180: SYSTEM: Attaching to [DSP] ...
[m3video] 28180: SYSTEM: Attaching to [DSP] ...
[m3video] 29180: SYSTEM: Attaching to [DSP] ...
[m3video] 30180: SYSTEM: Attaching to [DSP] ...
[m3video] 31180: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_1024M_256M.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** VIDEO Firmware build time 22:03:09 Sep 26 2013 EDG gcc 3.0 mode
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 813176448
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 813176 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 9: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 10: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 32137: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 5740: SYSTEM: ADMA: Module install successful, device major num = 251
ttaching to [DSPDRV: Module install successful
] ... SUCCESS !!DRV: Module built on Sep 26 2013 21:46:27
[c6xdsp ] 11: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3video] 32152: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 5741: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] 11: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
[m3video] Huanyiiiiiiiiiiiiiiiiiiii System_ipcIntraDucatiSrOpen
[m3video] 32153: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
[m3vpss ] Huanyiiiiiiiiiiiiiiiiiiii System_ipcIntraDucatiSrOpen
[m3vpss ] 5741: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
[c6xdsp ] 11: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[m3video] 32155: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 5741: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[c6xdsp ] 11: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[m3video] 32156: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 5742: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ] 12: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3video] 32165: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 5743: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[m3video] 32166: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 5743: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3video] 32166: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 5744: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: IPC init DONE !!!
[m3video] 32167: SYSTEM: IPC init DONE !!!
[m3vpss ] 5744: SYSTEM: IPC init DONE !!!
[c6xdsp ] 14: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x10900000 (265 MB)
[c6xdsp ] 14: MEM: ERROR: SharedRegion_setEntry (2, 0x9ffa7bbc) FAILED !!! (status=-1)
[m3video] 32199: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x10900000 (265 MB)
[m3vpss ] 5749: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x10900000 (265 MB)
[m3video] 32201: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c600000 (198 MB)
[m3vpss ] 5749: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c600000 (198 MB)
[ [m3video] 32214: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] === HDVPSS Clocks are enabled ===
[m3video] 32215: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3vpss ] === HDVPSS is fully functional ===
[m3video] 32216: SYSTEM: ListElem Shared Addr = 0xbf273e00
[m3vpss ] === HDVPSS module is not in standby ===
[m3video] 32228: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 32229: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 32230: SYSTEM: ListElem Shared Addr = 0xbf277300
[m3video] 32264: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
[m3vpss ] === I2C1 Clk is active ===
[m3video] 32265: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
[m3vpss ] 5760: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 32266: SYSTEM: ListElem Shared Addr = 0xbf27dd00
[m3vpss ] 5760: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 32280: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
[m3vpss ] 5761: SYSTEM: ListElem Shared Addr = 0xbf27a800
[m3video] 32281: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
[m3vpss ] 5763: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 32282: SYSTEM: ListElem Shared Addr = 0xbf2a6a00
[m3vpss ] 5763: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 32295: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
[m3vpss ] 5763: SYSTEM: ListElem Shared Addr = 0xbf2a3500
[m3video] 32297: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
[m3vpss ] 5777: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
[m3video] 32298: SYSTEM: ListElem Shared Addr = 0xbf2cc200
[m3vpss ] 5777: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
[m3video] 32377: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 5778: SYSTEM: ListElem Shared Addr = 0xbf2f1a00
[m3video] 32379: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 5780: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
[m3video] 32380: SYSTEM: ListElem Shared Addr = 0xbf33ca00
[m3vpss ] 5780: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
[m3video] 32392: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 5780: SYSTEM: ListElem Shared Addr = 0xbf317200
[m3video] 32393: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 5783: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
[m3video] 32394: SYSTEM: ListElem Shared Addr = 0xbf37fd00
[m3vpss ] 5783: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
[m3video] 32404: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 5783: SYSTEM: ListElem Shared Addr = 0xbf35a500
[m3video] 32405: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 5898: UTILS: DMA: HWI Create for INT63 !!!
[m3video] 32405: HDVICP: Doing PRCM for IVAHD[1] ...
[m3vpss ] 5899: SYSTEM : Initializing Links !!!
[m3video] 32406: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3video] 32406: HDVICP: Doing PRCM for IVAHD[2] ...
[m3vpss ] 6015: SYSTEM : Initializing Links ... DONE !!!
[m3video] 32407: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3video] 32409: SYSTEM : Initializing Links !!!
[m3vpss ] 6016: SYSTEM : Set Static L3 pressure for HDVPSS as High
[c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
[m3video] Remote Debug Shared Memory @ 0xbf010820
[m3vpss ] Remote Debug Shared Memory @ 0xbf021040
[m3vpss ] Received character 's'
[m3video] 32614: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 's'
[c6xdsp ] 1020: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c600000 (198 MB)
[c6xdsp ] Huanyiiiiiiiiiiiiiiiiiiii Utils_memInit end
[c6xdsp ] 1008: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[c6xdsp ] 1023: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
[c6xdsp ] 1024: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
[c6xdsp ] 1024: SYSTEM: ListElem Shared Addr = 0xbf39d800
[c6xdsp ] 1024: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
[c6xdsp ] 1024: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
[c6xdsp ] 1024: SYSTEM: ListElem Shared Addr = 0xbf3c3000
[c6xdsp ] 1025: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
[c6xdsp ] 1025: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
[c6xdsp ] 1025: SYSTEM: ListElem Shared Addr = 0xbf3e8800
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 1026: SYSTEM: ListElem Shared Addr = 0xbf40e000
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 1026: SYSTEM: ListElem Shared Addr = 0xbf42bb00
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 1014: SYSTEM : Initializing Links !!!
[c6xdsp ] ----- zpav ----- init
[c6xdsp ] ChNo: 0, InputSrc: 0
==========================END=============================
two days ago, the problem almost exist !
who can help me to resolve this?
thanks very much!
