Is there a bug in swms in RDK4.0?
Hi all,
    Please look at the log below and give me some advices how to fix it . Why the first SwMsLink_drvPrintLayoutParams shows right but the second SwMsLink_drvPrintLayoutParams shows that the win 3 was wrong?
    Thanks!
    best regards!
The first log:
 [m3vpss ]  175747: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  175747: SWMS0    : Loading Vertical Co-effs (3/16)x ...
 [m3vpss ]  175747: SWMS0    : Loading Horizontal Co-effs (3/16)x ...
 [m3vpss ]  175748: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
 [m3vpss ]
 [m3vpss ]  Output FPS: 60
 [m3vpss ]
 [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
 [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
 [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    1 |   1 |    0,    0 |  1280 x    720 |  1408 /  1408 | NON-TILED   |  100,  100 |  1280 x    720 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |  200,  200 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    3 |   3 |    0,    0 |   720 x    480 |   896 /   896 | NON-TILED   |  300,  300 |   720 x    480 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]
 [m3vpss ] 175750:SWMS:SwMs window overlap.WinId1[0]:startX[0]:startY[0]:endX[480]:endY[270]::WinId2[1]:startX[100]:startY[100]:endX[1380]:endY[820]
 [m3vpss ]  175752: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  175752: SWMS0    : Loading Vertical Co-effs (3/16)x ...
 [m3vpss ]  175752: SWMS0    : Loading Horizontal Co-effs (3/16)x ...
 [m3vpss ]  175753: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    1 |   3 |    0,    0 |   720 x    480 |   896 /   896 | NON-TILED   |  100,  100 |  1280 x    720 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    3 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  300,  300 |   720 x    480 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
 [m3vpss ]
 [m3vpss ] 175755:SWMS:SwMs window overlap.WinId1[0]:startX[0]:startY[0]:endX[480]:endY[270]::WinId2[1]:startX[100]:startY[100]:endX[1380]:endY[820]
 [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS faileddue to invalid cfg
 [m3vpss ] Config:DisplayID[0],ChID[3]
The second log:
 [m3vpss ]  54282: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  54282: SWMS0    : Loading Vertical Co-effs (3/16)x ...
 [m3vpss ]  54282: SWMS0    : Loading Horizontal Co-effs (3/16)x ...
 [m3vpss ]  54282: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  54283: SWMS0    : Loading Vertical Co-effs (3/16)x ...
 [m3vpss ]  54283: SWMS0    : Loading Horizontal Co-effs (3/16)x ...
 [m3vpss ]  54283: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    1 |   3 |    0,    0 |   720 x    480 |   896 /   896 | NON-TILED   |  100,  100 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]
 [m3vpss ] 54284:SWMS:SwMs window overlap.WinId1[0]:startX[0]:startY[0]:endX[480]:endY[270]::WinId2[1]:startX[100]:startY[100]:endX[580]:endY[370]
 [m3vpss ]  54285: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  54285: SWMS0    : Loading Vertical Co-effs (8/16)x ...
 [m3vpss ]  54285: SWMS0    : Loading Horizontal Co-effs (10/16)x ...
 [m3vpss ]  54285: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    0 |   3 |    0,    0 |   720 x    480 |   896 /   896 | NON-TILED   |    0,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    1 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  100,  100 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    1 |  422I  |   OFF |
 [m3vpss ]
 [m3vpss ] 54287:SWMS:SwMs window overlap.WinId1[0]:startX[0]:startY[0]:endX[480]:endY[270]::WinId2[1]:startX[100]:startY[100]:endX[580]:endY[370]
 [m3vpss ]  SWMS: *** UPDATING RT Params ***
 [m3vpss ]  54357: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  54357: SWMS0    : Loading Vertical Co-effs (3/16)x ...
 [m3vpss ]  54357: SWMS0    : Loading Horizontal Co-effs (3/16)x ...
 [m3vpss ]  54358: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]  54358: SWMS0    : Loading Vertical Co-effs (3/16)x ...
 [m3vpss ]  54358: SWMS0    : Loading Horizontal Co-effs (3/16)x ...
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    0 |   3 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    1 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  100,  100 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    1 |  422I  |    ON |
 [m3vpss ]
 [m3vpss ] SWMS:Restoring blank frame params for winId:1
