Other Parts Discussed in Thread: CCSTUDIO
I am trying to use the SPI0 interrupt example but I can not compile it. I change the folder of the project and add the files It needs, but something is wrong.
The error is this one:
[Linking...] "C:\Archivos de programa\Texas Instruments\C6000 Code Generation Tools 6.1.9\bin\cl6x" -@"Debug.lkf"
<Linking>
error: cannot find file
"ti\pspiom\platforms\evmOMAPL137\lib\Debug\ti.pspiom.platforms.evmOMAPL137.e
vmInit.a674"
error: cannot find file "ti\pspiom\spi\lib\OMAPL137\Debug\ti.pspiom.spi.a674"
error: cannot find file "ti\pspiom\psc\lib\OMAPL137\Debug\ti.pspiom.psc.a674"
"ti\pspiom\gpio\lib\OMAPL137\Debug\ti.pspiom.gpio.a674"
undefined first referenced
symbol in file
_Psc_ModuleClkCtrl C:\\src\\dsp\\test\\spi_interrupt\\build\\Debug\\spiSample_io.obj
_Spi_IOMFXNS C:\\src\\dsp\\test\\spi_interrupt\\build\\Debug\\spiSamplecfg.obj
_Spi_PARAMS C:\\src\\dsp\\test\\spi_interrupt\\build\\Debug\\spiSample_io.obj
_Spi_init C:\\src\\dsp\\test\\spi_interrupt\\build\\Debug\\spiSample_main.obj
_configureSpi C:\\src\\dsp\\test\\spi_interrupt\\build\\Debug\\spiSample_main.obj
error: unresolved symbols remain
error: errors encountered during linking;
"C:/src/dsp/test/spi_interrupt/build/../bin/Debug/spiSample.out" not built
I don't know where I have to change to make the linker find those files.
If I compile from the original folder the problem is other:
<Linking>
warning: creating output section ".DVTEvent_Log$buf" without a SECTIONS
specification
warning: creating output section ".LOG_system$buf" without a SECTIONS
specification
warning: creating output section ".TSK_idle$stk" without a SECTIONS
specification
warning: creating output section ".clk" without a SECTIONS specification
warning: creating output section ".devtable" without a SECTIONS specification
warning: creating output section ".echoTask$stk" without a SECTIONS
specification
warning: creating output section ".gblinit" without a SECTIONS specification
warning: creating output section ".hst" without a SECTIONS specification
warning: creating output section ".hst0" without a SECTIONS specification
warning: creating output section ".hst1" without a SECTIONS specification
warning: creating output section ".hwi_vec" without a SECTIONS specification
warning: creating output section ".idl" without a SECTIONS specification
warning: creating output section ".idlcal" without a SECTIONS specification
warning: creating output section ".log" without a SECTIONS specification
warning: creating output section ".mem" without a SECTIONS specification
warning: creating output section ".pip" without a SECTIONS specification
warning: creating output section ".printf" without a SECTIONS specification
warning: creating output section ".rtdx_data" without a SECTIONS specification
warning: creating output section ".sts" without a SECTIONS specification
warning: creating output section ".swi" without a SECTIONS specification
warning: creating output section ".sys" without a SECTIONS specification
warning: creating output section ".sysinit" without a SECTIONS specification
warning: creating output section ".trace$buf" without a SECTIONS specification
warning: creating output section ".tsk" without a SECTIONS specification
warning: creating output section ".vers" without a SECTIONS specification
warning: entry-point symbol "_c_int00" undefined
undefined
first
referenced
symbol in
file
CLK_A_TABBEG C:\\Program Files\\Texas
Instruments\\pspdrivers_01_20_00\\packages\\ti\\pspiom\\examples\\evmOMAPL137\\spi\\interrupt\\build\\Debug\\spiSamplecfg.obj
CLK_F_isr C:\\Program Files\\Texas
FXN_F_run C:\\Program Files\\Texas
GBL_initdone C:\\Program Files\\Texas
GBL_stackbeg C:\\Program Files\\Texas
GBL_stackend C:\\Program Files\\Texas
HWI_A_VECS C:\\Program Files\\Texas
HWI_F_dispatch C:\\Program Files\\Texas
IDL_D_busyObj C:\\Program Files\\Texas
IDL_D_calibrate C:\\Program Files\\Texas
IDL_F_busy C:\\Program Files\\Texas
IDL_F_loop C:\\Program Files\\Texas
IRAM$B C:\\Program Files\\Texas
IRAM$L C:\\Program Files\\Texas
KNL_glue C:\\Program Files\\Texas
LNK_F_dataPump C:\\Program Files\\Texas
LNK_dspFrameReadyMask C:\\Program Files\\Texas
LNK_dspFrameRequestMask C:\\Program Files\\Texas
PIP_D_tabbeg C:\\Program Files\\Texas
PIP_F_start C:\\Program Files\\Texas
PRD_F_tick C:\\Program Files\\Texas
RTA_F_dispatch C:\\Program Files\\Texas
RTA_F_or C:\\Program Files\\Texas
SWI_D_rdytab C:\\Program Files\\Texas
SWI_F_enable C:\\Program Files\\Texas
TRC_R_mask C:\\Program Files\\Texas
TRC_cinit C:\\Program Files\\Texas
TSK_VCREATEFXN C:\\Program Files\\Texas
TSK_VDELETEFXN C:\\Program Files\\Texas
TSK_VEXITFXN C:\\Program Files\\Texas
_BCACHE_inv C:/Program Files/Texas
Instruments/edma3_lld_01_06_00_01/packages/ti\sdo\edma3\drv\sample\lib\omapl137\Debug\edma3_drv_bios_sample.lib<bios_edma3_drv_sample_cs.obj>
_BCACHE_wb C:/Program Files/Texas
_BCACHE_wbInv C:/Program Files/Texas
Instruments/pspdrivers_01_20_00/packages/ti/pspiom/examples/evmOMAPL137/spi/interrupt/build/../../../../../../../ti\pspiom\spi\lib\OMAPL137\Debug\ti.pspiom.spi.a674<Spi_edma.obj>
_C64_enableIER
Instruments/pspdrivers_01_20_00/packages/ti/pspiom/examples/evmOMAPL137/spi/interrupt/build/../../../../../../../ti\pspiom\spi\lib\OMAPL137\Debug\ti.pspiom.spi.a674<Spi.obj>
_CLK_DFLTMICROSECS C:\\Program Files\\Texas
_CLK_D_microseconds C:\\Program Files\\Texas
_CLK_D_prd C:\\Program Files\\Texas
_CLK_gethtime C:/Program Files/Texas
_CLK_htimePerLtime C:\\Program Files\\Texas
_CLK_inputClock C:\\Program Files\\Texas
_DEV_D_devinit C:\\Program Files\\Texas
_DEV_init C:\\Program Files\\Texas
_ECM_ATTRS C:/Program Files/Texas
_ECM_disableEvent C:/Program Files/Texas
_ECM_dispatch C:\\Program Files\\Texas
_ECM_dispatchPlug C:/Program Files/Texas
_ECM_enableEvent C:/Program Files/Texas
_EXC_dispatch C:\\Program Files\\Texas
_EXC_init C:\\Program Files\\Texas
_FXN_F_nop C:\\Program Files\\Texas
_GBL_cacheInit64P C:\\Program Files\\Texas
_GBL_getVersion C:\\Program Files\\Texas
_GBL_procId C:\\Program Files\\Texas
_GIO_ATTRS C:\\Program Files\\Texas
Instruments\\pspdrivers_01_20_00\\packages\\ti\\pspiom\\examples\\evmOMAPL137\\spi\\interrupt\\build\\Debug\\spiSample_io.obj
_GIO_create C:\\Program Files\\Texas
_GIO_delete C:\\Program Files\\Texas
_GIO_submit C:\\Program Files\\Texas
_HSRTDX_rec C:\\Program Files\\Texas
_HSRTDX_xmt C:\\Program Files\\Texas
_HWI_D_inhwi C:/Program Files/Texas
_HWI_disable C:/Program Files/Texas
_HWI_dispatchTab C:\\Program Files\\Texas
_HWI_restore C:/Program Files/Texas
_KNL_curtask C:/Program Files/Texas
_KNL_dummy C:/Program Files/Texas
_KNL_exit C:\\Program Files\\Texas
_KNL_queues C:\\Program Files\\Texas
_KNL_run C:\\Program Files\\Texas
_LOG_printf C:\\Program Files\\Texas
_MEM C:\\Program Files\\Texas
_MEM_init C:\\Program Files\\Texas
_OBJ_table C:\\Program Files\\Texas
_QUE_get C:/Program Files/Texas
_QUE_put C:/Program Files/Texas
_RTDX_Poll C:\\Program Files\\Texas
_SEM_create C:/Program Files/Texas
_SEM_delete C:/Program Files/Texas
_SEM_pend C:\\Program Files\\Texas
_SEM_post C:/Program Files/Texas
_SWI_D_inswi C:/Program Files/Texas
_SYS_printf C:/Program Files/Texas
_TSK
_TSK_config C:\\Program Files\\Texas
_TSK_disable C:/Program Files/Texas
_TSK_enable C:/Program Files/Texas
_TSK_exit C:\\Program Files\\Texas
_TSK_init C:\\Program Files\\Texas
_TSK_setup C:\\Program Files\\Texas
_TSK_startup C:\\Program Files\\Texas
_TSK_timerSem C:\\Program Files\\Texas
_UTL_doAbort C:\\Program Files\\Texas
_UTL_doError C:\\Program Files\\Texas
_UTL_doPutc C:\\Program Files\\Texas
_UTL_halt C:\\Program Files\\Texas
__DEV_D_NUMINITFXNS C:\\Program Files\\Texas
__HOOK_NUMHOOKS C:\\Program Files\\Texas
__HOOK_knlId C:\\Program Files\\Texas
__SEM_dopost C:/Program Files/Texas
__abort_msg C:/Program Files/Texas
__divu C:/Program Files/Texas
__strasgi_64plus C:\\Program Files\\Texas
_memset C:\\Program Files\\Texas
Instruments\\pspdrivers_01_20_00\\packages\\ti\\pspiom\\examples\\evmOMAPL137\\spi\\interrupt\\build\\Debug\\spiSample_main.obj
_scanf C:\\Program Files\\Texas
_trace C:\\Program Files\\Texas
Someone can help me, please?
Dani.
