vdec vdis exit bug
hi all ,now i exit my own vdec_vdis app like that :
                        Vdec_stop();
                            Vdis_stop();
                                Vsys_deConfigureDisplay();
                                    /* delete can be done in any order */
                                    Vdec_delete();
                                    Vdis_delete();
                                    System_linkDelete(gMultiCh_VdecVdisObj.dupId);
                                        System_linkDelete(gMultiCh_VdecVdisObj.ipcOutVideoId );
                                        System_linkDelete(gMultiCh_VdecVdisObj.ipcInVpssId );
                                    /* De-initialize components */
                                    Vdec_exit();
                                    Vdis_exit();
                                    Vsys_exit();
that will has following error,but i didn't use the dup link .so why?
 [m3video]  11831: DECODE: Stop in progress !!!
 [m3video]  11831: DECODE: Stop Done !!!
 [m3vpss ]  11858: SWMS: Stop in Progress !!!
 [m3vpss ]  11858: SWMS: Stop Done !!!
 [m3vpss ]  11859: DISPLAY: Stop in progress !!!
 [m3vpss ]  11918: DISPLAY: Stop Done !!!
 [m3video]  12020: DECODE: Stop in progress !!!
 [m3video]  12020: DECODE: Stop Done !!!
 [m3vpss ]  12020: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 218, HDDAC(BP0) 220, DVO2(BP1) 221, SDDAC(SEC1) 221
 [m3video]  12020: DECODE: Delete in progress !!!
 [m3video] MemoryLeak:STAGE:0   HEAPNUM:0       ALLOC=4264      FREED=2368
 [host]  4179: IPC_BITS_OUT   : Delete in progress !!!
 [host]
4180: IPCBITSOUT:Link[30000019]:
 [host] RECV:144        FREE:142,DROPPED:0,AVGLATENCY:2811
 [host] IPC_BITSOUT:BitBuffer Free.chID:0,Size:0x9E3400
 [host] ******* RingBuf 0 deleted ********
 [host] IPC_BITSOUT:BitBuffer Free.chID:1,Size:0x9E3400
 [host] ******* RingBuf 1 deleted ********
 [host]  4197: IPC_BITS_OUT   : Delete Done !!!
 [m3video]
 [m3video] 12028:ERR::linkID:10000022::channelID:-1::errorCode:-10::FileName:links_m3video/iva_dec/decLink_common.c::linuNum:158::errorCondition:(Utils_queIsFull(&pObj->dupObj.dupQue) == TRUE)
 [m3video]  12029: DECODE: Delete Done !!!
 4202: SYSTEM: System Common De-Init in progress !!!
 [host] OSA_tskDelete:In progress...
 [host] OSA_tskDelete:In progress... 4206: SYSTEM: IPC de-init in progress !!!
 [m3video] 12029: IPCBITSIN:Link[1000001b]:
 [m3video] RECV:142     FREE:142,DROPPED:2,AVGLATENCY:15
 [m3video]  12029: IPC_BITS_IN   : Delete in progress !!!
 [m3vpss ]  12047: SWMS: Frames = 1536 (fps = 520) !!!
 [m3video]  12029: IPC_BITS_IN   : Delete Done !!!
 [m3vpss ]  12047: SWMS: Delete in progress !!!
 [m3video]  12051: IPC_OUT_M3   : Delete in progress !!!
 [m3vpss ]  UTILS: DMA: Free'ed CH (TCC) = 58 (58)
 [m3video]  12051: IPC_OUT_M3   : Delete Done !!!
 [m3vpss ]  12050: SWMS: Delete Done !!!
 [m3vpss ]  12050: DISPLAY: Frames = 191 (fps = 52) !!!
 [m3vpss ]  12050: DISPLAY: Delete in progress !!!
 [m3vpss ]  12050: DISPLAY: Delete Done !!!
 [m3vpss ]  12051: IPC_IN_M3   : Delete in progress !!!
 [m3vpss ]  12051: IPC_IN_M3   : Delete Done !!!
 4219: SYSTEM: IPC de-init DONE !!!
 4219: SYSTEM: System Common De-Init Done !!!
  • then i run the original app and fount that is also has the same error ,but not affect the app exit out normally .
    but in my app , i use the function MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE)
    that print information is following,so why?and how to fix that
     [m3video] 11559: IPCBITSIN:Link[1000001b]:
     [m3video] RECV:142     FREE:142,DROPPED:0,AVGLATENCY:14
     [m3video]  11559: IPC_BITS_IN   : Delete in progress !!!
     [c6xdsp ]  10066: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
     [m3video]  11559: IPC_BITS_IN   : Delete Done !!!
     [m3vpss ]  11580: SWMS: Delete Done !!!
     [c6xdsp ]
     [m3video]  11581: IPC_OUT_M3   : Delete in progress !!!
     [m3vpss ]  11580: DISPLAY: Frames = 176 (fps = 51) !!!
     [m3video]  11581: IPC_OUT_M3   : Delete Done !!!
     [m3vpss ]  11580: DISPLAY: Delete in progress !!!
     [m3video]
     [m3vpss ]  11581: DISPLAY: Delete Done !!!
     [m3video]  11583: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
     [m3vpss ]  11581: IPC_IN_M3   : Delete in progress !!!
     [m3video]
     [m3vpss ]  11582: IPC_IN_M3   : Delete Done !!!
     [m3vpss ]
     [m3vpss ]  11582: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
     [m3vpss ]
  • and then i run the app again when i exit the app,it will have follow error:
     Vdec_init : Initialize the decoder successfully !
     [host]  67: IPC_BITS_OUT   : Create in progress !!!
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:0,Size:0x9E3400
     [host]
    ******* RingBuf 0 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4130c080 To Phy:0x90000080
     [host]
    ###Bit buff of size from the SR # 1 : 10368000 / bufsize 2073600, maxQueueDepth 50
     [host] ###Bit buff BasePtr: 4130C080 / PhyAddr 90000080
     [host] IPC_BITSOUT:BitBuffer Alloc.ChID:1,Size:0x9E3400
     [host]
    ******* RingBuf 1 created ********
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x41cef480 To Phy:0x909e3480
     [host]
     [host] ###Bit buff BasePtr: 41CEF480 / PhyAddr 909E3480
     [host]  68: IPC_BITS_OUT   : Create Done !!!
     [m3video]  60730: IPC_BITS_IN   : Create in progress !!!
     [m3video]  60730: SYSTEM: Opening ListMP [HOST_IPC_OUT_25] ...
     [m3video]  60730: SYSTEM: Opening ListMP [HOST_IPC_IN_25] ...
     [m3video]  60732: IPC_BITS_IN   : Create Done !!!
     [m3video]  60732: DECODE: Create in progress ... !!!
     [m3video] DECLINK_H264:HEAPID:0        USED:2368
     [m3video] DECLINK_H264:HEAPID:3        USED:9363456
     [m3video]  60777: SYSTEM  : FREE SPACE : System Heap      = 6273888 B, Mbx = 10239 msgs)
     [m3video]  60777: SYSTEM  : FREE SPACE : SR0 Heap         = 8712320 B (8 MB)
     [m3video]  60777: SYSTEM  : FREE SPACE : Frame Buffer     = 264985472 B (252 MB)
     [m3video]  60778: SYSTEM  : FREE SPACE : Bitstream Buffer = 187930496 B (179 MB)
     [m3video]  60778: SYSTEM  : FREE SPACE : Tiler Buffer     = 224 B (0 MB)  - TILER OFF
     [m3video]  60778: Assertion @ Line: 181 in utils/src/utils_tiler.c: (UInt32)(pFrame->addr[0][0]) != SYSTEM_TILER_INVALID_ADDR : failed !!!
  • You have to delete all links you create and also if you have disabled tiler allocator in your usecase you should enable it. Basically you should do reverse of all operations done in usecase create. Don't use Vdec_delete/Vdis_delete. Write explicit usecase delete function which deletes all links you have created like what is doen in all dvr rdk usecases like multich_vdec_vdis.c
  • as you told ,i delete all the link that i created.but i still has the error.
    following is the log information when i run my app at the first time.
     0: SYSTEM: System Common Init in progress !!!
     0: SYSTEM: IPC init in progress !!!
     13: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
     13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
     13: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
     13: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
     13: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
     16: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
     17: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
     19: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     19: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     20: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     20: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     21: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     22: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     22: SYSTEM: IPC init DONE !!!
     24: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
     26: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
     27: SYSTEM: ListElem Shared Addr = 0x406fd880
     28: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
     30: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
     31: SYSTEM: ListElem Shared Addr = 0x40732a80
     33: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
     35: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
     37: SYSTEM: ListElem Shared Addr = 0x40767c80
     38: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
     40: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
     41: SYSTEM: ListElem Shared Addr = 0x407aaf80
     42: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
     45: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
     46: SYSTEM: ListElem Shared Addr = 0x407ee280
     63: SYSTEM: System Common Init Done !!!
    ---------dec numChn = 2---------
     [host]  64: IPC_BITS_OUT   : Create in progress !!!
     [host]
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4124d080 To Phy:0x90000080
     [host]
     [host] ###Bit buff BasePtr: 4124D080 / PhyAddr 90000080
     [host]
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x41c30480 To Phy:0x909e3480
     [host]
     [host] ###Bit buff BasePtr: 41C30480 / PhyAddr 909E3480
     [host]  65: IPC_BITS_OUT   : Create Done !!!
     [m3video]  44965: IPC_BITS_IN   : Create in progress !!!
     [m3video]  44965: SYSTEM: Opening ListMP [HOST_IPC_OUT_25] ...
     [m3video]  44966: SYSTEM: Opening ListMP [HOST_IPC_IN_25] ...
     [m3video]  44966: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
     [m3video]  44968: IPC_BITS_IN   : Create Done !!!
     [m3video]  44968: DECODE: Create in progress ... !!!
     [m3video] DECLINK_H264:HEAPID:0        USED:4264
     [m3video]  45016: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     Ready to create  ipcBitsOutHost link !
     Vtmcl_createVdecLink : Create the decode links successfully !
     Vdec_start : Start the decoder successfully !
     [host] HDMI Ctrl :Initializing
     [host] HDMI Ctrl :Initialized
     [host] HDMI Ctrl :Sink Connected
     [m3vpss ]  45073: IPC_IN_M3   : Create in progress !!!
     [m3vpss ]  45073: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_1] ...
     [m3video]  45063: DECODE: Creating CH1 of 1920 x 1080 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  45073: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_1] ...
     [m3video]  45064: DECODE: All CH Create ... DONE !!!
     [m3vpss ]  45074: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  45076: IPC_IN_M3   : Create Done !!!
     [m3vpss ]  45076: SWMS: Create in progress !!!
     [m3video] DECLINK:HEAPID:0     USED:6752
     [m3video] DECLINK:HEAPID:3     USED:18726912
     [m3video]  45067: DECODE: Create ... DONE !!!
     [m3video]  45068: IPC_OUT_M3   : Create in progress !!!
     [m3video]  45068: IPC_OUT_M3   : Create Done !!!
     [m3video]  45069: DECODE: CH0:
     [m3video] Queueing last frame in prev IVA[2]
     [m3video] Iva Map Change Serialization: Last Frame of Prev IVA [2] received
     [m3video]  45069: DECODE: CH1:
     [m3video] Queueing last frame in prev IVA[1]
     [m3video] Iva Map Change Serialization: Last Frame of Prev IVA [1] received
     [m3video] Queueing first frame in next IVA[0]
     [m3video] Iva Map Change Serialization: First Frame of Next IVA [0] received
     [m3video]  45070: DECODE: CH0:
     [m3video] Iva Map Change Serialization: First Frame of Next IVA [0] received. Serialization complete!!
     [m3video]  45070: DECODE: CH1:
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
     [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 58 (0x49004740)
     [m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 15
     [m3vpss ] SWMS: instance 1, sc id 7, start win 16 end win 33
     [m3vpss ]  45177: SWMS    : VipScReq is FALSE!!!
     [m3vpss ]  45181: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  45181: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  45181: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  45181: SWMS    : VipScReq is FALSE!!!
     [c6xdsp ]  43494: IPC_FRAMES_IN   : Create in progress !!!
     [m3vpss ]  45184: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [c6xdsp ]  43494: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
     [m3vpss ]  45184: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [c6xdsp ]  43494: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
     [m3vpss ]  45184: SWMS    : Co-effs Loading ... DONE !!!
     [c6xdsp ]  43495: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3vpss ]  45185: SWMS    : ******* Configuring clock 15 secs...
     [m3vpss ]  WARNING: WIN2: CH2, Channel ID is INVALID (max allowed CH ID is CH1), !!!
     [m3vpss ]  WARNING: WIN3: CH3, Channel ID is INVALID (max allowed CH ID is CH1), !!!
     [m3vpss ]  WARNING: WIN4: CH4, Channel ID is INVALID (max allowed CH ID is CH1), !!!
     [m3vpss ]  WARNING: WIN5: CH5, Channel ID is INVALID (max allowed CH ID is CH1), !!!
     [m3vpss ]  WARNING: WIN6: CH6, Channel ID is INVALID (max allowed CH ID is CH1), !!!
     [m3vpss ]  WARNING: WIN7: CH7, Channel ID is INVALID (max allowed CH ID is CH1), !!!
     [m3vpss ]  45186: SWMS0    : Loading Vertical Co-effs (7/16)x ...
     [m3vpss ]  45186: SWMS0    : Loading Horizontal Co-effs (6/16)x ...
     [m3vpss ]  45186: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]  Output FPS: 60
     [m3vpss ]
     [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
     [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
     [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
     [m3vpss ]    0 |   0 |    0,    0 |  1920 x   1080 | 16384 / 32768 | TILED       |    0,    0 |   768 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    1 |   1 |    0,    0 |  1920 x   1080 | 16384 / 32768 | TILED       |  768,    0 |   768 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    2 |   2 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  540 |   768 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
     [m3vpss ]    3 |   3 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  768,  540 |   768 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
     [m3vpss ]    4 |   4 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1536,    0 |   384 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    5 |   5 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1536,  270 |   384 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    6 |   6 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1536,  540 |   384 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [c6xdsp ] IPC_FRAMES_IN:HEAPID:0       USED:304
     [m3vpss ]    7 |   7 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1536,  810 |   384 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [c6xdsp ]  43496: IPC_FRAMES_IN   : Create Done !!!
     [m3vpss ]
     [c6xdsp ]  43496: ALG : Create in progress !!!
     [m3vpss ] SWMS:HEAPID:0        USED:288
     [m3vpss ] SWMS:HEAPID:1        USED:30592
     [c6xdsp ] ALGLINK:HEAPID:0     USED:2616
     [m3vpss ] SWMS:HEAPID:4        USED:20736000
     [c6xdsp ] ALGLINK:HEAPID:1     USED:5912
     [m3vpss ]  45189: SWMS: Create Done !!!
     [c6xdsp ]  43504: ALG : Create Done !!!
     [m3vpss ]  45190: IPC_FRAMES_OUT   : Create in progress !!!
     [m3vpss ]  45191: IPC_FRAMES_OUT   : Create Done !!!
     [m3vpss ]  45204: DISPLAY: Create in progress !!!
     [m3vpss ]  45205: DISPLAY: Create Done !!!
     [m3vpss ]  45206: DISPLAY: Start in progress !!!
     [m3vpss ]  45264: DISPLAY: Start Done !!!
     [m3vpss ]  45264: DISPLAY: HDDAC(BP0) : 34 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7811 / 0 ) !!!
     [m3vpss ]  45264: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
     [m3vpss ]  45264: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 1
     [m3vpss ]  45265: SYSTEM  : FREE SPACE : System Heap      = 67784 B, Mbx = 10238 msgs)
     [m3vpss ]  45265: SYSTEM  : FREE SPACE : SR0 Heap         = 8713728 B (8 MB)
     [m3vpss ]  45265: SYSTEM  : FREE SPACE : Frame Buffer     = 234886016 B (224 MB)
     [m3vpss ]  45265: SYSTEM  : FREE SPACE : Bitstream Buffer = 190027648 B (181 MB)
     [m3vpss ]  45265: SWMS: Start in Progress !!!
     [m3vpss ]  45265: SWMS: Start Done !!!
     [m3vpss ] TILER_STATS: CNT :8BIT
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    16384 x 8192
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
     [m3vpss ] TILER_STATS: NUM FREE BUCKETS:  0
     [m3vpss ] TILER_STATS: NUM USED BUCKETS:  1
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   110067712 (82 %)
     [m3vpss ] TILER_STATS: TOTAL USED AREA:   24084480 (17 %)
     [m3vpss ] TILER_STATS: TOTAL WASTE AREA:  0 (0 %)
     [m3vpss ] TILER_STATS: MAX WIDTH RECT:    16384 x 5836
     [m3vpss ] TILER_STATS: MAX HEIGHT RECT:    16384 x 5836
     [m3vpss ] TILER_STATS: RES ALLOC COUNT [1080P] :  10
     [m3vpss ] TILER_STATS: CNT :16BIT
     [m3vpss ] TILER_STATS: CNT RESOLUTION:    32768 x 3072
     [m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 3072
     [m3vpss ] TILER_STATS: TOTAL FREE AREA:   88621056 (88 %)
     [m3vpss ] TILER_STATS: TOTAL USED AREA:   12042240 (11 %)
     [m3vpss ] TILER_STATS: MAX WIDTH RECT:    32768 x 2484
     [m3vpss ] TILER_STATS: MAX HEIGHT RECT:    32768 x 2484
     [m3vpss ]  45267: SYSTEM  : FREE SPACE : Tiler 8-bit      = 110067712 B (104 MB)  - TILER ON
     [m3vpss ]  45267: SYSTEM  : FREE SPACE : Tiler 16-bit     = 88621056 B (84 MB)  - TILER ON
  • i have a try again ,do not call the function SystemTiler_disableAllocator(),and then my app can exit normally ,so why ?
    and another question is that why when i call the function MultiCh_prfLoadCalcEnable() to get the load information ,the result is following ?: the data 100% is what wrong ?
     [c6xdsp ] 44254: IPCFRAMESIN:Link[16]:
     [c6xdsp ] RECV:315     FREE:315,DROPPED:0,AVGLATENCY:0
     [c6xdsp ]  44254: IPC_FRAMES_IN   : Delete in progress !!!
     [m3video]  45673: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
     [m3vpss ]  45671: SWMS: Delete Done !!!
     [c6xdsp ]  44254: IPC_FRAMES_IN   : Delete Done !!!
     [m3video]
     [m3vpss ]  45671: IPC_FRAMES_OUT   : Delete in progress !!!
     [c6xdsp ]  44254: ALG : Delete in progress !!!
     [c6xdsp ]  44255: ALG : Delete Done !!!
     [m3vpss ] 45671: IPCFRAMESOUT:Link[20000013]:
     [m3vpss ] RECV:315     FORWARD:315,DROPPED:0,AVGLATENCY:0
     [m3vpss ]  45671: PRF : IPC_FRAMES_OUT0 : t: 9 ms, c: 315, f: 315, fps: 35000, fpc: 1
     [c6xdsp ]
     [c6xdsp ]  44256: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
     [m3vpss ]  45671: IPC_FRAMES_OUT   : Delete Done !!!
     [c6xdsp ]
     [m3vpss ]  45672: DISPLAY: Frames = 314 (fps = 52) !!!
     [m3vpss ]  45672: DISPLAY: Delete in progress !!!
     [m3vpss ]  45672: DISPLAY: Delete Done !!!
     [m3vpss ]
     [m3vpss ]  45673: LOAD: CPU: 100.0% HWI: 0.0%, SWI:0.0%
     [m3vpss ]
     [m3vpss ]  45674: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 361, HDDAC(BP0) 363, DVO2(BP1) 363, SDDAC(SEC1) 363
