critical section execution
We are in a crital section exection, example SPI data transmit and receive
Can any one suggest how to block
1)Task of higher or lower priority interrupting
2) other high priority interrupts
3) Block all the other, during critical section execution
Bindu
  • Hi Bindu,
    => if other Task instances can access the same resource, semaphore_pend/post can be used to share the critical section safely,  Semaphore instance should be a counting semaphore initialized with 1. Or, Task_disable/restore.
    =>  Swi_disable/restore and Hwi_disable/restore
    You can find the various gate implementations in <bios_install_dir>\packages\ti\sysbios\gates.
    Hope this helps.
    Kawada
