WatchDog init code problem on C6748
I use the watchdog on C6748, but it reboot all the time after initating it.
My initate code as bellow, what's the matter?
void WatchDogInit(void)
    uint64_t Period;
    TMR1->TGCR = 0;
    TMR1->TGCR = 0x0B;
    TMR1->PRD12 = (uint32_t)(0xFFFFFFFF);//Period, set as very long time
    TMR1->PRD34 = (uint32_t)(0xFFFFFFFF);
    TMR1->WDTCR = (1 << 14) | (0x0000A5C6 << 16);//enable and feed the wathcdog
    TMR1->WDTCR = (1 << 14) | (0x0000DA7E << 16);
  • Jack,
    You can find the WATCHDOG TIMER (WDT) driver and test code from the StarterWare package, which is released by TI. Please refer the WDT driver APIs at watchdog.c (C6748_StarterWare_1_20_03_03\drivers) and test code at wdtReset.c (C6748_StarterWare_1_20_03_03\examples\lcdkC6748\wdt)
     * \file  wdtReset.c
     * \brief Sample application for WDT
    * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
    *  Redistribution and use in source and binary forms, with or without
    *  modification, are permitted provided that the following conditions
    *  are met:
    *    Redistributions of source code must retain the above copyright
    *    Redistributions in binary form must reproduce the above copyright
    *    documentation and/or other materials provided with the
    *    distribution.
    *    Neither the name of Texas Instruments Incorporated nor the names of
    *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "uart.h"
    #include "hw_uart.h"
    #include "interrupt.h"
    #include "soc_C6748.h"
    #include "timer.h"
    #include "lcdkC6748.h"
    #include "uartStdio.h"
    **                      INTERNAL MACRO DEFINITIONS
    #define TMR_PERIOD_LSB32               (0x06FFFFFF)
    #define TMR_PERIOD_MSB32               (0x0)
    **                      INTERNAL FUNCTION PROTOTYPES
    static void TimerSetUpWatchDog(void);
    **                      INTERNAL VARIABLE DEFINITIONS
    **                          FUNCTION DEFINITIONS
    int main(void)
        /* Set up the UART2 peripheral */
        UARTStdioInit();
        /* Set up the Timer2 peripheral */
        TimerSetUpWatchDog();
        /* Send the message to UART console */
        UARTPuts("\nProgram Reset!", -1);
        UARTPuts("\nInput any key at least once in every 4 seconds to avoid a further reset.\n\r", -1);
        /* Activate the Watch Dog Timer */
        TimerWatchdogActivate(SOC_TMR_1_REGS);
        /* Reset the WDT upon any character input */
        while(1)
            ** Wait for an input through UART. If no input is given, the WDT
            ** will timeout and reset will occur
            UARTGetc();
            ** Reactivate the WDT upon character input. The WDT will restart
            ** at this point.
            TimerWatchdogReactivate(SOC_TMR_1_REGS);
    ** Setup the timer for 64 bit WDT mode
        /* Configuration of Timer */
        TimerConfigure(SOC_TMR_1_REGS, TMR_CFG_64BIT_WATCHDOG);
        /* Set the 64 bit timer period */
        TimerPeriodSet(SOC_TMR_1_REGS, TMR_TIMER12, TMR_PERIOD_LSB32);
        TimerPeriodSet(SOC_TMR_1_REGS, TMR_TIMER34, TMR_PERIOD_MSB32);
    /***************************** End Of File ***********************************/
     *  \file   watchdog.c
     *  \brief  WATCHDOG TIMER APIs.
     *   This file contains the device abstraction layer APIs for Watchdog Timer.
    * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
    *  are met:
    *    distribution.
    #include "hw_types.h"
    #include "watchdog.h"
    #define WDT_DISABLE_SEQ1           (0x0000AAAAu)
    #define WDT_DISABLE_SEQ2           (0x00005555u)
    #define WDT_ENABLE_SEQ1            (0x0000BBBBu)
    #define WDT_ENABLE_SEQ2            (0x00004444u)
    *                        API FUNCTION DEFINITIONS
     * \brief   Starts/Enables the watchdog timer.
     * \param   baseAdd       Base Address of the Watchdog Timer Module Registers.
     * \return  None.
    void WatchdogTimerEnable(unsigned int baseAdd)
        /* Write the first value of the watchdog timer enabling sequence */
        HWREG(baseAdd + WDT_WSPR) = WDT_ENABLE_SEQ1;
        /* Wait until write is successful to WDT_WSPR register */
        while(WatchdogTimerWritePostedStatusGet(baseAdd,
                                                WDT_WRITE_PENDING_WSPR));
        /* Write the second value of the watchdog timer enabling sequence */
        HWREG(baseAdd + WDT_WSPR) = WDT_ENABLE_SEQ2;
     * \brief   Stops/Disables the watchdog timer.
     * \return  None.
    void WatchdogTimerDisable(unsigned int baseAdd)
        /* Write the first value of the watchdog timer disabling sequence */
        HWREG(baseAdd + WDT_WSPR) = WDT_DISABLE_SEQ1;
        /* Write the second value of the watchdog timer disabling sequence */
        HWREG(baseAdd + WDT_WSPR) = WDT_DISABLE_SEQ2;
     * \brief   Return the revision id of the SOC used.
     * \return  Returns the revision id  of the SOC used.
    unsigned int WatchdogTimerRevisionIDGet(unsigned int baseAdd)
        /* Return the revision id to the called function */
        return(HWREG(baseAdd + WDT_WIDR));
     * \brief   Reset the watchdog timer module.
     * \return  None.
    void WatchdogTimerReset(unsigned int baseAdd)
        /* Reset the Watchdog timer module */
        HWREG(baseAdd + WDT_WDSC) |= WDT_WDSC_SOFTRESET;
        /* Wait until the reset is done */
        while(!(HWREG(baseAdd + WDT_WDST) & WDT_WDST_RESETDONE));
     * \brief   Configure the emulation mode of operation for the watchdog timer.
     * \param   emuMode      Configure Emulation mode.
     * emuMode can take the following values \n
     *     WDT_EMULATION_FROZEN - WDT counter frozen in emulation mode \n
     *     WDT_EMULATION_FREE - WDT counter free running in emulation mode \n
     * \return  None.
    void WatchdogTimerEmulationModeConfigure(unsigned int baseAdd, unsigned int emuMode)
        /* Clear the EMUFREE field of WDT_WDSC register */
        HWREG(baseAdd + WDT_WDSC) &= ~WDT_WDSC_EMUFREE;
        /* Set the EMUFREE field of WDT_WDSC register with the emuMode value */
        HWREG(baseAdd + WDT_WDSC) |= (emuMode & WDT_WDSC_EMUFREE);
     * \brief   This API will configure and enable the pre-scaler clock.
     * \param   baseAdd      Base Address of the Watchdog Timer Module Register.
     * \param   ptv          Pre-scale clock Timer value.
     * 'ptv' can take the following values \n
     *    WDT_PRESCALER_CLK_DIV_1   - WDT Functional clock divide by 1 \n
     *    WDT_PRESCALER_CLK_DIV_2   - WDT Functional clock divide by 2 \n
     *    WDT_PRESCALER_CLK_DIV_4   - WDT Functional clock divide by 4 \n
     *    WDT_PRESCALER_CLK_DIV_8   - WDT Functional clock divide by 8 \n
     *    WDT_PRESCALER_CLK_DIV_16  - WDT Functional clock divide by 16 \n
     *    WDT_PRESCALER_CLK_DIV_32  - WDT Functional clock divide by 32 \n
     *    WDT_PRESCALER_CLK_DIV_64  - WDT Functional clock divide by 64 \n
     *    WDT_PRESCALER_CLK_DIV_128 - WDT Functional clock divide by 128 \n
     * \return  None.
    void WatchdogTimerPreScalerClkEnable(unsigned int baseAdd, unsigned int ptv)
        /* Clear the ptv field of WDT_WCLR register */
        HWREG(baseAdd + WDT_WCLR) &= ~WDT_WCLR_PTV;
        /* Wait until write is successful to WDT_WCLR register */
                                                  WDT_WRITE_PENDING_WCLR));
        ** Set the ptv field of WDT_WCLR register with the ptv value and also
        ** enable the pre-scaler clock
        HWREG(baseAdd + WDT_WCLR) |= ((ptv & WDT_WCLR_PTV) |
                                                  WDT_WCLR_PRE);
     * \brief   This API will disable the pre-scaler clock.
     * \return  None.
    void WatchdogTimerPreScalerClkDisable(unsigned int baseAdd)
        /* Disable Pre-scaler clock */
        HWREG(baseAdd + WDT_WCLR) &= ~WDT_WCLR_PRE;
     * \brief   Set/Write the Counter register with the counter value.
     * \param   counter       Count value for the Watchdog Timer.
     * \return  None.
    void WatchdogTimerCounterSet(unsigned int baseAdd, unsigned int countVal)
        /* Set the WDT_WCRR register with the countVal */
        HWREG(baseAdd + WDT_WCRR) = countVal;
        /* Wait until write is successful to WDT_WCRR register */
                                                WDT_WRITE_PENDING_WCRR));
     * \brief   Get/Read the counter value from the counter register.
     * \return  This API returns the count value present in the Watchdog Timer
     *            Counter register.
    unsigned int WatchdogTimerCounterGet(unsigned int baseAdd)
        /* Read the counter value from WDT_WCRR register */
        return(HWREG(baseAdd + WDT_WCRR));
     * \brief   Set the reload count value in the Watchdog timer load register.
     * \param   reload        The reload count value of the Watchdog timer.
     * \return  None.
     * \note:   It is recommended to not use reload value as 0xFFFFFFFF.
    void WatchdogTimerReloadSet(unsigned int baseAdd, unsigned int reloadVal)
        /* Load the WDT_WLDR register with the re-load value */
        HWREG(baseAdd + WDT_WLDR) = reloadVal;
        /* Wait until write is successful to the WDT_WLDR register */
        while(WatchdogTimerWritePostedStatusGet(baseAdd, WDT_WRITE_PENDING_WLDR));
     * \brief   Get the reload count value from the Watchdog timer load register.
     * \return  This API returns the value present in Watchdog Timer Load Register.
    unsigned int WatchdogTimerReloadGet(unsigned int baseAdd)
        /* Return the contents of WDT_WLDR */
        return(HWREG(baseAdd + WDT_WLDR));
     * \brief   Set/enable the trigger write access.
     * \param   trigVal       Value to be written to the WTGR register.
     * \return  None.
     * \note    This API should be called if the Watchdog timer WDT_WCRR
     *          register has to be loaded with the WDT_WLDR register before
     *          overflow occurs. If this API has to be called more than once in an
     *          application then ensure each time this API is called, pass a
     *          different value to the parameter 'trigVal' to ensure proper working.
    void WatchdogTimerTriggerSet(unsigned int baseAdd, unsigned int trigVal)
        /* Set the WDT_WTGR register with the trigVal*/
        HWREG(baseAdd + WDT_WTGR) = trigVal;
        /* Wait till write is successful to WDT_WTGR register */
                                                      WDT_WRITE_PENDING_WTGR));
     * \brief   Load the delay register of Watchdog timer with the delay value.
     * \param   delayVal      Delay value.
     * \return  None.
    void WatchdogTimerDelaySet(unsigned int baseAdd, unsigned int delayVal)
        /* Set the WDT_WDLY register with the delayVal */
        HWREG(baseAdd + WDT_WDLY) = delayVal;
        /* Wait until write is successful to the WDT_WDLY register */
              WDT_WRITE_PENDING_WDLY));
     * \brief   Return the delay register value of Watchdog timer.
     * \return  This API returns the delay register(WDT_WDLY) value of Watchdog
     *          timer.
    unsigned int WatchdogTimerDelayGet(unsigned int baseAdd)
        /* Return the WDT_WDLY register value */
        return(HWREG(baseAdd + WDT_WDLY));
     * \brief   Set IRQ status by software.
     * \param   intFlags      Variable used to trigger the events.
     * 'intFlags' can take the following values \n
     *    WDT_INT_DELAY - Set the status for delay interrupt \n
     *    WDT_INT_OVERFLOW - Set the status for overflow interrupt \n
     * \return  None.
    void WatchdogTimerIntRawStatusSet(unsigned int baseAdd, unsigned int intFlags)
        /* Set the status in the WDT_WIRQSTATRAW register */
        HWREG(baseAdd + WDT_WIRQSTATRAW) = (intFlags &
                                                (WDT_INT_OVERFLOW |
                                                 WDT_INT_DELAY));
     * \brief   Return the Raw IRQ status.
     * \return  This API returns the status of the WDT_WIRQSTATRAW register.
    unsigned int WatchdogTimerIntRawStatusGet(unsigned int baseAdd)
        /* Return the status of the WDT_WIRQSTATRAW register */
        return(HWREG(baseAdd + WDT_WIRQSTATRAW));
     * \brief   Read the status of WDT_WIRQSTAT register.
     * \param   baseAdd       Base Address of the DMTimer Module Register.
     * \return  This API returns the status of WDT_WIRQSTAT register.
    unsigned int WatchdogTimerIntStatusGet(unsigned int baseAdd)
        /* Return the status of WDT_WIRQSTAT register */
        return(HWREG(baseAdd + WDT_WIRQSTAT));
     * \brief   Clear IRQ status.
     * \param   intFlags      Variable used to clear the events.
     *    WDT_INT_DELAY - Clear the status for delay interrupt \n
     *    WDT_INT_OVERFLOW - Clear the status for overflow interrupt \n
     * \return  None.
    void WatchdogTimerIntStatusClear(unsigned int baseAdd, unsigned int intFlags)
        /* Clear the status in the WDT_WIRQSTAT register */
        HWREG(baseAdd + WDT_WIRQSTAT) = (intFlags &
                                             (WDT_INT_OVERFLOW |
                                              WDT_INT_DELAY));
     * \brief   Enable Watchdog timer interrupts.
     * \param   intFlags      Variable used to enable interrupts.
     *    WDT_INT_ENABLE_DELAY - Enable the delay interrupt \n
     *    WDT_INT_ENABLE_OVRFLW - Enable the overflow interrupt \n
     * \return  None.
    void WatchdogTimerIntEnable(unsigned int baseAdd, unsigned int intFlags)
        /* Enable the watchdog timer interrupts */
        HWREG(baseAdd + WDT_WIRQENSET) = (intFlags &
                                              (WDT_INT_ENABLE_OVRFLW |
                                               WDT_INT_ENABLE_DELAY));
     * \brief   Used to check whether interrupts of Watchdog timer are enabled
     *          or disabled.
     * \return  This API returns the status of WDT_WIRQENSET register.
    unsigned int WatchdogTimerIntEnableStatusGet(unsigned int baseAdd)
        /* Return the status of WDT_WIRQENSET register */
        return(HWREG(baseAdd + WDT_WIRQENSET));
     * \brief   Disable Watchdog timer interrupts.
     *    WDT_INT_DISABLE_DELAY - Disable the delay interrupt \n
     *    WDT_INT_DISABLE_OVRFLW - Disable the overflow interrupt \n
     * \return  None.
    void WatchdogTimerIntDisable(unsigned int baseAdd, unsigned int intFlags)
        /* Disable the Watchdog timer interrupts */
        HWREG(baseAdd + WDT_WIRQENCLR) = (intFlags &
                                              (WDT_INT_DISABLE_DELAY |
                                               WDT_INT_DISABLE_OVRFLW));
     * \brief   Read the status of WDT_WWPS register.
     * \param   flags         Status of the particular field to be returned.
     * 'flags' can take the following values \n
     *    WDT_WRITE_PENDING_WCLR - Write pending for register WDT_WCLR \n
     *    WDT_WRITE_PENDING_WCRR - Write pending for register WDT_WCRR \n
     *    WDT_WRITE_PENDING_WLDR - Write pending for register WDT_WLDR \n
     *    WDT_WRITE_PENDING_WTGR - Write pending for register WDT_WTGR \n
     *    WDT_WRITE_PENDING_WSPR - Write pending for register WDT_WSPR \n
     *    WDT_WRITE_PENDING_WDLY - Write pending for register WDT_WDLY \n
     * \return  Returns the status of Write posted status(WDT_WWPS) register.
    unsigned int WatchdogTimerWritePostedStatusGet(unsigned int baseAdd, unsigned int flags)
        /* Return the status of WDT_WWPS register addressed by flags */
        return(HWREG(baseAdd + WDT_WWPS) & flags);
    /************************* END OF WATCHDOG TIMER DAL **************************/
  • Pubesh,
    Thank you for your reply!
    I get the example, but I found that wdtReset.c didn't use any function in watchdog.c. It use some function in timer.c(D:\ti\C6748_StarterWare_1_20_03_03\drivers\timer.c)
    Then what's the usage of these functions in wdtReset.c?
    Jack
