Debugging into IPC-calls doesn't work properly
We experience stability issues when sending Messages using IPC MessageQs over SRIO, therefore I tried  to debug into IPC functions.
Although I set the build-profile to "debug", the RTSC build profile also to "debug" and appended the following lines to the rtsc-config-file:
> BIOS.libType = BIOS.LibType_Custom;
> BIOS.customCCOpts = BIOS.customCCOpts.replace("-o3", "-o0");
... when I step into an IPC function, it seems debug-symbols and source-code don't match (line-numbers, branches, etc) - even although I manually located the source of MessageQ.c within the same version of IPC I use for linking.
Any idea how I can get debug-information and source-code in sync for external libaries like IPC?
Thank you in advance, Clemens
