Boot fail on pandaboard rev a6
Other Parts Discussed in Thread: TWL6030
I am trying to run android JB on pandaboard rev a6 with kernel 3.4.0. The code that i have works perfectly good with pandaboard revision a4.
On panda A6 the kernel boots, but in the middle of the booting process everything goes off. The status LEDS goes off and the serial console freezes. I thinks that it is crashed but i cant see any crash log on console. I am attaching the log i am getting during the process.
It will be great help if someone will be able to give some insight about what is wrong in it.
Sunil.
LOG:
U-Boot SPL 2013.01.-rc1-00002-g7261fdb (Oct 04 2013 - 14:45:59)
OMAP4430 ES2.3
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.01.-rc1-00002-g7261fdb (Oct 04 2013 - 14:45:59)
CPU : OMAP4430 ES2.3
Board: OMAP4 Panda
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
checking for preEnv.txt
reading preEnv.txt
** Unable to read file preEnv.txt **
Hit any key to stop autoboot: 0
mmc0 is current device
reading uEnv.txt
** Unable to read file uEnv.txt **
reading boot.scr
498 bytes read
Loaded script from boot.scr
Running bootscript from mmc0 ...
## Executing script at 82000000
reading uImage
3682368 bytes read
reading uInitrd
241397 bytes read
reading board.dtb
2018 bytes read
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-3.4.0-00021-gdc989e1-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3682304 Bytes = 3.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 81600000 ...
Image Name: Android Ramdisk Image
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 241333 Bytes = 235.7 KiB
Load Address: 00000000
Entry Point: 00000000
## Flattened Device Tree blob at 815f0000
Booting using the fdt blob at 0x815f0000
Loading Kernel Image ... OK
OK
reserving fdt memory region: addr=9d000000 size=3000000
Using Device Tree in place at 815f0000, end 815f37e1
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.0-00021-gdc989e1-dirty (sunil@sunilshahu) (gcc version 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02) )3
[ 0.000000] CPU: ARMv7 Processor [411fc093] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 Panda board, model: TI OMAP4 PandaBoard
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: CMA: reserved 8 MiB at a8800000
[ 0.000000] cma: CMA: reserved 104 MiB at a9000000
[ 0.000000] cma: CMA: reserved 32 MiB at a6800000
[ 0.000000] cma: CMA: reserved 16 MiB at a5000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] omap2_set_globals_tap
[ 0.000000] OMAP4: Map 0xa6600000 to 0xfe600000 for dram barrier
[ 0.000000] OMAP4430 ES2.3
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c1109000 s10944 r8192 d13632 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 245248
[ 0.000000] Kernel command line: console=ttyO2,115200n8 rootwait ro earlyprintk fixrtc nocompcache vram=48M omapfb.vram=0:24M,1:24M mem=456
[ 0.000000]
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 456MB 102MB 408MB = 966MB total
[ 0.000000] Memory: 806916k/806916k available, 184316k reserved, 270336K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc06d2000 (6952 kB)
[ 0.000000] .init : 0xc06d2000 - 0xc072fac0 ( 375 kB)
[ 0.000000] .data : 0xc0730000 - 0xc07ad2d0 ( 501 kB)
[ 0.000000] .bss : 0xc07ad2f4 - 0xc08ff59c (1353 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:538
[ 0.000000] omap_sr_disable: omap_sr struct for sr_wakeup not found
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.004943] Calibrating delay loop... 1590.23 BogoMIPS (lpj=6213632)
[ 0.036132] pid_max: default: 32768 minimum: 301
[ 0.041320] Mount-cache hash table entries: 512
[ 0.047454] CPU: Testing write buffer coherency: ok
[ 0.052673] ftrace: allocating 20891 entries in 62 pages
[ 0.103790] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.109985] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 0.118530] Setting up static identity map for 0x80512f98 - 0x80512ff0
[ 0.125366] L310 cache controller enabled
[ 0.129608] l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x7e470000, Cache size: 1048576 B
[ 0.138183] omap_sar_ram_init
[ 0.141448] generating sar_ram layout...
[ 0.145751] sar ram layout created
[ 0.227661] CPU1: Booted secondary processor
[ 0.297485] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.297515] CPU1: Unknown IPI message 0x1
[ 0.297515] Brought up 2 CPUs
[ 0.297546] SMP: Total of 2 processors activated (3188.82 BogoMIPS).
[ 0.298217] devtmpfs: initialized
[ 0.303161] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303192] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303222] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303253] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303283] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303314] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.303314] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303344] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303375] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.303405] omap_sr_disable: omap_sr struct for sr_core not found
[ 0.303436] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.320220] omap_hwmod: ipu: failed to hardreset
[ 0.320281] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.320312] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.320434] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.320465] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.320495] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.323150] omap_hwmod: mcpdm: _wait_target_ready error: -16
[ 0.323181] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.323181] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.323455] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.323486] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.323516] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.324707] omap_sr_disable: omap_sr struct for sr_iva not found
[ 0.325866] dummy:
[ 0.338317] NET: Registered protocol family 16
[ 0.503631] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.511169] GPMC revision 6.0
[ 0.517272] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.523742] OMAP GPIO hardware version 0.1
[ 0.528167] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.534851] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.541503] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.548278] gpiochip_add: registered GPIOs 128 to 159 on device: gpio
[ 0.555114] gpiochip_add: registered GPIOs 160 to 191 on device: gpio
[ 0.563903] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.570831] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.577911] Adding es5125 as I2C Device on bus 4
[ 0.584045] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.591308] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.602813] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.611145] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.620758] Updated GPU clock source to be dpll_per_m7x2_ck
[ 0.629241] omap-mcbsp.1: alias pad_fck already exists
[ 0.634948] omap-mcbsp.2: alias pad_fck already exists
[ 0.640655] omap-mcbsp.3: alias pad_fck already exists
[ 0.646392] omap-mcbsp.4: alias pad_fck already exists
[ 0.653076] OMAP DMA hardware revision 0.0
[ 0.657684] emif emif.1: Device configured with addr = fd100000 and IRQ142
[ 0.664978] emif emif.2: Device configured with addr = fd200000 and IRQ143
[ 0.692901] bio: create slab <bio-0> at 0
[ 0.698211] vwl1271: 1800 mV
[ 0.702850] SCSI subsystem initialized
[ 0.707550] usbcore: registered new interface driver usbfs
[ 0.713562] usbcore: registered new interface driver hub
[ 0.719299] usbcore: registered new device driver usb
[ 0.725769] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 400 kHz
[ 0.732299] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 0.741394] twl 1-0048: PIH (irq 39) chaining IRQs 416..436
[ 0.747863] VUSB: 3300 mV normal standby
[ 0.754852] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[ 0.762359] V1V8: 1800 mV normal standby
[ 0.766876] V2V1: 2100 mV normal standby
[ 0.771545] VMMC: 1200 <--> 3000 mV at 3000 mV normal standby
[ 0.778228] VPP: 1800 <--> 2500 mV at 1900 mV normal standby
[ 0.784912] VCXIO: 1800 mV normal standby
[ 0.789123] VCXIO: supplied by V2V1
[ 0.793762] VDAC: 1800 mV normal standby
[ 0.797912] VDAC: supplied by V2V1
[ 0.802337] VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
[ 0.809570] VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
[ 0.816864] CLK32KG:
[ 0.819641] VANA: 2100 mV normal standby
[ 0.824127] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 400 kHz
[ 0.830139] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[ 0.836303] omap_i2c omap_i2c.4: bus 4 rev2.4.0 at 400 kHz
[ 0.843170] omap-iommu omap-iommu.0: dsp registered
[ 0.848358] omap-iommu omap-iommu.1: ipu registered
[ 0.853729] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.861785] Switching to clocksource 32k_counter
[ 0.897583] NET: Registered protocol family 2
[ 0.902374] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.910430] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.920043] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 0.928009] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.934906] TCP: reno registered
[ 0.938323] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.944519] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.951416] NET: Registered protocol family 1
[ 0.956329] RPC: Registered named UNIX socket transport module.
[ 0.962493] RPC: Registered udp transport module.
[ 0.967407] RPC: Registered tcp transport module.
[ 0.972351] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.979187] usbhs_omap usbhs_omap: ehci_logic_fck failed:-2
[ 0.986114] Trying to unpack rootfs image as initramfs...
[ 1.006713] Freeing initrd memory: 232K
[ 1.023010] Registering 23 OPPs
[ 1.027923] omap_sr_disable: omap_sr struct for sr_iva not found
[ 1.034271] omap_sr_disable: omap_sr struct for sr_iva not found
[ 1.040618] omap_sr_disable: omap_sr struct for sr_iva not found
[ 1.046936] omap_sr_disable: omap_sr struct for sr_iva not found
[ 1.056243] highmem bounce pool size: 64 pages
[ 1.071350] VFS: Disk quotas dquot_6.5.2
[ 1.075866] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.086273] NFS: Registering the id_resolver key type
[ 1.092285] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.099304] fuse init (API version 7.18)
[ 1.104003] msgmni has been set to 1368
[ 1.109069] io scheduler noop registered
[ 1.113189] io scheduler deadline registered
[ 1.117950] io scheduler cfq registered (default)
[ 1.123809] OMAP DSS rev 4.0
[ 1.150756] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.158935] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.166778] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 1.174591] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 1.182128] console [ttyO2] enabled, bootconsole disabled
[ 1.193817] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 1.202056] [drm] Initialized drm 1.1.0 20060810
[ 1.216949] brd: module loaded
[ 1.225402] loop: module loaded
[ 1.228851] (stk) :sysfs entries created
[ 1.233032] (stk) : debugfs entries created
[ 1.241577] usbcore: registered new interface driver asix
[ 1.247650] usbcore: registered new interface driver cdc_ether
[ 1.253997] usbcore: registered new interface driver smsc95xx
[ 1.260223] usbcore: registered new interface driver net1080
[ 1.266357] usbcore: registered new interface driver cdc_subset
[ 1.272766] usbcore: registered new interface driver zaurus
[ 1.278808] usbcore: registered new interface driver cdc_ncm
[ 1.285400] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.292419] ehci-omap.0 supply hsusb0 not found, using dummy regulator
[ 1.299438] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 1.305450] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 1.314514] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 1.335418] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 1.341583] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.348785] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.356414] usb usb1: Product: OMAP-EHCI Host Controller
[ 1.362060] usb usb1: Manufacturer: Linux 3.4.0-00021-gdc989e1-dirty ehci_hcd
[ 1.369598] usb usb1: SerialNumber: ehci-omap.0
[ 1.375122] hub 1-0:1.0: USB hub found
[ 1.379089] hub 1-0:1.0: 3 ports detected
[ 1.413879] Initializing USB Mass Storage driver...
[ 1.419250] usbcore: registered new interface driver usb-storage
[ 1.425598] USB Mass Storage support registered.
[ 1.430511] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.638000] musb-hdrc musb-hdrc: USB OTG mode controller at fc0ab000 using DMA, IRQ 124
[ 1.718231] usb 1-1: new high-speed USB device number 2 using ehci-omap
[ 1.849761] gadget: Mass Storage Function, version: 2009/09/11
[ 1.856048] gadget: Number of LUNs=1
[ 1.859924] lun0: LUN: removable file: (no medium)
[ 1.865478] gadget: android_usb ready
[ 1.874908] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.881988] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.890258] hub 1-1:1.0: USB hub found
[ 1.894378] hub 1-1:1.0: 5 ports detected
[ 2.070159] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 2.075592] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
[ 2.083312] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.090484] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.098144] usb usb2: Product: MUSB HDRC host driver
[ 2.103424] usb usb2: Manufacturer: Linux 3.4.0-00021-gdc989e1-dirty musb-hcd
[ 2.110992] usb usb2: SerialNumber: musb-hdrc
[ 2.116180] hub 2-0:1.0: USB hub found
[ 2.120147] hub 2-0:1.0: 1 port detected
[ 2.156982] twl_rtc twl_rtc: Power up reset detected.
[ 2.163116] twl_rtc twl_rtc: Enabling TWL-RTC
[ 2.170715] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 2.177459] i2c /dev entries driver
[ 2.184600] omap_hsmmc.0 supply vmmc_aux not found, using dummy regulator
[ 2.195037] usb 1-1.1: new high-speed USB device number 3 using ehci-omap
[ 2.298004] omap_hsmmc.4 supply vmmc_aux not found, using dummy regulator
[ 2.320159] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.327423] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.337921] smsc95xx v1.0.4
[ 2.416687] usbcore: registered new interface driver usbhid
[ 2.422668] usbhid: USB HID core driver
[ 2.427886] ashmem: initialized
[ 2.431579] logger: created 256K log 'log_main'
[ 2.436706] logger: created 256K log 'log_events'
[ 2.442321] logger: created 256K log 'log_radio'
[ 2.447845] logger: created 256K log 'log_system'
[ 2.453399] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-ehci-omap.0-1.1, smsc95xx USB 2.0 Ethernet, 2a:40:b4:32:3d:0a
[ 2.465728] thermal_governor_dev_register:Adding omap_ondie_governor governor
[ 2.473480] thermal_get_slope:Getting slope is not supported for domain cpu
[ 2.482025] thermal_get_offset:Getting offset is not supported for domain cpu
[ 2.491607] thermal_governor_dev_register:Adding omap_ongpu_governor governor
[ 2.499176] thermal_get_slope:Getting slope is not supported for domain gpu
[ 2.506591] thermal_get_offset:Getting offset is not supported for domain gpu
[ 2.514221] RMH: STM: 956: stm_arm_init
[ 2.518402] RMH: STM device init
[ 2.521850] RMH: STM: 808: stm_device_setup
[ 2.526306] RMH: STM: 815: stm_probe: base_addr=0x5415a000 regs=0xfe95a000
[ 2.534637] RMH: STM: 823: stm_device_setup: probing device
[ 2.542541] RMH: STM: 826: DEVTYPE = 0x0
[ 2.546722] RMH: STM: 836: PID=0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0
[ 2.552886] RMH: STM: 843: CID=0x0 0x0 0x0 0x0
[ 2.557617] RMH: STM device init'd
[ 2.561218] stm_fw: vendor driver stm_arm registered
[ 2.569610] omap_pcm_dummy() init
[ 2.573608] SDP4430 SoC init
[ 2.576873] soc-audio soc-audio: ASoC machine Panda should use snd_soc_register_card()
[ 2.586029] Panda board snd_card dev:e6229208
[ 2.590728] OMAP4/5 SoC init
[ 2.593811] omap_pcm_dummy() init
[ 2.597320] omap_mcpdm_dummy() init
[ 2.601867] aess aess: ABE Firmware version 9560
[ 2.609191] omap_sr_disable: omap_sr struct for sr_iva not found
[ 2.619110] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.629608] mmc0: new high speed SDHC card at address b368
[ 2.636077] mmcblk0: mmc0:b368 14.9 GiB
[ 2.644256] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 2.650970] omap_sr_disable: omap_sr struct for sr_iva not found
[ 2.661224] asoc: snd-soc-dummy-dai <-> MultiMedia1 mapping ok
[ 2.668762] asoc: snd-soc-dummy-dai <-> MultiMedia2 mapping ok
[ 2.677368] asoc: snd-soc-dummy-dai <-> Voice mapping ok
[ 2.684539] asoc: snd-soc-dummy-dai <-> Tones mapping ok
[ 2.691558] asoc: snd-soc-dummy-dai <-> Vibra mapping ok
[ 2.697509] asoc: snd-soc-dummy-dai <-> MODEM mapping ok
[ 2.703552] asoc: snd-soc-dummy-dai <-> MultiMedia1 LP mapping ok
[ 2.710174] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 2.718780] asoc: twl6040-legacy <-> mcpdm-legacy mapping ok
[ 2.725341] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 2.731018] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 2.736541] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 2.742156] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 2.747772] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
[ 2.754302] asoc: snd-soc-dummy-dai <-> omap-mcbsp.1 mapping ok
[ 2.760742] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 2.767211] asoc: snd-soc-dummy-dai <-> omap-mcbsp.2 mapping ok
[ 2.774566] input: PandaBoard Headset Jack as /devices/platform/omap-abe-twl6040/sound/card1/input0
[ 2.789550] asoc: omap-hdmi-hifi <-> omap-hdmi-audio-dai mapping ok
[ 2.797851] oprofile: using arm/armv7-ca9
[ 2.802429] TCP: cubic registered
[ 2.806945] NET: Registered protocol family 10
[ 2.812499] IPv6 over IPv4 tunneling driver
[ 2.817810] NET: Registered protocol family 17
[ 2.822540] NET: Registered protocol family 15
[ 2.827819] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 2.835968] ThumbEE CPU extension supported.
[ 2.840484] Registering SWP/SWPB emulation handler
[ 2.849212] omap_sr_disable: omap_sr struct for sr_mpu not found
[ 2.855590] omap_sr_disable: omap_sr struct for sr_core not found
[ 2.862213] Power Management for TI OMAP4XX/OMAP5XXX devices.
[ 2.868377] hwmod gpmc not found
[ 2.871887] sr_init: No PMIC hook to init smartreflex
[ 2.877441] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 2.885742] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 2.894195] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 2.902587] SmartReflex Class3 initialized
[ 2.906951] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 2.911163] clock: disabling unused clocks to save power
[ 2.922637] registered taskstats version 1
[ 2.927398] VANA: incomplete constraints, leaving on
[ 2.933776] VDAC: incomplete constraints, leaving on
[ 2.939788] VUSB: incomplete constraints, leaving on
[ 2.946075] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 2.960174] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.967834] dmm dmm: initialized all PAT entries
[ 2.973602] mmc1: new SDIO card at address 0001
[ 3.032379] No connectors reported connected with modes
[ 3.037902] [drm] Cannot find any crtc or sizes - going 1024x768
[ 3.081878] Console: switching to colour frame buffer device 128x48
[ 3.097778] fb0: omapdrm frame buffer device
[ 3.102325] drm: registered panic notifier
[ 3.106658] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 3.113647] [drm] No driver support for vblank timestamp query.
[ 3.119903] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 3.126434] ALSA device list:
[ 3.129577] #0: TI OMAP4 Board
[ 3.132995] #1: PandaBoard
[ 3.136016] #2: OMAPHDMI
[ 3.139373] Freeing init memory: 372K
[ 3.146820] init: could not import file '/init.partitions.rc' from '/init.rc'
[ 3.154479] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.275573] init: cannot open '/initlogo.rle'
[ 3.306030] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.695922] EXT4-fs (mmcblk0p3): recovery complete
[ 4.079711] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[ 4.097686] EXT4-fs (mmcblk0p5): recovery complete
[ 4.482788] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
[ 4.705383] Bluetooth: Core ver 2.16
[ 4.709320] NET: Registered protocol family 31
[ 4.714019] Bluetooth: HCI device and connection manager initialized
[ 4.720764] Bluetooth: HCI socket layer initialized
[ 4.725891] Bluetooth: L2CAP socket layer initialized
[ 4.731262] Bluetooth: SCO socket layer initialized
[ 4.768218] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.817687] Bluetooth: RFCOMM TTY layer initialized
[ 4.822875] Bluetooth: RFCOMM socket layer initialized
[ 4.828308] Bluetooth: RFCOMM ver 1.11
[ 4.844055] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 4.852050] (stc): st_register(4)
[ 4.855438] (stc): chnl_id list empty :4
[ 4.860229] (stk) : st_kim_start
[ 4.867614] lib80211: common routines for IEEE802.11 drivers
[ 4.988159] (stk) :ldisc_install = 1
[ 5.071319] cfg80211: Calling CRDA to update world regulatory domain
[ 5.837188] android_usb: already disabled
[ 5.918426] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[ 5.927001] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 5.936614] init: cannot find '/system/bin/pvrsrvinit', disabling 'pvrsrvinit'
[ 5.944702] init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
[ 5.955627] init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
[ 5.965820] init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
