Debugging ICE rev2 board fails
Other Parts Discussed in Thread: AM3359
I am trying to load and debug the standard EtherNet/IP adapter application and EtherCAT demo application on the new ICE rev2 board, but I am get errors when loading either program. I am using CCS 5.4, NDK 2.22.03.20, and Industrial SDK 1.1.0.1. I can debug these same exact applications on a ICE rev1 board with no issues.
In CCS, when setting up the Target Configuration, I am selecting the ICE_AM3359 board/device. I can connect to the target (ICE rev2 board) and this successfully performs the AM3359 ICE initialization. When I go to load the program (Run->Load->Load Program...), I get the following errors:
CortxA8: Breakpoint Manager: Retrying with a AET breakpoint
CortxA8: Trouble Setting Breakpoint with the Action "Process CIO" at 0x80017508: (Error -1066 @ 0x333C) Unable to set requested breakpoint in memory. Verify that the breakpoint address is in writable memory. (Emulation package 5.1.73.0)
CortxA8: Trouble Setting Breakpoint with the Action "Terminate Program Execution" at 0x8001899c: (Error -1066 @ 0x333C) Unable to set requested breakpoint in memory. Verify that the breakpoint address is in writable memory. (Emulation package 5.1.73.0)
CortxA8: Trouble Setting Breakpoint with the Action "Finish Auto Run" at 0x80014810: (Error -1066 @ 0x333C) Unable to set requested breakpoint in memory. Verify that the breakpoint address is in writable memory. (Emulation package 5.1.73.0)
I assume someone (at TI) must have tested debugging applications on an ICE rev2 board. If so, could you please tell me what specific versions of software worked for debugging? Is there a newer "gel" file for the ICE rev2 board?
  • Fyang,
    The issue seems to be arising due to incorrect gel file. The GEL files for ICE rev1 and rev2 are not the same. You can find the GEL file for ICE rev 2 at - sdk/tools/gel/ICE/TMDXICE3359_v2_1A.gel .
    Vinesh
  • Thanks for pointing out the gel file. However, I am still having problems. When I connect to the target, I get the following errors:
    CortxA8: Output: ****  AM3359_ICE Initialization is in progress ..........
    CortxA8: Output: ****  AM335x ALL PLL Config for OPP == OPP100 is in progress .........
    CortxA8: Output: Input Clock Read from SYSBOOT[15:14]:  24MHz
    CortxA8: Output: ****  Going to Bypass...
    CortxA8: Output: ****  Bypassed, changing values...
    CortxA8: Output: ****  Locking ARM PLL
    CortxA8: Output: ****  Core Bypassed
    CortxA8: Output: ****  Now locking Core...
    CortxA8: Output: ****  Core locked
    CortxA8: Output: ****  DDR DPLL Bypassed
    CortxA8: Output: ****  DDR DPLL Locked
    CortxA8: Output: ****  PER DPLL Bypassed
    CortxA8: Output: ****  PER DPLL Locked
    CortxA8: Output: ****  DISP PLL Config is in progress ..........
    CortxA8: Output: ****  DISP PLL Config is DONE ..........
    CortxA8: Output: ****  AM335x ALL ADPLL Config for OPP == OPP100 is Done .........
    CortxA8: Output: ****  AM335x DDR3 EMIF and PHY configuration is in progress...
    CortxA8: Output: EMIF PRCM is in progress .......
    CortxA8: Output: EMIF PRCM Done
    CortxA8: Output: DDR PHY Configuration in progress
    CortxA8: Output: Waiting for VTP Ready .......
    CortxA8: Output: VTP is Ready!
    CortxA8: Output: DDR PHY CMD0 Register configuration is in progress .......
    CortxA8: Output: DDR PHY CMD1 Register configuration is in progress .......
    CortxA8: Output: DDR PHY CMD2 Register configuration is in progress .......
    CortxA8: Output: DDR PHY DATA0 Register configuration is in progress .......
    CortxA8: Output: DDR PHY DATA1 Register configuration is in progress .......
    CortxA8: Output: Setting IO control registers.......
    CortxA8: Output: EMIF Timing register configuration is in progress .......
    CortxA8: Trouble Writing Memory Block at 0x4c0000e4 on Page 0 of Length 0x4: (Error -1065 @ 0x4C0000E4) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.73.0)
    CortxA8: GEL: Error while executing OnTargetConnect(): target access failed     at *((unsigned int *) (0x4C000000+0x0E4))=(unsigned int) 0x07 [TMDXICE3359_v2_1A.gel:281]     at DDR3_EMIF_Config() [TMDXICE3359_v2_1A.gel:373]     at AM3359_ICE_Initialization() [TMDXICE3359_v2_1A.gel:359]     at OnTargetConnect() .
    CortxA8: Trouble Reading Register CP15_Registers_CP15_CONTROL_REGISTER: (Error -2131 @ 0x20013F00) Unable to access device register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.73.0)
    It appears that there is a problem with accessing DDR3. Did you experience any similar problems?
  • Just do a RESET CPU(HW) on the ARM target before running the GEL. That should work.
  • Hi Frank,
    Sorry for the long delay. I tried performing the CPU Reset (HW) and then running the GEL, but I get the same results. However, the following combination of launching gel files got me a bit further in the initialization, but I'm sure I'm still having DDR3 issues:
    Since ICE rev2 gel file was not working, I launched and ran the ICE rev1 gel. Surprisingly, the ICE initialization completed. I then went back and launched the ICE rev2 gel and now the ICE initialization was also completing successfully. However, if I run the DDR3 tests, there are failures. I have attached the results of the DDR3 tests:
    CortxA8: Output: EMIF Timing register configuration is done .......
    CortxA8: Output: PHY is READY!!
    CortxA8: Output: DDR PHY Configuration done
    CortxA8: Output: ****  AM3359_ICE Initialization is Done ******************
    CortxA8: GEL Output: Try Accessing DDR memory....Write data
    CortxA8: GEL Output: Data written at :: 0x80000000
    CortxA8: GEL Output: Data written at :: 0x80000004
    CortxA8: GEL Output: Data written at :: 0x80000008
    CortxA8: GEL Output: Data written at :: 0x8000000C
    CortxA8: GEL Output: Data written at :: 0x80000010
    CortxA8: GEL Output: Data written at :: 0x80000014
    CortxA8: GEL Output: Data written at :: 0x80000018
    CortxA8: GEL Output: Data written at :: 0x8000001C
    CortxA8: GEL Output: Data written at :: 0x80000020
    CortxA8: GEL Output: Data written at :: 0x80000024
    CortxA8: GEL Output: Data written at :: 0x80000028
    CortxA8: GEL Output: Data written at :: 0x8000002C
    CortxA8: GEL Output: Data written at :: 0x80000030
    CortxA8: GEL Output: Data written at :: 0x80000034
    CortxA8: GEL Output: Data written at :: 0x80000038
    CortxA8: GEL Output: Data written at :: 0x8000003C
    CortxA8: GEL Output: Data written at :: 0x80000040
    CortxA8: GEL Output: Data written at :: 0x80000044
    CortxA8: GEL Output: Data written at :: 0x80000048
    CortxA8: GEL Output: Data written at :: 0x8000004C
    CortxA8: GEL Output: Data written at :: 0x80000050
    CortxA8: GEL Output: Data written at :: 0x80000054
    CortxA8: GEL Output: Data written at :: 0x80000058
    CortxA8: GEL Output: Data written at :: 0x8000005C
    CortxA8: GEL Output: Data written at :: 0x80000060
    CortxA8: GEL Output: Data written at :: 0x80000064
    CortxA8: GEL Output: Data written at :: 0x80000068
    CortxA8: GEL Output: Data written at :: 0x8000006C
    CortxA8: GEL Output: Data written at :: 0x80000070
    CortxA8: GEL Output: Data written at :: 0x80000074
    CortxA8: GEL Output: Data written at :: 0x80000078
    CortxA8: GEL Output: Data written at :: 0x8000007C
    CortxA8: GEL Output: Data written at :: 0x80000080
    CortxA8: GEL Output: Data written at :: 0x80000084
    CortxA8: GEL Output: Data written at :: 0x80000088
    CortxA8: GEL Output: Data written at :: 0x8000008C
    CortxA8: GEL Output: Data written at :: 0x80000090
    CortxA8: GEL Output: Data written at :: 0x80000094
    CortxA8: GEL Output: Data written at :: 0x80000098
    CortxA8: GEL Output: Data written at :: 0x8000009C
    CortxA8: GEL Output: Data written at :: 0x800000A0
    CortxA8: GEL Output: Data written at :: 0x800000A4
    CortxA8: GEL Output: Data written at :: 0x800000A8
    CortxA8: GEL Output: Data written at :: 0x800000AC
    CortxA8: GEL Output: Data written at :: 0x800000B0
    CortxA8: GEL Output: Data written at :: 0x800000B4
    CortxA8: GEL Output: Data written at :: 0x800000B8
    CortxA8: GEL Output: Data written at :: 0x800000BC
    CortxA8: GEL Output: Data written at :: 0x800000C0
    CortxA8: GEL Output: Data written at :: 0x800000C4
    CortxA8: GEL Output: Data written at :: 0x800000C8
    CortxA8: GEL Output: Data written at :: 0x800000CC
    CortxA8: GEL Output: Data written at :: 0x800000D0
    CortxA8: GEL Output: Data written at :: 0x800000D4
    CortxA8: GEL Output: Data written at :: 0x800000D8
    CortxA8: GEL Output: Data written at :: 0x800000DC
    CortxA8: GEL Output: Data written at :: 0x800000E0
    CortxA8: GEL Output: Data written at :: 0x800000E4
    CortxA8: GEL Output: Data written at :: 0x800000E8
    CortxA8: GEL Output: Data written at :: 0x800000EC
    CortxA8: GEL Output: Data written at :: 0x800000F0
    CortxA8: GEL Output: Data written at :: 0x800000F4
    CortxA8: GEL Output: Data written at :: 0x800000F8
    CortxA8: GEL Output: Data written at :: 0x800000FC
    CortxA8: GEL Output: Data written at :: 0x80000100
    CortxA8: GEL Output: Data written at :: 0x80000104
    CortxA8: GEL Output: Data written at :: 0x80000108
    CortxA8: GEL Output: Data written at :: 0x8000010C
    CortxA8: GEL Output: Data written at :: 0x80000110
    CortxA8: GEL Output: Data written at :: 0x80000114
    CortxA8: GEL Output: Data written at :: 0x80000118
    CortxA8: GEL Output: Data written at :: 0x8000011C
    CortxA8: GEL Output: Data written at :: 0x80000120
    CortxA8: GEL Output: Data written at :: 0x80000124
    CortxA8: GEL Output: Data written at :: 0x80000128
    CortxA8: GEL Output: Data written at :: 0x8000012C
    CortxA8: GEL Output: Data written at :: 0x80000130
    CortxA8: GEL Output: Data written at :: 0x80000134
    CortxA8: GEL Output: Data written at :: 0x80000138
    CortxA8: GEL Output: Data written at :: 0x8000013C
    CortxA8: GEL Output: Data written at :: 0x80000140
    CortxA8: GEL Output: Data written at :: 0x80000144
    CortxA8: GEL Output: Data written at :: 0x80000148
    CortxA8: GEL Output: Data written at :: 0x8000014C
    CortxA8: GEL Output: Data written at :: 0x80000150
    CortxA8: GEL Output: Data written at :: 0x80000154
    CortxA8: GEL Output: Data written at :: 0x80000158
    CortxA8: GEL Output: Data written at :: 0x8000015C
    CortxA8: GEL Output: Data written at :: 0x80000160
    CortxA8: GEL Output: Data written at :: 0x80000164
    CortxA8: GEL Output: Data written at :: 0x80000168
    CortxA8: GEL Output: Data written at :: 0x8000016C
    CortxA8: GEL Output: Data written at :: 0x80000170
    CortxA8: GEL Output: Data written at :: 0x80000174
    CortxA8: GEL Output: Data written at :: 0x80000178
    CortxA8: GEL Output: Data written at :: 0x8000017C
    CortxA8: GEL Output: Data written at :: 0x80000180
    CortxA8: GEL Output: Data written at :: 0x80000184
    CortxA8: GEL Output: Data written at :: 0x80000188
    CortxA8: GEL Output: Data written at :: 0x8000018C
    CortxA8: GEL Output: Data written at :: 0x80000190
    CortxA8: GEL Output: Data written at :: 0x80000194
    CortxA8: GEL Output: Data written at :: 0x80000198
    CortxA8: GEL Output: Data written at :: 0x8000019C
    CortxA8: GEL Output: Data written at :: 0x800001A0
    CortxA8: GEL Output: Data written at :: 0x800001A4
    CortxA8: GEL Output: Data written at :: 0x800001A8
    CortxA8: GEL Output: Data written at :: 0x800001AC
    CortxA8: GEL Output: Data written at :: 0x800001B0
    CortxA8: GEL Output: Data written at :: 0x800001B4
    CortxA8: GEL Output: Data written at :: 0x800001B8
    CortxA8: GEL Output: Data written at :: 0x800001BC
    CortxA8: GEL Output: Data written at :: 0x800001C0
    CortxA8: GEL Output: Data written at :: 0x800001C4
    CortxA8: GEL Output: Data written at :: 0x800001C8
    CortxA8: GEL Output: Data written at :: 0x800001CC
    CortxA8: GEL Output: Data written at :: 0x800001D0
    CortxA8: GEL Output: Data written at :: 0x800001D4
    CortxA8: GEL Output: Data written at :: 0x800001D8
    CortxA8: GEL Output: Data written at :: 0x800001DC
    CortxA8: GEL Output: Data written at :: 0x800001E0
    CortxA8: GEL Output: Data written at :: 0x800001E4
    CortxA8: GEL Output: Data written at :: 0x800001E8
    CortxA8: GEL Output: Data written at :: 0x800001EC
    CortxA8: GEL Output: Data written at :: 0x800001F0
    CortxA8: GEL Output: Data written at :: 0x800001F4
    CortxA8: GEL Output: Data written at :: 0x800001F8
    CortxA8: GEL Output: Data written at :: 0x800001FC
    CortxA8: GEL Output: Data written at :: 0x80000200
    CortxA8: GEL Output: Data written at :: 0x80000204
    CortxA8: GEL Output: Data written at :: 0x80000208
    CortxA8: GEL Output: Data written at :: 0x8000020C
    CortxA8: GEL Output: Data written at :: 0x80000210
    CortxA8: GEL Output: Data written at :: 0x80000214
    CortxA8: GEL Output: Data written at :: 0x80000218
    CortxA8: GEL Output: Data written at :: 0x8000021C
    CortxA8: GEL Output: Data written at :: 0x80000220
    CortxA8: GEL Output: Data written at :: 0x80000224
    CortxA8: GEL Output: Data written at :: 0x80000228
    CortxA8: GEL Output: Data written at :: 0x8000022C
    CortxA8: GEL Output: Data written at :: 0x80000230
    CortxA8: GEL Output: Data written at :: 0x80000234
    CortxA8: GEL Output: Data written at :: 0x80000238
    CortxA8: GEL Output: Data written at :: 0x8000023C
    CortxA8: GEL Output: Data written at :: 0x80000240
    CortxA8: GEL Output: Data written at :: 0x80000244
    CortxA8: GEL Output: Data written at :: 0x80000248
    CortxA8: GEL Output: Data written at :: 0x8000024C
    CortxA8: GEL Output: Data written at :: 0x80000250
    CortxA8: GEL Output: Data written at :: 0x80000254
    CortxA8: GEL Output: Data written at :: 0x80000258
    CortxA8: GEL Output: Data written at :: 0x8000025C
    CortxA8: GEL Output: Data written at :: 0x80000260
    CortxA8: GEL Output: Data written at :: 0x80000264
    CortxA8: GEL Output: Data written at :: 0x80000268
    CortxA8: GEL Output: Data written at :: 0x8000026C
    CortxA8: GEL Output: Data written at :: 0x80000270
    CortxA8: GEL Output: Data written at :: 0x80000274
    CortxA8: GEL Output: Data written at :: 0x80000278
    CortxA8: GEL Output: Data written at :: 0x8000027C
    CortxA8: GEL Output: Data written at :: 0x80000280
    CortxA8: GEL Output: Data written at :: 0x80000284
    CortxA8: GEL Output: Data written at :: 0x80000288
    CortxA8: GEL Output: Data written at :: 0x8000028C
    CortxA8: GEL Output: Data written at :: 0x80000290
    CortxA8: GEL Output: Data written at :: 0x80000294
    CortxA8: GEL Output: Data written at :: 0x80000298
    CortxA8: GEL Output: Data written at :: 0x8000029C
    CortxA8: GEL Output: Data written at :: 0x800002A0
    CortxA8: GEL Output: Data written at :: 0x800002A4
    CortxA8: GEL Output: Data written at :: 0x800002A8
    CortxA8: GEL Output: Data written at :: 0x800002AC
    CortxA8: GEL Output: Data written at :: 0x800002B0
    CortxA8: GEL Output: Data written at :: 0x800002B4
    CortxA8: GEL Output: Data written at :: 0x800002B8
    CortxA8: GEL Output: Data written at :: 0x800002BC
    CortxA8: GEL Output: Data written at :: 0x800002C0
    CortxA8: GEL Output: Data written at :: 0x800002C4
    CortxA8: GEL Output: Data written at :: 0x800002C8
    CortxA8: GEL Output: Data written at :: 0x800002CC
    CortxA8: GEL Output: Data written at :: 0x800002D0
    CortxA8: GEL Output: Data written at :: 0x800002D4
    CortxA8: GEL Output: Data written at :: 0x800002D8
    CortxA8: GEL Output: Data written at :: 0x800002DC
    CortxA8: GEL Output: Data written at :: 0x800002E0
    CortxA8: GEL Output: Data written at :: 0x800002E4
    CortxA8: GEL Output: Data written at :: 0x800002E8
    CortxA8: GEL Output: Data written at :: 0x800002EC
    CortxA8: GEL Output: Data written at :: 0x800002F0
    CortxA8: GEL Output: Data written at :: 0x800002F4
    CortxA8: GEL Output: Data written at :: 0x800002F8
    CortxA8: GEL Output: Data written at :: 0x800002FC
    CortxA8: GEL Output: Data written at :: 0x80000300
    CortxA8: GEL Output: Data written at :: 0x80000304
    CortxA8: GEL Output: Data written at :: 0x80000308
    CortxA8: GEL Output: Data written at :: 0x8000030C
    CortxA8: GEL Output: Data written at :: 0x80000310
    CortxA8: GEL Output: Data written at :: 0x80000314
    CortxA8: GEL Output: Data written at :: 0x80000318
    CortxA8: GEL Output: Data written at :: 0x8000031C
    CortxA8: GEL Output: Data written at :: 0x80000320
    CortxA8: GEL Output: Data written at :: 0x80000324
    CortxA8: GEL Output: Data written at :: 0x80000328
    CortxA8: GEL Output: Data written at :: 0x8000032C
    CortxA8: GEL Output: Data written at :: 0x80000330
    CortxA8: GEL Output: Data written at :: 0x80000334
    CortxA8: GEL Output: Data written at :: 0x80000338
    CortxA8: GEL Output: Data written at :: 0x8000033C
    CortxA8: GEL Output: Data written at :: 0x80000340
    CortxA8: GEL Output: Data written at :: 0x80000344
    CortxA8: GEL Output: Data written at :: 0x80000348
    CortxA8: GEL Output: Data written at :: 0x8000034C
    CortxA8: GEL Output: Data written at :: 0x80000350
    CortxA8: GEL Output: Data written at :: 0x80000354
    CortxA8: GEL Output: Data written at :: 0x80000358
    CortxA8: GEL Output: Data written at :: 0x8000035C
    CortxA8: GEL Output: Data written at :: 0x80000360
    CortxA8: GEL Output: Data written at :: 0x80000364
    CortxA8: GEL Output: Data written at :: 0x80000368
    CortxA8: GEL Output: Data written at :: 0x8000036C
    CortxA8: GEL Output: Data written at :: 0x80000370
    CortxA8: GEL Output: Data written at :: 0x80000374
    CortxA8: GEL Output: Data written at :: 0x80000378
    CortxA8: GEL Output: Data written at :: 0x8000037C
    CortxA8: GEL Output: Data written at :: 0x80000380
    CortxA8: GEL Output: Data written at :: 0x80000384
    CortxA8: GEL Output: Data written at :: 0x80000388
    CortxA8: GEL Output: Data written at :: 0x8000038C
    CortxA8: GEL Output: Data written at :: 0x80000390
    CortxA8: GEL Output: Data written at :: 0x80000394
    CortxA8: GEL Output: Data written at :: 0x80000398
    CortxA8: GEL Output: Data written at :: 0x8000039C
    CortxA8: GEL Output: Data written at :: 0x800003A0
    CortxA8: GEL Output: Data written at :: 0x800003A4
    CortxA8: GEL Output: Data written at :: 0x800003A8
    CortxA8: GEL Output: Data written at :: 0x800003AC
    CortxA8: GEL Output: Data written at :: 0x800003B0
    CortxA8: GEL Output: Data written at :: 0x800003B4
    CortxA8: GEL Output: Data written at :: 0x800003B8
    CortxA8: GEL Output: Data written at :: 0x800003BC
    CortxA8: GEL Output: Data written at :: 0x800003C0
    CortxA8: GEL Output: Data written at :: 0x800003C4
    CortxA8: GEL Output: Data written at :: 0x800003C8
    CortxA8: GEL Output: Data written at :: 0x800003CC
    CortxA8: GEL Output: Data written at :: 0x800003D0
    CortxA8: GEL Output: Data written at :: 0x800003D4
    CortxA8: GEL Output: Data written at :: 0x800003D8
    CortxA8: GEL Output: Data written at :: 0x800003DC
    CortxA8: GEL Output: Data written at :: 0x800003E0
    CortxA8: GEL Output: Data written at :: 0x800003E4
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000000
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000001
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000002
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000003
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000004
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000005
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000006
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000007
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000008
    CortxA8: GEL Output: No of Failed locations  are :: 0x00000009
    CortxA8: GEL Output: No of Failed locations  are :: 0x0000000A
    CortxA8: GEL Output: No of Failed locations  are :: 0x0000000B
    CortxA8: GEL Output: No of Failed locations  are :: 0x0000000C
    CortxA8: GEL Output: No of Failed locations  are :: 0x0000000D
    CortxA8: GEL Output: No of Failed locations  are :: 0x0000000E
    CortxA8: GEL Output: No of Failed locations  are :: 0x0000000F
    CortxA8: GEL Output: Data Integrity check FailedCortxA8: GEL Output:
    This EDMA test consists of 8 tests.
      It will take approimately 13 minutes to complete
    CortxA8: GEL Output: Write is completed Starting @0x80000000
    CortxA8: GEL Output: Write is completed Starting @0x40300000
    Test 1
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000000
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000000
    Failed@0x40300400	Expected=0xAAAAABAA 	Read=0x00000000
    Failed@0x40300440	Expected=0xAAAAABBA 	Read=0x00000000
    Failed@0x40300480	Expected=0xAAAAABCA 	Read=0x00000000
    Failed@0x403004C0	Expected=0xAAAAABDA 	Read=0x00000000
    Failed@0x40300500	Expected=0xAAAAABEA 	Read=0x00000000
    Failed@0x40300540	Expected=0xAAAAABFA 	Read=0x00000000
    Failed@0x40300580	Expected=0xAAAAAC0A 	Read=0x00000000
    Failed@0x403005C0	Expected=0xAAAAAC1A 	Read=0x00000000
    Failed@0x40300600	Expected=0xAAAAAC2A 	Read=0x00000000
    Failed@0x40300640	Expected=0xAAAAAC3A 	Read=0x00000000
    Failed@0x40300680	Expected=0xAAAAAC4A 	Read=0x00000000
    Failed@0x403006C0	Expected=0xAAAAAC5A 	Read=0x00000000
    Failed@0x40300700	Expected=0xAAAAAC6A 	Read=0x00000000
    Failed@0x40300740	Expected=0xAAAAAC7A 	Read=0x00000000
    Failed@0x40300780	Expected=0xAAAAAC8A 	Read=0x00000000
    Failed@0x403007C0	Expected=0xAAAAAC9A 	Read=0x00000000
    CortxA8: GEL Output: Write is completed Starting @0x40300800
    CortxA8: GEL Output: Test Case Passed for Destination Addr=0x80000800
    Test 2
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000001
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000001
    CortxA8: GEL Output: Test Case Passed for Destination Addr=0x40300000
    Test 3
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000002
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000002
    Test 4
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000003
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000003
    Test 5
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000004
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000004
    Test 6
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000005
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000005
    Test 7
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000006
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000006
    Test 8
    CortxA8: GEL Output: EDMA Transfer Start for QUEPRI 0x00000007
    CortxA8: GEL Output: EDMA Transfer Complete for QUEPRI 0x00000007
    CortxA8: GEL Output: Test is complete
  • Frank,
    Ignore my last post. Your suggestion works now. I must have goofed somewhere. It seems that the first ICE initialization fails. After performing the RESET CPU (HW), you must wait patiently for the target to go into a "Suspended" state before trying the ICE initialization again. I may have been too hasty on the second ICE initialization.
