Other Parts Discussed in Thread: TMS320C6670
Dear Sir,
I am trying to build simple.eth file which is required for TMS320C6670 ethernet boot. I failed in the below step :
Dear Sir,
Hello!
We expect issuing make command will do the job with makefiles, but that requires environment to be set uniformly. When I was in your situation, I've just looked inside makefile to understand what it is doing. Tweaking path variables did not helped me, so I literally executed command one by one. See target simple.obj: in makefile. It uses cl6x compiler to make object file. So being in simple folder I typed something like
c:\ti\ccsv5\tools\compiler\c6000\bin\cl6x -g -c -k -mi200 -ml3 -pm -mv6400 simple.s
You'll see simple.obj there. Next build out module like
c:\ti\ccsv5\tools\compiler\c6000\bin\cl6x -z simple.cmd -o simple.out -m simple.map
and you'll get simple.out.
Next see commands simple.eth target, so you'll have to locate your hes6x and run commands like
c:\ti\ccsv5\tools\compiler\c6000\bin\hex6x simple.rmd
and you will get boot table. Next you call bconvert64x and bootpacket utilities to convert boot table using similar way. Just make sure you're able doing these steps. Next, of course, you might with to have some automation with batch file.
Hi Krupa,
Please try to build this under minGW and setting the path to the make package.
Rahul
I apologize for delay in my reply. Your answer helped me a lot. Thank you.
Krupa
