Setting IO Expander lines
Other Parts Discussed in Thread: TCI6638K2K
We are on BOC for TCI6638K2K EVM, the BOC has an IO Expander using I2C2 routed to the 120 pin connector. I need to set the lines of this IO Expander. Is there any reference code from which i can begin with? Any suggestions example codes would be very helpfull. The IO Expander part number is TCA9555RTW.
I found the evmc66x_i2c_eeprom.c file. Wil it be helpful? I have attached the file.
 * Copyright (c) 2010-2011 Texas Instruments Incorporated - http://www.ti.com
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * File Name:  	evmc66x_i2c_eeprom.c
 * Description:	Provides a polling i2c driver.
 * Include Files
#include "platform_internal.h"
#if (PLATFORM_EEPROM_IN)
 * Defines and Macros
#define DELAY_CONST 			2
#define MACADDRESS_SIZE			12
#define MAC_OFFSET				0xF400
 * Globals
uint32_t gI2cBlock[17];
 * Function:	i2cDelay
 * Description:	Creates a delay.
 * Parameters:	UINT32 uiCount - counter for the loop
 * Return Value: void
static void i2cDelay (uint32_t uiCount)
	uint32_t i;
  	for (i = 0; i < uiCount; i++) platform_delaycycles(50000);
 * Function:	i2cEepromWriteBlock
 * Description:	Enters master transmitter mode, writes a specified number
 *              of bytes.
 * Parameters:	uint8_t uchEepromI2cAddress - i2c address of EEPROM
 * 				uint32_t *puiData - pointer to the buffer base address
 * 				uint32_t uiNumBytes - number of bytes of buffer
 * 				uint32_t uiEndBusState - The state on which bus should be left
 * Return Value: I2C_RET - status
I2C_RET i2cEepromWriteBlock( uint8_t uchEepromI2cAddress, uint32_t *puiData,
							 uint32_t uiNumBytes, uint32_t uiEndBusState)
  	uint32_t uiTimeoutCounter;
  	uint32_t uiPollingStatus;
  	uint32_t uiValue;
  	uint32_t uiStatusReg;
  	uint32_t uiCount;
  	uint32_t uiByteType;
  	/* Check for the bus busy signal */
  	uiTimeoutCounter = 0;
  	do
    	uiPollingStatus = I2C_REG_STR_FIELD_BB(I2CR->ICSTR);
    	if (uiPollingStatus)
      		i2cDelay (I2C_MASTER_TRANSMITTER_BUS_ACCESS_DELAY_US);
      		uiTimeoutCounter += 1;
      		if (uiTimeoutCounter >= I2C_MAX_MASTER_TRANSMITTER_BUS_ACCESS_TIMEOUT)
      			/* Return to slave receiver, clear nack and bus busy */
        		I2CR->ICMDR = I2C_VAL_REG_MDR_SLVRCV;
				I2CR->ICSTR = I2C_VAL_REG_STR_ON_FAIL;
                platform_errno = PLATFORM_ERRNO_DEV_TIMEOUT;
        		return (I2C_RET_IDLE_TIMEOUT);
    	else
    		/* The bus is free */
  	}while (uiTimeoutCounter != 0);
  	/* Enter master transmitter mode, set the slave address register */
  	I2CR->ICMDR = I2C_VAL_REG_MDR_MSTXMT;
  	I2CR->ICSAR = (uint8_t)uchEepromI2cAddress;
  	i2cDelay (DELAY_CONST);
  	/* Put the first byte into the transmit register, set the start bit */
  	uiValue = (*puiData >> 8) & 0x00ff;
  	I2CR->ICDXR =  uiValue;
  	uiByteType = I2C_BYTE_LSB;
  	/* Set the start bit */
  	I2CR->ICMDR = I2C_VAL_REG_MDR_MSTXMTSTRT;
  	for (uiCount = 1; uiCount < uiNumBytes; uiCount++)
    	do
	      	/* Read status */
      		uiStatusReg = I2CR->ICSTR;
      		/* On Nack return failure */
      		if (I2C_REG_STR_FIELD_NACK(uiStatusReg))
                platform_errno = PLATFORM_ERRNO_DEV_NAK;
				return (I2C_RET_NO_ACK);
      		/* Check for transmit ready */
      		if (I2C_REG_STR_FIELD_XRDY(uiStatusReg))
        		if (uiByteType == I2C_BYTE_MSB)
          			uiValue = (*puiData >> 24) & 0x00ff;
          			uiByteType = I2C_BYTE_SMSB;
        		else if (uiByteType == I2C_BYTE_SMSB)
          			uiValue =  (*puiData >> 16) & 0x00ff;
          			uiByteType = I2C_BYTE_SLSB;
        		else if (uiByteType == I2C_BYTE_SLSB)
        		else
          			uiValue = (*puiData) & 0x00ff;
          			uiByteType = I2C_BYTE_MSB;
          			puiData += 1;
        	/*Write data Transmit Data Register */
      		else
      			/* XRDY bit not set */
        		if (uiTimeoutCounter >= I2C_MAX_MASTER_TRANSMITTER_TIMEOUT)
  	} /* end for loop */
  	/* If releasing the bus, send a stop bit */
  	if (uiEndBusState == I2C_RELEASE_BUS)
	    /* Wait for the ardy bit to go high */
	    do
	      	if (I2C_REG_STR_FIELD_ARDY(uiStatusReg))
	        	I2CR->ICMDR = I2C_VAL_REG_MDR_MSTXMTSTOP;
	        	I2CR->ICSTR = I2C_VAL_REG_STR_CLR_BUSY;
	      	else
	      		/* Registers not ready for access */
	        	if (uiTimeoutCounter >= I2C_MAX_MASTER_TRANSMITTER_ARDY_TIMEOUT)
	           		/* On timeout put the peripheral into reset, wait, then
	            	* take it out of reset */
	           		I2CR->ICMDR = I2C_VAL_REG_MDR_RESET;
	} /* end bus release */
  	return (I2C_RET_OK);
} // i2cEepromWriteBlock
 * Function:	i2cEepromRead
 * Description:	Reads a fixed number of bytes from an I2C prom. The read
 *              consists of a master write of 2 bytes (forming a 16 bit address,
 *              msb transmitted first), followed by a master read of the
 *              input number of bytes.The bytes that are read are placed
 *              in puiData in big endian format
I2C_RET i2cEepromRead ( uint32_t byte_addr, uint32_t uiNumBytes,
                        uint8_t *puiData, uint8_t uchEepromI2cAddress)
  	uint32_t  iCount;
  	I2C_RET uiReturnValue;
  	uint16_t  ushValue;
  	/* Write the byte address to the eeprom. Do not send a stop */
  	uiReturnValue = i2cEepromWriteBlock ( uchEepromI2cAddress, &byte_addr,
  										  2, I2C_DO_NOT_RELEASE_BUS);
  	if (uiReturnValue != I2C_RET_OK)
    	return (uiReturnValue);
  	/* Give the I2C prom 10ms to process the read command */
  	/* Set the start bit, begin the master read */
  	I2CR->ICMDR = I2C_VAL_REG_MDR_MSTRCV;
 	for (iCount = 0; iCount < uiNumBytes; iCount++)
    	do
      		/* Read status */
      		/* Check for receive byte ready */
      		if (I2C_REG_STR_FIELD_RRDY(uiStatusReg))
        		ushValue = I2CR->ICDRR & 0x00ff;
        		*puiData = ushValue;
        		puiData++;
      		else
      		{   /* RRDY bit not set */
        		if (uiTimeoutCounter >= I2C_MAX_MASTER_RECEIVE_TIMEOUT)  {
    } while (uiTimeoutCounter != 0);
  	/* The data block has been read. Send the stop bit */
  	I2CR->ICMDR = I2C_VAL_REG_MDR_MSTRCVSTOP;
  	/* Wait for the rrdy and read the dummy byte */
  	do
    	else
    	{  /* rrdy not set */
} // i2cEepromRead
 * Description:	Writes specified number of bytes from the I2C EEPROM
I2C_RET i2cEepromWrite( uint16_t uchEepromI2cAddress, uint32_t *puiData,
  	uint32_t uiBytesWritten, uiBlockCount, uiByteNum, uiCount, uiSizeBytes, uiAddress;
  	I2C_RET iret;
  	uiSizeBytes = uiNumBytes;
  	uiAddress = *puiData;
  	uiByteNum = 1;
  	uiBytesWritten = 0;
  	/* Block the data into 64 byte blocks, perform a write */
  	do{
    	/* Get the number of bytes in the current block */
    	uiBlockCount = uiSizeBytes - uiBytesWritten;
    	if (uiBlockCount > 64)
      		uiBlockCount = 64;
    	if (uiBlockCount == 0)
      		break;
    	for (uiCount = 0; uiCount < (uiBlockCount+3)>>2; uiCount++)
      		gI2cBlock[uiCount+1] = puiData[uiByteNum++];
    	gI2cBlock[0] = uiAddress;
    	iret = i2cEepromWriteBlock(uchEepromI2cAddress, gI2cBlock, uiBlockCount+2, uiEndBusState);
    	if (iret != I2C_RET_OK)
      		return (iret);
		i2cDelay(DELAY_CONST);
    	uiBytesWritten = uiBytesWritten + uiBlockCount;
    	uiAddress = uiAddress + uiBlockCount;
  	}while (uiBlockCount);
 * Function:	i2cEepromWriteByteAddr
 *(Same as above function except it takes byte address as a parameter)
I2C_RET i2cEepromWriteByteAddr( uint32_t byte_addr, uint16_t uchEepromI2cAddress, uint8_t *puiData,
  	I2C_RET iret;
  	uiAddress = byte_addr;
  	uiByteNum = 0;
  	uiBytesWritten = 0;
  	do{
      		uiBlockCount = 64;
      		break;
      		gI2cBlock[uiCount+1] = (puiData[uiByteNum] << 24) | (puiData[uiByteNum+1] << 16) | (puiData[uiByteNum+2] << 8) | (puiData[uiByteNum+3]);
      		uiByteNum += 4;
      		return (iret);
		i2cDelay(0x100);
 * Function:  	i2cEepromMacWrite
 * Description:	Writing MAC addresses to EEPROM.
 * Parameters:	uint8_t *puchSrc - pointer to mac address
I2C_RET i2cEepromMacWrite( uint8_t *puchSrc)
    uint32_t uiIndex;
  	do
    	else
	I2CR->ICCNT = MACADDRESS_SIZE + 2;
  	I2CR->ICSAR = EEPROM_SLAVE_ADDR_51;
	// setting the first byte of offset
    I2CR->ICDXR = ((MAC_OFFSET & 0xFF00)>>8);
	/* Read status */
    while(0 == I2C_REG_STR_FIELD_XRDY(uiStatusReg));
    // setting the second byte of offset
    I2CR->ICDXR = (MAC_OFFSET & 0xFF);
	/* Read status */
    // EEPROM offset written
	for ( uiIndex = 0 ; uiIndex < MACADDRESS_SIZE ; uiIndex++ )
	   I2CR->ICDXR = puchSrc[uiIndex];            // Write
		/* Read status */
	/* Set the stop bit */
    return I2C_RET_OK;
 * Function:  	i2cEepromMacRead
 * Description:	API to read MAC addresses from I2C EEPROM
 * Parameters:  uint8_t *puchDst - pointer to buffer for reading mac address
I2C_RET i2cEepromMacRead( uint8_t *puchDst)
    uint32_t uiIndex;
    uint8_t uchDummyByte;
  	do
    	else
	I2CR->ICCNT = 2;
	/* Read status */
	/* Read status */
	// Reading Data
	I2CR->ICCNT = MACADDRESS_SIZE;
	for ( uiIndex = 0 ; uiIndex < MACADDRESS_SIZE; uiIndex++ )
	   	puchDst[uiIndex] = I2CR->ICDRR ; //Read MAc data
		/* Read status */
      	while(0 == I2C_REG_STR_FIELD_RRDY(uiStatusReg));
  	uchDummyByte = I2CR->ICDRR;
  	do
      		if(uchDummyByte)
    	else
    return I2C_RET_OK;
#endif
Pradeep
