Other Parts Discussed in Thread: TWL6030
This is cheluvaraj. I am trying to boot pandaboard from android jelly bean 2.5. I am following http://omappedia.org/wiki/4AJ.2.5_OMAP4-Panda_Jelly_Bean_Release_Notes link. But while booting I am getting errors as below, Please help me out.
Texas Instruments X-Loader 1.41 (Oct 21 2011 - 09:28:33)
OMAP4460: 1.2 GHz capable SOM
Starting OS Bootloader from MMC/SD1 ...
U-Boot 1.1.4-g01f17198-dirty (Oct 21 2013 - 12:00:59)
Load address: 0x80e80000
DRAM: 1024 MB
Flash: 0 kB
Using default environment
In: serial
Out: serial
Err: serial
efi partition table:
256 128K xloader
512 256K bootloader
2048 8M recovery
18432 8M boot
34816 512M system
1083392 256M cache
1607680 2996M userdata
Net: KS8851SNL
Hit any key to stop autoboot: 5 4 3 2 1 0
kernel @ 80008000 (4585516)
ramdisk @ 81000000 (185683)
I2C read: I/O error
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.31-01901-g8ef6b3c (x0187393@gl-ti-build-30) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #1 SMP PREEMPT Mon Nov 26 08:53:48 EET 2012
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 Panda board
[ 0.000000] omap4_total_ram_size = 0x40000000
[ 0.000000] omap4_smc_size = 0x300000
[ 0.000000] omap4_ion_heap_secure_input_size = 0x5a00000
[ 0.000000] omap4_ion_heap_secure_output_wfdhdcp_size = 0x1000000
[ 0.000000] omap4_ducati_heap_size = 0x6d00000
[ 0.000000] omap4_ion_heap_tiler_mem_size = 0x0
[ 0.000000] omap4_ion_heap_nonsec_tiler_mem_size = 0x0
[ 0.000000] omap4_smc_addr = 0xbfd00000
[ 0.000000] omap4_ion_heap_secure_input_addr = 0xba300000
[ 0.000000] omap4_ion_heap_secure_output_wfdhdcp_addr = 0xb9300000
[ 0.000000] omap4_ducati_heap_addr = 0xb2600000
[ 0.000000] omap4_ion_heap_tiler_mem_addr = 0xb2600000
[ 0.000000] omap4_ion_heap_nonsec_tiler_mem_addr = 0xb2600000
[ 0.000000] omap_ion_init: secure_input id=2 [ba300000-bfd00000] size=5a00000
[ 0.000000] omap_ion_init: secure_output_wfdhdcp id=5 [b9300000-ba300000] size=1000000
[ 0.000000] omap_ion_init: tiler id=1 [b2600000-b2600000] size=0
[ 0.000000] omap_ion_init: nonsecure_tiler id=3 [b2600000-b2600000] size=0
[ 0.000000] omap_ion_init: system id=0 [0-0] size=0
[ 0.000000] omap_ion_init: tiler_reservation id=4 [0-0] size=0
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4460 ES1.1
[ 0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[ 0.000000] On node 0 totalpages: 204288
[ 0.000000] free_area_init_node: node 0, pgdat c08ec400, node_mem_map c102e000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] HighMem zone: 1792 pages used for memmap
[ 0.000000] HighMem zone: 169728 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1839000 s7488 r8192 d12992 u32768
[ 0.000000] pcpu-alloc: s7488 r8192 d12992 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 202240
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G vmalloc=768M androidboot.console=ttyO2 omap_wdt.timer_margin=30 androidboot.serialno=014E37831900B008 androidboot.bootloader=U-Boot_1.1.4-g01f17198-dirty
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 256MB 542MB = 798MB total
[ 0.000000] Memory: 797924k/797924k available, 250652k reserved, 686080K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0050000 ( 288 kB)
[ 0.000000] .text : 0xc0050000 - 0xc0865000 (8276 kB)
[ 0.000000] .data : 0xc0866000 - 0xc08ee240 ( 545 kB)
[ 0.000000] .bss : 0xc08ee264 - 0xc0a64828 (1498 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410
[ 0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000061] Calibrating delay loop... 1194.24 BogoMIPS (lpj=4665344)
[ 0.070404] pid_max: default: 32768 minimum: 301
[ 0.070404] Mount-cache hash table entries: 512
[ 0.070404] Initializing cgroup subsys debug
[ 0.070404] Initializing cgroup subsys cpuacct
[ 0.070404] Initializing cgroup subsys freezer
[ 0.070404] CPU: Testing write buffer coherency: ok
[ 0.072174] L310 cache controller enabled
[ 0.072204] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x5e470000, Cache size: 1048576 B
[ 0.150390] CPU1: Booted secondary processor
[ 0.181610] Brought up 2 CPUs
[ 0.181610] SMP: Total of 2 processors activated (2388.48 BogoMIPS).
[ 0.185699] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[ 0.185699] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_instr
[ 0.185729] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_1
[ 0.185729] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_2
[ 0.185729] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[ 0.185791] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[ 0.185791] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[ 0.185791] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[ 0.185821] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_private
[ 0.185913] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[ 0.185913] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for thermal_sensor
[ 0.185913] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
[ 0.186004] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
[ 0.186004] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[ 0.186004] omap_hwmod: l4_div_ck: missing clockdomain for l4_div_ck.
[ 0.188568] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[ 0.194763] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.197204] print_constraints: dummy:
[ 0.197662] NET: Registered protocol family 16
[ 0.198181] GPMC revision 6.0
[ 0.198181] EMIF0 is enabled with IRQ142
[ 0.199707] EMIF1 is enabled with IRQ143
[ 0.199707] Last reset was cold reset (PRM_RSTST=0x1)
[ 0.199707]
[ 0.200317] OMAP GPIO hardware version 0.1
[ 0.201873] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.203948] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.205017] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.205383] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.214874] HSI: skipping omap_device registration
[ 0.215332] OMAP DMA hardware revision 0.0
[ 0.215332] omap_rproc_get_pool: dsp - static memory is unavailable: 0x0, 0x0
[ 0.215332] omap_rproc_get_pool: ipu - carveout memory is unavailable: 0x0, 0x0
[ 0.226409] bio: create slab <bio-0> at 0
[ 0.226867] print_constraints: vwl1271: 1800 mV
[ 0.227386] i2c-core: driver [twl] using legacy suspend method
[ 0.227813] i2c-core: driver [twl] using legacy resume method
[ 0.227813] SCSI subsystem initialized
[ 0.229522] usbcore: registered new interface driver usbfs
[ 0.229522] usbcore: registered new interface driver hub
[ 0.229827] usbcore: registered new device driver usb
[ 0.230560] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[ 0.231445] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 0.235504] twl6030: PIH (irq 39) chaining IRQs 368..387
[ 0.237274] machine_constraints_voltage: VUSB: failed to apply 3300000uV constraint
[ 0.237762] twl_reg twl_reg.46: can't register VUSB, -22
[ 0.237762] twl_reg: probe of twl_reg.46 failed with error -22
[ 0.238128] twl6030_usb twl6030_usb: ldo init failed
[ 0.238861] print_constraints: VMMC: 1200 <--> 3000 mV at 3000 mV normal standby
[ 0.239501] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal standby
[ 0.239501] print_constraints: VCXIO: 1800 mV normal standby
[ 0.240325] print_constraints: VDAC: 1800 mV normal standby
[ 0.240783] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
[ 0.241333] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
[ 0.241333] print_constraints: VANA: 2100 mV normal standby
[ 0.242675] print_constraints: CLK32KG:
[ 0.242950] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.243316] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[ 0.243713] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[ 0.244537] omap-rproc omap-rproc.0: dsp is available
[ 0.244537] omap-rproc omap-rproc.1: ipu is available
[ 0.244812] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.244812] Switching to clocksource 32k_counter
[ 0.251892] Switched to NOHz mode on CPU #0
[ 0.251922] Switched to NOHz mode on CPU #1
[ 0.263092] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[ 0.263092] HS USB OTG: no transceiver configured
[ 0.263092] musb-hdrc musb-hdrc: musb_init_controller failed with status -19
[ 0.263549] NET: Registered protocol family 2
[ 0.263549] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.265167] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.265167] TCP bind hash table entries: 16384 (order: 6, 393216 bytes)
[ 0.265167] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.266296] TCP reno registered
[ 0.266326] UDP hash table entries: 64 (order: 0, 4096 bytes)
[ 0.266326] UDP-Lite hash table entries: 64 (order: 0, 4096 bytes)
[ 0.266387] NET: Registered protocol family 1
[ 0.267517] RPC: Registered named UNIX socket transport module.
[ 0.267517] RPC: Registered udp transport module.
[ 0.267547] RPC: Registered tcp transport module.
[ 0.267547] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.267822] Trying to unpack rootfs image as initramfs...
[ 0.286590] Freeing initrd memory: 180K
[ 0.824279] omap_init_opp_table: no hwmod or odev for hsi, [22] cannot add OPPs.
[ 0.824279] omap_init_opp_table: no hwmod or odev for hsi, [23] cannot add OPPs.
[ 1.097412] ram_console: got buffer at 90000000, size 200000
[ 1.097412] ram_console: found existing buffer, size 33597, start 33597
[ 1.183837] console [ram-1] enabled
[ 1.206054] omap-iommu omap-iommu.0: ducati registered
[ 1.206054] omap-iommu omap-iommu.1: tesla registered
[ 1.364837] highmem bounce pool size: 64 pages
[ 1.365386] ashmem: initialized
[ 1.375518] fuse init (API version 7.16)
[ 1.376342] msgmni has been set to 218
[ 1.376342] Registering char device tf_driver (122:0)
[ 1.377471] SMCAG01.06p6.0 D
[ 1.379791] io scheduler noop registered
[ 1.380004] io scheduler deadline registered
[ 1.380004] io scheduler cfq registered (default)
[ 1.380310] start plist test
[ 1.386535] end plist test
[ 1.389221] OMAP DSS rev 4.0
[ 1.391967] Keyboard driver not present
[ 1.392730] dsscomp: initializing.
[ 1.392730] misc dsscomp: display0=generic_dpi_panel
[ 1.393371] misc dsscomp: display1=hdmi_panel
[ 1.393371] misc dsscomp: found 2 displays and 4 overlays, WB overlay 1
[ 1.394134] could not allocate slot
[ 1.394958] omap-rproc omap-rproc.1: powering up ipu
[ 1.395416] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfully
[ 1.395416] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfully
[ 1.395416] omap-rproc omap-rproc.0: powering up dsp
[ 1.397247] virtio_rpmsg_bus virtio2: rpmsg backend virtproc probed successfully
[ 1.397247] OMAPRPC: Registration of OMAPRPC rpmsg service returned 0!
[ 1.397247] OMAPRPC: debug=0
[ 1.397247] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.399291] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 1.400115] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 2.595336] console [ttyO2] enabled
[ 2.599548] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 2.608276] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 2.617309] omap_ion_probe: adding heap secure_output_wfdhdcp of type 2 with b9300000@800000
[ 2.626831] omap_ion_probe: adding heap tiler of type 4 with b2600000@0
[ 2.634399] omap_ion_probe: adding heap nonsecure_tiler of type 4 with b2600000@0
[ 2.642883] omap_ion_probe: adding heap system of type 0 with 0@0
[ 2.649749] omap_ion_probe: adding heap tiler_reservation of type 5 with 0@0
[ 2.666412] brd: module loaded
[ 2.669921] loop: module loaded
[ 2.677856] (stk) :sysfs entries created
[ 2.677856] (stk) : debugfs entries created
[ 2.691192] PPP generic driver version 2.4.2
[ 2.691192] PPP Deflate Compression module registered
[ 2.702850] PPP BSD Compression module registered
[ 2.709136] PPP MPPE Compression module registered
[ 2.709167] NET: Registered protocol family 24
[ 2.720092] tun: Universal TUN/TAP device driver, 1.6
[ 2.727752] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.727752] usbcore: registered new interface driver asix
[ 2.741241] usbcore: registered new interface driver cdc_ether
[ 2.743377] usbcore: registered new interface driver net1080
[ 2.754333] usbcore: registered new interface driver cdc_subset
[ 2.761138] usbcore: registered new interface driver zaurus
[ 2.767486] cdc_ncm: 04-Aug-2011
[ 2.771270] usbcore: registered new interface driver cdc_ncm
[ 2.777679] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.785308] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 2.785308] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 2.800170] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 2.808441] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 2.808441] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.822601] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.822601] usb usb1: Product: OMAP-EHCI Host Controller
[ 2.836578] usb usb1: Manufacturer: Linux 3.0.31-01901-g8ef6b3c ehci_hcd
[ 2.836578] usb usb1: SerialNumber: ehci-omap.0
[ 2.849822] hub 1-0:1.0: USB hub found
[ 2.854034] hub 1-0:1.0: 3 ports detected
[ 2.917755] usbcore: registered new interface driver cdc_acm
[ 2.917968] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.933166] Initializing USB Mass Storage driver...
[ 2.938751] usbcore: registered new interface driver usb-storage
[ 2.945495] USB Mass Storage support registered.
[ 2.945526] usbcore: registered new interface driver usbserial
[ 2.945526] usbserial: USB Serial Driver core
[ 2.962371] mousedev: PS/2 mouse device common for all mice
[ 2.969909] twl6030_pwrbutton_probe: Enter
[ 2.975250] input: twl6030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input0
[ 2.992736] using rtc device, twl_rtc, for alarms
[ 2.998291] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 3.005615] i2c /dev entries driver
[ 3.010437] lirc_dev: IR Remote Control driver registered, major 249
[ 3.010437] IR NEC protocol handler initialized
[ 3.022705] IR RC5(x) protocol handler initialized
[ 3.028137] IR RC6 protocol handler initialized
[ 3.028167] IR JVC protocol handler initialized
[ 3.028167] IR Sony protocol handler initialized
[ 3.043457] IR RC5 (streamzap) protocol handler initialized
[ 3.049652] IR LIRC bridge handler initialized
[ 3.049652] Linux video capture interface: v2.00
[ 3.059814] usbcore: registered new interface driver uvcvideo
[ 3.066528] USB Video Class driver (v1.1.0)
[ 3.066619] dmm: probe base: fd300000, irq 145
[ 3.084838] OMAP Watchdog Timer Rev 0x01: initial timeout 30 sec
[ 3.092620] device-mapper: uevent: version 1.0.3
[ 3.092620] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 3.108551] cpuidle: using governor ladder
[ 3.113128] cpuidle: using governor menu
[ 3.123352] leds-gpio: probe of leds-gpio failed with error -16
[ 3.133209] usbcore: registered new interface driver usbhid
[ 3.139556] usbhid: USB HID core driver
[ 3.144042] logger: created 256K log 'log_main'
[ 3.149627] logger: created 256K log 'log_events'
[ 3.155090] logger: created 256K log 'log_radio'
[ 3.160247] logger: created 256K log 'log_system'
[ 3.167755] thermal_sensor_set_temp: no cooling agents for domain cpu
[ 3.175781] omap_report_temp:thermal_sensor_set_temp reports error
[ 3.183044] omap_temp_sensor omap_temp_sensor.0: omap_ondie_sensor : 'omap_temp_sensor'
[ 3.183135] thermal_sensor_set_temp: no cooling agents for domain cpu
[ 3.191223] usb 1-1: new high speed USB device number 2 using ehci-omap
[ 3.206390] pcb_temp_sensor pcb_temp_sensor.0: pcb_sensor : 'pcb_temp_sensor'
[ 3.215698] OMAP HSI: HSI driver version 0.4.3
[ 3.221679] OMAP HSI: Platform DRIVER register FAILED: -19
[ 3.221679] usbcore: registered new interface driver snd-usb-audio
[ 3.240631] SDP4430 SoC init
[ 3.253326] twl6040-codec twl6040-codec: couldn't get VDDHF regulator -19
[ 3.291900] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[ 3.299743] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[ 3.308166] asoc: null-codec-dai <-> Voice mapping ok
[ 3.315399] asoc: null-codec-dai <-> Tones mapping ok
[ 3.322692] asoc: null-codec-dai <-> Vibra mapping ok
[ 3.329498] asoc: null-codec-dai <-> MODEM mapping ok
[ 3.336090] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[ 3.344696] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 3.352478] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[ 3.358428] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 3.360626] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[ 3.371887] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.379791] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stereo In debugfs file
[ 3.389404] hub 1-1:1.0: USB hub found
[ 3.390350] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 3.391418] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 3.392517] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 3.393585] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 3.394744] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 3.395904] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 3.397094] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 3.398254] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[ 3.399353] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 3.400451] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 3.401519] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 3.402770] asoc: null-codec-dai <-> omap-abe-vxrec-dai mapping ok
[ 3.405456] input: Panda Headset Jack as /devices/platform/soc-audio/sound/card0/input1
[ 3.410919] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[ 3.411590] ALSA device list:
[ 3.411590] #0: TI OMAP4 Board
[ 3.411590] #1: OMAP4HDMI
[ 3.411743] GACT probability NOT on
[ 3.411773] Mirror/redirect action on
[ 3.411773] u32 classifier
[ 3.411773] Actions configured
[ 3.411804] Netfilter messages via NETLINK v0.30.
[ 3.411895] nf_conntrack version 0.5.0 (12470 buckets, 49880 max)
[ 3.413391] ctnetlink v0.93: registering with nfnetlink.
[ 3.413452] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.413452] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.413940] xt_time: kernel timezone is -0000
[ 3.416809] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.417053] arp_tables: (C) 2002 David S. Miller
[ 3.417144] TCP cubic registered
[ 3.418151] NET: Registered protocol family 10
[ 3.422546] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 3.425537] Mobile IPv6
[ 3.425628] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.426086] IPv6 over IPv4 tunneling driver
[ 3.433807] NET: Registered protocol family 17
[ 3.433868] NET: Registered protocol family 15
[ 3.434204] Bridge firewalling registered
[ 3.434265] NET: Registered protocol family 35
[ 3.434753] NET: Registered protocol family 37
[ 3.434753] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 3.619049] ThumbEE CPU extension supported.
[ 3.619049] hub 1-1:1.0: 5 ports detected
[ 3.628295] Registering SWP/SWPB emulation handler
[ 3.633789] mmc0: new high speed SDHC card at address e624
[ 3.640350] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 3.649993] Reprogramming LPDDR2 timings to 400000000 Hz
[ 3.656188] sr_init: No PMIC hook to init smartreflex
[ 3.661926] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 3.670654] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 3.679382] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 3.688232] SmartReflex class 1.5 driver: initialized (86400000ms)
[ 3.695770] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 3.703308] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 3.703308] Alternate GPT is invalid, using primary GPT.
[ 3.703430] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 3.721588] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1203000Calib=1010000 margin=0
[ 3.732421] omap_cpu_thermal_manager:sensor 52400 avg sensor 0 pcb
[ 3.739288] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=1127000Calib=1012840 margin=13000
[ 3.750823] 0, delta 8934 hot spot 61334
[ 3.755249] omap_cpu_thermal_manager: hot spot temp 61334 - going into safe zone
[ 3.763519] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 3.771118] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 3.779052] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 3.786590] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 3.794525] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 3.802032] sr_class1p5_calib_work: iva Stop sampling: Voltage Nominal=950000 samples=2
[ 3.810913] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 3.818878] sr_class1p5_calib_work: iva: Calibration complete: Voltage Nominal=950000Calib=860920 margin=13000
[ 3.829895] Power Management for TI OMAP4.
[ 3.834594] OMAP4 PM: Static dependency added between MPUSS and DUCATI <-> L4_PER/CFG and L3_1.
[ 3.846557] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 3.853820] clock: disabling unused clocks to save power
[ 3.854553] omapfb omapfb: no driver for display
[ 3.854583] omapfb omapfb: failed to setup omapfb
[ 3.872589] regulator_init_complete: VANA: incomplete constraints, leaving on
[ 3.881774] regulator_init_complete: VDAC: incomplete constraints, leaving on
[ 3.890075] regulator_init_complete: VCXIO: incomplete constraints, leaving on
[ 3.899200] otg_wakelock_init: No OTG transceiver found
[ 3.906433] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:07:38 UTC (946685258)
[ 3.917480] Freeing init memory: 288K
[ 3.929626] init: could not import file '/init.omap4pandaboard.rc' from '/init.rc'
[ 3.934997] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.936248] mmc1: new SDIO card at address 0001
[ 3.949981] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.996063] usb 1-1.1: new high speed USB device number 3 using ehci-omap
[ 4.058502] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1317000Calib=1110000 margin=0
[ 4.113433] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 4.121002] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.153961] init: Unable to open persistent property directory /data/property errno: 2
[ 4.165740] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[ 4.167785] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 4.167785] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 4.167816] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 4.167816] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 4.219390] omap-rproc omap-rproc.1: rproc_loader_cont: failed to load ducati-m3.bin
[ 4.219512] omap-rproc omap-rproc.0: rproc_loader_cont: failed to load tesla-dsp.bin
[ 4.236267] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1380000Calib=1200000 margin=0
[ 4.238098] init: cannot find '/system/bin/vold', disabling 'vold'
[ 4.238128] init: cannot find '/system/bin/netd', disabling 'netd'
[ 4.238159] init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
[ 4.238159] init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[ 4.238189] init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
[ 4.238189] init: cannot find '/system/bin/app_process', disabling 'zygote'
[ 4.238220] init: cannot find '/system/bin/drmserver', disabling 'drm'
[ 4.238220] init: cannot find '/system/bin/mediaserver', disabling 'media'
[ 4.238250] init: cannot find '/system/bin/installd', disabling 'installd'
[ 4.238250] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 4.238281] init: cannot find '/system/bin/keystore', disabling 'keystore'
[ 4.238952] init: cannot find '/system/bin/sh', disabling 'console'
[ 4.239105] android_usb: already disabled
[ 4.246276] HDCP: failed to load keys
[ 5.160461] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 5.167846] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 5.175628] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 5.183044] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 5.190765] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 5.198272] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 5.472656] sr_class1p5_calib_work: mpu Stop sampling: Voltage Nominal=1025000 samples=70
[ 5.482086] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1025000Calib=840000 margin=10000
[ 6.199768] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 6.207550] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 6.215576] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 6.223480] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 6.231628] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 6.231658] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 7.231048] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 7.238708] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 7.246856] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 7.254760] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 7.262786] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 7.270538] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 8.277893] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 8.285797] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 8.293975] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 8.301605] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 8.309753] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 8.317535] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 9.324768] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 9.332550] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 9.340576] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 9.348327] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 9.356475] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 9.364105] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 10.371673] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 10.379333] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 10.387359] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 10.395111] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 10.403137] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 10.410888] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 11.418548] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 11.426208] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 11.434356] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 11.441986] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 11.450134] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 11.457885] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 12.465393] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 12.473175] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 12.481292] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 12.488952] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 12.497100] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 12.504882] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 13.512298] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 13.520080] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 13.528076] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 13.536010] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 13.544006] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 13.551788] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 14.559173] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 14.566955] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 14.575103] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 14.582885] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 14.590911] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 14.598663] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 15.606048] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 15.613800] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 15.621948] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 15.629608] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 15.637756] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 15.645385] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 16.652923] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 16.660705] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 16.668731] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 16.676483] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 16.684661] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 16.692291] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 17.699798] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 17.707427] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 17.715576] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 17.723358] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 17.731384] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 17.739135] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 18.746673] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 18.754333] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 18.762481] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 18.770111] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 18.778259] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 18.786163] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 19.793518] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 19.801300] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 19.809326] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 19.817230] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 19.825378] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 19.833007] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 20.840393] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 20.848327] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 20.856323] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 20.864105] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 20.872131] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 20.879882] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 21.887298] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 21.894927] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 21.903076] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 21.910736] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 21.918884] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 21.926635] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 22.934143] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 22.941925] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 22.950073] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 22.957702] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 22.965850] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 22.973480] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 23.981018] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 23.988800] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 23.996795] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 24.004577] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 24.012725] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 24.020416] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 25.027893] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 25.035552] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 25.043701] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 25.051452] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 25.059478] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 25.067382] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 26.074768] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 26.082519] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 26.090667] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 26.098449] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 26.106628] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 26.114379] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 27.121643] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 27.129547] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 27.137573] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 27.145355] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 27.153503] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 27.161132] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 28.168487] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 28.176116] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 28.184265] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 28.192047] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 28.200073] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 28.207824] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 29.215393] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 29.223022] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 29.231201] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 29.238830] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 29.246978] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 29.254730] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 30.262268] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 30.270050] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 30.278045] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 30.285827] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 30.293975] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 30.301605] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 31.309173] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 31.316955] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 31.324981] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 31.332733] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 31.340759] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 31.348663] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 32.356018] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 32.363677] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 32.371795] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 32.379608] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 32.387634] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 32.395385] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 33.402923] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 33.410827] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 33.418975] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 33.426635] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 33.434783] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 33.442413] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 34.449737] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 34.457489] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 34.465515] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 34.473297] thermal_lookup_temp: getting temp is not supported for domain pcb
[ 34.481445] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 34.489074] thermal_lookup_temp: getting temp is not supported for domain pcb
\00
cheluvaraj
