run load.sh, down!(DVRRDK4.0)
Hi ,
    I migrage my project from 2.0 to 4.0.
    I run init.sh is ok. But when i run load.sh, the log is:
--------------------------------------------------------Begin-----------------------------------------------------------------
root@dm816x:/opt/dvr_rdk/ti816x# ./load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_1024M_256M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
 [m3vpss ] ***** VPSS Firmware build time 16:49:52 Sep 30 2013  EDG gcc 3.0 mode
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 279999968
 [m3vpss ] notify_attach  rtnVal  0
 [m3vpss ] initProxyServer  rtnVal  0
 [m3vpss ]
 [m3vpss ]  *** UTILS: CPU KHz = 559999 Khz ***
 [m3vpss ]
 [m3vpss ]  35: SYSTEM: IPC init in progress !!!
 [m3vpss ]  35: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  42: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
Attached to slave procId 1.
 [m3vpss ]  1037: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  2037: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  3037: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_m3video_1024M_256M.xem3 on slave procId 1.
Started slave procId 1.
 [m3video] ***** VIDEO Firmware build time 16:51:15 Sep 30 2013  EDG gcc 3.0 mode
 [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 50000000
 [m3video]
 [m3video]  *** UTILS: CPU KHz = 100000 Khz ***
 [m3video]
 [m3video]  20358: SYSTEM: IPC init in progress !!!
 [m3video]  20358: SYSTEM: Attaching to [HOST] ...
 [m3video]  20372: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 0.
 [m3video]  21371: SYSTEM: Attaching to [DSP] ...
 [m3video]  22371: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  4037: SYSTEM: Attaching to [DSP] ...
 [m3video]  23371: SYSTEM: Attaching to [DSP] ...
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_1024M_256M.xe674 on slave procId 0.
Started slave procId 0.
 [m3video]  30670: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  5478: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [c6xdsp ] ***** VIDEO Firmware build time 16:46:11 Sep 30 2013  EDG gcc 3.0 mode
 [m3video]  30684: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  5479: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [c6xdsp ] ***** SYSTEM  :DMA: Module install successful, device major num = 251
 Frequency <ORG>DRV: Module install successful
 - 800000000, <NDRV: Module built on Sep 30 2013 16:28:53
EW> - 813176448
 [m3video]  30686: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
 [m3vpss ]  5479: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
 [c6xdsp ]
 [m3video]  30687: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  5479: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [c6xdsp ]  *** UTILS: CPU KHz = 813176 Khz ***
 [m3video]  30688: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  5480: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [c6xdsp ]
 [m3video]  30697: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3vpss ]  5481: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [c6xdsp ]  5: SYSTEM: IPC init in progress !!!
 [m3video]  30698: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [m3vpss ]  5481: SYSTEM: Notify register to [DSP] line 0, event 15 ...
 [c6xdsp ]  5: SYSTEM: Attaching to [HOST] ...
 [m3video]  30699: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3vpss ]  5482: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [c6xdsp ]  9: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  30700: SYSTEM: IPC init DONE !!!
 [m3vpss ]  5482: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  10: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  30732: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
 [m3vpss ]  5487: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
 [c6xdsp ]  11: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3video]  30734: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c800000 (200 MB)
 [m3vpss ]  5487: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c800000 (200 MB)
 [c6xdsp ]  11: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
 [m3video]  30747: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [m3vpss ] === HDVPSS Clocks are enabled ===
 [c6xdsp ]  11: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [m3video]  30748: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [m3vpss ] === HDVPSS is fully functional ===
 [c6xdsp ]  12: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [m3video]  30749: SYSTEM: ListElem Shared Addr = 0xbf31fc00
 [m3vpss ] === HDVPSS module is not in standby ===
 [c6xdsp ]  12: SYSTEM: Notify register to [HOST] line 0, event 15 ...
 [m3video]  30762: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [m3vpss ] === I2C1 Clk is active ===
 [c6xdsp ]  12: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
 [m3video]  30764: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [m3vpss ]  5498: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [c6xdsp ]  12: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
 [m3video]  30765: SYSTEM: ListElem Shared Addr = 0xbf323100
 [m3vpss ]  5498: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [c6xdsp ]  12: SYSTEM: IPC init DONE !!!
 [m3video]  30799: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
 [m3vpss ]  5499: SYSTEM: ListElem Shared Addr = 0xbf326600
 [c6xdsp ]  14: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x109c0000 (265 MB)
 [m3video]  30800: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
 [m3vpss ]  5501: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [c6xdsp ]  14: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c800000 (200 MB)
 [m3video]  30801: SYSTEM: ListElem Shared Addr = 0xbf329b00
 [m3vpss ]  5501: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [c6xdsp ]  9: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
 [m3video]  30815: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
 [m3vpss ]  5501: SYSTEM: ListElem Shared Addr = 0xbf34f300
 [c6xdsp ]  17: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
 [m3video]  30817: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
 [m3vpss ]  5515: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
 [c6xdsp ]  17: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
 [m3video]  30818: SYSTEM: ListElem Shared Addr = 0xbf352800
 [m3vpss ]  5516: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
 [c6xdsp ]  17: SYSTEM: ListElem Shared Addr = 0xbf273e00
 [m3video]  30832: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
 [m3vpss ]  5516: SYSTEM: ListElem Shared Addr = 0xbf39d800
 [c6xdsp ]  18: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
 [m3video]  30833: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
 [m3vpss ]  5518: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
 [c6xdsp ]  18: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
 [m3video]  30834: SYSTEM: ListElem Shared Addr = 0xbf378000
 [m3vpss ]  5518: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
 [c6xdsp ]  18: SYSTEM: ListElem Shared Addr = 0xbf299600
 [m3video]  30914: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  5519: SYSTEM: ListElem Shared Addr = 0xbf3c3000
 [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
 [m3video]  30916: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  5521: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
 [c6xdsp ]  19: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
 [m3video]  30917: SYSTEM: ListElem Shared Addr = 0xbf3e8800
 [m3vpss ]  5521: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
 [c6xdsp ]  19: SYSTEM: ListElem Shared Addr = 0xbf2bee00
 [m3video]  30930: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
 [m3vpss ]  5521: SYSTEM: ListElem Shared Addr = 0xbf406300
 [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [m3video]  30931: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  5637: UTILS: DMA: HWI Create for INT63 !!!
 [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [m3video]  30932: SYSTEM: ListElem Shared Addr = 0xbf42bb00
 [m3vpss ]  5638: SYSTEM  : Initializing Links !!!
 [c6xdsp ]  20: SYSTEM: ListElem Shared Addr = 0xbf2e4600
 [m3video]  30941: HDVICP: Doing PRCM for IVAHD[0] ...
 [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [m3video]  30942: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3vpss ]  5754: SYSTEM  : Initializing Links ... DONE !!!
 [c6xdsp ]  20: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [m3video]  30942: HDVICP: Doing PRCM for IVAHD[1] ...
 [c6xdsp ]  21: SYSTEM: ListElem Shared Addr = 0xbf302100
 [m3video]  30943: HDVICP: PRCM for IVAHD[1] ... DONE.
 [m3vpss ]  5754: SYSTEM  : Set Static L3 pressure for HDVPSS as High
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  15: SYSTEM  : Initializing Links !!!
 [m3video]  30944: HDVICP: Doing PRCM for IVAHD[2] ...
 [m3video]  30944: HDVICP: PRCM for IVAHD[2] ... DONE.
 [c6xdsp ]  ----- zpav ----- init
 [m3video]  30947: SYSTEM  : Initializing Links !!!
 [c6xdsp ]  ChNo: 0, InputSrc: 0
 [c6xdsp ]  ChNo: 1, InputSrc: 1
 [m3video]  31152: SYSTEM  : Initializing Links ... DONE !!!
 [c6xdsp ]  ChNo: 2, InputSrc: 2
 [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
 [m3video] Remote Debug Shared Memory @ 0xbf010820
 [m3vpss ] Remote Debug Shared Memory @ 0xbf021040
 [m3vpss ] Received character 's'
 [m3video] Received character 's'
-------------------------------------------------------------------End--------------------------------------------------------------------------
   It is stop! The problem is exist some days. I can't resolved it.
   Who can help me to it ?
   Thanks very mush!
