hi all .now i construct the link like that vdec->swms->osd->vdis
when i run the app ,it will has following errors and warnings that althougn not affect the program run
i think that seems like the osd max 64 channel can not be synchro.so how can we fix that warning? thanks!!
[m3vpss ] 8908:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[0] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[1] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[2] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8909:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[3] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[4] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[5] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[6] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8910:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[7] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[8] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[9] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[10] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8911:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[11] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[12] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[13] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8912:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[14] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[15] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[16] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[17] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8913:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[18] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[19] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[20] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[21] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8914:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[22] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[23] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[24] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[25] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8915:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[26] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[27] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[28] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[29] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8916:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[30] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[31] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[32] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[33] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8917:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[34] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[35] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[36] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[37] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8918:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[38] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[39] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[40] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8919:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[41] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[42] Will Default to AVSYNC disabled
[m3vpss ]
[c6xdsp ] 7263: IPC_FRAMES_IN : Create in progress !!!
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[43] Will Default to AVSYNC disabled
[m3vpss ]
[c6xdsp ] 7263: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[44] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8920:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[c6xdsp ] 7263: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[45] Will Default to AVSYNC disabled
[m3vpss ]
[c6xdsp ] 7264: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[46] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[47] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[48] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8921:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[49] Will Default to AVSYNC disabled
[m3vpss ]
[c6xdsp ] 7265: IPC_FRAMES_IN : Create Done !!!
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[50] Will Default to AVSYNC disabled
[m3vpss ]
[c6xdsp ] 7265: ALG : Create in progress !!!
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[51] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[52] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8922:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[53] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[54] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[55] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[56] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8923:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[57] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[58] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[59] Will Default to AVSYNC disabled
[m3vpss ]
[c6xdsp ] ALGLINK:HEAPID:0 USED:2616
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[60] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] 8924:ERR::linkID:20000036::channelID:-1::errorCode:-3::FileName:links_m3vpss/avsync/avsync_m3vpss.c::linuNum:1236::errorCondition:((avsync_map_linkid2displayid(pObj,cp->syncLinkID) != AVSYNC_INVALID_DISPLAY_ID) || (cp->displayID != AVSYNC_INVALID_DISPLAY_ID))
[c6xdsp ] ALGLINK:HEAPID:1 USED:5912
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[61] Will Default to AVSYNC disabled
[m3vpss ]
[c6xdsp ] 7276: ALG : Create Done !!!
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[62] Will Default to AVSYNC disabled
[m3vpss ]
[m3vpss ] AVSYNC:WARNING!!!.AVSYNC config invalid for linkID[20000030]:chId[63] Will Default to AVSYNC disabled
[m3vpss ] 8925: SWMS : ******* Configuring clock 15 secs...
